path: root/net/tipc/Makefile
2011-01-01tipc: rename dbg.[ch] to log.[ch]Allan Stephens
As the first step in removing obsolete debugging code from TIPC the files that implement TIPC's non-debug-related log buffer subsystem are renamed to better reflect their true nature. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove user registry subsystemAllan Stephens
Eliminates routines, data structures, and files that make up TIPC's user registry. The user registry is no longer needed since the native API routines that utilized it no longer exist and there are no longer any internal TIPC services that use it. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting multiple clustersAllan Stephens
Eliminates routines, data structures, and files that were intended to allow TIPC to support a network containing multiple clusters. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-01tipc: Remove prototype code for supporting multiple zonesAllan Stephens
Eliminates routines, data structures, and files that were intended to allows TIPC to support a network containing multiple zones. Currently, TIPC supports only networks consisting of a single cluster within a single zone, so this code is unnecessary. Signed-off-by: Allan Stephens <Allan.Stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[TIPC] Initial mergePer Liden
TIPC (Transparent Inter Process Communication) is a protocol designed for intra cluster communication. For more information see http://tipc.sourceforge.net Signed-off-by: Per Liden <per.liden@nospam.ericsson.com>
