path: root/net/xfrm/xfrm_input.c
2008-03-24[IPSEC]: Fix inter address family IPsec tunnel handling.Kazunori MIYAZAWA
Signed-off-by: Kazunori MIYAZAWA <kazunori@miyazawa.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-12[IPSEC]: Fix bogus usage of u64 on input sequence numberHerbert Xu
Al Viro spotted a bogus use of u64 on the input sequence number which is big-endian. This patch fixes it by giving the input sequence number its own member in the xfrm_skb_cb structure. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[XFRM]: Fix statistics.Masahide NAKAMURA
o Outbound sequence number overflow error status is counted as XfrmOutStateSeqError. o Additionaly, it changes inbound sequence number replay error name from XfrmInSeqOutOfWindow to XfrmInStateSeqError to apply name scheme above. o Inbound IPv4 UDP encapsuling type mismatch error is wrongly mapped to XfrmInStateInvalid then this patch fiex the error to XfrmInStateMismatch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[XFRM]: Remove unused exports.Adrian Bunk
This patch removes the following no longer used EXPORT_SYMBOL's: - xfrm_input.c: xfrm_parse_spi - xfrm_state.c: xfrm_replay_check - xfrm_state.c: xfrm_replay_advance Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move all calls to xfrm_audit_state_icvfail to xfrm_inputHerbert Xu
Let's nip the code duplication in the bud :) Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: RFC4303 compliant auditingPaul Moore
This patch adds a number of new IPsec audit events to meet the auditing requirements of RFC4303. This includes audit hooks for the following events: * Could not find a valid SA [sections 2.1, 3.4.2] . xfrm_audit_state_notfound() . xfrm_audit_state_notfound_simple() * Sequence number overflow [section 3.3.3] . xfrm_audit_state_replay_overflow() * Replayed packet [section 3.4.3] . xfrm_audit_state_replay() * Integrity check failure [sections 3.4.4.1, 3.4.4.2] . xfrm_audit_state_icvfail() While RFC4304 deals only with ESP most of the changes in this patch apply to IPsec in general, i.e. both AH and ESP. The one case, integrity check failure, where ESP specific code had to be modified the same was done to the AH code for the sake of consistency. Signed-off-by: Paul Moore <paul.moore@hp.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: Support to increment packet dropping statistics.Masahide NAKAMURA
2008-01-28[IPSEC]: Add xfrm_input_state helperHerbert Xu
This patch adds the xfrm_input_state helper function which returns the current xfrm state being processed on the input path given an sk_buff. This is currently only used by xfrm_input but will be used by ESP upon asynchronous resumption. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Use the correct family for input state lookupHerbert Xu
When merging the input paths of IPsec I accidentally left a hard-coded AF_INET for the state lookup call. This broke IPv6 obviously. This patch fixes by getting the input callers to specify the family through skb->cb. Credit goes to Kazunori Miyazawa for diagnosing this and providing an initial patch. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Add async resume support on inputHerbert Xu
This patch adds support for async resumptions on input. To do so, the transform would return -EINPROGRESS and subsequently invoke the function xfrm_input_resume to resume processing. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Remove nhoff from xfrm_inputHerbert Xu
The nhoff field isn't actually necessary in xfrm_input. For tunnel mode transforms we now throw away the output IP header so it makes no sense to fill in the nexthdr field. For transport mode we can now let the function transport_finish do the setting and it knows where the nexthdr field is. The only other thing that needs the nexthdr field to be set is the header extraction code. However, we can simply move the protocol extraction out of the generic header extraction. We want to minimise the amount of info we have to carry around between transforms as this simplifies the resumption process for async crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move state lock into x->type->inputHerbert Xu
This patch releases the lock on the state before calling x->type->input. It also adds the lock to the spots where they're currently needed. Most of those places (all except mip6) are expected to disappear with async crypto. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Move integrity stat collection into xfrm_inputHerbert Xu
Similar to the moving out of the replay processing on the output, this patch moves the integrity stat collectin from x->type->input into xfrm_input. This would eventually allow transforms such as AH/ESP to be lockless. The error value EBADMSG (currently unused in the crypto layer) is used to indicate a failed integrity check. In future this error can be directly returned by the crypto layer once we switch to aead algorithms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Store xfrm states in security path directlyHerbert Xu
As it is xfrm_input first collects a list of xfrm states on the stack before storing them in the packet's security path just before it returns. For async crypto, this construction presents an obstacle since we may need to leave the loop after each transform. In fact, it's much easier to just skip the stack completely and always store to the security path. This is proven by the fact that this patch actually shrinks the code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Merge most of the input pathHerbert Xu
As part of the work on asynchronous cryptographic operations, we need to be able to resume from the spot where they occur. As such, it helps if we isolate them to one spot. This patch moves most of the remaining family-specific processing into the common input code. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Separate inner/outer mode processing on inputHerbert Xu
With inter-family transforms the inner mode differs from the outer mode. Attempting to handle both sides from the same function means that it needs to handle both IPv4 and IPv6 which creates duplication and confusion. This patch separates the two parts on the input path so that each function deals with one family only. In particular, the functions xfrm4_extract_inut/xfrm6_extract_inut moves the pertinent fields from the IPv4/IPv6 IP headers into a neutral format stored in skb->cb. This is then used by the inner mode input functions to modify the inner IP header. In this way the input function no longer has to know about the outer address family. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17[IPSEC]: Fix length check in xfrm_parse_spiHerbert Xu
Currently xfrm_parse_spi requires there to be 16 bytes for AH and ESP. In contrived cases there may not actually be 16 bytes there since the respective header sizes are less than that (8 and 12 currently). This patch changes the test to use the actual header length instead of 16. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] XFRM: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-07[PATCH] slab: remove SLAB_ATOMICChristoph Lameter
SLAB_ATOMIC is an alias of GFP_ATOMIC Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-28[XFRM]: xfrm_parse_spi() annotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Use SLAB_PANICAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-22[NET]: Fix "ntohl(ntohs" bugsAlexey Dobriyan
2006-04-01[IPSEC]: Kill unused decap state structureHerbert Xu
This patch removes the *_decap_state structures which were previously used to share state between input/post_input. This is no longer needed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: use __read_mostly on kmem_cache_t , DEFINE_SNMP_STAT pointersEric Dumazet
This patch puts mostly read only data in the right section (read_mostly), to help sharing of these data between CPUS without memory ping pongs. On one of my production machine, tcp_statistics was sitting in a heavily modified cache line, so *every* SNMP update had to force a reload. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
