Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de>
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
pull request (net-next): ipsec-next 2015-05-28
1) Remove xfrm_queue_purge as this is the same as skb_queue_purge.
2) Optimize policy and state walk.
3) Use a sane return code if afinfo registration fails.
4) Only check fori a acquire state if the state is not valid.
5) Remove a unnecessary NULL check before xfrm_pol_hold
as it checks the input for NULL.
6) Return directly if the xfrm hold queue is empty, avoid
to take a lock as it is nothing to do in this case.
7) Optimize the inexact policy search and allow for matching
of policies with priority ~0U.
All from Li RongQing.
Please pull or let me know if there are problems.
After commit 07f4c90062f8f ("tcp/dccp: try to not exhaust
ip_local_port_range in connect()") it is advised to have an even number
of ports described in /proc/sys/net/ipv4/ip_local_port_range
This means start/end values should have a different parity.
Let's warn sysadmins of this, so that they can update their settings
if they want to.
Suggested-by: David S. Miller <davem@davemloft.net>
__inet_hash_connect() does not use its third argument (port_offset)
if socket was already bound to a source port.
No need to perform useless but expensive md5 computations.
Reported-by: Crestez Dan Leonard <cdleonard@gmail.com>
A long standing problem on busy servers is the tiny available TCP port
range (/proc/sys/net/ipv4/ip_local_port_range) and the default
sequential allocation of source ports in connect() system call.
If a host is having a lot of active TCP sessions, chances are
very high that all ports are in use by at least one flow,
and subsequent bind(0) attempts fail, or have to scan a big portion of
space to find a slot.
In this patch, I changed the starting point in __inet_hash_connect()
so that we try to favor even [1] ports, leaving odd ports for bind()
users.
We still perform a sequential search, so there is no guarantee, but
if connect() targets are very different, end result is we leave
more ports available to bind(), and we spread them all over the range,
lowering time for both connect() and bind() to find a slot.
This strategy only works well if /proc/sys/net/ipv4/ip_local_port_range
is even, ie if start/end values have different parity.
Therefore, default /proc/sys/net/ipv4/ip_local_port_range was changed to
32768 - 60999 (instead of 32768 - 61000)
There is no change on security aspects here, only some poor hashing
schemes could be eventually impacted by this change.
[1] : The odd/even property depends on ip_local_port_range values parity
We currently always send fragments without DF bit set.
Thus, given following setup:
mtu1500 - mtu1500:1400 - mtu1400:1280 - mtu1280
A R1 R2 B
Where R1 and R2 run linux with netfilter defragmentation/conntrack
enabled, then if Host A sent a fragmented packet _with_ DF set to B, R1
will respond with icmp too big error if one of these fragments exceeded
1400 bytes.
However, if R1 receives fragment sizes 1200 and 100, it would
forward the reassembled packet without refragmenting, i.e.
R2 will send an icmp error in response to a packet that was never sent,
citing mtu that the original sender never exceeded.
The other minor issue is that a refragmentation on R1 will conceal the
MTU of R2-B since refragmentation does not set DF bit on the fragments.
This modifies ip_fragment so that we track largest fragment size seen
both for DF and non-DF packets, and set frag_max_size to the largest
value.
If the DF fragment size is larger or equal to the non-df one, we will
consider the packet a path mtu probe:
We set DF bit on the reassembled skb and also tag it with a new IPCB flag
to force refragmentation even if skb fits outdev mtu.
We will also set DF bit on each fragment in this case.
Joint work with Hannes Frederic Sowa.
Reported-by: Jesse Gross <jesse@nicira.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
ip_skb_dst_mtu is small inline helper, but its called in several places.
before: 17061 44 0 17105 42d1 net/ipv4/ip_output.o
after: 16805 44 0 16849 41d1 net/ipv4/ip_output.o
We used to get this indirectly I supposed, but no longer do.
Either way, an explicit include should have been done in the
first place.
net/ipv4/fib_trie.c: In function '__node_free_rcu':
>> net/ipv4/fib_trie.c:293:3: error: implicit declaration of function 'vfree' [-Werror=implicit-function-declaration]
vfree(n);
net/ipv4/fib_trie.c: In function 'tnode_alloc':
>> net/ipv4/fib_trie.c:312:3: error: implicit declaration of function 'vzalloc' [-Werror=implicit-function-declaration]
return vzalloc(size);
>> net/ipv4/fib_trie.c:312:3: warning: return makes pointer from integer without a cast
cc1: some warnings being treated as errors
Reported-by: kbuild test robot <fengguang.wu@intel.com>
By making sure sk->sk_gso_max_segs minimal value is one,
and sysctl_tcp_min_tso_segs minimal value is one as well,
tcp_tso_autosize() will return a non zero value.
We can then revert 843925f33fcc293d80acf2c5c8a78adf3344d49b
("tcp: Do not apply TSO segment limit to non-TSO packets")
and save few cpu cycles in fast path.
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
If tcp ehash table is constrained to a very small number of buckets
(eg boot parameter thash_entries=128), then we can crash if spinlock
array has more entries.
While we are at it, un-inline inet_ehash_locks_alloc() and make
following changes :
- Budget 2 cache lines per cpu worth of 'spinlocks'
- Try to kmalloc() the array to avoid extra TLB pressure.
(Most servers at Google allocate 8192 bytes for this hash table)
- Get rid of various #ifdef
In commit dd3f9e70f59f43a5712eba9cf3ee4f1e6999540c
("tipc: add packet sequence number at instant of transmission") we
made a change with the consequence that packets in the link backlog
queue don't contain valid sequence numbers.
However, when we create a link protocol message, we still use the
sequence number of the first packet in the backlog, if there is any,
as "next_sent" indicator in the message. This may entail unnecessary
retransissions or stale packet transmission when there is very low
traffic on the link.
This commit fixes this issue by only using the current value of
tipc_link::snd_nxt as indicator.
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
make C=2 CF=-D__CHECK_ENDIAN__ net/core/utils.o
net/core/utils.c:307:72: warning: incorrect type in argument 2 (different base types)
net/core/utils.c:307:72: expected restricted __wsum [usertype] addend
net/core/utils.c:307:72: got restricted __be32 [usertype] from
net/core/utils.c:308:34: warning: incorrect type in argument 2 (different base types)
net/core/utils.c:308:34: expected restricted __wsum [usertype] addend
net/core/utils.c:308:34: got restricted __be32 [usertype] to
net/core/utils.c:310:70: warning: incorrect type in argument 2 (different base types)
net/core/utils.c:310:70: expected restricted __wsum [usertype] addend
net/core/utils.c:310:70: got restricted __be32 [usertype] from
net/core/utils.c:310:77: warning: incorrect type in argument 2 (different base types)
net/core/utils.c:310:77: expected restricted __wsum [usertype] addend
net/core/utils.c:310:77: got restricted __be32 [usertype] to
net/core/utils.c:312:72: warning: incorrect type in argument 2 (different base types)
net/core/utils.c:312:72: expected restricted __wsum [usertype] addend
net/core/utils.c:312:72: got restricted __be32 [usertype] from
net/core/utils.c:313:35: warning: incorrect type in argument 2 (different base types)
net/core/utils.c:313:35: expected restricted __wsum [usertype] addend
net/core/utils.c:313:35: got restricted __be32 [usertype] to
Note we can use csum_replace4() helper
Fixes: 58e3cac5613aa ("net: optimise inet_proto_csum_replace4()")
make C=2 CF=-D__CHECK_ENDIAN__ net/core/secure_seq.o
net/core/secure_seq.c:157:50: warning: restricted __be32 degrades to
integer
Check in fdb_add_entry() if the source port should learn, similar
check is used in br_fdb_update.
Note that new fdb entries which are added manually or
as local ones are still permitted.
This patch has been tested by running traffic via a bridge port and
switching the port's state, also by manually adding/removing entries
from the bridge's fdb.
Signed-off-by: Wilson Kok <wkok@cumulusnetworks.com>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
net/core/pktgen.c:2672:43: warning: incorrect type in assignment (different base types)
net/core/pktgen.c:2672:43: expected unsigned short [unsigned] [short] [usertype] <noident>
net/core/pktgen.c:2672:43: got restricted __be16 [usertype] protocol
Let's use proper struct ethhdr instead of hard coding everything.
ipv6_select_ident() returns a 32bit value in network order.
Fixes: 286c2349f666 ("ipv6: Clean up ipv6_select_ident() and ip6_fragment()")
Acked-by: Martin KaFai Lau <kafai@fb.com>
API compliance scanning with coccinelle flagged:
./net/irda/timer.c:63:35-37: use of msecs_to_jiffies probably perferable
Converting milliseconds to jiffies by "val * HZ / 1000" technically
is not a clean solution as it does not handle all corner cases correctly.
By changing the conversion to use msecs_to_jiffies(val) conversion is
correct in all cases. Further the () around the arithmetic expression
was dropped.
Patch was compile tested for x86_64_defconfig + CONFIG_IRDA=m
Patch is against 4.1-rc4 (localversion-next is -next-20150522)
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Network managers like netifd (used in OpenWRT for instance) try to
configure interface options after creation but before setting the
interface up.
Unfortunately the sysfs / bridge currently only allows to configure the
hash_max and multicast_router options when the bridge interface is up.
But since br_multicast_init() doesn't start any timers and only sets
default values and initializes timers it should be save to reconfigure
the default values after that, before things actually get active after
the bridge is set up.
Signed-off-by: Linus Lüssing <linus.luessing@c0d3.blue>
since commit 6aafeef03b9d ("netfilter: push reasm skb through instead of
original frag skbs") we will end up sometimes re-fragmenting skbs
that we've reassembled.
ipv6 defrag preserves the original skbs using the skb frag list, i.e. as long
as the skb frag list is preserved there is no problem since we keep
original geometry of fragments intact.
However, in the rare case where the frag list is munged or skb
is linearized, we might send larger fragments than what we originally
received.
A router in the path might then send packet-too-big errors even if
sender never sent fragments exceeding the reported mtu:
mtu 1500 - 1500:1400 - 1400:1280 - 1280
A R1 R2 B
1 - A sends to B, fragment size 1400
2 - R2 sends pkttoobig error for 1280
3 - A sends to B, fragment size 1280
4 - R2 sends pkttoobig error for 1280 again because it sees fragments of size 1400.
make sure ip6_fragment always caps MTU at largest packet size seen
when defragmented skb is forwarded.
After the patch
'ipv6: Only create RTF_CACHE routes after encountering pmtu exception',
we need to compensate the performance hit (bouncing dst->__refcnt).
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Julian Anastasov <ja@ssi.bg>
This patch breaks up ip6_rt_copy() into ip6_rt_copy_init() and
ip6_rt_cache_alloc().
In the later patch, we need to create a percpu rt6_info copy. Hence,
refactor the common rt6_info init codes to ip6_rt_copy_init().
This patch keeps track of the DST_NOCACHE routes in a list and replaces its
dev with loopback during the iface down/unregister event.
This patch always creates RTF_CACHE clone with DST_NOCACHE
when FLOWI_FLAG_KNOWN_NH is set so that the rt6i_dst is set to
the fl6->daddr.
Acked-by: Julian Anastasov <ja@ssi.bg>
Tested-by: Julian Anastasov <ja@ssi.bg>
The neighbor look-up used to depend on the rt6i_gateway (if
there is a gateway) or the rt6i_dst (if it is a RTF_CACHE clone)
as the nexthop address. Note that rt6i_dst is set to fl6->daddr
for the RTF_CACHE clone where fl6->daddr is the one used to do
the route look-up.
Now, we only create RTF_CACHE clone after encountering exception.
When doing the neighbor look-up with a route that is neither a gateway
nor a RTF_CACHE clone, the daddr in skb will be used as the nexthop.
In some cases, the daddr in skb is not the one used to do
the route look-up. One example is in ip_vs_dr_xmit_v6() where the
real nexthop server address is different from the one in the skb.
This patch is going to follow the IPv4 approach and ask the
ip6_pol_route() callers to set the FLOWI_FLAG_KNOWN_NH properly.
In the next patch, ip6_pol_route() will honor the FLOWI_FLAG_KNOWN_NH
and create a RTF_CACHE clone.
Instead of doing the rt6->rt6i_node check whenever we need
to get the route's cookie. Refactor it into rt6_get_cookie().
It is a prep work to handle FLOWI_FLAG_KNOWN_NH and also
percpu rt6_info later.
This patch creates a RTF_CACHE routes only after encountering a pmtu
exception.
After ip6_rt_update_pmtu() has inserted the RTF_CACHE route to the fib6
tree, the rt->rt6i_node->fn_sernum is bumped which will fail the
ip6_dst_check() and trigger a relookup.
A prep work for creating RTF_CACHE on exception only. After this
patch, the same condition (rt->rt6i_flags & (RTF_NONEXTHOP | RTF_GATEWAY))
is checked twice. This redundancy will be removed in the later patch.
When creating a RTF_CACHE route, RTF_ANYCAST is set based on rt6i_dst.
Also, rt6i_gateway is always set to the nexthop while the nexthop
could be a gateway or the rt6i_dst.addr.
After removing the rt6i_dst and rt6i_src dependency in the last patch,
we also need to stop the caller from depending on rt6i_gateway and
RTF_ANYCAST.
This patch removes the assumptions that the returned rt is always
a RTF_CACHE entry with the rt6i_dst and rt6i_src containing the
destination and source address. The dst and src can be recovered from
the calling site.
We may consider to rename (rt6i_dst, rt6i_src) to
(rt6i_key_dst, rt6i_key_src) later.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
This patch changes the ipv6_select_ident() signature to return a
fragment id instead of taking a whole frag_hdr as a param to
only set the frag_hdr->identification.
It also cleans up ip6_fragment() to obtain the fragment id at the
beginning instead of using multiple "if" later to check fragment id
has been generated or not.
Send icmp pmtu error if we find that the largest fragment of df-skb
exceeded the output path mtu.
The ip output path will still catch this later on but we can avoid the
forward/postrouting hook traversal by rejecting right away.
This is what ipv6 already does.
unix_stream_recvmsg is refactored to unix_stream_read_generic in this
patch and enhanced to deal with pipe splicing. The refactoring is
inneglible, we mostly have to deal with a non-existing struct msghdr
argument.
Prepare skb_splice_bits to be able to deal with AF_UNIX sockets.
AF_UNIX sockets don't use lock_sock/release_sock and thus we have to
use a callback to make the locking and unlocking configureable.
This patch implements sendpage support for AF_UNIX SOCK_STREAM
sockets. This is also required for a complete splice implementation.
The implementation is a bit tricky because we append to already existing
skbs and so have to hold unix_sk->readlock to protect the reading side
from either advancing UNIXCB.consumed or freeing the skb at the socket
receive tail.
drivers/net/ethernet/cadence/macb.c
drivers/net/phy/phy.c
include/linux/skbuff.h
net/ipv4/tcp.c
net/switchdev/switchdev.c
Switchdev was a case of RTNH_H_{EXTERNAL --> OFFLOAD}
renaming overlapping with net-next changes of various
sorts.
phy.c was a case of two changes, one adding a local
variable to a function whilst the second was removing
one.
tcp.c overlapped a deadlock fix with the addition of new tcp_info
statistic values.
macb.c involved the addition of two zyncq device entries.
skbuff.h involved adding back ipv4_daddr to nf_bridge_info
whilst net-next changes put two other existing members of
that struct into a union.
Giving /proc/net/pktgen/pgctrl an invalid command just returns shell
success and prints a warning in dmesg. This is not very useful for
shell scripting, as it can only detect the error by parsing dmesg.
Instead return -EINVAL when the command is unknown, as this provides
userspace shell scripting a way of detecting this.
Also bump version tag to 2.75, because (1) reading /proc/net/pktgen/pgctrl
output this version number which would allow to detect this small
semantic change, and (2) because the pktgen version tag have not been
updated since 2010.
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Too many spaces were introduced in commit 63adc6fb8ac0 ("pktgen: cleanup
checkpatch warnings"), thus misaligning "src_min:" to other columns.
Fixes: 63adc6fb8ac0 ("pktgen: cleanup checkpatch warnings")
Following lockdep splat was reported :
[ 29.382286] ===============================
[ 29.382315] [ INFO: suspicious RCU usage. ]
[ 29.382344] 4.1.0-0.rc0.git11.1.fc23.x86_64 #1 Not tainted
[ 29.382380] -------------------------------
[ 29.382409] net/bridge/br_private.h:626 suspicious
rcu_dereference_check() usage!
[ 29.382455]
[ 29.382507]
rcu_scheduler_active = 1, debug_locks = 0
[ 29.382549] 2 locks held by swapper/0/0:
[ 29.382576] #0: (((&p->forward_delay_timer))){+.-...}, at:
[<ffffffff81139f75>] call_timer_fn+0x5/0x4f0
[ 29.382660] #1: (&(&br->lock)->rlock){+.-...}, at:
[<ffffffffa0450dc1>] br_forward_delay_timer_expired+0x31/0x140
[bridge]
[ 29.382754]
stack backtrace:
[ 29.382787] CPU: 0 PID: 0 Comm: swapper/0 Not tainted
[ 29.382838] Hardware name: LENOVO 422916G/LENOVO, BIOS A1KT53AUS 04/07/2015
[ 29.382882] 0000000000000000 3ebfc20364115825 ffff880666603c48
ffffffff81892d4b
[ 29.382943] 0000000000000000 ffffffff81e124e0 ffff880666603c78
ffffffff8110bcd7
[ 29.383004] ffff8800785c9d00 ffff88065485ac58 ffff880c62002800
ffff880c5fc88ac0
[ 29.383065] Call Trace:
[ 29.383084] <IRQ> [<ffffffff81892d4b>] dump_stack+0x4c/0x65
[ 29.383130] [<ffffffff8110bcd7>] lockdep_rcu_suspicious+0xe7/0x120
[ 29.383178] [<ffffffffa04520f9>] br_fill_ifinfo+0x4a9/0x6a0 [bridge]
[ 29.383225] [<ffffffffa045266b>] br_ifinfo_notify+0x11b/0x4b0 [bridge]
[ 29.383271] [<ffffffffa0450d90>] ? br_hold_timer_expired+0x70/0x70 [bridge]
[ 29.383320] [<ffffffffa0450de8>]
br_forward_delay_timer_expired+0x58/0x140 [bridge]
[ 29.383371] [<ffffffffa0450d90>] ? br_hold_timer_expired+0x70/0x70 [bridge]
[ 29.383416] [<ffffffff8113a033>] call_timer_fn+0xc3/0x4f0
[ 29.383454] [<ffffffff81139f75>] ? call_timer_fn+0x5/0x4f0
[ 29.383493] [<ffffffff8110a90f>] ? lock_release_holdtime.part.29+0xf/0x200
[ 29.383541] [<ffffffffa0450d90>] ? br_hold_timer_expired+0x70/0x70 [bridge]
[ 29.383587] [<ffffffff8113a6a4>] run_timer_softirq+0x244/0x490
[ 29.383629] [<ffffffff810b68cc>] __do_softirq+0xec/0x670
[ 29.383666] [<ffffffff810b70d5>] irq_exit+0x145/0x150
[ 29.383703] [<ffffffff8189f506>] smp_apic_timer_interrupt+0x46/0x60
[ 29.383744] [<ffffffff8189d523>] apic_timer_interrupt+0x73/0x80
[ 29.383782] <EOI> [<ffffffff816f131f>] ? cpuidle_enter_state+0x5f/0x2f0
[ 29.383832] [<ffffffff816f131b>] ? cpuidle_enter_state+0x5b/0x2f0
Problem here is that br_forward_delay_timer_expired() is a timer
handler, calling br_ifinfo_notify() which assumes either rcu_read_lock()
or RTNL are held.
Simplest fix seems to add rcu read lock section.
Reported-by: Josh Boyer <jwboyer@fedoraproject.org>
Reported-by: Dominick Grift <dac.override@gmail.com>
Cc: Vlad Yasevich <vyasevich@gmail.com>
When trying to configure the settings for PHY1, using commands
like 'ethtool -s eth0 phyad 1 speed 100', the 'ethtool' seems to
modify other settings apart from the speed of the PHY1, in the
above case.
The ethtool seems to query the settings for PHY0, and use this
as the base to apply the new settings to the PHY1. This is
causing the other settings of the PHY 1 to be wrongly
configured.
The issue is caused by the '_ethtool_get_settings()' API, which
gets called because of the 'ETHTOOL_GSET' command, is clearing
the 'cmd' pointer (of type 'struct ethtool_cmd') by calling
memset. This clears all the parameters (if any) passed for the
'ETHTOOL_GSET' cmd. So the driver's callback is always invoked
with 'cmd->phy_address' as '0'.
The '_ethtool_get_settings()' is called from other files in the
'net/core'. So the fix is applied to the 'ethtool_get_settings()'
which is only called in the context of the 'ethtool'.
Signed-off-by: Arun Parameswaran <aparames@broadcom.com>
Reviewed-by: Ray Jui <rjui@broadcom.com>
Reviewed-by: Scott Branden <sbranden@broadcom.com>
When more than a multicast address is present in a MLDv2 report, all but
the first address is ignored, because the code breaks out of the loop if
there has not been an error adding that address.
This has caused failures when two guests connected through the bridge
tried to communicate using IPv6. Neighbor discoveries would not be
transmitted to the other guest when both used a link-local address and a
static address.
This only happens when there is a MLDv2 querier in the network.
The fix will only break out of the loop when there is a failure adding a
multicast address.
The mdb before the patch:
dev ovirtmgmt port vnet0 grp ff02::1:ff7d:6603 temp
dev ovirtmgmt port vnet1 grp ff02::1:ff7d:6604 temp
dev ovirtmgmt port bond0.86 grp ff02::2 temp
After the patch:
dev ovirtmgmt port bond0.86 grp ff02::fb temp
dev ovirtmgmt port bond0.86 grp ff02::d temp
dev ovirtmgmt port vnet0 grp ff02::1:ff00:76 temp
dev ovirtmgmt port bond0.86 grp ff02::16 temp
dev ovirtmgmt port vnet1 grp ff02::1:ff00:77 temp
dev ovirtmgmt port bond0.86 grp ff02::1:ff00:def temp
dev ovirtmgmt port bond0.86 grp ff02::1:ffa1:40bf temp
Fixes: 08b202b67264 ("bridge br_multicast: IPv6 MLD support.")
Reported-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@redhat.com>
Tested-by: Rik Theys <Rik.Theys@esat.kuleuven.be>
When replacing an IPv4 route, tb_id member of the new fib_alias
structure is not set in the replace code path so that the new route is
ignored.
Fixes: 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse")
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contain Netfilter fixes for your net tree, they are:
1) Fix a race in nfnetlink_log and nfnetlink_queue that can lead to a crash.
This problem is due to wrong order in the per-net registration and netlink
socket events. Patch from Francesco Ruggeri.
2) Make sure that counters that userspace pass us are higher than 0 in all the
x_tables frontends. Discovered via Trinity, patch from Dave Jones.
3) Revert a patch for br_netfilter to rely on the conntrack status bits. This
breaks stateless IPv6 NAT transformations. Patch from Florian Westphal.
ip_error does not check if in_dev is NULL before dereferencing it.
IThe following sequence of calls is possible:
CPU A CPU B
ip_rcv_finish
ip_route_input_noref()
ip_route_input_slow()
inetdev_destroy()
dst_input()
With the result that a network device can be destroyed while processing
an input packet.
A crash was triggered with only unicast packets in flight, and
forwarding enabled on the only network device. The error condition
was created by the removal of the network device.
As such it is likely the that error code was -EHOSTUNREACH, and the
action taken by ip_error (if in_dev had been accessible) would have
been to not increment any counters and to have tried and likely failed
to send an icmp error as the network device is going away.
Therefore handle this weird case by just dropping the packet if
!in_dev. It will result in dropping the packet sooner, and will not
result in an actual change of behavior.
Fixes: 251da4130115b ("ipv4: Cache ip_error() routes even when not forwarding.")
Reported-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Tested-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
Signed-off-by: Vittorio Gambaletta <linuxbugs@vittgam.net>
This restored previous behaviour. If caller does not want ports to be
filled, we should not break.
Fixes: 06635a35d13d ("flow_dissect: use programable dissector in skb_flow_dissect and friends")
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
Taking socket spinlock in tcp_get_info() can deadlock, as
inet_diag_dump_icsk() holds the &hashinfo->ehash_locks[i],
while packet processing can use the reverse locking order.
We could avoid this locking for TCP_LISTEN states, but lockdep would
certainly get confused as all TCP sockets share same lockdep classes.
[ 523.722504] ======================================================
[ 523.728706] [ INFO: possible circular locking dependency detected ]
[ 523.734990] 4.1.0-dbg-DEV #1676 Not tainted
[ 523.739202] -------------------------------------------------------
[ 523.745474] ss/18032 is trying to acquire lock:
[ 523.750002] (slock-AF_INET){+.-...}, at: [<ffffffff81669d44>] tcp_get_info+0x2c4/0x360
[ 523.758129]
[ 523.758129] but task is already holding lock:
[ 523.763968] (&(&hashinfo->ehash_locks[i])->rlock){+.-...}, at: [<ffffffff816bcb75>] inet_diag_dump_icsk+0x1d5/0x6c0
[ 523.774661]
[ 523.774661] which lock already depends on the new lock.
[ 523.774661]
[ 523.782850]
[ 523.782850] the existing dependency chain (in reverse order) is:
[ 523.790326]
-> #1 (&(&hashinfo->ehash_locks[i])->rlock){+.-...}:
[ 523.796599] [<ffffffff811126bb>] lock_acquire+0xbb/0x270
[ 523.802565] [<ffffffff816f5868>] _raw_spin_lock+0x38/0x50
[ 523.808628] [<ffffffff81665af8>] __inet_hash_nolisten+0x78/0x110
[ 523.815273] [<ffffffff816819db>] tcp_v4_syn_recv_sock+0x24b/0x350
[ 523.822067] [<ffffffff81684d41>] tcp_check_req+0x3c1/0x500
[ 523.828199] [<ffffffff81682d09>] tcp_v4_do_rcv+0x239/0x3d0
[ 523.834331] [<ffffffff816842fe>] tcp_v4_rcv+0xa8e/0xc10
[ 523.840202] [<ffffffff81658fa3>] ip_local_deliver_finish+0x133/0x3e0
[ 523.847214] [<ffffffff81659a9a>] ip_local_deliver+0xaa/0xc0
[ 523.853440] [<ffffffff816593b8>] ip_rcv_finish+0x168/0x5c0
[ 523.859624] [<ffffffff81659db7>] ip_rcv+0x307/0x420
Lets use u64_sync infrastructure instead. As a bonus, 64bit
arches get optimized, as these are nop for them.
Fixes: 0df48c26d841 ("tcp: add tcpi_bytes_acked to tcp_info")
This patch tracks the total number of inbound and outbound segments on a
TCP socket. One may use this number to have an idea on connection
quality when compared against the retransmissions.
RFC4898 named these : tcpEStatsPerfSegsIn and tcpEStatsPerfSegsOut
These are a 32bit field each and can be fetched both from TCP_INFO
getsockopt() if one has a handle on a TCP socket, or from inet_diag
netlink facility (iproute2/ss patch will follow)
Note that tp->segs_out was placed near tp->snd_nxt for good data
locality and minimal performance impact, while tp->segs_in was placed
near tp->bytes_received for the same reason.
Join work with Eric Dumazet.
Note that received SYN are accounted on the listener, but sent SYNACK
are not accounted.
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
ip -6 addr add dead::1/128 dev eth0
sleep 5
ip -6 route add default via dead::1/128
-> fails
-> succeeds
reason is that if (nonsensensical) route above is added,
dead::1 is still subject to DAD, so the route lookup will
pick eth0 as outdev due to the prefix route that is added before
DAD work is started.
Add explicit test that checks if nexthop gateway is a local address.
Link: https://bugzilla.redhat.com/show_bug.cgi?id=1167969
inet_csk_get_port() randomization effort tends to spread
sockets on all the available range (ip_local_port_range)
This is unfortunate because SO_REUSEADDR sockets have
less requirements than non SO_REUSEADDR ones.
If an application uses SO_REUSEADDR hint, it is to try to
allow source ports being shared.
So instead of picking a random port number in ip_local_port_range,
lets try first in first half of the range.
This gives more chances to use upper half of the range for the
sockets with strong requirements (not using SO_REUSEADDR)
Note this patch does not add a new sysctl, and only changes
the way we try to pick port number.
Cc: Marcelo Ricardo Leitner <mleitner@redhat.com>
Cc: Flavio Leitner <fbl@redhat.com>
Acked-by: Flavio Leitner <fbl@redhat.com>
