This patch increases the headroom TIPC reserves in each sk_buff
to accommodate the largest possible link level device header.
Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
I found some places, that erroneously return the value obtained from
the copy_to_user() call: if some amount of bytes were not able to get
to the user (this is what this one returns) the proper behavior is to
return the -EFAULT error, not that number itself.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This patch is a largely cosmetic cleanup of the TIPC reference
table code.
- The object reference field in each table entry is now single
32-bit integer instead of a union of two 32-bit integers.
- Variable naming has been made more consistent.
- Error message output has been made more consistent.
- Useless #includes have been eliminated.
This patch modifies TIPC's reference table code to delay initializing
table entries until they are actually needed by applications.
This patch converts the TIPC reference table locking routines
into non-inlined routines, since they are mainly called from
non-performance critical areas of TIPC and the added code
footprint incurred through inlining can no longer be justified.
This patch ensures that TIPC properly handles incoming messages
that have incorrect or unexpected formats. Most significantly,
it now ensures that each sl_buff has at least as much data as
the message header indicates it should, and that the entire
message header is stored contiguously; this prevents TIPC from
accidentally accessing memory that is not part of the sk_buff.
This patch allows TIPC to process incoming messages that are
stored in a fragmented sk_buff, by forcing the linearization
of any such messages it receives.
Note: This is an interim solution to allow TIPC to operate with
Ethernet devices that generate non-linear buffers (such as the
gianfar driver), until such time as the rest of TIPC is enhanced
to handle sk_buffs with multiple data areas.
This patch causes TIPC to allocate fast clonable sk_buffs,
rather than standard ones. This speeds up the cloning
operation done by the link code each time a message is sent
off-node.
This patch eliminates a null pointer check when discarding a
TIPC message buffer, since kfree_skb() already handles this
situation.
Acknowledgements to Florian Westphal (fw@strlen.de> for
suggesting this enhancement.
This patch modifies TIPC's socket code to follow the same approach
used by other protocols. This change eliminates the need for a
mutex in the TIPC-specific portion of the socket protocol data
structure -- in its place, the standard Linux socket backlog queue
and associated locking routines are utilized. These changes fix
a long-standing receive queue bug on SMP systems, and also enable
individual read and write threads to utilize a socket without
unnecessarily interfering with each other.
This patch fixes TIPC's connect routine to conform to Linux
kernel style norms of indentation, line length, etc.
This patch causes TIPC to return an error indication if the non-
blocking form of connect() is requested (which TIPC does not yet
support).
This patch fixes a bug that allowed TIPC to queue 1 more message
than allowed by the socket receive queue threshold limits. The
patch also improves the threshold code's logic and naming to help
prevent this sort of error from recurring in the future.
This patch ensures that padding bytes appearing at the end of
an incoming TIPC message are not returned as valid stream data.
This patch allows a stream socket to receive data from multiple
TIPC messages in its receive queue, without requiring the use of
the MSG_WAITALL flag.
Acknowledgements to Florian Westphal <fw-tipc@strlen.de> for
identifying this issue and suggesting how to correct it.
This patch optimizes the receive path for SOCK_DGRAM and SOCK_RDM
messages by skipping over code that handles connection-based flow
control.
This patch modifies TIPC's socket code to use standard kernel
routines to handle time conversions between jiffies and ms.
This ensures proper operation even when HZ isn't 1000.
Acknowledgements to Eric Sesterhenn <snakebyte@gmx.de> for
identifying this issue and proposing a solution.
This patch eliminates re-initialization of the standard socket
wait queue used for sleeping in TIPC's socket creation code.
This patch eliminates an unnecessary poll-related routine
by merging it into TIPC's main polling routine, and updates
the comments associated with this code.
Introduce per-sock inlines: sock_net(), sock_net_set()
and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Introduce per-net_device inlines: dev_net(), dev_net_set().
This patch updates TIPC's version number to 1.6.3.
This patch makes two enhancements to the routine used to
set bit fields within a TIPC message header:
1) It now ignores any bits of the new field value that are not
covered by the mask being used. (Previously, if the new value
exceeded the size of the mask the extra bits could corrupt
other fields in the message header word being updated.)
2) The code has been optimized to minimize the number of run-time
endianness conversion operations by leveraging the fact that the
mask (and, in some cases, the value as well) is constant and the
necessary conversion can be performed by the compiler.
This patch ensures that the 3-bit version field of the TIPC
message header is masked correctly when written into a message.
This patch eliminates some unused or duplicate message header
symbols, and fixes up the comments and/or location of a few
other symbols.
This patch eliminates warnings about undeclared symbols.
This patch validates that the "how" argument to shutdown()
is SHUT_RDWR, since this is the only form that TIPC supports.
This patch removes code associated with optional, user-specified
fields of the TIPC message header. Such fields were never
utilized by TIPC, and have now been removed from the protocol
specification.
The semaphore tsock->sem is used as mutex, convert it to the mutex API
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
net/tipc/cluster.c:145:2: warning: Using plain integer as NULL pointer
net/tipc/link.c:3254:36: warning: Using plain integer as NULL pointer
net/tipc/ref.c:151:15: warning: Using plain integer as NULL pointer
net/tipc/zone.c:85:2: warning: Using plain integer as NULL pointer
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
All these static inlines are unused:
in_own_zone 1 (net/tipc/addr.h)
msg_dataoctet 1 (net/tipc/msg.h)
msg_direct 1 (include/net/tipc/tipc_msg.h)
msg_options 1 (include/net/tipc/tipc_msg.h)
tipc_nmap_get 1 (net/tipc/bcast.h)
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
The file net/tipc/port.c takes a lock using the function tipc_port_lock and
then releases the lock sometimes using tipc_port_unlock and sometimes using
spin_unlock_bh(p_ptr->publ.lock). tipc_port_unlock simply does the
spin_unlock_bh, but it seems cleaner to use it everywhere.
The problem was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
struct port *p_ptr;
p_ptr = tipc_port_lock(...)
p_ptr = tipc_port_lock(...);
?- spin_unlock_bh(p_ptr->publ.lock);
+ tipc_port_unlock(p_ptr);
// </smpl>
Acked-by: Jon Paul Maloy <maloy@donjonn.com>
Many-many code in the kernel initialized the timer->function
and timer->data together with calling init_timer(timer). There
is already a helper for this. Use it for networking code.
The patch is HUGE, but makes the code 130 lines shorter
(98 insertions(+), 228 deletions(-)).
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
As noted by Kevin, tipc's release() does down_interruptible() and
ignores the return value. So if signal_pending() we'll end up doing
up() on a non-downed semaphore. Fix.
Finally, the zero_it argument can be completely removed from
the callers and from the function prototype.
Besides, fix the checkpatch.pl warnings about using the
assignments inside if-s.
This patch is rather big, and it is a part of the previous one.
I splitted it wishing to make the patches more readable. Hope
this particular split helped.
Add inline for common usage of hardware header creation, and
fix bug in IPV6 mcast where the assumption about negative return is
an errno. Negative return from hard_header means not enough space
was available,(ie -N bytes).
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This is nicer than the MAC_FMT stuff.
This patch makes most of the generic device layer network
namespace safe. This patch makes dev_base_head a
network namespace variable, and then it picks up
a few associated variables. The functions:
dev_getbyhwaddr
dev_getfirsthwbytype
dev_get_by_flags
dev_get_by_name
__dev_get_by_name
dev_get_by_index
__dev_get_by_index
dev_ioctl
dev_ethtool
dev_load
wireless_process_ioctl
were modified to take a network namespace argument, and
deal with it.
vlan_ioctl_set and brioctl_set were modified so their
hooks will receive a network namespace argument.
So basically anthing in the core of the network stack that was
affected to by the change of dev_base was modified to handle
multiple network namespaces. The rest of the network stack was
simply modified to explicitly use &init_net the initial network
namespace. This can be fixed when those components of the network
stack are modified to handle multiple network namespaces.
For now the ifindex generator is left global.
Fundametally ifindex numbers are per namespace, or else
we will have corner case problems with migration when
we get that far.
At the same time there are assumptions in the network stack
that the ifindex of a network device won't change. Making
the ifindex number global seems a good compromise until
the network stack can cope with ifindex changes when
you change namespaces, and the like.
Every user of the network device notifiers is either a protocol
stack or a pseudo device. If a protocol stack that does not have
support for multiple network namespaces receives an event for a
device that is not in the initial network namespace it quite possibly
can get confused and do the wrong thing.
To avoid problems until all of the protocol stacks are converted
this patch modifies all netdev event handlers to ignore events on
devices that are not in the initial network namespace.
As the rest of the code is made network namespace aware these
checks can be removed.
This patch modifies every packet receive function
registered with dev_add_pack() to drop packets if they
are not from the initial network namespace.
This should ensure that the various network stacks do
not receive packets in a anything but the initial network
namespace until the code has been converted and is ready
for them.
This patch passes in the namespace a new socket should be created in
and has the socket code do the appropriate reference counting. By
virtue of this all socket create methods are touched. In addition
the socket create methods are modified so that they will fail if
you attempt to create a socket in a non-default network namespace.
Failing if we attempt to create a socket outside of the default
network namespace ensures that as we incrementally make the network stack
network namespace aware we will not export functionality that someone
has not audited and made certain is network namespace safe.
Allowing us to partially enable network namespaces before all of the
exotic protocols are supported.
Any protocol layers I have missed will fail to compile because I now
pass an extra parameter into the socket creation code.
[ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ]
This patch cleans up duplicate includes in
net/tipc/
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
fix two warnings generated by sparse:
link.c:2386 symbol 'msgcount' shadows an earlier one
node.c:244 symbol 'addr_string' shadows an earlier one
make needlessly global function tipc_nameseq_subscribe static.
if printbuf allocation or tipc_node_attach_link() fails, invalid
references to the link are left in the associated node and bearer
structures.
Fix by allocating printbuf early and moving timer initialization
and the addition of the new link to the b_ptr->links list after
tipc_node_attach_link() succeeded.
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits)
[TG3]: Fix msi issue with kexec/kdump.
[NET] XFRM: Fix whitespace errors.
[NET] TIPC: Fix whitespace errors.
[NET] SUNRPC: Fix whitespace errors.
[NET] SCTP: Fix whitespace errors.
[NET] RXRPC: Fix whitespace errors.
[NET] ROSE: Fix whitespace errors.
[NET] RFKILL: Fix whitespace errors.
[NET] PACKET: Fix whitespace errors.
[NET] NETROM: Fix whitespace errors.
[NET] NETFILTER: Fix whitespace errors.
[NET] IPV4: Fix whitespace errors.
[NET] DCCP: Fix whitespace errors.
[NET] CORE: Fix whitespace errors.
[NET] BLUETOOTH: Fix whitespace errors.
[NET] AX25: Fix whitespace errors.
[PATCH] mac80211: remove rtnl locking in ieee80211_sta.c
[PATCH] mac80211: fix GCC warning on 64bit platforms
[GENETLINK]: Dynamic multicast groups.
[NETLIKN]: Allow removing multicast groups.
