Since cfg80211 maintains separate BSS table entries for APs if the same
BSSID, SSID pair is seen on multiple channels, it is possible that it
can map the current_bss to a BSS entry on the wrong channel. This
current_bss will not get flushed unless disconnected and cfg80211
reports a wrong channel as the associated channel.
Fix this by introducing a new cfg80211_connect_bss() function which is
similar to cfg80211_connect_result(), but it includes an additional
parameter: the bss the STA is connected to. This allows drivers to
provide the exact bss entry that matches the BSS to which the connection
was completed.
Reviewed-by: Jouni Malinen <jouni@qca.qualcomm.com>
Signed-off-by: Vidyullatha Kanchanapally <vkanchan@qti.qualcomm.com>
Signed-off-by: Sunil Dutt <usdutt@qti.qualcomm.com>
This enum is already perfectly aliased to enum nl80211_band, and
the only reason for it is that we get IEEE80211_NUM_BANDS out of
it. There's no really good reason to not declare the number of
bands in nl80211 though, so do that and remove the cfg80211 one.
If the user space issues a NL80211_CMD_CONNECT with
NL80211_ATTR_PREV_BSSID when there is already a connection, allow this
to proceed as a reassociation instead of rejecting the new connect
command with EALREADY.
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[validate prev_bssid]
This allows scans for a specific BSSID to be optimized by the user space
application by requesting the driver to set the Probe Request frame
BSSID field (Address 3) to the specified BSSID instead of the wildcard
BSSID. This prevents other APs from replying which reduces airtime need
and latency in getting the response from the target AP through.
This is an optimization and as such, it is acceptable for some of the
drivers not to support the mechanism. If not supported, the wildcard
BSSID will be used and more responses may be received.
Several cases of overlapping changes, as well as one instance
(vxlan) of a bug fix in 'net' overlapping with code movement
in 'net-next'.
PBSS (Personal Basic Service Set) is a new BSS type for DMG
networks. It is similar to infrastructure BSS, having an AP-like
entity called PCP (PBSS Control Point), but it has few differences.
PBSS support is mandatory for 11ad devices.
Add support for PBSS by introducing a new PBSS flag attribute.
The PBSS flag is used in the START_AP command to request starting
a PCP instead of an AP, and in the CONNECT command to request
connecting to a PCP instead of an AP.
Signed-off-by: Lior David <liord@codeaurora.org>
When user-space has started a critical protocol session and a disconnect
event occurs, the rdev::crit_prot_nlportid remains set. This caused a
subsequent NL80211_CMD_CRIT_PROTO_START to fail (-EBUSY). Fix this by
clearing the rdev attribute and call .crit_proto_stop() callback upon
disconnect event.
Reviewed-by: Hante Meuleman <meuleman@broadcom.com>
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
When we disconnect from the AP, drivers call cfg80211_disconnect().
This doesn't know whether the disconnection was initiated locally
or by the AP though, which can cause problems with the supplicant,
for example with WPS. This issue obviously doesn't show up with any
mac80211 based driver since mac80211 doesn't call this function.
Fix this by requiring drivers to indicate whether the disconnect is
locally generated or not. I've tried to update the drivers, but may
not have gotten the values correct, and some drivers may currently
not be able to report correct values. In case of doubt I left it at
false, which is the current behaviour.
For libertas, make adjustments as indicated by Dan Williams.
Reported-by: Matthieu Mauger <matthieux.mauger@intel.com>
Tested-by: Matthieu Mauger <matthieux.mauger@intel.com>
If the connect request from userspace didn't include an extended
capabilities IE, create one using the driver capabilities. This
fixes VHT associations, since those need to set the operating mode
notification capability.
Reviewed-by: Gregory Greenman <gregory.greenman@intel.com>
802.11ad adds new a network type (PBSS) and changes the capability
field interpretation for the DMG (60G) band.
The same 2 bits that were interpreted as "ESS" and "IBSS" before are
re-used as a 2-bit field with 3 valid values (and 1 reserved). Valid
values are: "IBSS", "PBSS" (new) and "AP".
In order to get the BSS struct for the new PBSS networks, change the
cfg80211_get_bss() function to take a new enum ieee80211_bss_type
argument with the valid network types, as "capa_mask" and "capa_val"
no longer work correctly (the search must be band-aware now.)
The remaining bits in "capa_mask" and "capa_val" are used only for
privacy matching so replace those two with a privacy enum as well.
Signed-off-by: Dedy Lansky <dlansky@codeaurora.org>
[rewrite commit log, tiny fixes]
ATM, specifying the frequency when connecting sends a void 'supported
rates' EID.
Signed-off-by: Karl Beldan <karl.beldan@rivierawaves.com>
[fix memory leak in error path]
When freeing the connect keys, clear the memory to avoid
having the key material stick around in memory "forever".
This also propagates through the drivers.
The orinoco driver uses the cfg80211 API structs for internal
bookkeeping, and so needs a (void *) cast that removes the
const - but that's OK because it allocates those pointers.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
cfg80211 is notified about connection failures by
__cfg80211_connect_result() call. However, this
function currently does not free cfg80211 sme.
This results in hanging connection attempts in some cases
e.g. when mac80211 authentication attempt is denied,
we have this function call:
ieee80211_rx_mgmt_auth() -> cfg80211_rx_mlme_mgmt() ->
cfg80211_process_auth() -> cfg80211_sme_rx_auth() ->
but cfg80211_sme_free() is never get called.
Fixes: ceca7b712 ("cfg80211: separate internal SME implementation")
Cc: stable@vger.kernel.org (3.10+)
Signed-off-by: Eliad Peller <eliadx.peller@intel.com>
These really can't trigger unless somebody messes up the code,
but don't make debugging it needlessly complicated, WARN and
return instead of BUG_ON().
Name wiphy_to_rdev is more accurate to describe what the function
does, i.e., return a pointer pointing to struct
cfg80211_registered_device.
Signed-off-by: Zhao, Gang <gamerh2o@gmail.com>
Wdev->ssid_len has already been set in cfg80211_connect() and is equal
to connect->ssid_len. Use wdev->ssid_len instead of connect->ssid_len
so it will be consistent with previous ssid assignment statement.
If bss is found in cfg80211_get_conn_bss(), wdev->conn->state is set
to CFG80211_CONN_AUTHENTICATE_NEXT in there. So it's not needed to set
it manually to CFG80211_CONN_AUTHENTICATE_NEXT if bss is found in that
function.
Macro ASSERT_RDEV_LOCK(rdev) is equal to ASSERT_RTNL(), so replace it
with ASSERT_RTNL() and remove it.
Due to the previous commit, when a scan finishes, it is in theory
possible to hit the following sequence:
1. interface starts being removed
2. scan is cancelled by driver and cfg80211 is notified
3. scan done work is scheduled
4. interface is removed completely, rdev->scan_req is freed,
event sent to userspace but scan done work remains pending
5. new scan is requested on another virtual interface
6. scan done work runs, freeing the still-running scan
To fix this situation, hang on to the scan done message and block
new scans while that is the case, and only send the message from
the work function, regardless of whether the scan_req is already
freed from interface removal. This makes step 5 above impossible
and changes step 6 to be
5. scan done work runs, sending the scan done message
As this can't work for wext, so we send the message immediately,
but this shouldn't be an issue since we still return -EBUSY.
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
Add a utility function to get the number of channels supported by
the device, and update the places in the code that need this data.
Signed-off-by: Ilan Peer <ilan.peer@intel.com>
[replace another occurrence in libertas, fix kernel-doc, fix bugs]
This allows QoS mapping from external networks to be implemented as
defined in IEEE Std 802.11-2012, 10.24.9. APs can use this to advertise
DSCP ranges and exceptions for mapping frames to a specific UP over
Wi-Fi.
The payload of the QoS Map Set element (IEEE Std 802.11-2012, 8.4.2.97)
is sent to the driver through the new NL80211_ATTR_QOS_MAP attribute to
configure the local behavior either on the AP (based on local
configuration) or on a station (based on information received from the
AP).
Signed-off-by: Kyeyoon Park <kyeyoonp@qca.qualcomm.com>
cfg80211 allows re-association in managed mode and if a user
wants to re-associate to the same AP network after the time
period of IEEE80211_SCAN_RESULT_EXPIRE, cfg80211 warns with
the following message on receiving the connect result event.
WARNING: CPU: 0 PID: 13984 at net/wireless/sme.c:658
__cfg80211_connect_result+0x3a6/0x3e0 [cfg80211]()
Call Trace:
[<ffffffff81747a41>] dump_stack+0x46/0x58
[<ffffffff81045847>] warn_slowpath_common+0x87/0xb0
[<ffffffff81045885>] warn_slowpath_null+0x15/0x20
[<ffffffffa05345f6>] __cfg80211_connect_result+0x3a6/0x3e0 [cfg80211]
[<ffffffff8107168b>] ? update_rq_clock+0x2b/0x50
[<ffffffff81078c01>] ? update_curr+0x1/0x160
[<ffffffffa05133d2>] cfg80211_process_wdev_events+0xb2/0x1c0 [cfg80211]
[<ffffffff81079303>] ? pick_next_task_fair+0x63/0x170
[<ffffffffa0513518>] cfg80211_process_rdev_events+0x38/0x90 [cfg80211]
[<ffffffffa050f03d>] cfg80211_event_work+0x1d/0x30 [cfg80211]
[<ffffffff8105f21f>] process_one_work+0x17f/0x420
[<ffffffff8105f90a>] worker_thread+0x11a/0x370
[<ffffffff8105f7f0>] ? rescuer_thread+0x2f0/0x2f0
[<ffffffff8106638b>] kthread+0xbb/0xc0
[<ffffffff810662d0>] ? kthread_create_on_node+0x120/0x120
[<ffffffff817574bc>] ret_from_fork+0x7c/0xb0
---[ end trace 61f3bddc9c4981f7 ]---
The reason is that, in connect result event cfg80211 unholds
the BSS to which the device is associated (and was held so
far). So, for the event with status successful, when cfg80211
wants to get that BSS from the device's BSS list it gets a
NULL BSS because the BSS has been expired and unheld already.
Fix it by reshuffling the code.
Signed-off-by: Ujjal Roy <royujjal@gmail.com>
It is incorrect to refer to this as 11d as 802.11d was just a
proposed amendment, 802.11d was merged to the standard so
use proper terminology.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Neil Brown reports that with libertas, my recent cfg80211
SME changes in commit ceca7b7121795ef81bd598a240d53a92566
("cfg80211: separate internal SME implementation") broke
libertas suspend because it we now asked it to disconnect
while already disconnected.
The problematic change is in cfg80211_disconnect() as it
previously checked the SME state and now calls the driver
disconnect operation unconditionally.
Fix this by checking if there's a current_bss indicating
a connection, and do nothing if not.
Reported-and-tested-by: Neil Brown <neilb@suse.de>
When splitting the SME implementation from the MLME code,
I introduced a few bugs:
* association failures no longer sent a connect-failure event
* getting disassociated from the AP caused deauth to be sent
but state wasn't cleaned up, leading to warnings
* authentication failures weren't cleaned up properly, causing
new connection attempts to warn and fail
Fix these bugs.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Should help the next person that tries to understand
the bss refcounting logic.
Signed-off-by: Ben Greear <greearb@candelatech.com>
Otherwise, we can leak a bss reference.
This fixes the potential issue that the BSS struct that we use
and later assign to wdev->current_bss is removed from the scan
list while associating.
Also warn when we don't have a BSS struct in connect_result
unless it's from a driver that only has the connect() API.
The current internal SME implementation in cfg80211 is
very mixed up with the MLME handling, which has been
causing issues for a long time. There are three things
that the implementation has to provide:
* a basic SME implementation for nl80211's connect()
call (for drivers implementing auth/assoc, which is
really just mac80211) and wireless extensions
* MLME events for the userspace SME
* SME events (connected, disconnected etc.) for all
different SME implementation possibilities (driver,
cfg80211 and userspace)
To achieve these goals it isn't necessary to track the
software SME's connection status outside of it's state
(which is the part that caused many issues.) Instead,
track it only in the SME data (wdev->conn) and in the
general case only track whether the wdev is connected
or not (via wdev->current_bss.)
Also separate the internal implementation to not have
callbacks from the SME events, but rather call it from
the API functions that the driver (or rather mac80211)
calls. This separates the code better.
By making all the API functions require wdev locking we
can clean up the API a bit, getting rid of the locking
version of each function. This also decreases the size
of cfg80211 by a small amount.
Virtually all code paths in cfg80211 already (need to) hold
the RTNL. As such, there's little point in having another
four mutexes for various parts of the code, they just cause
lock ordering issues (and much of the time, the RTNL and a
few of the others need thus be held.)
Simplify all this by getting rid of the extra four mutexes
and just use the RTNL throughout. Only a few code changes
were needed to do this and we can get rid of a work struct
for bonus points.
If a P2P-Device is present and another virtual interface triggers
the connection work, the system crash because it tries to check
if the P2P-Device's netdev (which doesn't exist) is up. Skip any
wdevs that have no netdev to fix this.
Reported-by: YanBo <dreamfly281@gmail.com>
When the interface goes down, there's no need to call
cfg80211_mlme_down() after __cfg80211_disconnect() as
the latter will call the former (if appropriate.)
Also, in __cfg80211_disconnect(), if the cfg80211 SME
isn't used, __cfg80211_disconnected() may still need
to be called (depending on the current state) so that
the SME state gets cleared.
drivers/net/wireless/rt2x00/rt2x00pci.c
Introduced in f9f475292dbb0e7035fb6661d1524761ea0888d9
("cfg80211: always check for scan end on P2P device")
cfg80211_conn_scan() which requires sched_scan_mtx to be held can be called
from cfg80211_conn_work(). Without this we are hitting multiple warnings like
the following:
WARNING: at net/wireless/sme.c:88 cfg80211_conn_scan+0x1dc/0x3a0 [cfg80211]()
Hardware name: 0578A21
Modules linked in: ...
Pid: 620, comm: kworker/3:1 Not tainted 3.9.0-rc4-next-20130328+ #326
Call Trace:
[<c1036992>] warn_slowpath_common+0x72/0xa0
[<c10369e2>] warn_slowpath_null+0x22/0x30
[<faa4b0ec>] cfg80211_conn_scan+0x1dc/0x3a0 [cfg80211]
[<faa4b344>] cfg80211_conn_do_work+0x94/0x380 [cfg80211]
[<faa4c3b2>] cfg80211_conn_work+0xa2/0x130 [cfg80211]
[<c1051858>] process_one_work+0x198/0x450
Signed-off-by: Artem Savkov <artem.savkov@gmail.com>
net/mac80211/sta_info.c
net/wireless/core.h
If a P2P device wdev is removed while it has a scan, then the
scan completion might crash later as it is already freed by
that time. To avoid the crash always check the scan completion
when the P2P device is being removed for some reason. If the
driver already canceled it, don't want and free it, otherwise
warn and leak it to avoid later crashes.
In order to do this, locking needs to be changed away from the
rdev mutex (which can't always be guaranteed). For now, use
the sched_scan_mtx instead, I'll rename it to just scan_mtx in
a later patch.
If wpa_supplicant and iw/iwconfig are used together, very
rarely the system crashes. It seems to be related to the
connection parameters not being set up, but it's not all
clear to me how this happens. In any case, checking that
the conn pointer exists here is probably a good idea.
cfg80211_mlme_assoc() has grown far too many arguments,
make the caller build almost all of the driver struct
and pass that to the function instead.
For testing it's sometimes useful to be able to
override certain VHT capability advertisement,
add the ability to do that in cfg80211.
This prepares for using the spinlock instead of krefs
which is needed in the next patch to track the refs
of combined BSSes correctly.
Acked-by: Bing Zhao <bzhao@marvell.com> [mwifiex]
The NL80211_ATTR_USE_MFP attribute was originally added for
NL80211_CMD_ASSOCIATE, but it is actually as useful (if not even more
useful) with NL80211_CMD_CONNECT, so process that attribute with the
connect command, too.
Clean up various things like indentation, extra
parentheses, too many/few line breaks, etc.
Acked-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
When a BSS struct is updated, the IEs are currently
overwritten or freed. This can lead to races if some
other CPU is accessing the BSS struct and using the
IEs concurrently.
Fix this by always allocating the IEs in a new struct
that holds the data and length and protecting access
to this new struct with RCU.
This will allow adding central tracing like in mac80211.
Signed-off-by: Hila Gonen <hila.gonen@intel.com>
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
