path: root/net/wanrouter
2006-04-11[WAN]: Remove broken and unmaintained Sangoma drivers.Adrian Bunk
The in-kernel Sangoma drivers are both not compiling and marked as BROKEN since at least kernel 2.6.0. Sangoma offers out-of-tree drivers, and David Mandelstam told me Sangoma does no longer maintain the in-kernel drivers and prefers to provide them as a separate installation package. This patch therefore removes these drivers. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NET]: Add a dev_ioctl() fallback to sock_ioctl()Christoph Hellwig
Currently all network protocols need to call dev_ioctl as the default fallback in their ioctl implementations. This patch adds a fallback to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD. This way all the procotol ioctl handlers can be simplified and we don't need to export dev_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: kfree cleanupJesper Juhl
From: Jesper Juhl <jesper.juhl@gmail.com> This is the net/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in net/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Acked-by: Marcel Holtmann <marcel@holtmann.org> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Andrew Morton <akpm@osdl.org>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-12[NET]: __be'ify *_type_trans()Alexey Dobriyan
tr_type_trans(), hippi_type_trans() left as-is. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-11[NET]: move config options out to individual protocolsSam Ravnborg
Move the protocol specific config options out to the specific protocols. With this change net/Kconfig now starts to become readable and serve as a good basis for further re-structuring. The menu structure is left almost intact, except that indention is fixed in most cases. Most visible are the INET changes where several "depends on INET" are replaced with a single ifdef INET / endif pair. Several new files were created to accomplish this change - they are small but serve the purpose that config options are now distributed out where they belongs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-01[PATCH] misc verify_area cleanupsJesper Juhl
There were still a few comments left refering to verify_area, and two functions, verify_area_skas & verify_area_tt that just wrap corresponding access_ok_skas & access_ok_tt functions, just like verify_area does for access_ok - deprecate those. There was also a few places that still used verify_area in commented-out code, fix those up to use access_ok. After applying this one there should not be anything left but finally removing verify_area completely, which will happen after a kernel release or two. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
