path: root/net/x25/af_x25.c
2011-10-17x25: Prevent skb overreads when checking call user dataMatthew Daley
x25_find_listener does not check that the amount of call user data given in the skb is big enough in per-socket comparisons, hence buffer overreads may occur. Fix this by adding a check. Signed-off-by: Matthew Daley <mattjd@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Cc: stable <stable@kernel.org> Acked-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-17x25: Handle undersized/fragmented skbsMatthew Daley
There are multiple locations in the X.25 packet layer where a skb is assumed to be of at least a certain size and that all its data is currently available at skb->data. These assumptions are not checked, hence buffer overreads may occur. Use pskb_may_pull to check these minimal size assumptions and ensure that data is available at skb->data when necessary, as well as use skb_copy_bits where needed. Signed-off-by: Matthew Daley <mattjd@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Andrew Hendry <andrew.hendry@gmail.com> Cc: stable <stable@kernel.org> Acked-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-17x25: Validate incoming call user data lengthsMatthew Daley
X.25 call user data is being copied in its entirety from incoming messages without consideration to the size of the destination buffers, leading to possible buffer overflows. Validate incoming call user data lengths before these copies are performed. It appears this issue was noticed some time ago, however nothing seemed to come of it: see http://www.spinics.net/lists/linux-x25/msg00043.html and commit 8db09f26f912f7c90c764806e804b558da520d4f. Signed-off-by: Matthew Daley <mattjd@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Andrew Hendry <andrew.hendry@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-01x25: Reduce switch/case indentJoe Perches
Make the case labels the same indent as the switch. git diff -w shows 80 column line reflowing. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-05x25: remove the BKLArnd Bergmann
This replaces all instances of lock_kernel in x25 with lock_sock, taking care to release the socket lock around sleeping functions (sock_alloc_send_skb and skb_recv_datagram). It is not clear whether this is a correct solution, but it seem to be what other protocols do in the same situation. Includes a fix suggested by Eric Dumazet. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Andrew Hendry <andrew.hendry@gmail.com> Cc: linux-x25@vger.kernel.org Cc: netdev@vger.kernel.org Cc: Eric Dumazet <eric.dumazet@gmail.com>
2010-11-28X25 remove bkl in call user data length ioctlandrew hendry
Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-28X25 remove bkl from causediag ioctlsandrew hendry
2010-11-28X25 remove bkl from calluserdata ioctlsandrew hendry
2010-11-28X25 remove bkl in facility ioctlsandrew hendry
2010-11-28X25 remove bkl in subscription ioctlsandrew hendry
2010-11-19X25: remove bkl in routing ioctlsandrew hendry
Routing doesn't use the socket data and is protected by x25_route_list_lock Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-19X25: remove bkl in inq and outq ioctlsandrew hendry
2010-11-19X25: remove bkl in timestamp ioctlsandrew hendry
2010-11-19X25: pushdown bkl in ioctlsandrew hendry
Push down the bkl in the ioctls so they can be removed one at a time. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-22X.25 remove bkl in pollandrew hendry
The x25_datagram_poll didn't add anything, removed it. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-22X.25 remove bkl in getsocknameandrew hendry
2010-09-14X.25 remove bkl in connectandrew hendry
Connect already has socket locking. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14X.25 remove bkl in acceptAndrew Hendry
Accept already has socket locking. [ Extend socket locking over TCP_LISTEN state test. -DaveM ] Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14X.25 remove bkl in bindandrew hendry
Accept updates socket values in 3 lines so wrapped with lock_sock. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-14X.25 remove bkl in listenandrew hendry
Listen updates socket values and needs lock_sock. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Remove bkl in sockoptsandrew hendry
Removes the BKL in x25 setsock and getsockopts. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Move accept approve flag to bitfieldandrew hendry
Moves the x25 accept approve flag from char into bitfield. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Move interrupt flag to bitfieldandrew hendry
Moves the x25 interrupt flag from char into bitfield. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17X25: Move qbit flag to bitfieldandrew hendry
Moves the X25 q bit flag from char into a bitfield to allow BKL cleanup. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/e100.c drivers/net/e1000e/netdev.c
2010-04-21X25 fix dead unaccepted socketsandrew hendry
1, An X25 program binds and listens 2, calls arrive waiting to be accepted 3, Program exits without accepting 4, Sockets time out but don't get correctly cleaned up 5, cat /proc/net/x25/socket shows the dead sockets with bad inode fields. This line borrowed from AX25 sets the dying socket so the timers clean up later. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-11Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-04-07x.25 attempts to negotiate invalid throughputJohn Hughes
The current X.25 code has some bugs in throughput negotiation: 1. It does negotiation in all cases, usually there is no need 2. It incorrectly attempts to negotiate the throughput class in one direction only. There are separate throughput classes for input and output and if either is negotiated both mist be negotiates. This is bug https://bugzilla.kernel.org/show_bug.cgi?id=15681 This bug was first reported by Daniel Ferenci to the linux-x25 mailing list on 6/8/2004, but is still present. The current (2.6.34) x.25 code doesn't seem to know that the X.25 throughput facility includes two values, one for the required throughput outbound, one for inbound. This causes it to attempt to negotiate throughput 0x0A, which is throughput 9600 inbound and the illegal value "0" for inbound throughput. Because of this some X.25 devices (e.g. Cisco 1600) refuse to connect to Linux X.25. The following patch fixes this behaviour. Unless the user specifies a required throughput it does not attempt to negotiate. If the user does not specify a throughput it accepts the suggestion of the remote X.25 system. If the user requests a throughput then it validates both the input and output throughputs and correctly negotiates them with the remote end. Signed-off-by: John Hughes <john@calva.com> Tested-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-07x25: Patch to fix bug 15678 - x25 accesses fields beyond end of packet.John Hughes
Here is a patch to stop X.25 examining fields beyond the end of the packet. For example, when a simple CALL ACCEPTED was received: 10 10 0f x25_parse_facilities was attempting to decode the FACILITIES field, but this packet contains no facilities field. Signed-off-by: John Hughes <john@calva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-15X25: Dont let x25_bind use addresses containing charactersandrew hendry
Addresses should be all digits. Stops x25_bind using addresses containing characters. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-15X25: Fix x25_create errors for bad protocol and ENOBUFSandrew hendry
alloc_socket failures should return -ENOBUFS a bad protocol should return -EINVAL Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29X25: Check for errors in x25_initandrew hendry
Adds error checking to x25_init. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29X25: Move SYSCTL ifdefs into headerandrew hendry
Moves the CONFIG_SYSCTL ifdefs in x25_init into header. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18X25: Enable setting of cause and diagnostic fieldsAndrew Hendry
Adds SIOCX25SCAUSEDIAG, allowing X.25 programs to set the cause and diagnostic fields. Normally used to indicate status upon closing connections. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-07net/x25: push BKL usage into x25_protoArnd Bergmann
The x25 driver uses lock_kernel() implicitly through its proto_ops wrapper. The makes the usage explicit in order to get rid of that wrapper and to better document the usage of the BKL. The next step should be to get rid of the usage of the BKL in x25 entirely, which requires understanding what data structures need serialized accesses. Cc: Henner Eisen <eis@baty.hanse.de> Cc: David S. Miller <davem@davemloft.net> Cc: linux-x25@vger.kernel.org Cc: netdev@vger.kernel.org Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-13x25: bit and/or confusion in x25_ioctl()?roel kluin
Looking at commit ebc3f64b864f it appears that this was intended and not the original, equivalent to `if (facilities.reverse & ~0x81)'. In x25_parse_facilities() that patch changed how facilities->reverse was set. No other bits were set than 0x80 and/or 0x01. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17net: sk_wmem_alloc has initial value of one, not zeroEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. Some protocols check sk_wmem_alloc value to determine if a timer must delay socket deallocation. We must take care of the sk_wmem_alloc value being one instead of zero when no write allocations are pending. Reported by Ingo Molnar, and full diagnostic from David Miller. This patch introduces three helpers to get read/write allocations and a followup patch will use these helpers to report correct write allocations to user. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16x25: Fix sleep from timer on socket destroy.David S. Miller
If socket destuction gets delayed to a timer, we try to lock_sock() from that timer which won't work. Use bh_lock_sock() in that case. Signed-off-by: David S. Miller <davem@davemloft.net> Tested-by: Ingo Molnar <mingo@elte.hu>
2009-03-27af_rose/x25: Sanity check the maximum user frame sizeAlan Cox
Otherwise we can wrap the sizes and end up sending garbage. Closes #10423 Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13x25: '< 0' and '>= 0' test on unsignedRoel Kluin
skb->len is an unsigned int, so the test in x25_rx_call_request() always evaluates to true. len in x25_sendmsg() is unsigned as well. so -ERRORS returned by x25_output() are not noticed. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
