path: root/net/wireless/Kconfig
2011-01-20kconfig: rename CONFIG_EMBEDDED to CONFIG_EXPERTDavid Rientjes
The meaning of CONFIG_EMBEDDED has long since been obsoleted; the option is used to configure any non-standard kernel with a much larger scope than only small devices. This patch renames the option to CONFIG_EXPERT in init/Kconfig and fixes references to the option throughout the kernel. A new CONFIG_EMBEDDED option is added that automatically selects CONFIG_EXPERT when enabled and can be used in the future to isolate options that should only be considered for embedded systems (RISC architectures, SLOB, etc). Calling the option "EXPERT" more accurately represents its intention: only expert users who understand the impact of the configuration changes they are making should enable it. Reviewed-by: Ingo Molnar <mingo@elte.hu> Acked-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Greg KH <gregkh@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jens Axboe <axboe@kernel.dk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Robin Holt <holt@sgi.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-28wireless: remove CONFIG_WIRELESS_OLD_REGULATORYJohn W. Linville
This is no longer needed with the availability of CONFIG_CFG80211_INTERNAL_REGDB. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21wireless: support internal statically compiled regulatory databaseJohn W. Linville
This patch provides infrastructure for machine translation of the regulatory rules database used by CRDA into a C data structure. It includes code for searching that database as an alternative to dynamic regulatory rules updates via CRDA. Most people should use CRDA instead of this infrastructure, but it provides a better alternative than the WIRELESS_OLD_REGULATORY infrastructure (which can now be removed). Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-19cfg80211: convert bools into flagsJohannes Berg
We've accumulated a number of options for wiphys which make more sense as flags as we keep adding more. Convert the existing ones. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-07wext: refactorJohannes Berg
Refactor wext to * split out iwpriv handling * split out iwspy handling * split out procfs support * allow cfg80211 to have wireless extensions compat code w/o CONFIG_WIRELESS_EXT After this, drivers need to - select WIRELESS_EXT - for wext support - select WEXT_PRIV - for iwpriv support - select WEXT_SPY - for iwspy support except cfg80211 -- which gets new hooks in wext-core.c and can then get wext handlers without CONFIG_WIRELESS_EXT. Wireless extensions procfs support is auto-selected based on PROC_FS and anything that requires the wext core (i.e. WIRELESS_EXT or CFG80211_WEXT). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-08wireless: update cfg80211 kconfig entryLuis R. Rodriguez
cfg80211 is now *the* wireless configuration API. Lets also give a little explanation as to what it is and refer people to the wireless wiki for more information. Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-09-02wireless: update reg debug kconfig entryLuis R. Rodriguez
Refer to the wireless wiki for more information. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-28cfg80211: make spurious warnings less likely, configurableJohannes Berg
Bob reported that he got warnings in IBSS mode about the ssid_len being zero on a joined event, but only when kmemcheck was enabled. This appears to be due to a race condition between drivers and userspace, when the driver reports joined but the user in the meantime decided to leave the IBSS again, the warning would trigger. This was made more likely by kmemcheck delaying the code that does the check and sends the event. So first, make the warning trigger closer to the driver, which means it's not locked, but since only the warning depends on it that's ok. And secondly, users will not want to have spurious warnings at all, so make those that are known to be racy in such a way configurable. Reported-by: Bob Copeland <me@bobcopeland.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: implement iwpowerJohannes Berg
Just on/off and timeout, and with a hacky cfg80211 method until we figure out what we want, though this is probably sufficient as we want to use pm_qos for wifi everywhere. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: introduce nl80211 testmode commandJohannes Berg
This introduces a new NL80211_CMD_TESTMODE for testing and calibration use with nl80211. There's no multiplexing like like iwpriv had, and the command is not available by default, it needs to be explicitly enabled in Kconfig and shouldn't be enabled in most kernels. The command requires a wiphy index or interface index to identify the device to operate on, and the new TESTDATA attribute. There also is API for sending replies to the command, and testmode multicast messages (on a testmode multicast group). I've also updated mac80211 to be able to pass through the command to the driver, since it itself doesn't implement the testmode command. Additionally, to give people an idea of how to use the command, I've added a little code to hwsim that makes use of the new command to set the powersave mode, this is currently done via debugfs and should remain there, and the testmode command only serves as an example of how to use this best -- with nested netlink attributes in the TESTDATA attribute. A hwsim testmode tool can be found at http://git.sipsolutions.net/hwsim.git/. This tool is BSD licensed so people can easily use it as a basis for their own internal fabrication and validation tools. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10wext: default to yJohannes Berg
The way I initially thought we could do wireless extensions is by making all the compat code in cfg80211 be independent of CONFIG_WIRELESS_EXT, but this is turning out to not be feasible. Therefore, fix the Kconfig help text and make the option default to yes, so people won't get a nasty surprise when mac80211 will get rid of its 'select WIRELESS_EXT' any time now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: add rfkill supportJohannes Berg
To be easier on drivers and users, have cfg80211 register an rfkill structure that drivers can access. When soft-killed, simply take down all interfaces; when hard-killed the driver needs to notify us and we will take down the interfaces after the fact. While rfkilled, interfaces cannot be set UP. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20mac80211/cfg80211: move wiphy specific debugfs entries to cfg80211Luis R. Rodriguez
This moves the cfg80211 specific stuff to new cfg80211 debugfs entries. Non-mac80211 will also get these entries now. There were only 4 which we take: rts_threshold fragmentation_threshold short_retry_limit long_retry_limit Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27cfg80211: default CONFIG_WIRELESS_OLD_REGULATORY to nLuis R. Rodriguez
And update description and feature-removal schedule according to the new plan. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27cfg80211/nl80211: remove usage of CONFIG_NL80211Reinette Chatre
The scan capability added to cfg80211/nl80211 introduced a dependency on nl80211 by cfg80211. We can thus no longer have just cfg80211 without nl80211. Specifically, cfg80211_scan_done() calls nl80211_send_scan_aborted() or nl80211_send_scan_done(). Now we remove the option for user to select nl80211. It will always be compiled if user selects cfg80211. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-16lib80211: silence excessive crypto debugging messagesJohn W. Linville
When they were part of the now defunct ieee80211 component, these messages were only visible when special debugging settings were enabled. Let's mirror that with a new lib80211 debugging Kconfig option. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-25cfg80211/mac80211: Add 802.11d supportLuis R. Rodriguez
This adds country IE parsing to mac80211 and enables its usage within the new regulatory infrastructure in cfg80211. We parse the country IEs only on management beacons for the BSSID you are associated to and disregard the IEs when the country and environment (indoor, outdoor, any) matches the already processed country IE. To avoid following misinformed or outdated APs we build and use a regulatory domain out of the intersection between what the AP provides us on the country IE and what CRDA is aware is allowed on the same country. A secondary device is allowed to follow only the same country IE as it make no sense for two devices on a system to be in two different countries. In the case the AP is using country IEs for an incorrect country the user may help compliance further by setting the regulatory domain before or after the IE is parsed and in that case another intersection will be performed. CONFIG_WIRELESS_OLD_REGULATORY is supported but requires CRDA present. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-11-21lib80211: absorb crypto bits from net/ieee80211John W. Linville
These bits are shared already between ipw2x00 and hostap, and could probably be shared both more cleanly and with other drivers. This commit simply relocates the code to lib80211 and adjusts the drivers appropriately. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31wireless: consolidate on a single escape_essid implementationJohn W. Linville
2008-10-26wireless: fix regression caused by regulatory config optionArjan van de Ven
The default for the regulatory compatibility option is wrong; if you picked the default you ended up with a non-functional wifi system (at least I did on Fedora 9 with iwl4965). I don't think even the October 2008 releases of the various distros has the new userland so clearly the default is wrong, and also we can't just go about deleting this in 2.6.29... Change the default to "y" and also adjust the config text a little to reflect this. This patch fixes regression #11859 With thanks to Johannes Berg for the diagnostics Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-06wireless: fix typo in Kconfig.Davide Pesavento
Signed-off-by: Davide Pesavento <davidepesa@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15cfg80211: Add new wireless regulatory infrastructureLuis R. Rodriguez
This adds the new wireless regulatory infrastructure. The main motiviation behind this was to centralize regulatory code as each driver was implementing their own regulatory solution, and to replace the initial centralized code we have where: * only 3 regulatory domains are supported: US, JP and EU * regulatory domains can only be changed through module parameter * all rules were built statically in the kernel We now have support for regulatory domains for many countries and regulatory domains are now queried through a userspace agent through udev allowing distributions to update regulatory rules without updating the kernel. Each driver can regulatory_hint() a regulatory domain based on either their EEPROM mapped regulatory domain value to a respective ISO/IEC 3166-1 country code or pass an internally built regulatory domain. We also add support to let the user set the regulatory domain through userspace in case of faulty EEPROMs to further help compliance. Support for world roaming will be added soon for cards capable of this. For more information see: http://wireless.kernel.org/en/developers/Regulatory/CRDA For now we leave an option to enable the old module parameter, ieee80211_regdom, and to build the 3 old regdomains statically (US, JP and EU). This option is CONFIG_WIRELESS_OLD_REGULATORY. These old static definitions and the module parameter is being scheduled for removal for 2.6.29. Note that if you use this you won't make use of a world regulatory domain as its pointless. If you leave this option enabled and if CRDA is present and you use US or JP we will try to ask CRDA to update us a regulatory domain for us. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-02net/wireless/Kconfig: clarify the description for CONFIG_WIRELESS_EXT_SYSFSFlorian Mickler
Current setup with hal and NetworkManager will fail to work without newest hal version with this config option disabled. Although this will solve itself by time, at the moment it is dishonest to say that we don't know any software that uses it, if there are many many people relying on old hal versions. Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14wext: make sysfs bits optional and deprecate themJohannes Berg
The /sys/class/net/*/wireless/ direcory is, as far as I know, not used by anyone. Additionally, the same data is available via wext ioctls. Hence the sysfs files are pretty much useless. This patch makes them optional and schedules them for removal. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-01-28net/wireless/Kconfig: whitespace correctionsJohn W. Linville
Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[WIRELESS]: Fix Kconfig.Andrew Morton
Seems that a bare "depends" is no longer allowed in Sam's kbuild tree. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NL80211]: add netlink interface to cfg80211Johannes Berg
Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[WIRELESS]: Remove wext over netlink.Johannes Berg
As scheduled, this patch removes the pointless wext over netlink code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[WIRELESS] cfg80211: New wireless config infrastructure.Johannes Berg
This patch creates the core cfg80211 code along with some sysfs bits. This is a stripped down version to allow mac80211 to function, but doesn't include any configuration yet except for creating and removing virtual interfaces. This patch includes the nl80211 header file but it only contains the interface types which the cfg80211 interface for creating virtual interfaces relies on. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[WIRELESS]: Refactor wireless Kconfig.Johannes Berg
This patch refactors the wireless Kconfig all over and already introduces net/wireless/Kconfig with just the WEXT bit for now, the cfg80211 patch will add to that as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
