Ethernet media initialization is only done when TIPC is started or
switched to network mode. So the initialization of the network device
notifier structure can be moved out of this function and done
statically instead.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
Some of the comment blocks are floating in limbo between two
functions, or between blocks of code. Delete the extra line
feeds between any comment and its associated following block
of code, to be consistent with the majority of the rest of
the kernel. Also delete trailing newlines at EOF and fix
a couple trivial typos in existing comments.
This is a 100% cosmetic change with no runtime impact. We get
rid of over 500 lines of non-code, and being blank line deletes,
they won't even show up as noise in git blame.
Give it a meaningful prefix, as suggested by DaveM, so that it
is consistent with things like struct tipc_bearer, and so it isn't
confused with anything else. This has no impact on the actual
runtime code behaviour.
Gets rid of two pointless operations that zero out the array used to
record information about TIPC's Ethernet bearers. There is no need to
initialize the array on start up since it is a global variable that is
already zero'd out, and there is no need to zero it out on exit because
the array is never referenced again.
Signed-off-by: Allan Stephens <allan.stephens@windriver.com>
Modifies Ethernet bearer disable logic to break the association between
the bearer and its device driver at the time the bearer is disabled,
rather than when the TIPC module is unloaded. This allows the array
entry used by the disabled bearer to be re-used if the same bearer (or
a different one) is subsequently enabled.
Change TIPC's shutdown code to deactivate generic networking support
before terminating Ethernet media support. The deactivation of generic
networking support causes all existing bearers to be destroyed, meaning
the Ethernet media termination routine no longer has to bother marking
them as unavailable.
Reworks TIPC's media address data structure and associated processing
routines to transfer all media-specific details of address conversion
to the associated TIPC media adaptation code. TIPC's generic bearer code
now only needs to know which media type an address is associated with
and whether or not it is a broadcast address, and totally ignores the
"value" field that contains the actual media-specific addressing info.
These changes eliminate the need for a number of endianness conversion
operations and will make it easier for TIPC to support new media types
in the future.
Enhances TIPC's Ethernet media support to provide 3 new address conversion
routines, which allow TIPC to interpret an address that is in string form
and to convert an address to and from the 20 byte format used in TIPC's
neighbor discovery messages.
These routines are pre-requisites to a follow on commit that hides all
media-specific addressing details from TIPC's generic bearer code.
Enhances conversion of a media address to printable form so that an
unconvertable address will be displayed as a string of hex digits,
rather than not being displayed at all. (Also removes a pointless check
for the existence of the media-specific address conversion routine,
since the routine is not optional.)
Speeds up the registration of TIPC media types by passing in a structure
containing the required information, rather than by passing in the various
fields describing the media type individually.
Reduces the number of bearers a node can support to 2, which can use
identical or non-identical media. This change won't impact users,
since they are currently limited to a maximum of 2 Ethernet bearers,
and will save memory by eliminating a number of unused entries in
TIPC's media and bearer arrays.
Removes obsolete code that searches for an Ethernet bearer structure entry
to use for a newly enabled bearer, since this search is now performed
at the start of the enabling algorithm.
Ensures that the device list lock is held while trying to locate
the Ethernet device used by a newly enabled bearer, so that the
addition or removal of a device does not cause problems.
Cleans up TIPC's source code to eliminate the needless initialization
of static variables to zero.
These changes are purely cosmetic and do not alter the operation of TIPC
in any way.
Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com>
Cleans up TIPC's source code to eliminate deviations from generally
accepted coding conventions relating to leading/trailing white space
and white space around commas, braces, cases, and sizeof.
in any way.
Eliminates a number of #include statements that no longer serve any
useful purpose.
As part of the removal of TIPC's native API support it is no longer
necessary for TIPC to export symbols for routines that can be called
by kernel-based applications, nor for it to have header files that
kernel-based applications can include to access the declarations for
those routines. This commit eliminates the exporting of symbols by
TIPC and migrates the contents of each obsolete native API include
file into its corresponding non-native API equivalent.
The code which was migrated in this commit was migrated intact, in
that there are no technical changes combined with the relocation.
Remove code that trimmed excess trailing info from incoming messages
arriving over an Ethernet interface. TIPC now ignores the extra info
while the message is being processed by the node, and only trims it off
if the message is retransmitted to another node. (This latter step is
done to ensure the extra info doesn't cause the sk_buff to exceed the
outgoing interface's MTU limit.) The outgoing buffer is guaranteed to
be linear.
Cause TIPC to return EAGAIN if it is unable to enable a new Ethernet
bearer because one or more recently disabled Ethernet bearers are
temporarily consuming resources during shut down. (The previous error
code, EDQUOT, is now returned only if all available Ethernet bearer
data structures are fully enabled at the time the request to enable an
additional bearer is received.)
Add code to expand the headroom of an outgoing TIPC message if the
sk_buff has insufficient room to hold the header for the associated
Ethernet device. This change is necessary to ensure that messages
TIPC does not create itself (eg. incoming messages that are being
routed to another node) do not cause problems, since TIPC has no
control over the amount of headroom available in such messages.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Patch fixes issues with dev->dev_addr changing from array to pointer.
Hopefully there are no others.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
This converts pretty much everything to print_mac. There were
a few things that had conflicts which I have just dropped for
now, no harm done.
I've built an allyesconfig with this and looked at the files
that weren't built very carefully, but it's a huge patch.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch corrects many places where TIPC routines indicated
successful completion by returning TIPC_OK instead of 0.
(The TIPC_OK symbol has the value 0, but it should only be used
in contexts that deal with the error code field of a TIPC
message header.)
Introduce per-net_device inlines: dev_net(), dev_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Add inline for common usage of hardware header creation, and
fix bug in IPV6 mcast where the assumption about negative return is
an errno. Negative return from hard_header means not enough space
was available,(ie -N bytes).
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This is nicer than the MAC_FMT stuff.
This patch makes most of the generic device layer network
namespace safe. This patch makes dev_base_head a
network namespace variable, and then it picks up
a few associated variables. The functions:
dev_getbyhwaddr
dev_getfirsthwbytype
dev_get_by_flags
dev_get_by_name
__dev_get_by_name
dev_get_by_index
__dev_get_by_index
dev_ioctl
dev_ethtool
dev_load
wireless_process_ioctl
were modified to take a network namespace argument, and
deal with it.
vlan_ioctl_set and brioctl_set were modified so their
hooks will receive a network namespace argument.
So basically anthing in the core of the network stack that was
affected to by the change of dev_base was modified to handle
multiple network namespaces. The rest of the network stack was
simply modified to explicitly use &init_net the initial network
namespace. This can be fixed when those components of the network
stack are modified to handle multiple network namespaces.
For now the ifindex generator is left global.
Fundametally ifindex numbers are per namespace, or else
we will have corner case problems with migration when
we get that far.
At the same time there are assumptions in the network stack
that the ifindex of a network device won't change. Making
the ifindex number global seems a good compromise until
the network stack can cope with ifindex changes when
you change namespaces, and the like.
Every user of the network device notifiers is either a protocol
stack or a pseudo device. If a protocol stack that does not have
support for multiple network namespaces receives an event for a
device that is not in the initial network namespace it quite possibly
can get confused and do the wrong thing.
To avoid problems until all of the protocol stacks are converted
this patch modifies all netdev event handlers to ignore events on
devices that are not in the initial network namespace.
As the rest of the code is made network namespace aware these
checks can be removed.
This patch modifies every packet receive function
registered with dev_add_pack() to drop packets if they
are not from the initial network namespace.
This should ensure that the various network stacks do
not receive packets in a anything but the initial network
namespace until the code has been converted and is ready
for them.
This patch simplifies TIPC's Ethernet receive routine to take
advantage of information already present in each incoming sk_buff
indicating whether the packet was explicitly sent to the interface,
has been broadcast to all interfaces, or was picked up because the
interface is in promiscous mode.
This new approach also fixes the problem of TIPC accepting unwanted
traffic through UML's multicast-based Ethernet interfaces (which
deliver traffic in a promiscuous manner even if the interface is
not configured to be promiscuous).
Signed-off-by: Jon Paul Maloy <jon.maloy@ericsson.com>
Cleanup of dev_base list use, with the aim to simplify making device
list per-namespace. In almost every occasion, use of dev_base variable
and dev->next pointer could be easily replaced by for_each_netdev
loop. A few most complicated places were converted to using
first_netdev()/next_netdev().
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Acked-by: Kirill Korotaev <dev@openvz.org>
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can
later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in
64bit land while possibly keeping it as a pointer on 32bit.
This one touches just the most simple case, next will handle the slightly more
"complex" cases.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the mac header, it is still legal to
touch skb->mac.raw directly if just adding to, subtracting from or setting it
to another layer header.
This one also converts some more cases to skb_reset_mac_header() that my
regex missed as it had no spaces before nor after '=', ugh.
This fix prevents a bearer from being enabled using the wrong interface.
For example, specifying "eth:eth14" might enable "eth:eth1" by mistake.
Signed-off-by: Per Liden <per.liden@ericsson.com>
Tried to run the new tipc stack through sparse.
Following patch fixes all cases where 0 was used
as replacement of NULL.
Use NULL to document this is a pointer and to silence sparse.
This brough sparse warning count down with 127 to 24 warnings.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
This patch adds a tipc_ prefix to all externally visible symbols.
Added macros for min/default/max link priority in tipc_config.h.
Also renamed TIPC_NUM_LINK_PRI to TIPC_MEDIA_LINK_PRI since that
is a more accurate description of what it is used for.
Updated copyright notice to include the year the file was
actually created. Information about file creation dates
was extracted from the files in the old CVS repository
at tipc.sourceforge.net.
Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
The copyright statements from different parts of Ericsson
have been merged into one.
The license header in each file now more clearly state that this
code is licensed under a dual BSD/GPL. Before this was only
evident if you looked at the MODULE_LICENSE line in core.c.
TIPC (Transparent Inter Process Communication) is a protocol designed for
intra cluster communication. For more information see
http://tipc.sourceforge.net
