Replace open-coded loop with for_each_set_bit().
Cc: netdev@vger.kernel.org
The spinlock aun_queue_lock is initialized statically. It is unnecessary
to initialize by spin_lock_init() at module load time.
This is detected by the semantic patch.
// <smpl>
@def@
declarer name DEFINE_SPINLOCK;
identifier spinlock;
DEFINE_SPINLOCK(spinlock);
identifier def.spinlock;
- spin_lock_init(&spinlock);
// </smpl>
Cc: Julia Lawall <julia@diku.dk>
compare_ether_header() can have a special implementation on 64 bit
arches if CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS is defined.
__napi_gro_receive() and vlan_gro_common() can avoid a conditional
branch to perform device match.
On x86_64, __napi_gro_receive() has now 38 instructions instead of 53
As gcc-4.4.3 still choose to not inline it, add inline keyword to this
performance critical function.
CC: Herbert Xu <herbert@gondor.apana.org.au>
strlcpy() returns the total length of the string they tried to create, so
we should not use its return value without any check. scnprintf() returns
the number of characters written into @buf not including the trailing '\0',
so use it instead here.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Change SCTP_DEBUG_PRINTK and SCTP_DEBUG_PRINTK_IPADDR to
use do { print } while (0) guards.
Add SCTP_DEBUG_PRINTK_CONT to fix errors in log when
lines were continued.
Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
Add a missing newline in "Failed bind hash alloc"
Switch from GFP_ATOMIC allocations to GFP_KERNEL ones in
ip_vs_add_service() and ip_vs_new_dest(), as we hold a mutex and are
allowed to sleep in this context.
Signed-off-by: Simon Horman <horms@verge.net.au>
Also rename __ip_vs_securetcp_lock to ip_vs_securetcp_lock.
Spinlock conversion was suggested by Eric Dumazet.
Also rename __ip_vs_sched_lock to ip_vs_sched_lock.
Cc: Xiaoyu Du <tingsrain@gmail.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
If bridge port is offline, don't call ethtool to query speed.
The carrier check is not called from work queue in current code.
__ip_vs_service_get and __ip_vs_svc_fwm_get increment a reference count, so
that reference count should be decremented before leaving the function in an
error case.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression x;
expression E;
identifier f1;
iterator I;
x = __ip_vs_service_get(...);
<... when != x
when != true (x == NULL || ...)
when != if (...) { <+...x...+> }
when != I (...) { <+...x...+> }
x == NULL
x == E
x->f1
* return ...;
// </smpl>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
drivers/net/wireless/libertas/if_sdio.c
Trivial extension to existing meta data match rules to allow
matching on skb receive hash value.
Compiler is not smart enough to avoid a conditional branch.
Allow userspace to register for more than just
action frames by giving the frame subtype, and
make it possible to use this in various modes
as well.
With some tweaks and some added functionality
this will, in the future, also be usable in AP
mode and be able to replace the cooked monitor
interface currently used in that case.
When MFP is disabled, action frames will not
be encrypted since they are management frames
and the only management frames that can then
be encrypted are authentication frames.
Therefore, setting the don't-encrypt flag on
action frames is unnecessary.
This function analyses only its single, value-passed
argument, and has no side effects. Thus it can be
const, which makes mac80211 smaller, for example:
362518 16720 884 380122 5ccda mac80211.ko (before)
362358 16720 884 379962 5cc3a mac80211.ko (after)
a 160 byte saving in text size, and an optimisation
because the function won't be called as often.
The SNMP daemon uses ethtool to determine the speed of
network interfaces. This fails on Debian (and probably elsewhere)
because for security SNMP daemon runs as non-root user (snmp).
Note: A similar patch was rejected previously because of a concern about
the possibility that on some hardware querying the ethtool settings
requires access to the PHY and could slow the machine down. But the
security risk of requiring SNMP daemon (and related services)
to run as root far out weighs the risk of denial-of-service.
No need to use a temporary struct rtnl_link_stats64 variable,
just copy the source to skb buffer.
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
It uses ip_send_check() and stuff like that.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
The current CCID-2 RTT estimator code is in parts broken and lags behind the
suggestions in RFC2988 of using scaled variants for SRTT/RTTVAR.
That code is replaced by the present patch, which reuses the Linux TCP RTT
estimator code.
Further details:
1. The minimum RTO of previously one second has been replaced with TCP's, since
RFC4341, sec. 5 says that the minimum of 1 sec. (suggested in RFC2988, 2.4)
is not necessary. Instead, the TCP_RTO_MIN is used, which agrees with DCCP's
concept of a default RTT (RFC 4340, 3.4).
2. The maximum RTO has been set to DCCP_RTO_MAX (64 sec), which agrees with
RFC2988, (2.5).
3. De-inlined the function ccid2_new_ack().
4. Added a FIXME: the RTT is sampled several times per Ack Vector, which will
give the wrong estimate. It should be replaced with one sample per Ack.
However, at the moment this can not be resolved easily, since
- it depends on TX history code (which also needs some work),
- the cleanest solution is not to use the `sent' time at all (saves 4 bytes
per entry) and use DCCP timestamps / elapsed time to estimated the RTT,
which however is non-trivial to get right (but needs to be done).
Reasons for reusing the Linux TCP estimator algorithm:
Some time was spent to find a better alternative, using basic RFC2988 as a first
step. Further analysis and experimentation showed that the Linux TCP RTO
estimator is superior to a basic RFC2988 implementation. A summary is on
http://www.erg.abdn.ac.uk/users/gerrit/dccp/notes/ccid2/rto_estimator/
In addition, this estimator fared well in a recent empirical evaluation:
Rewaskar, Sushant, Jasleen Kaur and F. Donelson Smith.
A Performance Study of Loss Detection/Recovery in Real-world TCP
Implementations. Proceedings of 15th IEEE International
Conference on Network Protocols (ICNP-07), 2007.
Thus there is significant benefit in reusing the existing TCP code.
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
This removes the dec_pipe function and improves the way the RTO timer is rearmed
when a new acknowledgment comes in.
Details and justification for removal:
1) The BUG_ON in dec_pipe is never triggered: pipe is only decremented for TX
history entries between tail and head, for which it had previously been
incremented in tx_packet_sent; and it is not decremented twice for the same
entry, since it is
- either decremented when a corresponding Ack Vector cell in state 0 or 1
was received (and then ccid2s_acked==1),
- or it is decremented when ccid2s_acked==0, as part of the loss detection
in tx_packet_recv (and hence it can not have been decremented earlier).
2) Restarting the RTO timer happens for every single entry in each Ack Vector
parsed by tx_packet_recv (according to RFC 4340, 11.4 this can happen up to
16192 times per Ack Vector).
3) The RTO timer should not be restarted when all outstanding data has been
acknowledged. This is currently done similar to (2), in dec_pipe, when
pipe has reached 0.
The patch onsolidates the code which rearms the RTO timer, combining the
segments from new_ack and dec_pipe. As a result, the code becomes clearer
(compare with tcp_rearm_rto()).
This removes the ccid2_hc_tx_check_sanity function: it is redundant.
Details:
The tx_check_sanity function performs three tests:
1) it checks that the circular TX list is sorted
- in ascending order of sequence number (ccid2s_seq)
- and time (ccid2s_sent),
- in the direction from `tail' (hctx_seqt) to `head' (hctx_seqh);
2) it ensures that the entire list has the length seqbufc * CCID2_SEQBUF_LEN;
3) it ensures that pipe equals the number of packets that were not
marked `acked' (ccid2s_acked) between `tail' and `head'.
The following argues that each of these tests is redundant, this can be verified
by going through the code.
(1) is not necessary, since both time and GSS increase from one packet to the
next, so that subsequent insertions in tx_packet_sent (which advance the `head'
pointer) will be in ascending order of time and sequence number.
In (2), the length of the list is always equal to seqbufc times CCID2_SEQBUF_LEN
(set to 1024) unless allocation caused an earlier failure, because:
* at initialisation (tx_init), there is one chunk of size 1024 and seqbufc=1;
* subsequent calls to tx_alloc_seq take place whenever head->next == tail in
tx_packet_sent; then a new chunk of size 1024 is inserted between head and
tail, and seqbufc is incremented by one.
To show that (3) is redundant requires looking at two cases.
The `pipe' variable of the TX socket is incremented only in tx_packet_sent, and
decremented in tx_packet_recv. When head == tail (TX history empty) then pipe
should be 0, which is the case directly after initialisation and after a
retransmission timeout has occurred (ccid2_hc_tx_rto_expire).
The first case involves parsing Ack Vectors for packets recorded in the live
portion of the buffer, between tail and head. For each packet marked by the
receiver as received (state 0) or ECN-marked (state 1), pipe is decremented by
one, so for all such packets the BUG_ON in tx_check_sanity will not trigger.
The second case is the loss detection in the second half of tx_packet_recv,
below the comment "Check for NUMDUPACK".
The first while-loop here ensures that the sequence number of `seqp' is either
above or equal to `high_ack', or otherwise equal to the highest sequence number
sent so far (of the entry head->prev, as head points to the next unsent entry).
The next while-loop ("while (1)") counts the number of acked packets starting
from that position of seqp, going backwards in the direction from head->prev to
tail. If NUMDUPACK=3 such packets were counted within this loop, `seqp' points
to the last acknowledged packet of these, and the "if (done == NUMDUPACK)" block
is entered next.
The while-loop contained within that block in turn traverses the list backwards,
from head to tail; the position of `seqp' is saved in the variable `last_acked'.
For each packet not marked as `acked', a congestion event is triggered within
the loop, and pipe is decremented. The loop terminates when `seqp' has reached
`tail', whereupon tail is set to the position previously stored in `last_acked'.
Thus, between `last_acked' and the previous position of `tail',
- pipe has been decremented earlier if the packet was marked as state 0 or 1;
- pipe was decremented if the packet was not marked as acked.
That is, pipe has been decremented by the number of packets between `last_acked'
and the previous position of `tail'. As a consequence, pipe now again reflects
the number of packets which have not (yet) been acked between the new position
of tail (at `last_acked') and head->prev, or 0 if head==tail. The result is that
the BUG_ON condition in check_sanity will also not be triggered, hence the test
(3) is also redundant.
The CCIDs are activated as last of the features, at the end of the handshake,
were the LISTEN state of the master socket is inherited into the server
state of the child socket. Thus, the only states visible to CCIDs now are
OPEN/PARTOPEN, and the closing states.
This allows to remove tests which were previously necessary to protect
against referencing a socket in the listening state (in CCID-3), but which
now have become redundant.
As a further byproduct of enabling the CCIDs only after the connection has been
fully established, several typecast-initialisations of ccid3_hc_{rx,tx}_sock
can now be eliminated:
* the CCID is loaded, so it is not necessary to test if it is NULL,
* if it is possible to load a CCID and leave the private area NULL, then this
is a bug, which should crash loudly - and earlier,
* the test for state==OPEN || state==PARTOPEN now reduces only to the closing
phase (e.g. when the node has received an unexpected Reset).
Acked-by: Ian McDonald <ian.mcdonald@jandi.co.nz>
This patch collects cosmetics-only changes to separate these from
code changes:
* update with regard to CodingStyle and whitespace changes,
* documentation:
- adding/revising comments,
- remove CCID-3 RX socket documentation which is either
duplicate or refers to fields that no longer exist,
* expand embedded tfrc_tx_info struct inline for consistency,
removing indirections via #define.
SKBs can be "fragmented" in two ways, via a page array (called
skb_shinfo(skb)->frags[]) and via a list of SKBs (called
skb_shinfo(skb)->frag_list).
Since skb_has_frags() tests the latter, it's name is confusing
since it sounds more like it's testing the former.
Via setsockopt it is possible to reduce the socket RX buffer
(SO_RCVBUF). TCP method to select the initial window and window scaling
option in tcp_select_initial_window() currently misbehaves and do not
consider a reduced RX socket buffer via setsockopt.
Even though the server's RX buffer is reduced via setsockopt() to 256
byte (Initial Window 384 byte => 256 * 2 - (256 * 2 / 4)) the window
scale option is still 7:
192.168.1.38.40676 > 78.47.222.210.5001: Flags [S], seq 2577214362, win 5840, options [mss 1460,sackOK,TS val 338417 ecr 0,nop,wscale 0], length 0
78.47.222.210.5001 > 192.168.1.38.40676: Flags [S.], seq 1570631029, ack 2577214363, win 384, options [mss 1452,sackOK,TS val 2435248895 ecr 338417,nop,wscale 7], length 0
192.168.1.38.40676 > 78.47.222.210.5001: Flags [.], ack 1, win 5840, options [nop,nop,TS val 338421 ecr 2435248895], length 0
Within tcp_select_initial_window() the original space argument - a
representation of the rx buffer size - is expanded during
tcp_select_initial_window(). Only sysctl_tcp_rmem[2], sysctl_rmem_max
and window_clamp are considered to calculate the initial window.
This patch adjust the window_clamp argument if the user explicitly
reduce the receive buffer.
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
While looking at using netdev_rx_handler_register for openvswitch Jesse
Gross suggested that an unlikely() might be worthwhile in that code.
I'm interested to see if its appropriate for the bridge code.
Cc: Jesse Gross <jesse@nicira.com>
vlan_hwaccel_do_receive() always returns 0, so make it return void.
for the declararion of csum_ipv6_magic.
Fixes this build error on PowerPC (at least):
net/sched/act_csum.c: In function 'tcf_csum_ipv6_icmp':
net/sched/act_csum.c:178: error: implicit declaration of function 'csum_ipv6_magic'
We can use rxhash to classify the traffic into flows. As rxhash maybe
supplied by NIC or RPS, it is cheaper.
Acked-by: Jamal Hadi Salim <hadi@cyberus.ca>
struct net_device has its own struct net_device_stats member, so use
this one instead of a private copy in the irlan_cb struct.
PPP: introduce "pptp" module which implements point-to-point tunneling protocol using pppox framework
NET: introduce the "gre" module for demultiplexing GRE packets on version criteria
(required to pptp and ip_gre may coexists)
NET: ip_gre: update to use the "gre" module
This patch introduces then pptp support to the linux kernel which
dramatically speeds up pptp vpn connections and decreases cpu usage in
comparison of existing user-space implementation
(poptop/pptpclient). There is accel-pptp project
(https://sourceforge.net/projects/accel-pptp/) to utilize this module,
it contains plugin for pppd to use pptp in client-mode and modified
pptpd (poptop) to build high-performance pptp NAS.
There was many changes from initial submitted patch, most important are:
1. using rcu instead of read-write locks
2. using static bitmap instead of dynamically allocated
3. using vmalloc for memory allocation instead of BITS_PER_LONG + __get_free_pages
4. fixed many coding style issues
Thanks to Eric Dumazet.
Signed-off-by: Dmitry Kozlov <xeb@mail.ru>
__skb_get_rxhash() was broken after the commit:
commit bfb564e7391340638afe4ad67744a8f3858e7566
Author: Krishna Kumar <krkumar2@in.ibm.com>
Date: Wed Aug 4 06:15:52 2010 +0000
core: Factor out flow calculation from get_rps_cpu
net/sched: add ACT_CSUM action to update packets checksums
ACT_CSUM can be called just after ACT_PEDIT in order to re-compute some
altered checksums in IPv4 and IPv6 packets. The following checksums are
supported by this patch:
- IPv4: IPv4 header, ICMP, IGMP, TCP, UDP & UDPLite
- IPv6: ICMPv6, TCP, UDP & UDPLite
It's possible to request in the same action to update different kind of
checksums, if the packets flow mix TCP, UDP and UDPLite, ...
An example of usage is done in the associated iproute2 patch.
Version 3 changes:
- remove useless goto instructions
- improve IPv6 hop options decoding
Version 2 changes:
- coding style correction
- remove useless arguments of some functions
- use stack in tcf_csum_dump()
- add tcf_csum_skb_nextlayer() to factor code
Signed-off-by: Gregoire Baron <baronchon@n7mm.org>
Acked-by: jamal <hadi@cyberus.ca>
Now cmpxchg() is available on all arches, we can use it in
build_ehash_secret() and rt_bind_peer() instead of using spinlocks.
CC: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
The SPI isn't at the beginning of an AH message.
Fragmented IP packets may have no transfer header, so when computing
rxhash, we should skip them.
skb_get_rxhash() assumes the network header pointer of the skb is set
properly after the commit:
After skb is queued, its illegal to dereference it.
Cache skb->len into a temporary variable.
When adding a new vlan, if the underlying interface has no carrier,
then the newly added vlan interface should also have no carrier.
At present, this is not true - the newly added vlan is added with
carrier up. Fix by checking state of real device.
Signed-off-by: Phil Oester <kernel@linuxace.com>
No need to clear device stats in lec_open()
This patch removes the abstraction introduced by the union skb_shared_tx in
the shared skb data.
The access of the different union elements at several places led to some
confusion about accessing the shared tx_flags e.g. in skb_orphan_try().
http://marc.info/?l=linux-netdev&m=128084897415886&w=2
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
