path: root/net/sunrpc
2018-09-15sunrpc: Don't use stack buffer with scatterlistLaura Abbott
[ Upstream commit 44090cc876926277329e1608bafc01b9f6da627f ] Fedora got a bug report from NFS: kernel BUG at include/linux/scatterlist.h:143! ... RIP: 0010:sg_init_one+0x7d/0x90 .. make_checksum+0x4e7/0x760 [rpcsec_gss_krb5] gss_get_mic_kerberos+0x26e/0x310 [rpcsec_gss_krb5] gss_marshal+0x126/0x1a0 [auth_rpcgss] ? __local_bh_enable_ip+0x80/0xe0 ? call_transmit_status+0x1d0/0x1d0 [sunrpc] call_transmit+0x137/0x230 [sunrpc] __rpc_execute+0x9b/0x490 [sunrpc] rpc_run_task+0x119/0x150 [sunrpc] nfs4_run_exchange_id+0x1bd/0x250 [nfsv4] _nfs4_proc_exchange_id+0x2d/0x490 [nfsv4] nfs41_discover_server_trunking+0x1c/0xa0 [nfsv4] nfs4_discover_server_trunking+0x80/0x270 [nfsv4] nfs4_init_client+0x16e/0x240 [nfsv4] ? nfs_get_client+0x4c9/0x5d0 [nfs] ? _raw_spin_unlock+0x24/0x30 ? nfs_get_client+0x4c9/0x5d0 [nfs] nfs4_set_client+0xb2/0x100 [nfsv4] nfs4_create_server+0xff/0x290 [nfsv4] nfs4_remote_mount+0x28/0x50 [nfsv4] mount_fs+0x3b/0x16a vfs_kern_mount.part.35+0x54/0x160 nfs_do_root_mount+0x7f/0xc0 [nfsv4] nfs4_try_mount+0x43/0x70 [nfsv4] ? get_nfs_version+0x21/0x80 [nfs] nfs_fs_mount+0x789/0xbf0 [nfs] ? pcpu_alloc+0x6ca/0x7e0 ? nfs_clone_super+0x70/0x70 [nfs] ? nfs_parse_mount_options+0xb40/0xb40 [nfs] mount_fs+0x3b/0x16a vfs_kern_mount.part.35+0x54/0x160 do_mount+0x1fd/0xd50 ksys_mount+0xba/0xd0 __x64_sys_mount+0x21/0x30 do_syscall_64+0x60/0x1f0 entry_SYSCALL_64_after_hwframe+0x49/0xbe This is BUG_ON(!virt_addr_valid(buf)) triggered by using a stack allocated buffer with a scatterlist. Convert the buffer for rc4salt to be dynamically allocated instead. Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1615258 Signed-off-by: Laura Abbott <labbott@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-09NFSv4 client live hangs after live data migration recoveryBill Baker
commit 0f90be132cbf1537d87a6a8b9e80867adac892f6 upstream. After a live data migration event at the NFS server, the client may send I/O requests to the wrong server, causing a live hang due to repeated recovery events. On the wire, this will appear as an I/O request failing with NFS4ERR_BADSESSION, followed by successful CREATE_SESSION, repeatedly. NFS4ERR_BADSSESSION is returned because the session ID being used was issued by the other server and is not valid at the old server. The failure is caused by async worker threads having cached the transport (xprt) in the rpc_task structure. After the migration recovery completes, the task is redispatched and the task resends the request to the wrong server based on the old value still present in tk_xprt. The solution is to recompute the tk_xprt field of the rpc_task structure so that the request goes to the correct server. Signed-off-by: Bill Baker <bill.baker@oracle.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: Helen Chao <helen.chao@oracle.com> Fixes: fb43d17210ba ("SUNRPC: Use the multipath iterator to assign a ...") Cc: stable@vger.kernel.org # v4.9+ Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-25xprtrdma: Return -ENOBUFS when no pages are availableChuck Lever
commit a8f688ec437dc2045cc8f0c89fe877d5803850da upstream. The use of -EAGAIN in rpcrdma_convert_iovs() is a latent bug: the transport never calls xprt_write_space() when more pages become available. -ENOBUFS will trigger the correct "delay briefly and call again" logic. Fixes: 7a89f9c626e3 ("xprtrdma: Honor ->send_request API contract") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: stable@vger.kernel.org # 4.8+ Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-24rpc_pipefs: fix double-dput()Al Viro
commit 4a3877c4cedd95543f8726b0a98743ed8db0c0fb upstream. if we ever hit rpc_gssd_dummy_depopulate() dentry passed to it has refcount equal to 1. __rpc_rmpipe() drops it and dput() done after that hits an already freed dentry. Cc: stable@kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-20sunrpc: remove incorrect HMAC request initializationEric Biggers
commit f3aefb6a7066e24bfea7fcf1b07907576de69d63 upstream. make_checksum_hmac_md5() is allocating an HMAC transform and doing crypto API calls in the following order: crypto_ahash_init() crypto_ahash_setkey() crypto_ahash_digest() This is wrong because it makes no sense to init() the request before a key has been set, given that the initial state depends on the key. And digest() is short for init() + update() + final(), so in this case there's no need to explicitly call init() at all. Before commit 9fa68f620041 ("crypto: hash - prevent using keyed hashes without setting key") the extra init() had no real effect, at least for the software HMAC implementation. (There are also hardware drivers that implement HMAC-MD5, and it's not immediately obvious how gracefully they handle init() before setkey().) But now the crypto API detects this incorrect initialization and returns -ENOKEY. This is breaking NFS mounts in some cases. Fix it by removing the incorrect call to crypto_ahash_init(). Reported-by: Michael Young <m.a.young@durham.ac.uk> Fixes: 9fa68f620041 ("crypto: hash - prevent using keyed hashes without setting key") Fixes: fffdaef2eb4a ("gss_krb5: Add support for rc4-hmac encryption") Cc: stable@vger.kernel.org Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-04-13SUNRPC: ensure correct error is reported by xs_tcp_setup_socket()NeilBrown
[ Upstream commit 6ea44adce91526700535b3150f77f8639ae8c82d ] If you attempt a TCP mount from an host that is unreachable in a way that triggers an immediate error from kernel_connect(), that error does not propagate up, instead EAGAIN is reported. This results in call_connect_status receiving the wrong error. A case that it easy to demonstrate is to attempt to mount from an address that results in ENETUNREACH, but first deleting any default route. Without this patch, the mount.nfs process is persistently runnable and is hard to kill. With this patch it exits as it should. The problem is caused by the fact that xs_tcp_force_close() eventually calls xprt_wake_pending_tasks(xprt, -EAGAIN); which causes an error return of -EAGAIN. so when xs_tcp_setup_sock() calls xprt_wake_pending_tasks(xprt, status); the status is ignored. Fixes: 4efdd92c9211 ("SUNRPC: Remove TCP client connection reset hack") Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-24xprtrdma: Cancel refresh worker during buffer shutdownChuck Lever
[ Upstream commit 9378b274e1eb6925db315e345f48850d2d5d9789 ] Trying to create MRs while the transport is being torn down can cause a crash. Fixes: e2ac236c0b65 ("xprtrdma: Allocate MRs on demand") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03SUNRPC: Allow connect to return EHOSTUNREACHTrond Myklebust
[ Upstream commit 4ba161a793d5f43757c35feff258d9f20a082940 ] Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Tested-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-10kernel: make groups_sort calling a responsibility group_info allocatorsThiago Rafael Becker
commit bdcf0a423ea1c40bbb40e7ee483b50fc8aa3d758 upstream. In testing, we found that nfsd threads may call set_groups in parallel for the same entry cached in auth.unix.gid, racing in the call of groups_sort, corrupting the groups for that entry and leading to permission denials for the client. This patch: - Make groups_sort globally visible. - Move the call to groups_sort to the modifiers of group_info - Remove the call to groups_sort from set_groups Link: http://lkml.kernel.org/r/20171211151420.18655-1-thiago.becker@gmail.com Signed-off-by: Thiago Rafael Becker <thiago.becker@gmail.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Reviewed-by: NeilBrown <neilb@suse.com> Acked-by: "J. Bruce Fields" <bfields@fieldses.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14sunrpc: Fix rpc_task_begin trace pointChuck Lever
[ Upstream commit b2bfe5915d5fe7577221031a39ac722a0a2a1199 ] The rpc_task_begin trace point always display a task ID of zero. Move the trace point call site so that it picks up the new task ID. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27NFSv4: Fix callback server shutdownTrond Myklebust
commit ed6473ddc704a2005b9900ca08e236ebb2d8540a upstream. We want to use kthread_stop() in order to ensure the threads are shut down before we tear down the nfs_callback_info in nfs_callback_down. Tested-and-reviewed-by: Kinglong Mee <kinglongmee@gmail.com> Reported-by: Kinglong Mee <kinglongmee@gmail.com> Fixes: bb6aeba736ba9 ("NFSv4.x: Switch to using svc_set_num_threads()...") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Cc: Jan Hudoba <kernel@jahu.sk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-27SUNRPC: Refactor svc_set_num_threads()Trond Myklebust
commit 9e0d87680d689f1758185851c3da6eafb16e71e1 upstream. Refactor to separate out the functions of starting and stopping threads so that they can be used in other helpers. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Tested-and-reviewed-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Cc: Jan Hudoba <kernel@jahu.sk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30net: sunrpc: svcsock: fix NULL-pointer exceptionVadim Lomovtsev
commit eebe53e87f97975ee58a21693e44797608bf679c upstream. While running nfs/connectathon tests kernel NULL-pointer exception has been observed due to races in svcsock.c. Race is appear when kernel accepts connection by kernel_accept (which creates new socket) and start queuing ingress packets to new socket. This happens in ksoftirq context which could run concurrently on a different core while new socket setup is not done yet. The fix is to re-order socket user data init sequence and add write/read barrier calls to be sure that we got proper values for callback pointers before actually calling them. Test results: nfs/connectathon reports '0' failed tests for about 200+ iterations. Crash log: ---<-snip->--- [ 6708.638984] Unable to handle kernel NULL pointer dereference at virtual address 00000000 [ 6708.647093] pgd = ffff0000094e0000 [ 6708.650497] [00000000] *pgd=0000010ffff90003, *pud=0000010ffff90003, *pmd=0000010ffff80003, *pte=0000000000000000 [ 6708.660761] Internal error: Oops: 86000005 [#1] SMP [ 6708.665630] Modules linked in: nfsv3 nfnetlink_queue nfnetlink_log nfnetlink rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache overlay xt_CONNSECMARK xt_SECMARK xt_conntrack iptable_security ip_tables ah4 xfrm4_mode_transport sctp tun binfmt_misc ext4 jbd2 mbcache loop tcp_diag udp_diag inet_diag rpcrdma ib_isert iscsi_target_mod ib_iser rdma_cm iw_cm libiscsi scsi_transport_iscsi ib_srpt target_core_mod ib_srp scsi_transport_srp ib_ipoib ib_ucm ib_uverbs ib_umad ib_cm ib_core nls_koi8_u nls_cp932 ts_kmp nf_conntrack_ipv4 nf_defrag_ipv4 nf_conntrack vfat fat ghash_ce sha2_ce sha1_ce cavium_rng_vf i2c_thunderx sg thunderx_edac i2c_smbus edac_core cavium_rng nfsd auth_rpcgss nfs_acl lockd grace sunrpc xfs libcrc32c nicvf nicpf ast i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops [ 6708.736446] ttm drm i2c_core thunder_bgx thunder_xcv mdio_thunder mdio_cavium dm_mirror dm_region_hash dm_log dm_mod [last unloaded: stap_3c300909c5b3f46dcacd49aab3334af_87021] [ 6708.752275] CPU: 84 PID: 0 Comm: swapper/84 Tainted: G W OE 4.11.0-4.el7.aarch64 #1 [ 6708.760787] Hardware name: www.cavium.com CRB-2S/CRB-2S, BIOS 0.3 Mar 13 2017 [ 6708.767910] task: ffff810006842e80 task.stack: ffff81000689c000 [ 6708.773822] PC is at 0x0 [ 6708.776739] LR is at svc_data_ready+0x38/0x88 [sunrpc] [ 6708.781866] pc : [<0000000000000000>] lr : [<ffff0000029d7378>] pstate: 60000145 [ 6708.789248] sp : ffff810ffbad3900 [ 6708.792551] x29: ffff810ffbad3900 x28: ffff000008c73d58 [ 6708.797853] x27: 0000000000000000 x26: ffff81000bbe1e00 [ 6708.803156] x25: 0000000000000020 x24: ffff800f7410bf28 [ 6708.808458] x23: ffff000008c63000 x22: ffff000008c63000 [ 6708.813760] x21: ffff800f7410bf28 x20: ffff81000bbe1e00 [ 6708.819063] x19: ffff810012412400 x18: 00000000d82a9df2 [ 6708.824365] x17: 0000000000000000 x16: 0000000000000000 [ 6708.829667] x15: 0000000000000000 x14: 0000000000000001 [ 6708.834969] x13: 0000000000000000 x12: 722e736f622e676e [ 6708.840271] x11: 00000000f814dd99 x10: 0000000000000000 [ 6708.845573] x9 : 7374687225000000 x8 : 0000000000000000 [ 6708.850875] x7 : 0000000000000000 x6 : 0000000000000000 [ 6708.856177] x5 : 0000000000000028 x4 : 0000000000000000 [ 6708.861479] x3 : 0000000000000000 x2 : 00000000e5000000 [ 6708.866781] x1 : 0000000000000000 x0 : ffff81000bbe1e00 [ 6708.872084] [ 6708.873565] Process swapper/84 (pid: 0, stack limit = 0xffff81000689c000) [ 6708.880341] Stack: (0xffff810ffbad3900 to 0xffff8100068a0000) [ 6708.886075] Call trace: [ 6708.888513] Exception stack(0xffff810ffbad3710 to 0xffff810ffbad3840) [ 6708.894942] 3700: ffff810012412400 0001000000000000 [ 6708.902759] 3720: ffff810ffbad3900 0000000000000000 0000000060000145 ffff800f79300000 [ 6708.910577] 3740: ffff000009274d00 00000000000003ea 0000000000000015 ffff000008c63000 [ 6708.918395] 3760: ffff810ffbad3830 ffff800f79300000 000000000000004d 0000000000000000 [ 6708.926212] 3780: ffff810ffbad3890 ffff0000080f88dc ffff800f79300000 000000000000004d [ 6708.934030] 37a0: ffff800f7930093c ffff000008c63000 0000000000000000 0000000000000140 [ 6708.941848] 37c0: ffff000008c2c000 0000000000040b00 ffff81000bbe1e00 0000000000000000 [ 6708.949665] 37e0: 00000000e5000000 0000000000000000 0000000000000000 0000000000000028 [ 6708.957483] 3800: 0000000000000000 0000000000000000 0000000000000000 7374687225000000 [ 6708.965300] 3820: 0000000000000000 00000000f814dd99 722e736f622e676e 0000000000000000 [ 6708.973117] [< (null)>] (null) [ 6708.977824] [<ffff0000086f9fa4>] tcp_data_queue+0x754/0xc5c [ 6708.983386] [<ffff0000086fa64c>] tcp_rcv_established+0x1a0/0x67c [ 6708.989384] [<ffff000008704120>] tcp_v4_do_rcv+0x15c/0x22c [ 6708.994858] [<ffff000008707418>] tcp_v4_rcv+0xaf0/0xb58 [ 6709.000077] [<ffff0000086df784>] ip_local_deliver_finish+0x10c/0x254 [ 6709.006419] [<ffff0000086dfea4>] ip_local_deliver+0xf0/0xfc [ 6709.011980] [<ffff0000086dfad4>] ip_rcv_finish+0x208/0x3a4 [ 6709.017454] [<ffff0000086e018c>] ip_rcv+0x2dc/0x3c8 [ 6709.022328] [<ffff000008692fc8>] __netif_receive_skb_core+0x2f8/0xa0c [ 6709.028758] [<ffff000008696068>] __netif_receive_skb+0x38/0x84 [ 6709.034580] [<ffff00000869611c>] netif_receive_skb_internal+0x68/0xdc [ 6709.041010] [<ffff000008696bc0>] napi_gro_receive+0xcc/0x1a8 [ 6709.046690] [<ffff0000014b0fc4>] nicvf_cq_intr_handler+0x59c/0x730 [nicvf] [ 6709.053559] [<ffff0000014b1380>] nicvf_poll+0x38/0xb8 [nicvf] [ 6709.059295] [<ffff000008697a6c>] net_rx_action+0x2f8/0x464 [ 6709.064771] [<ffff000008081824>] __do_softirq+0x11c/0x308 [ 6709.070164] [<ffff0000080d14e4>] irq_exit+0x12c/0x174 [ 6709.075206] [<ffff00000813101c>] __handle_domain_irq+0x78/0xc4 [ 6709.081027] [<ffff000008081608>] gic_handle_irq+0x94/0x190 [ 6709.086501] Exception stack(0xffff81000689fdf0 to 0xffff81000689ff20) [ 6709.092929] fde0: 0000810ff2ec0000 ffff000008c10000 [ 6709.100747] fe00: ffff000008c70ef4 0000000000000001 0000000000000000 ffff810ffbad9b18 [ 6709.108565] fe20: ffff810ffbad9c70 ffff8100169d3800 ffff810006843ab0 ffff81000689fe80 [ 6709.116382] fe40: 0000000000000bd0 0000ffffdf979cd0 183f5913da192500 0000ffff8a254ce4 [ 6709.124200] fe60: 0000ffff8a254b78 0000aaab10339808 0000000000000000 0000ffff8a0c2a50 [ 6709.132018] fe80: 0000ffffdf979b10 ffff000008d6d450 ffff000008c10000 ffff000008d6d000 [ 6709.139836] fea0: 0000000000000054 ffff000008cd3dbc 0000000000000000 0000000000000000 [ 6709.147653] fec0: 0000000000000000 0000000000000000 0000000000000000 ffff81000689ff20 [ 6709.155471] fee0: ffff000008085240 ffff81000689ff20 ffff000008085244 0000000060000145 [ 6709.163289] ff00: ffff81000689ff10 ffff00000813f1e4 ffffffffffffffff ffff00000813f238 [ 6709.171107] [<ffff000008082eb4>] el1_irq+0xb4/0x140 [ 6709.175976] [<ffff000008085244>] arch_cpu_idle+0x44/0x11c [ 6709.181368] [<ffff0000087bf3b8>] default_idle_call+0x20/0x30 [ 6709.187020] [<ffff000008116d50>] do_idle+0x158/0x1e4 [ 6709.191973] [<ffff000008116ff4>] cpu_startup_entry+0x2c/0x30 [ 6709.197624] [<ffff00000808e7cc>] secondary_start_kernel+0x13c/0x160 [ 6709.203878] [<0000000001bc71c4>] 0x1bc71c4 [ 6709.207967] Code: bad PC value [ 6709.211061] SMP: stopping secondary CPUs [ 6709.218830] Starting crashdump kernel... [ 6709.222749] Bye! ---<-snip>--- Signed-off-by: Vadim Lomovtsev <vlomovts@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-27sunrpc: use constant time memory comparison for macJason A. Donenfeld
commit 15a8b93fd5690de017ce665382ea45e5d61811a4 upstream. Otherwise, we enable a MAC forgery via timing attack. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Jeff Layton <jlayton@poochiereds.net> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: Anna Schumaker <anna.schumaker@netapp.com> Cc: linux-nfs@vger.kernel.org Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12svcauth_gss: Close connection when dropping an incoming messageChuck Lever
[ Upstream commit 4d712ef1db05c3aa5c3b690a50c37ebad584c53f ] S5.3.3.1 of RFC 2203 requires that an incoming GSS-wrapped message whose sequence number lies outside the current window is dropped. The rationale is: The reason for discarding requests silently is that the server is unable to determine if the duplicate or out of range request was due to a sequencing problem in the client, network, or the operating system, or due to some quirk in routing, or a replay attack by an intruder. Discarding the request allows the client to recover after timing out, if indeed the duplication was unintentional or well intended. However, clients may rely on the server dropping the connection to indicate that a retransmit is needed. Without a connection reset, a client can wait forever without retransmitting, and the workload just stops dead. I've reproduced this behavior by running xfstests generic/323 on an NFSv4.0 mount with proto=rdma and sec=krb5i. To address this issue, have the server close the connection when it silently discards an incoming message due to a GSS sequence number problem. There are a few other places where the server will never reply. Change those spots in a similar fashion. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-26xprtrdma: Squelch kbuild sparse complaintChuck Lever
commit eed50879d64ab1b9f76445dbab822e43a098b309 upstream. New complaint from kbuild for 4.9.y: net/sunrpc/xprtrdma/verbs.c:489:19: sparse: incompatible types in comparison expression (different type sizes) verbs.c: 489 max_sge = min(ia->ri_device->attrs.max_sge, RPCRDMA_MAX_SEND_SGES); I can't reproduce this running sparse here. Likewise, "make W=1 net/sunrpc/xprtrdma/verbs.o" never indicated any issue. A little poking suggests that because the range of its values is small, gcc can make the actual width of RPCRDMA_MAX_SEND_SGES smaller than the width of an unsigned integer. Fixes: 16f906d66cd7 ("xprtrdma: Reduce required number of send SGEs") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12xprtrdma: Reduce required number of send SGEsChuck Lever
commit 16f906d66cd76fb9895cbc628f447532a7ac1faa upstream. The MAX_SEND_SGES check introduced in commit 655fec6987be ("xprtrdma: Use gathered Send for large inline messages") fails for devices that have a small max_sge. Instead of checking for a large fixed maximum number of SGEs, check for a minimum small number. RPC-over-RDMA will switch to using a Read chunk if an xdr_buf has more pages than can fit in the device's max_sge limit. This is considerably better than failing all together to mount the server. This fix supports devices that have as few as three send SGEs available. Reported-by: Selvin Xavier <selvin.xavier@broadcom.com> Reported-by: Devesh Sharma <devesh.sharma@broadcom.com> Reported-by: Honggang Li <honli@redhat.com> Reported-by: Ram Amrani <Ram.Amrani@cavium.com> Fixes: 655fec6987be ("xprtrdma: Use gathered Send for large ...") Tested-by: Honggang Li <honli@redhat.com> Tested-by: Ram Amrani <Ram.Amrani@cavium.com> Tested-by: Steve Wise <swise@opengridcomputing.com> Reviewed-by: Parav Pandit <parav@mellanox.com> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12xprtrdma: Disable pad optimization by defaultChuck Lever
commit c95a3c6b88658bcb8f77f85f31a0b9d9036e8016 upstream. Commit d5440e27d3e5 ("xprtrdma: Enable pad optimization") made the Linux client omit XDR round-up padding in normal Read and Write chunks so that the client doesn't have to register and invalidate 3-byte memory regions that contain no real data. Unfortunately, my cheery 2014 assessment that this optimization "is supported now by both Linux and Solaris servers" was premature. We've found bugs in Solaris in this area since commit d5440e27d3e5 ("xprtrdma: Enable pad optimization") was merged (SYMLINK is the main offender). So for maximum interoperability, I'm disabling this optimization again. If a CM private message is exchanged when connecting, the client recognizes that the server is Linux, and enables the optimization for that connection. Until now the Solaris server bugs did not impact common operations, and were thus largely benign. Soon, less capable devices on Linux NFS/RDMA clients will make use of Read chunks more often, and these Solaris bugs will prevent interoperation in more cases. Fixes: 677eb17e94ed ("xprtrdma: Fix XDR tail buffer marshalling") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12xprtrdma: Per-connection pad optimizationChuck Lever
commit b5f0afbea4f2ea52c613ac2b06cb6de2ea18cb6d upstream. Pad optimization is changed by echoing into /proc/sys/sunrpc/rdma_pad_optimize. This is a global setting, affecting all RPC-over-RDMA connections to all servers. The marshaling code picks up that value and uses it for decisions about how to construct each RPC-over-RDMA frame. Having it change suddenly in mid-operation can result in unexpected failures. And some servers a client mounts might need chunk round-up, while others don't. So instead, copy the pad_optimize setting into each connection's rpcrdma_ia when the transport is created, and use the copy, which can't change during the life of the connection, instead. This also removes a hack: rpcrdma_convert_iovs was using the remote-invalidation-expected flag to predict when it could leave out Write chunk padding. This is because the Linux server handles implicit XDR padding on Write chunks correctly, and only Linux servers can set the connection's remote-invalidation-expected flag. It's more sensible to use the pad optimization setting instead. Fixes: 677eb17e94ed ("xprtrdma: Fix XDR tail buffer marshalling") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12xprtrdma: Fix Read chunk paddingChuck Lever
commit 24abdf1be15c478e2821d6fc903a4a4440beff02 upstream. When pad optimization is disabled, rpcrdma_convert_iovs still does not add explicit XDR round-up padding to a Read chunk. Commit 677eb17e94ed ("xprtrdma: Fix XDR tail buffer marshalling") incorrectly short-circuited the test for whether round-up padding is needed that appears later in rpcrdma_convert_iovs. However, if this is indeed a regular Read chunk (and not a Position-Zero Read chunk), the tail iovec _always_ contains the chunk's padding, and never anything else. So, it's easy to just skip the tail when padding optimization is enabled, and add the tail in a subsequent Read chunk segment, if disabled. Fixes: 677eb17e94ed ("xprtrdma: Fix XDR tail buffer marshalling") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09svcrpc: fix oops in absence of krb5 moduleJ. Bruce Fields
commit 034dd34ff4916ec1f8f74e39ca3efb04eab2f791 upstream. Olga Kornievskaia says: "I ran into this oops in the nfsd (below) (4.10-rc3 kernel). To trigger this I had a client (unsuccessfully) try to mount the server with krb5 where the server doesn't have the rpcsec_gss_krb5 module built." The problem is that rsci.cred is copied from a svc_cred structure that gss_proxy didn't properly initialize. Fix that. [120408.542387] general protection fault: 0000 [#1] SMP ... [120408.565724] CPU: 0 PID: 3601 Comm: nfsd Not tainted 4.10.0-rc3+ #16 [120408.567037] Hardware name: VMware, Inc. VMware Virtual = Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015 [120408.569225] task: ffff8800776f95c0 task.stack: ffffc90003d58000 [120408.570483] RIP: 0010:gss_mech_put+0xb/0x20 [auth_rpcgss] ... [120408.584946] ? rsc_free+0x55/0x90 [auth_rpcgss] [120408.585901] gss_proxy_save_rsc+0xb2/0x2a0 [auth_rpcgss] [120408.587017] svcauth_gss_proxy_init+0x3cc/0x520 [auth_rpcgss] [120408.588257] ? __enqueue_entity+0x6c/0x70 [120408.589101] svcauth_gss_accept+0x391/0xb90 [auth_rpcgss] [120408.590212] ? try_to_wake_up+0x4a/0x360 [120408.591036] ? wake_up_process+0x15/0x20 [120408.592093] ? svc_xprt_do_enqueue+0x12e/0x2d0 [sunrpc] [120408.593177] svc_authenticate+0xe1/0x100 [sunrpc] [120408.594168] svc_process_common+0x203/0x710 [sunrpc] [120408.595220] svc_process+0x105/0x1c0 [sunrpc] [120408.596278] nfsd+0xe9/0x160 [nfsd] [120408.597060] kthread+0x101/0x140 [120408.597734] ? nfsd_destroy+0x60/0x60 [nfsd] [120408.598626] ? kthread_park+0x90/0x90 [120408.599448] ret_from_fork+0x22/0x30 Fixes: 1d658336b05f "SUNRPC: Add RPC based upcall mechanism for RPCGSS auth" Cc: Simo Sorce <simo@redhat.com> Reported-by: Olga Kornievskaia <kolga@netapp.com> Tested-by: Olga Kornievskaia <kolga@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-01SUNRPC: cleanup ida information when removing sunrpc moduleKinglong Mee
commit c929ea0b910355e1876c64431f3d5802f95b3d75 upstream. After removing sunrpc module, I get many kmemleak information as, unreferenced object 0xffff88003316b1e0 (size 544): comm "gssproxy", pid 2148, jiffies 4294794465 (age 4200.081s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffffb0cfb58a>] kmemleak_alloc+0x4a/0xa0 [<ffffffffb03507fe>] kmem_cache_alloc+0x15e/0x1f0 [<ffffffffb0639baa>] ida_pre_get+0xaa/0x150 [<ffffffffb0639cfd>] ida_simple_get+0xad/0x180 [<ffffffffc06054fb>] nlmsvc_lookup_host+0x4ab/0x7f0 [lockd] [<ffffffffc0605e1d>] lockd+0x4d/0x270 [lockd] [<ffffffffc06061e5>] param_set_timeout+0x55/0x100 [lockd] [<ffffffffc06cba24>] svc_defer+0x114/0x3f0 [sunrpc] [<ffffffffc06cbbe7>] svc_defer+0x2d7/0x3f0 [sunrpc] [<ffffffffc06c71da>] rpc_show_info+0x8a/0x110 [sunrpc] [<ffffffffb044a33f>] proc_reg_write+0x7f/0xc0 [<ffffffffb038e41f>] __vfs_write+0xdf/0x3c0 [<ffffffffb0390f1f>] vfs_write+0xef/0x240 [<ffffffffb0392fbd>] SyS_write+0xad/0x130 [<ffffffffb0d06c37>] entry_SYSCALL_64_fastpath+0x1a/0xa9 [<ffffffffffffffff>] 0xffffffffffffffff I found, the ida information (dynamic memory) isn't cleanup. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Fixes: 2f048db4680a ("SUNRPC: Add an identifier for struct rpc_clnt") Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26xprtrdma: Squelch "max send, max recv" messages at connect timeChuck Lever
commit 6d6bf72de914059b304f7b99530a7856e5c846aa upstream. Clean up: This message was intended to be a dprintk, as it is on the server-side. Fixes: 87cfb9a0c85c ('xprtrdma: Client-side support for ...') Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26xprtrdma: Make FRWR send queue entry accounting more accurateChuck Lever
commit 8d38de65644d900199f035277aa5f3da4aa9fc17 upstream. Verbs providers may perform house-keeping on the Send Queue during each signaled send completion. It is necessary therefore for a verbs consumer (like xprtrdma) to occasionally force a signaled send completion if it runs unsignaled most of the time. xprtrdma does not require signaled completions for Send or FastReg Work Requests, but does signal some LocalInv Work Requests. To ensure that Send Queue house-keeping can run before the Send Queue is more than half-consumed, xprtrdma forces a signaled completion on occasion by counting the number of Send Queue Entries it consumes. It currently does this by counting each ib_post_send as one Entry. Commit c9918ff56dfb ("xprtrdma: Add ro_unmap_sync method for FRWR") introduced the ability for frwr_op_unmap_sync to post more than one Work Request with a single post_send. Thus the underlying assumption of one Send Queue Entry per ib_post_send is no longer true. Also, FastReg Work Requests are currently never signaled. They should be signaled once in a while, just as Send is, to keep the accounting of consumed SQEs accurate. While we're here, convert the CQCOUNT macros to the currently preferred kernel coding style, which is inline functions. Fixes: c9918ff56dfb ("xprtrdma: Add ro_unmap_sync method for FRWR") Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26svcrdma: avoid duplicate dma unmapping during error recoverySriharsha Basavapatna
commit ce1ca7d2d140a1f4aaffd297ac487f246963dd2f upstream. In rdma_read_chunk_frmr() when ib_post_send() fails, the error code path invokes ib_dma_unmap_sg() to unmap the sg list. It then invokes svc_rdma_put_frmr() which in turn tries to unmap the same sg list through ib_dma_unmap_sg() again. This second unmap is invalid and could lead to problems when the iova being unmapped is subsequently reused. Remove the call to unmap in rdma_read_chunk_frmr() and let svc_rdma_put_frmr() handle it. Fixes: 412a15c0fe53 ("svcrdma: Port to new memory registration API") Signed-off-by: Sriharsha Basavapatna <sriharsha.basavapatna@broadcom.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Yuval Shaia <yuval.shaia@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26svcrpc: don't leak contexts on PROC_DESTROYJ. Bruce Fields
commit 78794d1890708cf94e3961261e52dcec2cc34722 upstream. Context expiry times are in units of seconds since boot, not unix time. The use of get_seconds() here therefore sets the expiry time decades in the future. This prevents timely freeing of contexts destroyed by client RPC_GSS_PROC_DESTROY requests. We'd still free them eventually (when the module is unloaded or the container shut down), but a lot of contexts could pile up before then. Fixes: c5b29f885afe "sunrpc: use seconds since boot in expiry cache" Reported-by: Andy Adamson <andros@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-26sunrpc: don't call sleeping functions from the notifier block callbacksScott Mayhew
commit 546125d1614264d26080817d0c8cddb9b25081fa upstream. The inet6addr_chain is an atomic notifier chain, so we can't call anything that might sleep (like lock_sock)... instead of closing the socket from svc_age_temp_xprts_now (which is called by the notifier function), just have the rpc service threads do it instead. Fixes: c3d4879e01be "sunrpc: Add a function to close..." Signed-off-by: Scott Mayhew <smayhew@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-15svcrdma: Clear xpt_bc_xps in xprt_setup_rdma_bc() error exit armChuck Lever
commit 1b9f700b8cfc31089e2dfa5d0905c52fd4529b50 upstream. Logic copied from xs_setup_bc_tcp(). Fixes: 39a9beab5acb ('rpc: share one xps between all backchannels') Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09SUNRPC: fix refcounting problems with auth_gss messages.NeilBrown
commit 1cded9d2974fe4fe339fc0ccd6638b80d465ab2c upstream. There are two problems with refcounting of auth_gss messages. First, the reference on the pipe->pipe list (taken by a call to rpc_queue_upcall()) is not counted. It seems to be assumed that a message in pipe->pipe will always also be in pipe->in_downcall, where it is correctly reference counted. However there is no guaranty of this. I have a report of a NULL dereferences in rpc_pipe_read() which suggests a msg that has been freed is still on the pipe->pipe list. One way I imagine this might happen is: - message is queued for uid=U and auth->service=S1 - rpc.gssd reads this message and starts processing. This removes the message from pipe->pipe - message is queued for uid=U and auth->service=S2 - rpc.gssd replies to the first message. gss_pipe_downcall() calls __gss_find_upcall(pipe, U, NULL) and it finds the *second* message, as new messages are placed at the head of ->in_downcall, and the service type is not checked. - This second message is removed from ->in_downcall and freed by gss_release_msg() (even though it is still on pipe->pipe) - rpc.gssd tries to read another message, and dereferences a pointer to this message that has just been freed. I fix this by incrementing the reference count before calling rpc_queue_upcall(), and decrementing it if that fails, or normally in gss_pipe_destroy_msg(). It seems strange that the reply doesn't target the message more precisely, but I don't know all the details. In any case, I think the reference counting irregularity became a measureable bug when the extra arg was added to __gss_find_upcall(), hence the Fixes: line below. The second problem is that if rpc_queue_upcall() fails, the new message is not freed. gss_alloc_msg() set the ->count to 1, gss_add_msg() increments this to 2, gss_unhash_msg() decrements to 1, then the pointer is discarded so the memory never gets freed. Fixes: 9130b8dbc6ac ("SUNRPC: allow for upcalls for same uid but different gss service") Link: https://bugzilla.opensuse.org/show_bug.cgi?id=1011250 Signed-off-by: NeilBrown <neilb@suse.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-18Merge tag 'nfsd-4.9-2' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd bugfix from Bruce Fields: "Just one fix for an NFS/RDMA crash" * tag 'nfsd-4.9-2' of git://linux-nfs.org/~bfields/linux: sunrpc: svc_age_temp_xprts_now should not call setsockopt non-tcp transports
2016-11-14sunrpc: svc_age_temp_xprts_now should not call setsockopt non-tcp transportsScott Mayhew
This fixes the following panic that can occur with NFSoRDMA. general protection fault: 0000 [#1] SMP Modules linked in: rpcrdma ib_isert iscsi_target_mod ib_iser libiscsi scsi_transport_iscsi ib_srpt target_core_mod ib_srp scsi_transport_srp scsi_tgt ib_ipoib rdma_ucm ib_ucm ib_uverbs ib_umad rdma_cm ib_cm iw_cm mlx5_ib ib_core intel_powerclamp coretemp kvm_intel kvm sg ioatdma ipmi_devintf ipmi_ssif dcdbas iTCO_wdt iTCO_vendor_support pcspkr irqbypass sb_edac shpchp dca crc32_pclmul ghash_clmulni_intel edac_core lpc_ich aesni_intel lrw gf128mul glue_helper ablk_helper mei_me mei ipmi_si cryptd wmi ipmi_msghandler acpi_pad acpi_power_meter nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sd_mod crc_t10dif crct10dif_generic mgag200 i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt ahci fb_sys_fops ttm libahci mlx5_core tg3 crct10dif_pclmul drm crct10dif_common ptp i2c_core libata crc32c_intel pps_core fjes dm_mirror dm_region_hash dm_log dm_mod CPU: 1 PID: 120 Comm: kworker/1:1 Not tainted 3.10.0-514.el7.x86_64 #1 Hardware name: Dell Inc. PowerEdge R320/0KM5PX, BIOS 2.4.2 01/29/2015 Workqueue: events check_lifetime task: ffff88031f506dd0 ti: ffff88031f584000 task.ti: ffff88031f584000 RIP: 0010:[<ffffffff8168d847>] [<ffffffff8168d847>] _raw_spin_lock_bh+0x17/0x50 RSP: 0018:ffff88031f587ba8 EFLAGS: 00010206 RAX: 0000000000020000 RBX: 20041fac02080072 RCX: ffff88031f587fd8 RDX: 0000000000000000 RSI: 0000000000000000 RDI: 20041fac02080072 RBP: ffff88031f587bb0 R08: 0000000000000008 R09: ffffffff8155be77 R10: ffff880322a59b00 R11: ffffea000bf39f00 R12: 20041fac02080072 R13: 000000000000000d R14: ffff8800c4fbd800 R15: 0000000000000001 FS: 0000000000000000(0000) GS:ffff880322a40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f3c52d4547e CR3: 00000000019ba000 CR4: 00000000001407e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: 20041fac02080002 ffff88031f587bd0 ffffffff81557830 20041fac02080002 ffff88031f587c78 ffff88031f587c40 ffffffff8155ae08 000000010157df32 0000000800000001 ffff88031f587c20 ffffffff81096acb ffffffff81aa37d0 Call Trace: [<ffffffff81557830>] lock_sock_nested+0x20/0x50 [<ffffffff8155ae08>] sock_setsockopt+0x78/0x940 [<ffffffff81096acb>] ? lock_timer_base.isra.33+0x2b/0x50 [<ffffffff8155397d>] kernel_setsockopt+0x4d/0x50 [<ffffffffa0386284>] svc_age_temp_xprts_now+0x174/0x1e0 [sunrpc] [<ffffffffa03b681d>] nfsd_inetaddr_event+0x9d/0xd0 [nfsd] [<ffffffff81691ebc>] notifier_call_chain+0x4c/0x70 [<ffffffff810b687d>] __blocking_notifier_call_chain+0x4d/0x70 [<ffffffff810b68b6>] blocking_notifier_call_chain+0x16/0x20 [<ffffffff815e8538>] __inet_del_ifa+0x168/0x2d0 [<ffffffff815e8cef>] check_lifetime+0x25f/0x270 [<ffffffff810a7f3b>] process_one_work+0x17b/0x470 [<ffffffff810a8d76>] worker_thread+0x126/0x410 [<ffffffff810a8c50>] ? rescuer_thread+0x460/0x460 [<ffffffff810b052f>] kthread+0xcf/0xe0 [<ffffffff810b0460>] ? kthread_create_on_node+0x140/0x140 [<ffffffff81696418>] ret_from_fork+0x58/0x90 [<ffffffff810b0460>] ? kthread_create_on_node+0x140/0x140 Code: ca 75 f1 5d c3 0f 1f 80 00 00 00 00 eb d9 66 0f 1f 44 00 00 0f 1f 44 00 00 55 48 89 e5 53 48 89 fb e8 7e 04 a0 ff b8 00 00 02 00 <f0> 0f c1 03 89 c2 c1 ea 10 66 39 c2 75 03 5b 5d c3 83 e2 fe 0f RIP [<ffffffff8168d847>] _raw_spin_lock_bh+0x17/0x50 RSP <ffff88031f587ba8> Signed-off-by: Scott Mayhew <smayhew@redhat.com> Fixes: c3d4879e ("sunrpc: Add a function to close temporary transports immediately") Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-11-11Merge tag 'nfs-for-4.9-3' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Anna Schumaker: "Most of these fix regressions in 4.9, and none are going to stable this time around. Bugfixes: - Trim extra slashes in v4 nfs_paths to fix tools that use this - Fix a -Wmaybe-uninitialized warnings - Fix suspicious RCU usages - Fix Oops when mounting multiple servers at once - Suppress a false-positive pNFS error - Fix a DMAR failure in NFS over RDMA" * tag 'nfs-for-4.9-3' of git://git.linux-nfs.org/projects/anna/linux-nfs: xprtrdma: Fix DMAR failure in frwr_op_map() after reconnect fs/nfs: Fix used uninitialized warn in nfs4_slot_seqid_in_use() NFS: Don't print a pNFS error if we aren't using pNFS NFS: Ignore connections that have cl_rpcclient uninitialized SUNRPC: Fix suspicious RCU usage NFSv4.1: work around -Wmaybe-uninitialized warning NFS: Trim extra slash in v4 nfs_path
2016-11-10xprtrdma: Fix DMAR failure in frwr_op_map() after reconnectChuck Lever
When a LOCALINV WR is flushed, the frmr is marked STALE, then frwr_op_unmap_sync DMA-unmaps the frmr's SGL. These STALE frmrs are then recovered when frwr_op_map hunts for an INVALID frmr to use. All other cases that need frmr recovery leave that SGL DMA-mapped. The FRMR recovery path unconditionally DMA-unmaps the frmr's SGL. To avoid DMA unmapping the SGL twice for flushed LOCAL_INV WRs, alter the recovery logic (rather than the hot frwr_op_unmap_sync path) to distinguish among these cases. This solution also takes care of the case where multiple LOCAL_INV WRs are issued for the same rpcrdma_req, some complete successfully, but some are flushed. Reported-by: Vasco Steinmetz <linux@kyberraum.net> Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: Vasco Steinmetz <linux@kyberraum.net> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-11-07SUNRPC: Fix suspicious RCU usageAnna Schumaker
We need to hold the rcu_read_lock() when calling rcu_dereference(), otherwise we can't guarantee that the object being dereferenced still exists. Fixes: 39e5d2df ("SUNRPC search xprt switch for sockaddr") Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-11-01svcrdma: backchannel cannot share a page for send and rcv buffersChuck Lever
The underlying transport releases the page pointed to by rq_buffer during xprt_rdma_bc_send_request. When the backchannel reply arrives, rq_rbuffer then points to freed memory. Fixes: 68778945e46f ('SUNRPC: Separate buffer pointers for RPC ...') Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Cc: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-10-28sunrpc: fix some missing rq_rbuffer assignmentsJeff Layton
We've been seeing some crashes in testing that look like this: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff8135ce99>] memcpy_orig+0x29/0x110 PGD 212ca2067 PUD 212ca3067 PMD 0 Oops: 0002 [#1] SMP Modules linked in: rpcsec_gss_krb5 nfsv4 dns_resolver nfs fscache ppdev parport_pc i2c_piix4 sg parport i2c_core virtio_balloon pcspkr acpi_cpufreq nfsd auth_rpcgss nfs_acl lockd grace sunrpc ip_tables xfs libcrc32c sd_mod ata_generic pata_acpi virtio_scsi 8139too ata_piix libata 8139cp mii virtio_pci floppy virtio_ring serio_raw virtio CPU: 1 PID: 1540 Comm: nfsd Not tainted 4.9.0-rc1 #39 Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2007 task: ffff88020d7ed200 task.stack: ffff880211838000 RIP: 0010:[<ffffffff8135ce99>] [<ffffffff8135ce99>] memcpy_orig+0x29/0x110 RSP: 0018:ffff88021183bdd0 EFLAGS: 00010206 RAX: 0000000000000000 RBX: ffff88020d7fa000 RCX: 000000f400000000 RDX: 0000000000000014 RSI: ffff880212927020 RDI: 0000000000000000 RBP: ffff88021183be30 R08: 01000000ef896996 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: ffff880211704ca8 R13: ffff88021473f000 R14: 00000000ef896996 R15: ffff880211704800 FS: 0000000000000000(0000) GS:ffff88021fc80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 0000000212ca1000 CR4: 00000000000006e0 Stack: ffffffffa01ea087 ffffffff63400001 ffff880215145e00 ffff880211bacd00 ffff88021473f2b8 0000000000000004 00000000d0679d67 ffff880211bacd00 ffff88020d7fa000 ffff88021473f000 0000000000000000 ffff88020d7faa30 Call Trace: [<ffffffffa01ea087>] ? svc_tcp_recvfrom+0x5a7/0x790 [sunrpc] [<ffffffffa01f84d8>] svc_recv+0xad8/0xbd0 [sunrpc] [<ffffffffa0262d5e>] nfsd+0xde/0x160 [nfsd] [<ffffffffa0262c80>] ? nfsd_destroy+0x60/0x60 [nfsd] [<ffffffff810a9418>] kthread+0xd8/0xf0 [<ffffffff816dbdbf>] ret_from_fork+0x1f/0x40 [<ffffffff810a9340>] ? kthread_park+0x60/0x60 Code: 00 00 48 89 f8 48 83 fa 20 72 7e 40 38 fe 7c 35 48 83 ea 20 48 83 ea 20 4c 8b 06 4c 8b 4e 08 4c 8b 56 10 4c 8b 5e 18 48 8d 76 20 <4c> 89 07 4c 89 4f 08 4c 89 57 10 4c 89 5f 18 48 8d 7f 20 73 d4 RIP [<ffffffff8135ce99>] memcpy_orig+0x29/0x110 RSP <ffff88021183bdd0> CR2: 0000000000000000 Both Bruce and Eryu ran a bisect here and found that the problematic patch was 68778945e46 (SUNRPC: Separate buffer pointers for RPC Call and Reply messages). That patch changed rpc_xdr_encode to use a new rq_rbuffer pointer to set up the receive buffer, but didn't change all of the necessary codepaths to set it properly. In particular the backchannel setup was missing. We need to set rq_rbuffer whenever rq_buffer is set. Ensure that it is. Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Tested-by: Chuck Lever <chuck.lever@oracle.com> Reported-by: Eryu Guan <guaneryu@gmail.com> Tested-by: Eryu Guan <guaneryu@gmail.com> Fixes: 68778945e46 "SUNRPC: Separate buffer pointers..." Reported-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-10-26sunrpc: don't pass on-stack memory to sg_set_bufJ. Bruce Fields
As of ac4e97abce9b "scatterlist: sg_set_buf() argument must be in linear mapping", sg_set_buf hits a BUG when make_checksum_v2->xdr_process_buf, among other callers, passes it memory on the stack. We only need a scatterlist to pass this to the crypto code, and it seems like overkill to require kmalloc'd memory just to encrypt a few bytes, but for now this seems the best fix. Many of these callers are in the NFS write paths, so we allocate with GFP_NOFS. It might be possible to do without allocations here entirely, but that would probably be a bigger project. Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-10-13Merge tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client updates from Anna Schumaker: "Highlights include: Stable bugfixes: - sunrpc: fix writ espace race causing stalls - NFS: Fix inode corruption in nfs_prime_dcache() - NFSv4: Don't report revoked delegations as valid in nfs_have_delegation() - NFSv4: nfs4_copy_delegation_stateid() must fail if the delegation is invalid - NFSv4: Open state recovery must account for file permission changes - NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic Features: - Add support for tracking multiple layout types with an ordered list - Add support for using multiple backchannel threads on the client - Add support for pNFS file layout session trunking - Delay xprtrdma use of DMA API (for device driver removal) - Add support for xprtrdma remote invalidation - Add support for larger xprtrdma inline thresholds - Use a scatter/gather list for sending xprtrdma RPC calls - Add support for the CB_NOTIFY_LOCK callback - Improve hashing sunrpc auth_creds by using both uid and gid Bugfixes: - Fix xprtrdma use of DMA API - Validate filenames before adding to the dcache - Fix corruption of xdr->nwords in xdr_copy_to_scratch - Fix setting buffer length in xdr_set_next_buffer() - Don't deadlock the state manager on the SEQUENCE status flags - Various delegation and stateid related fixes - Retry operations if an interrupted slot receives EREMOTEIO - Make nfs boot time y2038 safe" * tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (100 commits) NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic fs: nfs: Make nfs boot time y2038 safe sunrpc: replace generic auth_cred hash with auth-specific function sunrpc: add RPCSEC_GSS hash_cred() function sunrpc: add auth_unix hash_cred() function sunrpc: add generic_auth hash_cred() function sunrpc: add hash_cred() function to rpc_authops struct Retry operation on EREMOTEIO on an interrupted slot pNFS: Fix atime updates on pNFS clients sunrpc: queue work on system_power_efficient_wq NFSv4.1: Even if the stateid is OK, we may need to recover the open modes NFSv4: If recovery failed for a specific open stateid, then don't retry NFSv4: Fix retry issues with nfs41_test/free_stateid NFSv4: Open state recovery must account for file permission changes NFSv4: Mark the lock and open stateids as invalid after freeing them NFSv4: Don't test open_stateid unless it is set NFSv4: nfs4_do_handle_exception() handle revoke/expiry of a single stateid NFS: Always call nfs_inode_find_state_and_recover() when revoking a delegation NFSv4: Fix a race when updating an open_stateid NFSv4: Fix a race in nfs_inode_reclaim_delegation() ...
2016-10-13Merge tag 'nfsd-4.9' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Some RDMA work and some good bugfixes, and two new features that could benefit from user testing: - Anna Schumacker contributed a simple NFSv4.2 COPY implementation. COPY is already supported on the client side, so a call to copy_file_range() on a recent client should now result in a server-side copy that doesn't require all the data to make a round trip to the client and back. - Jeff Layton implemented callbacks to notify clients when contended locks become available, which should reduce latency on workloads with contended locks" * tag 'nfsd-4.9' of git://linux-nfs.org/~bfields/linux: NFSD: Implement the COPY call nfsd: handle EUCLEAN nfsd: only WARN once on unmapped errors exportfs: be careful to only return expected errors. nfsd4: setclientid_confirm with unmatched verifier should fail nfsd: randomize SETCLIENTID reply to help distinguish servers nfsd: set the MAY_NOTIFY_LOCK flag in OPEN replies nfs: add a new NFS4_OPEN_RESULT_MAY_NOTIFY_LOCK constant nfsd: add a LRU list for blocked locks nfsd: have nfsd4_lock use blocking locks for v4.1+ locks nfsd: plumb in a CB_NOTIFY_LOCK operation NFSD: fix corruption in notifier registration svcrdma: support Remote Invalidation svcrdma: Server-side support for rpcrdma_connect_private rpcrdma: RDMA/CM private message data structure svcrdma: Skip put_page() when send_reply() fails svcrdma: Tail iovec leaves an orphaned DMA mapping nfsd: fix dprintk in nfsd4_encode_getdeviceinfo nfsd: eliminate cb_minorversion field nfsd: don't set a FL_LAYOUT lease for flexfiles layouts
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-10-09Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull main rdma updates from Doug Ledford: "This is the main pull request for the rdma stack this release. The code has been through 0day and I had it tagged for linux-next testing for a couple days. Summary: - updates to mlx5 - updates to mlx4 (two conflicts, both minor and easily resolved) - updates to iw_cxgb4 (one conflict, not so obvious to resolve, proper resolution is to keep the code in cxgb4_main.c as it is in Linus' tree as attach_uld was refactored and moved into cxgb4_uld.c) - improvements to uAPI (moved vendor specific API elements to uAPI area) - add hns-roce driver and hns and hns-roce ACPI reset support - conversion of all rdma code away from deprecated create_singlethread_workqueue - security improvement: remove unsafe ib_get_dma_mr (breaks lustre in staging)" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (75 commits) staging/lustre: Disable InfiniBand support iw_cxgb4: add fast-path for small REG_MR operations cxgb4: advertise support for FR_NSMR_TPTE_WR IB/core: correctly handle rdma_rw_init_mrs() failure IB/srp: Fix infinite loop when FMR sg[0].offset != 0 IB/srp: Remove an unused argument IB/core: Improve ib_map_mr_sg() documentation IB/mlx4: Fix possible vl/sl field mismatch in LRH header in QP1 packets IB/mthca: Move user vendor structures IB/nes: Move user vendor structures IB/ocrdma: Move user vendor structures IB/mlx4: Move user vendor structures IB/cxgb4: Move user vendor structures IB/cxgb3: Move user vendor structures IB/mlx5: Move and decouple user vendor structures IB/{core,hw}: Add constant for node_desc ipoib: Make ipoib_warn ratelimited IB/mlx4/alias_GUID: Remove deprecated create_singlethread_workqueue IB/ipoib_verbs: Remove deprecated create_singlethread_workqueue IB/ipoib: Remove deprecated create_singlethread_workqueue ...
2016-10-07cred: simpler, 1D supplementary groupsAlexey Dobriyan
Current supplementary groups code can massively overallocate memory and is implemented in a way so that access to individual gid is done via 2D array. If number of gids is <= 32, memory allocation is more or less tolerable (140/148 bytes). But if it is not, code allocates full page (!) regardless and, what's even more fun, doesn't reuse small 32-entry array. 2D array means dependent shifts, loads and LEAs without possibility to optimize them (gid is never known at compile time). All of the above is unnecessary. Switch to the usual trailing-zero-len-array scheme. Memory is allocated with kmalloc/vmalloc() and only as much as needed. Accesses become simpler (LEA 8(gi,idx,4) or even without displacement). Maximum number of gids is 65536 which translates to 256KB+8 bytes. I think kernel can handle such allocation. On my usual desktop system with whole 9 (nine) aux groups, struct group_info shrinks from 148 bytes to 44 bytes, yay! Nice side effects: - "gi->gid[i]" is shorter than "GROUP_AT(gi, i)", less typing, - fix little mess in net/ipv4/ping.c should have been using GROUP_AT macro but this point becomes moot, - aux group allocation is persistent and should be accounted as such. Link: http://lkml.kernel.org/r/20160817201927.GA2096@p183.telecom.by Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Vasily Kulikov <segoon@openwall.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-30sunrpc: replace generic auth_cred hash with auth-specific functionFrank Sorenson
Replace the generic code to hash the auth_cred with the call to the auth-specific hash function in the rpc_authops struct. Signed-off-by: Frank Sorenson <sorenson@redhat.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-09-30sunrpc: add RPCSEC_GSS hash_cred() functionFrank Sorenson
Add a hash_cred() function for RPCSEC_GSS, using only the uid from the auth_cred. Signed-off-by: Frank Sorenson <sorenson@redhat.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-09-30sunrpc: add auth_unix hash_cred() functionFrank Sorenson
Add a hash_cred() function for auth_unix, using both the uid and gid from the auth_cred. Signed-off-by: Frank Sorenson <sorenson@redhat.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-09-30sunrpc: add generic_auth hash_cred() functionFrank Sorenson
Add a hash_cred() function for generic_auth, using both the uid and gid from the auth_cred. Signed-off-by: Frank Sorenson <sorenson@redhat.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-09-27fs: Replace CURRENT_TIME with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_time() instead. CURRENT_TIME is also not y2038 safe. This is also in preparation for the patch that transitions vfs timestamps to use 64 bit time and hence make them y2038 safe. As part of the effort current_time() will be extended to do range checks. Hence, it is necessary for all file system timestamps to use current_time(). Also, current_time() will be transitioned along with vfs to be y2038 safe. Note that whenever a single call to current_time() is used to change timestamps in different inodes, it is because they share the same time granularity. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Felipe Balbi <balbi@kernel.org> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27sunrpc: queue work on system_power_efficient_wqKe Wang
sunrpc uses workqueue to clean cache regulary. There is no real dependency of executing work on the cpu which queueing it. On a idle system, especially for a heterogeneous systems like big.LITTLE, it is observed that the big idle cpu was woke up many times just to service this work, which against the principle of power saving. It would be better if we can schedule it on a cpu which the scheduler believes to be the most appropriate one. After apply this patch, system_wq will be replaced by system_power_efficient_wq for sunrpc. This functionality is enabled when CONFIG_WQ_POWER_EFFICIENT is selected. Signed-off-by: Ke Wang <ke.wang@spreadtrum.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-09-23IB/core: add support to create a unsafe global rkey to ib_create_pdChristoph Hellwig
Instead of exposing ib_get_dma_mr to ULPs and letting them use it more or less unchecked, this moves the capability of creating a global rkey into the RDMA core, where it can be easily audited. It also prints a warning everytime this feature is used as well. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
