[ Upstream commit fb317eb23b5ee4c37b0656a9a52a3db58d9dd072 ]
KMSAN reported the following kernel-infoleak issue:
BUG: KMSAN: kernel-infoleak in instrument_copy_to_user include/linux/instrumented.h:114 [inline]
BUG: KMSAN: kernel-infoleak in copy_to_user_iter lib/iov_iter.c:24 [inline]
BUG: KMSAN: kernel-infoleak in iterate_ubuf include/linux/iov_iter.h:29 [inline]
BUG: KMSAN: kernel-infoleak in iterate_and_advance2 include/linux/iov_iter.h:245 [inline]
BUG: KMSAN: kernel-infoleak in iterate_and_advance include/linux/iov_iter.h:271 [inline]
BUG: KMSAN: kernel-infoleak in _copy_to_iter+0x4ec/0x2bc0 lib/iov_iter.c:186
copy_to_iter include/linux/uio.h:197 [inline]
simple_copy_to_iter net/core/datagram.c:532 [inline]
__skb_datagram_iter.5+0x148/0xe30 net/core/datagram.c:420
skb_copy_datagram_iter+0x52/0x210 net/core/datagram.c:546
skb_copy_datagram_msg include/linux/skbuff.h:3960 [inline]
netlink_recvmsg+0x43d/0x1630 net/netlink/af_netlink.c:1967
sock_recvmsg_nosec net/socket.c:1044 [inline]
sock_recvmsg net/socket.c:1066 [inline]
__sys_recvfrom+0x476/0x860 net/socket.c:2246
__do_sys_recvfrom net/socket.c:2264 [inline]
__se_sys_recvfrom net/socket.c:2260 [inline]
__x64_sys_recvfrom+0x130/0x200 net/socket.c:2260
do_syscall_x64 arch/x86/entry/common.c:51 [inline]
do_syscall_64+0x44/0x110 arch/x86/entry/common.c:82
entry_SYSCALL_64_after_hwframe+0x63/0x6b
Uninit was created at:
slab_post_alloc_hook+0x103/0x9e0 mm/slab.h:768
slab_alloc_node mm/slub.c:3478 [inline]
kmem_cache_alloc_node+0x5f7/0xb50 mm/slub.c:3523
kmalloc_reserve+0x13c/0x4a0 net/core/skbuff.c:560
__alloc_skb+0x2fd/0x770 net/core/skbuff.c:651
alloc_skb include/linux/skbuff.h:1286 [inline]
tipc_tlv_alloc net/tipc/netlink_compat.c:156 [inline]
tipc_get_err_tlv+0x90/0x5d0 net/tipc/netlink_compat.c:170
tipc_nl_compat_recv+0x1042/0x15d0 net/tipc/netlink_compat.c:1324
genl_family_rcv_msg_doit net/netlink/genetlink.c:972 [inline]
genl_family_rcv_msg net/netlink/genetlink.c:1052 [inline]
genl_rcv_msg+0x1220/0x12c0 net/netlink/genetlink.c:1067
netlink_rcv_skb+0x4a4/0x6a0 net/netlink/af_netlink.c:2545
genl_rcv+0x41/0x60 net/netlink/genetlink.c:1076
netlink_unicast_kernel net/netlink/af_netlink.c:1342 [inline]
netlink_unicast+0xf4b/0x1230 net/netlink/af_netlink.c:1368
netlink_sendmsg+0x1242/0x1420 net/netlink/af_netlink.c:1910
sock_sendmsg_nosec net/socket.c:730 [inline]
__sock_sendmsg net/socket.c:745 [inline]
____sys_sendmsg+0x997/0xd60 net/socket.c:2588
___sys_sendmsg+0x271/0x3b0 net/socket.c:2642
__sys_sendmsg net/socket.c:2671 [inline]
__do_sys_sendmsg net/socket.c:2680 [inline]
__se_sys_sendmsg net/socket.c:2678 [inline]
__x64_sys_sendmsg+0x2fa/0x4a0 net/socket.c:2678
Bytes 34-35 of 36 are uninitialized
Memory access of size 36 starts at ffff88802d464a00
Data copied to user address 00007ff55033c0a0
CPU: 0 PID: 30322 Comm: syz-executor.0 Not tainted 6.6.0-14500-g1c41041124bd #10
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.16.2-1.fc38 04/01/2014
tipc_add_tlv() puts TLV descriptor and value onto `skb`. This size is
calculated with TLV_SPACE() macro. It adds the size of struct tlv_desc and
the length of TLV value passed as an argument, and aligns the result to a
multiple of TLV_ALIGNTO, i.e., a multiple of 4 bytes.
If the size of struct tlv_desc plus the length of TLV value is not aligned,
the current implementation leaves the remaining bytes uninitialized. This
is the cause of the above kernel-infoleak issue.
This patch resolves this issue by clearing data up to an aligned size.
Fixes: d0796d1ef63d ("tipc: convert legacy nl bearer dump to nl compat")
Signed-off-by: Shigeru Yoshida <syoshida@redhat.com>
Reviewed-by: Simon Horman <horms@kernel.org>
[ Upstream commit 19b3f72a41a8751e26bffc093bb7e1cef29ad579 ]
syzbot reported the following uninit-value access issue [1]:
BUG: KMSAN: uninit-value in strlen lib/string.c:418 [inline]
BUG: KMSAN: uninit-value in strstr+0xb8/0x2f0 lib/string.c:756
tipc_nl_node_reset_link_stats+0x3ea/0xb50 net/tipc/node.c:2595
genl_family_rcv_msg_doit net/netlink/genetlink.c:971 [inline]
genl_family_rcv_msg net/netlink/genetlink.c:1051 [inline]
genl_rcv_msg+0x11ec/0x1290 net/netlink/genetlink.c:1066
netlink_rcv_skb+0x371/0x650 net/netlink/af_netlink.c:2545
genl_rcv+0x40/0x60 net/netlink/genetlink.c:1075
netlink_unicast+0xf47/0x1250 net/netlink/af_netlink.c:1368
netlink_sendmsg+0x1238/0x13d0 net/netlink/af_netlink.c:1910
sock_sendmsg net/socket.c:753 [inline]
____sys_sendmsg+0x9c2/0xd60 net/socket.c:2541
___sys_sendmsg+0x28d/0x3c0 net/socket.c:2595
__sys_sendmsg net/socket.c:2624 [inline]
__do_sys_sendmsg net/socket.c:2633 [inline]
__se_sys_sendmsg net/socket.c:2631 [inline]
__x64_sys_sendmsg+0x307/0x490 net/socket.c:2631
do_syscall_x64 arch/x86/entry/common.c:50 [inline]
do_syscall_64+0x41/0xc0 arch/x86/entry/common.c:80
entry_SYSCALL_64_after_hwframe+0x63/0xcd
slab_post_alloc_hook+0x12f/0xb70 mm/slab.h:767
kmem_cache_alloc_node+0x577/0xa80 mm/slub.c:3523
kmalloc_reserve+0x13d/0x4a0 net/core/skbuff.c:559
__alloc_skb+0x318/0x740 net/core/skbuff.c:650
netlink_alloc_large_skb net/netlink/af_netlink.c:1214 [inline]
netlink_sendmsg+0xb34/0x13d0 net/netlink/af_netlink.c:1885
TIPC bearer-related names including link names must be null-terminated
strings. If a link name which is not null-terminated is passed through
netlink, strstr() and similar functions can cause buffer overrun. This
causes the above issue.
This patch changes the nla_policy for bearer-related names from NLA_STRING
to NLA_NUL_STRING. This resolves the issue by ensuring that only
null-terminated strings are accepted as bearer-related names.
syzbot reported similar uninit-value issue related to bearer names [2]. The
root cause of this issue is that a non-null-terminated bearer name was
passed. This patch also resolved this issue.
Fixes: 7be57fc69184 ("tipc: add link get/dump to new netlink api")
Fixes: 0655f6a8635b ("tipc: add bearer disable/enable to new netlink api")
Reported-and-tested-by: syzbot+5138ca807af9d2b42574@syzkaller.appspotmail.com
Closes: https://syzkaller.appspot.com/bug?extid=5138ca807af9d2b42574 [1]
Reported-and-tested-by: syzbot+9425c47dccbcb4c17d51@syzkaller.appspotmail.com
Closes: https://syzkaller.appspot.com/bug?extid=9425c47dccbcb4c17d51 [2]
Reviewed-by: Jiri Pirko <jiri@nvidia.com>
Link: https://lore.kernel.org/r/20231030075540.3784537-1-syoshida@redhat.com
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit 2506a91734754de690869824fb0d1ac592ec1266 ]
If, for any reason, the open-coded arithmetic causes a wraparound,
the protection that `struct_size()` adds against potential integer
overflows is defeated. Fix this by hardening call to `struct_size()`
with `size_add()`.
Fixes: e034c6d23bc4 ("tipc: Use struct_size() helper")
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
[ Upstream commit 08e50cf071847323414df0835109b6f3560d44f5 ]
It seems that tipc_crypto_key_revoke() could be be invoked by
wokequeue tipc_crypto_work_rx() under process context and
timer/rx callback under softirq context, thus the lock acquisition
on &tx->lock seems better use spin_lock_bh() to prevent possible
deadlock.
This flaw was found by an experimental static analysis tool I am
developing for irq-related deadlock.
tipc_crypto_work_rx() <workqueue>
--> tipc_crypto_key_distr()
--> tipc_bcast_xmit()
--> tipc_bcbase_xmit()
--> tipc_bearer_bc_xmit()
--> tipc_crypto_xmit()
--> tipc_ehdr_build()
--> tipc_crypto_key_revoke()
--> spin_lock(&tx->lock)
<timer interrupt>
--> tipc_disc_timeout()
--> tipc_bearer_xmit_skb()
--> spin_lock(&tx->lock) <deadlock here>
Signed-off-by: Chengfeng Ye <dg573847474@gmail.com>
Reviewed-by: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Jon Maloy <jmaloy@redhat.com>
Fixes: fc1b6d6de220 ("tipc: introduce TIPC encryption & authentication")
Link: https://lore.kernel.org/r/20230927181414.59928-1-dg573847474@gmail.com
[ Upstream commit de52e17326c3e9a719c9ead4adb03467b8fae0ef ]
If tipc_link_bc_create() fails inside tipc_node_create() for a newly
allocated tipc node then we should stop its tipc crypto and free the
resources allocated with a call to tipc_crypto_start().
As the node ref is initialized to one to that point, just put the ref on
tipc_link_bc_create() error case that would lead to tipc_node_free() be
eventually executed and properly clean the node and its crypto resources.
Found by Linux Verification Center (linuxtesting.org).
Fixes: cb8092d70a6f ("tipc: move bc link creation back to tipc_node_create")
Suggested-by: Xin Long <lucien.xin@gmail.com>
Signed-off-by: Fedor Pchelkin <pchelkin@ispras.ru>
Reviewed-by: Xin Long <lucien.xin@gmail.com>
Link: https://lore.kernel.org/r/20230725214628.25246-1-pchelkin@ispras.ru
Signed-off-by: Paolo Abeni <pabeni@redhat.com>
[ Upstream commit e46e06ffc6d667a89b979701288e2264f45e6a7b ]
goto free_skb if an unexpected result is returned by pskb_tirm()
in tipc_crypto_rcv_complete().
Signed-off-by: Yuanjun Gong <ruc_gongyuanjun@163.com>
Reviewed-by: Tung Nguyen <tung.q.nguyen@dektech.com.au>
Link: https://lore.kernel.org/r/20230725064810.5820-1-ruc_gongyuanjun@163.com
[ Upstream commit 44194cb1b6045dea33ae9a0d54fb7e7cd93a2e09 ]
According to nla_parse_nested_deprecated(), the tb[] is supposed to the
destination array with maxtype+1 elements. In current
tipc_nl_media_get() and __tipc_nl_media_set(), a larger array is used
which is unnecessary. This patch resize them to a proper size.
Fixes: 1e55417d8fc6 ("tipc: add media set to new netlink api")
Fixes: 46f15c6794fb ("tipc: add media get/dump to new netlink api")
Signed-off-by: Lin Ma <linma@zju.edu.cn>
Reviewed-by: Florian Westphal <fw@strlen.de>
Link: https://lore.kernel.org/r/20230614120604.1196377-1-linma@zju.edu.cn
[ Upstream commit 35a089b5d793d2bfd2cc7cfa6104545184de2ce7 ]
Checking the bearer min mtu with tipc_udp_mtu_bad() only works for
IPv4 UDP bearer, and IPv6 UDP bearer has a different value for the
min mtu. This patch checks with encap_hlen + TIPC_MIN_BEARER_MTU
for min mtu, which works for both IPv4 and IPv6 UDP bearer.
Note that tipc_udp_mtu_bad() is still used to check media min mtu
in __tipc_nl_media_set(), as m->mtu currently is only used by the
IPv4 UDP bearer as its default mtu value.
Fixes: 682cd3cf946b ("tipc: confgiure and apply UDP bearer MTU on running links")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
[ Upstream commit 56077b56cd3fb78e1c8619e29581ba25a5c55e86 ]
When doing link mtu negotiation, a malicious peer may send Activate msg
with a very small mtu, e.g. 4 in Shuang's testing, without checking for
the minimum mtu, l->mtu will be set to 4 in tipc_link_proto_rcv(), then
n->links[bearer_id].mtu is set to 4294967228, which is a overflow of
'4 - INT_H_SIZE - EMSG_OVERHEAD' in tipc_link_mss().
With tipc_link.mtu = 4, tipc_link_xmit() kept printing the warning:
tipc: Too large msg, purging xmit list 1 5 0 40 4!
tipc: Too large msg, purging xmit list 1 15 0 60 4!
And with tipc_link_entry.mtu 4294967228, a huge skb was allocated in
named_distribute(), and when purging it in tipc_link_xmit(), a crash
was even caused:
general protection fault, probably for non-canonical address 0x2100001011000dd: 0000 [#1] PREEMPT SMP PTI
CPU: 0 PID: 0 Comm: swapper/0 Kdump: loaded Not tainted 6.3.0.neta #19
RIP: 0010:kfree_skb_list_reason+0x7e/0x1f0
Call Trace:
<IRQ>
skb_release_data+0xf9/0x1d0
kfree_skb_reason+0x40/0x100
tipc_link_xmit+0x57a/0x740 [tipc]
tipc_node_xmit+0x16c/0x5c0 [tipc]
tipc_named_node_up+0x27f/0x2c0 [tipc]
tipc_node_write_unlock+0x149/0x170 [tipc]
tipc_rcv+0x608/0x740 [tipc]
tipc_udp_recv+0xdc/0x1f0 [tipc]
udp_queue_rcv_one_skb+0x33e/0x620
udp_unicast_rcv_skb.isra.72+0x75/0x90
__udp4_lib_rcv+0x56d/0xc20
ip_protocol_deliver_rcu+0x100/0x2d0
This patch fixes it by checking the new mtu against tipc_bearer_min_mtu(),
and not updating mtu if it is too small.
Fixes: ed193ece2649 ("tipc: simplify link mtu negotiation")
Reported-by: Shuang Li <shuali@redhat.com>
[ Upstream commit 3ae6d66b605be604644d4bb5708a7ffd9cf1abe8 ]
As different media may requires different min mtu, and even the
same media with different net family requires different min mtu,
add tipc_bearer_min_mtu() to calculate min mtu accordingly.
This API will be used to check the new mtu when doing the link
mtu negotiation in the next patch.
Stable-dep-of: 56077b56cd3f ("tipc: do not update mtu if msg_max is too small in mtu negotiation")
[ Upstream commit d0ac89f6f9879fae316c155de77b5173b3e2c9c9 ]
__condition is evaluated twice in sk_wait_event() macro.
First invocation is lockless, and reads can race with writes,
as spotted by syzbot.
BUG: KCSAN: data-race in sk_stream_wait_connect / tcp_disconnect
write to 0xffff88812d83d6a0 of 4 bytes by task 9065 on cpu 1:
tcp_disconnect+0x2cd/0xdb0
inet_shutdown+0x19e/0x1f0 net/ipv4/af_inet.c:911
__sys_shutdown_sock net/socket.c:2343 [inline]
__sys_shutdown net/socket.c:2355 [inline]
__do_sys_shutdown net/socket.c:2363 [inline]
__se_sys_shutdown+0xf8/0x140 net/socket.c:2361
__x64_sys_shutdown+0x31/0x40 net/socket.c:2361
read to 0xffff88812d83d6a0 of 4 bytes by task 9040 on cpu 0:
sk_stream_wait_connect+0x1de/0x3a0 net/core/stream.c:75
tcp_sendmsg_locked+0x2e4/0x2120 net/ipv4/tcp.c:1266
tcp_sendmsg+0x30/0x50 net/ipv4/tcp.c:1484
inet6_sendmsg+0x63/0x80 net/ipv6/af_inet6.c:651
sock_sendmsg_nosec net/socket.c:724 [inline]
sock_sendmsg net/socket.c:747 [inline]
__sys_sendto+0x246/0x300 net/socket.c:2142
__do_sys_sendto net/socket.c:2154 [inline]
__se_sys_sendto net/socket.c:2150 [inline]
__x64_sys_sendto+0x78/0x90 net/socket.c:2150
value changed: 0x00000000 -> 0x00000068
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit c244c092f1ed2acfb5af3d3da81e22367d3dd733 ]
This unexpected behavior is observed:
node 1 | node 2
link is established | link is established
reboot | link is reset
up | send discovery message
receive discovery message |
send discovery message |
| link is reset (unexpected)
| send reset message
link is reset |
It is due to delayed re-discovery as described in function
tipc_node_check_dest(): "this link endpoint has already reset
and re-established contact with the peer, before receiving a
discovery message from that node."
However, commit 598411d70f85 has changed the condition for calling
tipc_node_link_down() which was the acceptance of new media address.
This commit fixes this by restoring the old and correct behavior.
Fixes: 598411d70f85 ("tipc: make resetting of links non-atomic")
Signed-off-by: Tung Nguyen <tung.q.nguyen@dektech.com.au>
[ Upstream commit 88956177db179e4eba7cd590971961857d1565b8 ]
When sending packets between nodes in netns, it calls tipc_lxc_xmit() for
peer node to receive the packets where tipc_sk_mcast_rcv()/tipc_sk_rcv()
might be called, and it's pretty much like in tipc_rcv().
Currently the local 'node rw lock' is held during calling tipc_lxc_xmit()
to protect the peer_net not being freed by another thread. However, when
receiving these packets, tipc_node_add_conn() might be called where the
peer 'node rw lock' is acquired. Then a dead lock warning is triggered by
lockdep detector, although it is not a real dead lock:
WARNING: possible recursive locking detected
conn_server/1086 is trying to acquire lock:
ffff8880065cb020 (&n->lock#2){++--}-{2:2}, \
at: tipc_node_add_conn.cold.76+0xaa/0x211 [tipc]
but task is already holding lock:
ffff8880065cd020 (&n->lock#2){++--}-{2:2}, \
at: tipc_node_xmit+0x285/0xb30 [tipc]
Possible unsafe locking scenario:
CPU0
lock(&n->lock#2);
lock(&n->lock#2);
*** DEADLOCK ***
May be due to missing lock nesting notation
4 locks held by conn_server/1086:
#0: ffff8880036d1e40 (sk_lock-AF_TIPC){+.+.}-{0:0}, \
at: tipc_accept+0x9c0/0x10b0 [tipc]
#1: ffff8880036d5f80 (sk_lock-AF_TIPC/1){+.+.}-{0:0}, \
at: tipc_accept+0x363/0x10b0 [tipc]
#2: ffff8880065cd020 (&n->lock#2){++--}-{2:2}, \
#3: ffff888012e13370 (slock-AF_TIPC){+...}-{2:2}, \
at: tipc_sk_rcv+0x2da/0x1b40 [tipc]
Call Trace:
<TASK>
dump_stack_lvl+0x44/0x5b
__lock_acquire.cold.77+0x1f2/0x3d7
lock_acquire+0x1d2/0x610
_raw_write_lock_bh+0x38/0x80
tipc_sk_finish_conn+0x21e/0x640 [tipc]
tipc_sk_filter_rcv+0x147b/0x3030 [tipc]
tipc_sk_rcv+0xbb4/0x1b40 [tipc]
tipc_lxc_xmit+0x225/0x26b [tipc]
tipc_node_xmit.cold.82+0x4a/0x102 [tipc]
__tipc_sendstream+0x879/0xff0 [tipc]
tipc_accept+0x966/0x10b0 [tipc]
do_accept+0x37d/0x590
This patch avoids this warning by not holding the 'node rw lock' before
calling tipc_lxc_xmit(). As to protect the 'peer_net', rcu_read_lock()
should be enough, as in cleanup_net() when freeing the netns, it calls
synchronize_rcu() before the free is continued.
Also since tipc_lxc_xmit() is like the RX path in tipc_rcv(), it makes
sense to call it under rcu_read_lock(). Note that the right lock order
must be:
rcu_read_lock();
tipc_node_read_lock(n);
tipc_node_read_unlock(n);
tipc_lxc_xmit();
rcu_read_unlock();
instead of:
rcu_read_lock();
tipc_lxc_xmit();
rcu_read_unlock();
and we have to call tipc_node_read_lock/unlock() twice in
tipc_node_xmit().
Fixes: f73b12812a3d ("tipc: improve throughput between nodes in netns")
Link: https://lore.kernel.org/r/5bdd1f8fee9db695cfff4528a48c9b9d0523fb00.1670110641.git.lucien.xin@gmail.com
[ Upstream commit 743117a997bbd4840e827295c07e59bcd7f7caa3 ]
Fix the potential risk of OOB if skb_linearize() fails in
tipc_link_proto_rcv().
Fixes: 5cbb28a4bf65 ("tipc: linearize arriving NAME_DISTR and LINK_PROTO buffers")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Link: https://lore.kernel.org/r/20221203094635.29024-1-yuehaibing@huawei.com
[ Upstream commit 3067bc61fcfe3081bf4807ce65560f499e895e77 ]
As the call trace shows, the original skb was freed in tipc_msg_validate(),
and dereferencing the old skb cb would cause an use-after-free crash.
BUG: KASAN: use-after-free in tipc_crypto_rcv_complete+0x1835/0x2240 [tipc]
Call Trace:
<IRQ>
tipc_crypto_rcv+0xd32/0x1ec0 [tipc]
tipc_rcv+0x744/0x1150 [tipc]
Allocated by task 47078:
kmem_cache_alloc_node+0x158/0x4d0
__alloc_skb+0x1c1/0x270
tipc_buf_acquire+0x1e/0xe0 [tipc]
tipc_msg_create+0x33/0x1c0 [tipc]
tipc_link_build_proto_msg+0x38a/0x2100 [tipc]
tipc_link_timeout+0x8b8/0xef0 [tipc]
tipc_node_timeout+0x2a1/0x960 [tipc]
call_timer_fn+0x2d/0x1c0
Freed by task 47078:
tipc_msg_validate+0x7b/0x440 [tipc]
tipc_crypto_rcv_complete+0x4b5/0x2240 [tipc]
This patch fixes it by re-fetching the skb cb from the new allocated skb
after calling tipc_msg_validate().
Link: https://lore.kernel.org/r/1b1cdba762915325bd8ef9a98d0276eb673df2a5.1669398403.git.lucien.xin@gmail.com
[ Upstream commit cd0f6421162201e4b22ce757a1966729323185eb ]
If skb_linearize() fails in tipc_disc_rcv(), we need to free the skb instead of
handle it.
Fixes: 25b0b9c4e835 ("tipc: handle collisions of 32-bit node address hash values")
Link: https://lore.kernel.org/r/20221119072832.7896-1-yuehaibing@huawei.com
[ Upstream commit a7b42969d63f47320853a802efd879fbdc4e010e ]
One extra conn_get() is needed in tipc_conn_alloc(), as after
tipc_conn_alloc() is called, tipc_conn_close() may free this
con before deferencing it in tipc_topsrv_accept():
tipc_conn_alloc();
newsk = newsock->sk;
<---- tipc_conn_close();
write_lock_bh(&sk->sk_callback_lock);
newsk->sk_data_ready = tipc_conn_data_ready;
Then an uaf issue can be triggered:
BUG: KASAN: use-after-free in tipc_topsrv_accept+0x1e7/0x370 [tipc]
Call Trace:
<TASK>
dump_stack_lvl+0x33/0x46
print_report+0x178/0x4b0
kasan_report+0x8c/0x100
kasan_check_range+0x179/0x1e0
process_one_work+0x6a3/0x1030
worker_thread+0x8a/0xdf0
This patch fixes it by holding it in tipc_conn_alloc(), then after
all accessing in tipc_topsrv_accept() releasing it. Note when does
this in tipc_topsrv_kern_subscr(), as tipc_conn_rcv_sub() returns
0 or -1 only, we don't need to check for "> 0".
Fixes: c5fa7b3cf3cb ("tipc: introduce new TIPC server infrastructure")
[ Upstream commit 0e5d56c64afcd6fd2d132ea972605b66f8a7d3c4 ]
A crash was reported by Wei Chen:
BUG: kernel NULL pointer dereference, address: 0000000000000018
RIP: 0010:tipc_conn_close+0x12/0x100
Call Trace:
tipc_topsrv_exit_net+0x139/0x320
ops_exit_list.isra.9+0x49/0x80
cleanup_net+0x31a/0x540
process_one_work+0x3fa/0x9f0
worker_thread+0x42/0x5c0
It was caused by !con->sock in tipc_conn_close(). In tipc_topsrv_accept(),
con is allocated in conn_idr then its sock is set:
con = tipc_conn_alloc();
... <----[1]
con->sock = newsock;
If tipc_conn_close() is called in anytime of [1], the null-pointer-def
is triggered by con->sock->sk due to con->sock is not yet set.
This patch fixes it by moving the con->sock setting to tipc_conn_alloc()
under s->idr_lock. So that con->sock can never be NULL when getting the
con from s->conn_idr. It will be also safer to move con->server and flag
CF_CONNECTED setting under s->idr_lock, as they should all be set before
tipc_conn_alloc() is called.
Reported-by: Wei Chen <harperchen1110@gmail.com>
[ Upstream commit 1c075b192fe41030457cd4a5f7dea730412bca40 ]
This is a follow-up for commit 974cb0e3e7c9 ("tipc: fix uninit-value
in tipc_nl_compat_name_table_dump") where it should have type casted
sizeof(..) to int to work when TLV_GET_DATA_LEN() returns a negative
value.
syzbot reported a call trace because of it:
BUG: KMSAN: uninit-value in ...
tipc_nl_compat_name_table_dump+0x841/0xea0 net/tipc/netlink_compat.c:934
__tipc_nl_compat_dumpit+0xab2/0x1320 net/tipc/netlink_compat.c:238
tipc_nl_compat_dumpit+0x991/0xb50 net/tipc/netlink_compat.c:321
tipc_nl_compat_recv+0xb6e/0x1640 net/tipc/netlink_compat.c:1324
genl_family_rcv_msg_doit net/netlink/genetlink.c:731 [inline]
genl_family_rcv_msg net/netlink/genetlink.c:775 [inline]
genl_rcv_msg+0x103f/0x1260 net/netlink/genetlink.c:792
netlink_rcv_skb+0x3a5/0x6c0 net/netlink/af_netlink.c:2501
genl_rcv+0x3c/0x50 net/netlink/genetlink.c:803
netlink_unicast_kernel net/netlink/af_netlink.c:1319 [inline]
netlink_unicast+0xf3b/0x1270 net/netlink/af_netlink.c:1345
netlink_sendmsg+0x1288/0x1440 net/netlink/af_netlink.c:1921
sock_sendmsg_nosec net/socket.c:714 [inline]
sock_sendmsg net/socket.c:734 [inline]
Reported-by: syzbot+e5dbaaa238680ce206ea@syzkaller.appspotmail.com
Fixes: 974cb0e3e7c9 ("tipc: fix uninit-value in tipc_nl_compat_name_table_dump")
Link: https://lore.kernel.org/r/ccd6a7ea801b15aec092c3b532a883b4c5708695.1667594933.git.lucien.xin@gmail.com
[ Upstream commit 82cb4e4612c633a9ce320e1773114875604a3cce ]
syzbot found a crash in tipc_topsrv_accept:
KASAN: null-ptr-deref in range [0x0000000000000008-0x000000000000000f]
Workqueue: tipc_rcv tipc_topsrv_accept
RIP: 0010:kernel_accept+0x22d/0x350 net/socket.c:3487
Call Trace:
<TASK>
tipc_topsrv_accept+0x197/0x280 net/tipc/topsrv.c:460
process_one_work+0x991/0x1610 kernel/workqueue.c:2289
worker_thread+0x665/0x1080 kernel/workqueue.c:2436
kthread+0x2e4/0x3a0 kernel/kthread.c:376
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:306
It was caused by srv->listener that might be set to null by
tipc_topsrv_stop() in net .exit whereas it's still used in
tipc_topsrv_accept() worker.
srv->listener is protected by srv->idr_lock in tipc_topsrv_stop(), so add
a check for srv->listener under srv->idr_lock in tipc_topsrv_accept() to
avoid the null-ptr-deref. To ensure the lsock is not released during the
tipc_topsrv_accept(), move sock_release() after tipc_topsrv_work_stop()
where it's waiting until the tipc_topsrv_accept worker to be done.
Note that sk_callback_lock is used to protect sk->sk_user_data instead of
srv->listener, and it should check srv in tipc_topsrv_listener_data_ready()
instead. This also ensures that no more tipc_topsrv_accept worker will be
started after tipc_conn_close() is called in tipc_topsrv_stop() where it
sets sk->sk_user_data to null.
Fixes: 0ef897be12b8 ("tipc: separate topology server listener socket from subcsriber sockets")
Reported-by: syzbot+c5ce866a8d30f4be0651@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/4eee264380c409c61c6451af1059b7fb271a7e7b.1666120790.git.lucien.xin@gmail.com
[ Upstream commit 777ecaabd614d47c482a5c9031579e66da13989a ]
Use a 8-byte write to initialize sub.usr_handle in
tipc_topsrv_kern_subscr(), otherwise four bytes remain uninitialized
when issuing setsockopt(..., SOL_TIPC, ...).
This resulted in an infoleak reported by KMSAN when the packet was
received:
BUG: KMSAN: kernel-infoleak in copyout+0xbc/0x100 lib/iov_iter.c:169
instrument_copy_to_user ./include/linux/instrumented.h:121
_copy_to_iter+0x5c0/0x20a0 lib/iov_iter.c:527
copy_to_iter ./include/linux/uio.h:176
simple_copy_to_iter+0x64/0xa0 net/core/datagram.c:513
__skb_datagram_iter+0x123/0xdc0 net/core/datagram.c:419
skb_copy_datagram_iter+0x58/0x200 net/core/datagram.c:527
skb_copy_datagram_msg ./include/linux/skbuff.h:3903
packet_recvmsg+0x521/0x1e70 net/packet/af_packet.c:3469
____sys_recvmsg+0x2c4/0x810 net/socket.c:?
___sys_recvmsg+0x217/0x840 net/socket.c:2743
__sys_recvmsg net/socket.c:2773
__do_sys_recvmsg net/socket.c:2783
__se_sys_recvmsg net/socket.c:2780
__x64_sys_recvmsg+0x364/0x540 net/socket.c:2780
do_syscall_64+0x3d/0xb0 arch/x86/entry/common.c:80
entry_SYSCALL_64_after_hwframe+0x63/0xcd arch/x86/entry/entry_64.S:120
Uninit was stored to memory at:
tipc_sub_subscribe+0x42d/0xb50 net/tipc/subscr.c:156
tipc_conn_rcv_sub+0x246/0x620 net/tipc/topsrv.c:375
tipc_topsrv_kern_subscr+0x2e8/0x400 net/tipc/topsrv.c:579
tipc_group_create+0x4e7/0x7d0 net/tipc/group.c:190
tipc_sk_join+0x2a8/0x770 net/tipc/socket.c:3084
tipc_setsockopt+0xae5/0xe40 net/tipc/socket.c:3201
__sys_setsockopt+0x87f/0xdc0 net/socket.c:2252
__do_sys_setsockopt net/socket.c:2263
__se_sys_setsockopt net/socket.c:2260
__x64_sys_setsockopt+0xe0/0x160 net/socket.c:2260
Local variable sub created at:
tipc_topsrv_kern_subscr+0x57/0x400 net/tipc/topsrv.c:562
Bytes 84-87 of 88 are uninitialized
Memory access of size 88 starts at ffff88801ed57cd0
Data copied to user address 0000000020000400
Signed-off-by: Alexander Potapenko <glider@google.com>
Fixes: 026321c6d056a5 ("tipc: rename tipc_server to tipc_topsrv")
[ Upstream commit 28be7ca4fcfd69a2d52aaa331adbf9dbe91f9e6e ]
The trial period exists until jiffies is after addr_trial_end. But as
jiffies will eventually overflow, just using time_after will eventually
give incorrect results. As the node address is set once the trial period
ends, this can be used to know that we are not in the trial period.
Fixes: e415577f57f4 ("tipc: correct discovery message handling during address trial period")
Signed-off-by: Mark Tomlinson <mark.tomlinson@alliedtelesis.co.nz>
[ Upstream commit e2b224abd9bf45dcb55750479fc35970725a430b ]
There is a shift wrapping bug in this code so anything thing above
31 will return false.
Fixes: 35c55c9877f8 ("tipc: add neighbor monitoring framework")
[ Upstream commit 02739545951ad4c1215160db7fbf9b7a918d3c0b ]
While reading these sysctl variables, they can be changed concurrently.
Thus, we need to add READ_ONCE() to their readers.
- .sysctl_rmem
- .sysctl_rwmem
- .sysctl_rmem_offset
- .sysctl_wmem_offset
- sysctl_tcp_rmem[1, 2]
- sysctl_tcp_wmem[1, 2]
- sysctl_decnet_rmem[1]
- sysctl_decnet_wmem[1]
- sysctl_tipc_rmem[1]
Signed-off-by: Kuniyuki Iwashima <kuniyu@amazon.com>
[ Upstream commit 00aff3590fc0a73bddd3b743863c14e76fd35c0c ]
Free sk in case tipc_sk_insert() fails.
Signed-off-by: Hangyu Hua <hbh25y@gmail.com>
commit cb8092d70a6f5f01ec1490fce4d35efed3ed996c upstream.
Shuang Li reported a NULL pointer dereference crash:
[] BUG: kernel NULL pointer dereference, address: 0000000000000068
[] RIP: 0010:tipc_link_is_up+0x5/0x10 [tipc]
[] Call Trace:
[] <IRQ>
[] tipc_bcast_rcv+0xa2/0x190 [tipc]
[] tipc_node_bc_rcv+0x8b/0x200 [tipc]
[] tipc_rcv+0x3af/0x5b0 [tipc]
[] tipc_udp_recv+0xc7/0x1e0 [tipc]
It was caused by the 'l' passed into tipc_bcast_rcv() is NULL. When it
creates a node in tipc_node_check_dest(), after inserting the new node
into hashtable in tipc_node_create(), it creates the bc link. However,
there is a gap between this insert and bc link creation, a bc packet
may come in and get the node from the hashtable then try to dereference
its bc link, which is NULL.
This patch is to fix it by moving the bc link creation before inserting
into the hashtable.
Note that for a preliminary node becoming "real", the bc link creation
should also be called before it's rehashed, as we don't create it for
preliminary nodes.
Fixes: 4cbf8ac2fe5a ("tipc: enable creating a "preliminary" node")
[ Upstream commit 911600bf5a5e84bfda4d33ee32acc75ecf6159f0 ]
syzbot found the following issue on:
BUG: KASAN: use-after-free in tipc_named_reinit+0x94f/0x9b0
net/tipc/name_distr.c:413
Read of size 8 at addr ffff88805299a000 by task kworker/1:9/23764
CPU: 1 PID: 23764 Comm: kworker/1:9 Not tainted
5.18.0-rc4-syzkaller-00878-g17d49e6e8012 #0
Hardware name: Google Compute Engine/Google Compute Engine,
BIOS Google 01/01/2011
Workqueue: events tipc_net_finalize_work
Call Trace:
<TASK>
__dump_stack lib/dump_stack.c:88 [inline]
dump_stack_lvl+0xcd/0x134 lib/dump_stack.c:106
print_address_description.constprop.0.cold+0xeb/0x495
mm/kasan/report.c:313
print_report mm/kasan/report.c:429 [inline]
kasan_report.cold+0xf4/0x1c6 mm/kasan/report.c:491
tipc_named_reinit+0x94f/0x9b0 net/tipc/name_distr.c:413
tipc_net_finalize+0x234/0x3d0 net/tipc/net.c:138
process_one_work+0x996/0x1610 kernel/workqueue.c:2289
kthread+0x2e9/0x3a0 kernel/kthread.c:376
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:298
</TASK>
In the commit
d966ddcc3821 ("tipc: fix a deadlock when flushing scheduled work"),
the cancel_work_sync() function just to make sure ONLY the work
tipc_net_finalize_work() is executing/pending on any CPU completed before
tipc namespace is destroyed through tipc_exit_net(). But this function
is not guaranteed the work is the last queued. So, the destroyed instance
may be accessed in the work which will try to enqueue later.
In order to completely fix, we re-order the calling of cancel_work_sync()
to make sure the work tipc_net_finalize_work() was last queued and it
must be completed by calling cancel_work_sync().
Reported-by: syzbot+47af19f3307fc9c5c82e@syzkaller.appspotmail.com
Fixes: d966ddcc3821 ("tipc: fix a deadlock when flushing scheduled work")
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Hoang Le <hoang.h.le@dektech.com.au>
[ Upstream commit 7f36f798f89bf32c0164049cb0e3fd1af613d0bb ]
syzbot reported uninit-value:
BUG: KMSAN: uninit-value in string_nocheck lib/vsprintf.c:644 [inline]
BUG: KMSAN: uninit-value in string+0x4f9/0x6f0 lib/vsprintf.c:725
vsnprintf+0x2222/0x3650 lib/vsprintf.c:2806
vprintk_store+0x537/0x2150 kernel/printk/printk.c:2158
vprintk_emit+0x28b/0xab0 kernel/printk/printk.c:2256
vprintk_default+0x86/0xa0 kernel/printk/printk.c:2283
vprintk+0x15f/0x180 kernel/printk/printk_safe.c:50
_printk+0x18d/0x1cf kernel/printk/printk.c:2293
tipc_enable_bearer net/tipc/bearer.c:371 [inline]
__tipc_nl_bearer_enable+0x2022/0x22a0 net/tipc/bearer.c:1033
tipc_nl_bearer_enable+0x6c/0xb0 net/tipc/bearer.c:1042
- Do sanity check the attribute length for TIPC_NLA_BEARER_NAME.
- Do not use 'illegal name' in printing message.
Reported-by: syzbot+e820fdc8ce362f2dea51@syzkaller.appspotmail.com
Fixes: cb30a63384bc ("tipc: refactor function tipc_enable_bearer()")
Link: https://lore.kernel.org/r/20220602063053.5892-1-hoang.h.le@dektech.com.au
[ Upstream commit 6a7d8cff4a3301087dd139293e9bddcf63827282 ]
In the timer callback function tipc_sk_timeout(), we're trying to
reschedule another timeout to retransmit a setup request if destination
link is congested. But we use the incorrect timeout value
(msecs_to_jiffies(100)) instead of (jiffies + msecs_to_jiffies(100)),
so that the timer expires immediately, it's irrelevant for original
description.
In this commit we correct the timeout value in sk_reset_timer()
Fixes: 6787927475e5 ("tipc: buffer overflow handling in listener socket")
Acked-by: Ying Xue <ying.xue@windriver.com>
Link: https://lore.kernel.org/r/20220321042229.314288-1-hoang.h.le@dektech.com.au
[ Upstream commit c79fcc27be90b308b3fa90811aefafdd4078668c ]
When receiving a state message, function tipc_link_validate_msg()
is called to validate its header portion. Then, its data portion
is validated before it can be accessed correctly. However, current
data sanity check is done after the message header is accessed to
update some link variables.
This commit fixes this issue by moving the data sanity check to
the beginning of state message handling and right after the header
sanity check.
Fixes: 9aa422ad3266 ("tipc: improve size validations for received domain records")
Link: https://lore.kernel.org/r/20220308021200.9245-1-tung.q.nguyen@dektech.com.au
[ Upstream commit be4977b847f5d5cedb64d50eaaf2218c3a55a3a3 ]
When enabling a bearer on a node, a kernel panic is observed:
[ 4.498085] RIP: 0010:tipc_mon_prep+0x4e/0x130 [tipc]
[ 4.520030] Call Trace:
[ 4.520689] <IRQ>
[ 4.521236] tipc_link_build_proto_msg+0x375/0x750 [tipc]
[ 4.522654] tipc_link_build_state_msg+0x48/0xc0 [tipc]
[ 4.524034] __tipc_node_link_up+0xd7/0x290 [tipc]
[ 4.525292] tipc_rcv+0x5da/0x730 [tipc]
[ 4.526346] ? __netif_receive_skb_core+0xb7/0xfc0
[ 4.527601] tipc_l2_rcv_msg+0x5e/0x90 [tipc]
[ 4.528737] __netif_receive_skb_list_core+0x20b/0x260
[ 4.530068] netif_receive_skb_list_internal+0x1bf/0x2e0
[ 4.531450] ? dev_gro_receive+0x4c2/0x680
[ 4.532512] napi_complete_done+0x6f/0x180
[ 4.533570] virtnet_poll+0x29c/0x42e [virtio_net]
The node in question is receiving activate messages in another
thread after changing bearer status to allow message sending/
receiving in current thread:
thread 1 | thread 2
tipc_enable_bearer() |
test_and_set_bit_lock() |
tipc_bearer_xmit_skb() |
| tipc_l2_rcv_msg()
| tipc_rcv()
| __tipc_node_link_up()
| tipc_link_build_state_msg()
| tipc_link_build_proto_msg()
| tipc_mon_prep()
| // null-pointer dereference
| u16 gen = mon->dom_gen;
// Not being executed yet |
tipc_mon_create() |
// allocate |
mon = kzalloc(); |
Monitoring pointer in thread 2 is dereferenced before monitoring data
is allocated in thread 1. This causes kernel panic.
This commit fixes it by allocating the monitoring data before enabling
the bearer to receive messages.
[ Upstream commit 143de8d97d79316590475dc2a84513c63c863ddf ]
msg_data_sz return a 32bit value, but size is 16bit. This may lead to a
bit overflow.
commit a1f8fec4dac8bc7b172b2bdbd881e015261a6322 upstream.
These tests are supposed to check if the loop exited via a break or not.
However the tests are wrong because if we did not exit via a break then
"p" is not a valid pointer. In that case, it's the equivalent of
"if (*(u32 *)sr == *last_key) {". That's going to work most of the time,
but there is a potential for those to be equal.
Fixes: 1593123a6a49 ("tipc: add name table dump to new netlink api")
Fixes: 1a1a143daf84 ("tipc: add publication dump to new netlink api")
commit c08e58438d4a709fb451b6d7d33432cc9907a2a8 upstream.
The previous bug fix had an unfortunate side effect that broke
distribution of binding table entries between nodes. The updated
tipc_sock_addr struct is also used further down in the same
function, and there the old value is still the correct one.
Fixes: 032062f363b4 ("tipc: fix wrong publisher node address in link publications")
Signed-off-by: Jon Maloy <jmaloy@redhat.com>
Link: https://lore.kernel.org/r/20220216020009.3404578-1-jmaloy@redhat.com
commit 032062f363b4bf02b1d547f329aa5d97b6a17410 upstream.
When a link comes up we add its presence to the name table to make it
possible for users to subscribe for link up/down events. However, after
a previous call signature change the binding is wrongly published with
the peer node as publishing node, instead of the own node as it should
be. This has the effect that the command 'tipc name table show' will
list the link binding (service type 2) with node scope and a peer node
as originator, something that obviously is impossible.
We correct this bug here.
Fixes: 50a3499ab853 ("tipc: simplify signature of tipc_namtbl_publish()")
Link: https://lore.kernel.org/r/20220214013852.2803940-1-jmaloy@redhat.com
[ Upstream commit c7223d687758462826a20e9735305d55bb874c70 ]
It would be easy to craft a message containing an illegal binding table
update operation. This is handled correctly by the code, but the
corresponding warning printout is not rate limited as is should be.
We fix this now.
Fixes: b97bf3fd8f6a ("[TIPC] Initial merge")
commit 9aa422ad326634b76309e8ff342c246800621216 upstream.
The function tipc_mon_rcv() allows a node to receive and process
domain_record structs from peer nodes to track their views of the
network topology.
This patch verifies that the number of members in a received domain
record does not exceed the limit defined by MAX_MON_DOMAIN, something
that may otherwise lead to a stack overflow.
tipc_mon_rcv() is called from the function tipc_link_proto_rcv(), where
we are reading a 32 bit message data length field into a uint16. To
avert any risk of bit overflow, we add an extra sanity check for this in
that function. We cannot see that happen with the current code, but
future designers being unaware of this risk, may introduce it by
allowing delivery of very large (> 64k) sk buffers from the bearer
layer. This potential problem was identified by Eric Dumazet.
This fixes CVE-2022-0435
Reported-by: Samuel Page <samuel.page@appgate.com>
Reported-by: Eric Dumazet <edumazet@google.com>
Reviewed-by: Samuel Page <samuel.page@appgate.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
commit d6d86830705f173fca6087a3e67ceaf68db80523 upstream.
struct tipc_socket_addr.ref has a 4-byte hole,and __tipc_getname() currently
copying it to user space,causing kernel-infoleak.
BUG: KMSAN: kernel-infoleak in instrument_copy_to_user include/linux/instrumented.h:121 [inline]
BUG: KMSAN: kernel-infoleak in instrument_copy_to_user include/linux/instrumented.h:121 [inline] lib/usercopy.c:33
BUG: KMSAN: kernel-infoleak in _copy_to_user+0x1c9/0x270 lib/usercopy.c:33 lib/usercopy.c:33
copy_to_user include/linux/uaccess.h:209 [inline]
copy_to_user include/linux/uaccess.h:209 [inline] net/socket.c:287
move_addr_to_user+0x3f6/0x600 net/socket.c:287 net/socket.c:287
__sys_getpeername+0x470/0x6b0 net/socket.c:1987 net/socket.c:1987
__do_sys_getpeername net/socket.c:1997 [inline]
__se_sys_getpeername net/socket.c:1994 [inline]
__do_sys_getpeername net/socket.c:1997 [inline] net/socket.c:1994
__se_sys_getpeername net/socket.c:1994 [inline] net/socket.c:1994
__x64_sys_getpeername+0xda/0x120 net/socket.c:1994 net/socket.c:1994
do_syscall_x64 arch/x86/entry/common.c:51 [inline] arch/x86/entry/common.c:82
do_syscall_64+0x54/0xd0 arch/x86/entry/common.c:82 arch/x86/entry/common.c:82
entry_SYSCALL_64_after_hwframe+0x44/0xae
tipc_getname+0x575/0x5e0 net/tipc/socket.c:757 net/tipc/socket.c:757
__sys_getpeername+0x3b3/0x6b0 net/socket.c:1984 net/socket.c:1984
msg_set_word net/tipc/msg.h:212 [inline]
msg_set_destport net/tipc/msg.h:619 [inline]
msg_set_word net/tipc/msg.h:212 [inline] net/tipc/socket.c:1486
msg_set_destport net/tipc/msg.h:619 [inline] net/tipc/socket.c:1486
__tipc_sendmsg+0x44fa/0x5890 net/tipc/socket.c:1486 net/tipc/socket.c:1486
tipc_sendmsg+0xeb/0x140 net/tipc/socket.c:1402 net/tipc/socket.c:1402
sock_sendmsg_nosec net/socket.c:704 [inline]
sock_sendmsg net/socket.c:724 [inline]
sock_sendmsg_nosec net/socket.c:704 [inline] net/socket.c:2409
sock_sendmsg net/socket.c:724 [inline] net/socket.c:2409
____sys_sendmsg+0xe11/0x12c0 net/socket.c:2409 net/socket.c:2409
___sys_sendmsg net/socket.c:2463 [inline]
___sys_sendmsg net/socket.c:2463 [inline] net/socket.c:2492
__sys_sendmsg+0x704/0x840 net/socket.c:2492 net/socket.c:2492
__do_sys_sendmsg net/socket.c:2501 [inline]
__se_sys_sendmsg net/socket.c:2499 [inline]
__do_sys_sendmsg net/socket.c:2501 [inline] net/socket.c:2499
__se_sys_sendmsg net/socket.c:2499 [inline] net/socket.c:2499
__x64_sys_sendmsg+0xe2/0x120 net/socket.c:2499 net/socket.c:2499
Local variable skaddr created at:
__tipc_sendmsg+0x2d0/0x5890 net/tipc/socket.c:1419 net/tipc/socket.c:1419
Bytes 4-7 of 16 are uninitialized
Memory access of size 16 starts at ffff888113753e00
Data copied to user address 0000000020000280
Reported-by: syzbot+cdbd40e0c3ca02cae3b7@syzkaller.appspotmail.com
Signed-off-by: Haimin Zhang <tcs_kernel@tencent.com>
Link: https://lore.kernel.org/r/1640918123-14547-1-git-send-email-tcs.kernel@gmail.com
commit 3e6db079751afd527bf3db32314ae938dc571916 upstream.
kmemdup can return a null pointer so need to check for it, otherwise
the null key will be dereferenced later in tipc_crypto_key_xmit as
can be seen in the trace [1].
Cc: tipc-discussion@lists.sourceforge.net
Cc: stable@vger.kernel.org # 5.15, 5.14, 5.10
[1] https://syzkaller.appspot.com/bug?id=bca180abb29567b189efdbdb34cbf7ba851c2a58
Signed-off-by: Tadeusz Struk <tadeusz.struk@linaro.org>
Link: https://lore.kernel.org/r/20211115160143.5099-1-tadeusz.struk@linaro.org
[ Upstream commit 271351d255b09e39c7f6437738cba595f9b235be ]
The MSG_CRYPTO msgs are always encrypted and sent to other nodes
for keys' deployment. But when receiving in peers, if those nodes
do not validate it and make sure it's encrypted, one could craft
a malicious MSG_CRYPTO msg to deploy its key with no need to know
other nodes' keys.
This patch is to do that by checking TIPC_SKB_CB(skb)->decrypted
and discard it if this packet never got decrypted.
Note that this is also a supplementary fix to CVE-2021-43267 that
can be triggered by an unencrypted malicious MSG_CRYPTO msg.
Fixes: 1ef6f7c9390f ("tipc: add automatic session key exchange")
The function tipc_crypto_key_rcv is used to parse MSG_CRYPTO messages
to receive keys from other nodes in the cluster in order to decrypt any
further messages from them.
This patch verifies that any supplied sizes in the message body are
valid for the received message.
Signed-off-by: Max VA <maxv@sentinelone.com>
In tipc_sk_enqueue() we use hardcoded 2 jiffies to extract
socket buffer from generic queue to particular socket.
The 2 jiffies is too short in case there are other high priority
tasks get CPU cycles for multiple jiffies update. As result, no
buffer could be enqueued to particular socket.
To solve this, we switch to use constant timeout 20msecs.
Then, the function will be expired between 2 jiffies (CONFIG_100HZ)
and 20 jiffies (CONFIG_1000HZ).
Fixes: c637c1035534 ("tipc: resolve race problem at unicast message reception")
There is a statement that is indented one character too deeply,
clean this up.
drivers/ptp/Kconfig:
55c8fca1dae1 ("ptp_pch: Restore dependency on PCI")
e5f31552674e ("ethernet: fix PTP_1588_CLOCK dependencies")
__tipc_sendmsg() is called to send SYN packet by either tipc_sendmsg()
or tipc_connect(). The difference is in tipc_connect(), it will call
tipc_wait_for_connect() after __tipc_sendmsg() to wait until connecting
is done. So there's no need to wait in __tipc_sendmsg() for this case.
This patch is to fix it by calling tipc_wait_for_connect() only when dlen
is not 0 in __tipc_sendmsg(), which means it's called by tipc_connect().
Note this also fixes the failure in tipcutils/test/ptts/:
# ./tipcTS &
# ./tipcTC 9
(hang)
Fixes: 36239dab6da7 ("tipc: fix implicit-connect for SYN+")
drivers/net/ethernet/broadcom/bnxt/bnxt_ptp.h
9e26680733d5 ("bnxt_en: Update firmware call to retrieve TX PTP timestamp")
9e518f25802c ("bnxt_en: 1PPS functions to configure TSIO pins")
099fdeda659d ("bnxt_en: Event handler for PPS events")
kernel/bpf/helpers.c
include/linux/bpf-cgroup.h
a2baf4e8bb0f ("bpf: Fix potentially incorrect results with bpf_get_local_storage()")
c7603cfa04e7 ("bpf: Add ambient BPF runtime context stored in current")
drivers/net/ethernet/mellanox/mlx5/core/pci_irq.c
5957cc557dc5 ("net/mlx5: Set all field of mlx5_irq before inserting it to the xarray")
2d0b41a37679 ("net/mlx5: Refcount mlx5_irq with integer")
MAINTAINERS
7b637cd52f02 ("MAINTAINERS: fix Microchip CAN BUS Analyzer Tool entry typo")
7d901a1e878a ("net: phy: add Maxlinear GPY115/21x/24x driver")
This reverts commit 0efea3c649f0 because of:
- The returning -ENOBUF error is fine on socket buffer allocation.
- There is side effect in the calling path
tipc_node_xmit()->tipc_link_xmit() when checking error code returning.
Fixes: 0efea3c649f0 ("tipc: Return the correct errno code")
Conflicting commits, all resolutions pretty trivial:
drivers/bus/mhi/pci_generic.c
5c2c85315948 ("bus: mhi: pci-generic: configurable network interface MRU")
56f6f4c4eb2a ("bus: mhi: pci_generic: Apply no-op for wake using sideband wake boolean")
drivers/nfc/s3fwrn5/firmware.c
a0302ff5906a ("nfc: s3fwrn5: remove unnecessary label")
46573e3ab08f ("nfc: s3fwrn5: fix undefined parameter values in dev_err()")
801e541c79bb ("nfc: s3fwrn5: fix undefined parameter values in dev_err()")
MAINTAINERS
8a7b46fa7902 ("MAINTAINERS: add Yasushi SHOJI as reviewer for the Microchip CAN BUS Analyzer Tool driver")
syzbot reported an use-after-free crash:
BUG: KASAN: use-after-free in tipc_recvmsg+0xf77/0xf90 net/tipc/socket.c:1979
Call Trace:
sock_recvmsg_nosec net/socket.c:943 [inline]
sock_recvmsg net/socket.c:961 [inline]
sock_recvmsg+0xca/0x110 net/socket.c:957
tipc_conn_rcv_from_sock+0x162/0x2f0 net/tipc/topsrv.c:398
tipc_conn_recv_work+0xeb/0x190 net/tipc/topsrv.c:421
process_one_work+0x98d/0x1630 kernel/workqueue.c:2276
worker_thread+0x658/0x11f0 kernel/workqueue.c:2422
As Hoang pointed out, it was caused by skb_cb->bytes_read still accessed
after calling tsk_advance_rx_queue() to free the skb in tipc_recvmsg().
This patch is to fix it by accessing skb_cb->bytes_read earlier than
calling tsk_advance_rx_queue().
Fixes: f4919ff59c28 ("tipc: keep the skb in rcv queue until the whole data is read")
Reported-by: syzbot+e6741b97d5552f97c24d@syzkaller.appspotmail.com
One skb's skb_shinfo frags are not writable, and they can be shared with
other skbs' like by pskb_copy(). To write the frags may cause other skb's
data crash.
So before doing en/decryption, skb_cow_data() should always be called for
a cloned or nonlinear skb if req dst is using the same sg as req src.
While at it, the likely branch can be removed, as it will be covered
by skb_cow_data().
Note that esp_input() has the same issue, and I will fix it in another
patch. tipc_aead_encrypt() doesn't have this issue, as it only processes
linear data in the unlikely branch.
