path: root/net
2005-06-21[IPV4]: Fix fib_trie.c's args to fib_dump_info().David S. Miller
2005-06-21[NETFILTER]: Fix ip6t_LOG sit tunnel loggingPatrick McHardy
Sit tunnel logging is currently broken: MAC=01:23:45:67:89:ab->01:23:45:47:89:ac TUNNEL=123.123. 0.123-> 12.123. 6.123 Apart from the broken IP address, MAC addresses are printed differently for sit tunnels than for everything else. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Drop conntrack reference in ip_call_ra_chain()/ip_mr_input()Patrick McHardy
Drop reference before handing the packets to raw_rcv() Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Check TCP checksum in ipt_REJECTPatrick McHardy
2005-06-21[NETFILTER]: Avoid unncessary checksum validation in UDP connection trackingKeir Fraser
Signed-off-by: Keir Fraser <Keir.Fraser@xl.cam.ac.uk> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Missing owner-field initialization in ip6table_rawPatrick McHardy
I missed this one when fixing up iptable_raw. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: expectation timeouts are compulsoryPhil Oester
Since expectation timeouts were made compulsory [1], there is no need to check for them in ip_conntrack_expect_insert. [1] https://lists.netfilter.org/pipermail/netfilter-devel/2005-January/018143.html Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Restore netfilter assumptions in IPv6 multicastPatrick McHardy
Netfilter assumes that skb->data == skb->nh.ipv6h Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[NETFILTER]: Kill nf_debugPatrick McHardy
2005-06-21[NETFILTER]: Kill lockhelp.hPatrick McHardy
2005-06-21[IPV6]: multicast join and miscDavid L Stevens
Here is a simplified version of the patch to fix a bug in IPv6 multicasting. It: 1) adds existence check & EADDRINUSE error for regular joins 2) adds an exception for EADDRINUSE in the source-specific multicast join (where a prior join is ok) 3) adds a missing/needed read_lock on sock_mc_list; would've raced with destroying the socket on interface down without 4) adds a "leave group" in the (INCLUDE, empty) source filter case. This frees unneeded socket buffer memory, but also prevents an inappropriate interaction among the 8 socket options that mess with this. Some would fail as if in the group when you aren't really. Item #4 had a locking bug in the last version of this patch; rather than removing the idev->lock read lock only, I've simplified it to remove all lock state in the path and treat it as a direct "leave group" call for the (INCLUDE,empty) case it covers. Tested on an MP machine. :-) Much thanks to HoerdtMickael <hoerdt@clarinet.u-strasbg.fr> who reported the original bug. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[IPV6]: V6 route events reported with wrong netlink PID and seq numberJamal Hadi Salim
Essentially netlink at the moment always reports a pid and sequence of 0 always for v6 route activities. To understand the repurcassions of this look at: http://lists.quagga.net/pipermail/quagga-dev/2005-June/003507.html While fixing this, i took the liberty to resolve the outstanding issue of IPV6 routes inserted via ioctls to have the correct pids as well. This patch tries to behave as close as possible to the v4 routes i.e maintains whatever PID the socket issuing the command owns as opposed to the process. That made the patch a little bulky. I have tested against both netlink derived utility to add/del routes as well as ioctl derived one. The Quagga folks have tested against quagga. This fixes the problem and so far hasnt been detected to introduce any new issues. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[IPV4]: Add LC-Trie FIB lookup algorithm.Robert Olsson
Signed-off-by: Robert Olsson <Robert.Olsson@data.slu.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[NETLINK]: fib_lookup() via netlinkRobert Olsson
Below is a more generic patch to do fib_lookup via netlink. For others we should say that we discussed this as a way to verify route selection. It's also possible there are others uses for this. In short the fist half of struct fib_result_nl is filled in by caller and netlink call fills in the other half and returns it. In case anyone is interested there is a corresponding user app to compare the full routing table this was used to test implementation of the LC-trie. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[ATALK]: endian annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[IPSEC]: Add XFRM_STATE_NOPMTUDISC flagHerbert Xu
This patch adds the flag XFRM_STATE_NOPMTUDISC for xfrm states. It is similar to the nopmtudisc on IPIP/GRE tunnels. It only has an effect on IPv4 tunnel mode states. For these states, it will ensure that the DF flag is always cleared. This is primarily useful to work around ICMP blackholes. In future this flag could also allow a larger MTU to be set within the tunnel just like IPIP/GRE tunnels. This could be useful for short haul tunnels where temporary fragmentation outside the tunnel is desired over smaller fragments inside the tunnel. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[IPSEC]: Add xfrm_state_afinfo->init_flagsHerbert Xu
This patch adds the xfrm_state_afinfo->init_flags hook which allows each address family to perform any common initialisation that does not require a corresponding destructor call. It will be used subsequently to set the XFRM_STATE_NOPMTUDISC flag in IPv4. It also fixes up the error codes returned by xfrm_init_state. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[IPSEC]: Add xfrm_init_stateHerbert Xu
This patch adds xfrm_init_state which is simply a wrapper that calls xfrm_get_type and subsequently x->type->init_state. It also gets rid of the unused args argument. Abstracting it out allows us to add common initialisation code, e.g., to set family-specific flags. The add_time setting in xfrm_user.c was deleted because it's already set by xfrm_state_alloc. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: James Morris <jmorris@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-20[SCTP] sctp_connectx() API supportFrank Filz
Implements sctp_connectx() as defined in the SCTP sockets API draft by tunneling the request through a setsockopt(). Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[TCP]: Fix sysctl_tcp_low_latencyDavid S. Miller
When enabled, this should disable UCOPY prequeue'ing altogether, but it does not due to a missing test. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPV4]: [4/4] signed vs unsigned cleanup in net/ipv4/raw.cJesper Juhl
This patch changes the type of the third parameter 'length' of the raw_send_hdrinc() function from 'int' to 'size_t'. This makes sense since this function is only ever called from one location, and the value passed as the third parameter in that location is itself of type size_t, so this makes the recieving functions parameter type match. Also, inside raw_send_hdrinc() the 'length' variable is used in comparisons with unsigned values and passed as parameter to functions expecting unsigned values (it's used in a single comparison with a signed value, but that one can never actually be negative so the patch also casts that one to size_t to stop gcc worrying, and it is passed in a single instance to memcpy_fromiovecend() which expects a signed int, but as far as I can see that's not a problem since the value of 'length' shouldn't ever exceed the value of a signed int). Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPV4]: [3/4] signed vs unsigned cleanup in net/ipv4/raw.cJesper Juhl
This patch changes the type of the local variable 'i' in raw_probe_proto_opt() from 'int' to 'unsigned int'. The only use of 'i' in this function is as a counter in a for() loop and subsequent index into the msg->msg_iov[] array. Since 'i' is compared in a loop to the unsigned variable msg->msg_iovlen gcc -W generates this warning : net/ipv4/raw.c:340: warning: comparison between signed and unsigned Changing 'i' to unsigned silences this warning and is safe since the array index can never be negative anyway, so unsigned int is the logical type to use for 'i' and also enables a larger msg_iov[] array (but I don't know if that will ever matter). Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPV4]: [2/4] signed vs unsigned cleanup in net/ipv4/raw.cJesper Juhl
This patch gets rid of the following gcc -W warning in net/ipv4/raw.c : net/ipv4/raw.c:387: warning: comparison of unsigned expression < 0 is always false Since 'len' is of type size_t it is unsigned and can thus never be <0, and since this is obvious from the function declaration just a few lines above I think it's ok to remove the pointless check for len<0. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPV4]: [1/4] signed vs unsigned cleanup in net/ipv4/raw.cJesper Juhl
This patch silences these two gcc -W warnings in net/ipv4/raw.c : net/ipv4/raw.c:517: warning: signed and unsigned type in conditional expression net/ipv4/raw.c:613: warning: signed and unsigned type in conditional expression It doesn't change the behaviour of the code, simply writes the conditional expression with plain 'if()' syntax instead of '? :' , but since this breaks it into sepperate statements gcc no longer complains about having both a signed and unsigned value in the same conditional expression. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: noop/noqueue qdisc style cleanupsThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: Cleanup pfifo_fast qdisc and remove unnecessary codeThomas Graf
Removes the skb trimming code which is not needed since we never touch the skb upon failure. Removes unnecessary initializers, and simplifies the code a bit. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: Add and use prio2list() in the pfifo_fast qdiscThomas Graf
prio2list() returns the relevant sk_buff_head for the band specified by the priority for a given skb. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: Transform pfifo_fast to use generic queue management interfaceThomas Graf
Gives pfifo_fast a byte based backlog. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: Cleanup fifo qdisc and remove unnecessary codeThomas Graf
Removes the skb trimming code which is not needed since we never touch the skb upon failure. Removes unnecessary includes, initializers, and simplifies the code a bit. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: Transform fifo qdisc to use generic queue management interfaceThomas Graf
The simplicity of the fifo qdisc allows several qdisc operations to be redirected to the relevant queue management function directly. Saves a lot of code lines and gives the pfifo a byte based backlog. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[SCTP]: Replace spin_lock_irqsave with spin_lock_bhHerbert Xu
This patch replaces the spin_lock_irqsave call on the receive queue lock in SCTP with spin_lock_bh. Despite the proliferation of spin_lock_irqsave calls in this stack, it is only entered from the IPv4/IPv6 stack and user space. That is, it is never entered from hardirq context. The call in question is only called from recvmsg which means that IRQs aren't disabled. Therefore it is safe to replace it with spin_lock_bh. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPV4/IPV6]: Replace spin_lock_irq with spin_lock_bhHerbert Xu
In light of my recent patch to net/ipv4/udp.c that replaced the spin_lock_irq calls on the receive queue lock with spin_lock_bh, here is a similar patch for all other occurences of spin_lock_irq on receive/error queue locks in IPv4 and IPv6. In these stacks, we know that they can only be entered from user or softirq context. Therefore it's safe to disable BH only. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Set correct pid for ioctl originating netlink eventsJamal Hadi Salim
This patch ensures that netlink events created as a result of programns using ioctls (such as ifconfig, route etc) contains the correct PID of those events. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Explicit typingJamal Hadi Salim
This patch converts "unsigned flags" to use more explict types like u16 instead and incrementally introduces NLMSG_NEW(). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[DECNET]: Remove unnecessary initilization of unused variable entriesThomas Graf
This patch was supposed to be part of the neighbour tables related patchset but apparently got lost. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPSEC]: Add XFRMA_SA/XFRMA_POLICY for delete notificationHerbert Xu
This patch changes the format of the XFRM_MSG_DELSA and XFRM_MSG_DELPOLICY notification so that the main message sent is of the same format as that received by the kernel if the original message was via netlink. This also means that we won't lose the byid information carried in km_event. Since this user interface is introduced by Jamal's patch we can still afford to change it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Correctly set NLM_F_MULTI without checking the pidJamal Hadi Salim
This patch rectifies some rtnetlink message builders that derive the flags from the pid. It is now explicit like the other cases which get it right. Also fixes half a dozen dumpers which did not set NLM_F_MULTI at all. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Introduce NLMSG_NEW macro to better handle netlink flagsThomas Graf
Introduces a new macro NLMSG_NEW which extends NLMSG_PUT but takes a flags argument. NLMSG_PUT stays there for compatibility but now calls NLMSG_NEW with flags == 0. NLMSG_PUT_ANSWER is renamed to NLMSG_NEW_ANSWER which now also takes a flags argument. Also converts the users of NLMSG_PUT_ANSWER to use NLMSG_NEW_ANSWER and fixes the two direct users of __nlmsg_put to either provide the flags or use NLMSG_NEW(_ANSWER). Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[PKT_SCHED]: Logic simplifications and codingstyle/whitespace cleanupsThomas Graf
2005-06-18[PKT_SCHED]: Make dsmark use the new dumping macrosThomas Graf
2005-06-18[PKT_SCHED]: Fix dsmark to apply changes consistentThomas Graf
Fixes dsmark to do all configuration sanity checks first and only apply the changes if all of them can be applied without any errors. Also fixes the weak sanity checks for DSMARK_VALUE and DSMASK_MASK. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NEIGH]: Fix use of uninitialized variable when trimming in neightbl_fill_parmsThomas Graf
2005-06-18[NETLINK]: Kill bogus NLMSG_SET_MULTIPART uses.Thomas Graf
2005-06-18[NETLINK]: Neighbour table configuration and statistics via rtnetlinkThomas Graf
To retrieve the neighbour tables send RTM_GETNEIGHTBL with the NLM_F_DUMP flag set. Every neighbour table configuration is spread over multiple messages to avoid running into message size limits on systems with many interfaces. The first message in the sequence transports all not device specific data such as statistics, configuration, and the default parameter set. This message is followed by 0..n messages carrying device specific parameter sets. Although the ordering should be sufficient, NDTA_NAME can be used to identify sequences. The initial message can be identified by checking for NDTA_CONFIG. The device specific messages do not contain this TLV but have NDTPA_IFINDEX set to the corresponding interface index. To change neighbour table attributes, send RTM_SETNEIGHTBL with NDTA_NAME set. Changeable attribute include NDTA_THRESH[1-3], NDTA_GC_INTERVAL, and all TLVs in NDTA_PARMS unless marked otherwise. Device specific parameter sets can be changed by setting NDTPA_IFINDEX to the interface index of the corresponding device. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET]: Move sysctl_max_syn_backlog into request_sock.cDavid S. Miller
This fixes the CONFIG_INET=n build failure noticed by Andrew Morton. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] rename struct tcp_listen_opt to struct listen_sockArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Generalise tcp_listen_optArnaldo Carvalho de Melo
This chunks out the accept_queue and tcp_listen_opt code and moves them to net/core/request_sock.c and include/net/request_sock.h, to make it useful for other transport protocols, DCCP being the first one to use it. Next patches will rename tcp_listen_opt to accept_sock and remove the inline tcp functions that just call a reqsk_queue_ function. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Rename open_request to request_sockArnaldo Carvalho de Melo
Ok, this one just renames some stuff to have a better namespace and to dissassociate it from TCP: struct open_request -> struct request_sock tcp_openreq_alloc -> reqsk_alloc tcp_openreq_free -> reqsk_free tcp_openreq_fastfree -> __reqsk_free With this most of the infrastructure closely resembles a struct sock methods subset. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NET] Generalise TCP's struct open_request minisock infrastructureArnaldo Carvalho de Melo
Kept this first changeset minimal, without changing existing names to ease peer review. Basicaly tcp_openreq_alloc now receives the or_calltable, that in turn has two new members: ->slab, that replaces tcp_openreq_cachep ->obj_size, to inform the size of the openreq descendant for a specific protocol The protocol specific fields in struct open_request were moved to a class hierarchy, with the things that are common to all connection oriented PF_INET protocols in struct inet_request_sock, the TCP ones in tcp_request_sock, that is an inet_request_sock, that is an open_request. I.e. this uses the same approach used for the struct sock class hierarchy, with sk_prot indicating if the protocol wants to use the open_request infrastructure by filling in sk_prot->rsk_prot with an or_calltable. Results? Performance is improved and TCP v4 now uses only 64 bytes per open request minisock, down from 96 without this patch :-) Next changeset will rename some of the structs, fields and functions mentioned above, struct or_calltable is way unclear, better name it struct request_sock_ops, s/struct open_request/struct request_sock/g, etc. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[IPSEC] Use NLMSG_LENGTH in xfrm_exp_state_notifyJamal Hadi Salim
Small fixup to use netlink macros instead of hardcoding. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
