When comparing uids use uid_eq instead of ==.
When comparing gids use gid_eq instead of ==.
And unfortunate cost of type safety.
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Convert variables that store uids and gids to be of type
kuid_t and kgid_t instead of type uid_t and gid_t.
Instead of (uid_t)0 use GLOBAL_ROOT_UID.
Instead of (gid_t)0 use GLOBAL_ROOT_GID.
Instead of (uid_t)-1 use INVALID_UID
Instead of (gid_t)-1 use INVALID_GID.
Instead of NOGROUP use INVALID_GID.
Introduce ipv6_addr_hash() helper doing a XOR on all bits
of an IPv6 address, with an optimized x86_64 version.
Use it in flow dissector, as suggested by Andrew McGregor,
to reduce hash collision probabilities in fq_codel (and other
users of flow dissector)
Use it in ip6_tunnel.c and use more bit shuffling, as suggested
by David Laight, as existing hash was ignoring most of them.
Use it in sunrpc and use more bit shuffling, using hash_32().
Use it in net/ipv6/addrconf.c, using hash_32() as well.
As a cleanup, use it in net/ipv4/tcp_metrics.c
Reported-by: Andrew McGregor <andrewmcgr@gmail.com>
Cc: Dave Taht <dave.taht@gmail.com>
Cc: Tom Herbert <therbert@google.com>
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Joe Perches <joe@perches.com>
Pull the rest of the nfsd commits from Bruce Fields:
"... and then I cherry-picked the remainder of the patches from the
head of my previous branch"
This is the rest of the original nfsd branch, rebased without the
delegation stuff that I thought really needed to be redone.
I don't like rebasing things like this in general, but in this situation
this was the lesser of two evils.
* 'for-3.5' of git://linux-nfs.org/~bfields/linux: (50 commits)
nfsd4: fix, consolidate client_has_state
nfsd4: don't remove rebooted client record until confirmation
nfsd4: remove some dprintk's and a comment
nfsd4: return "real" sequence id in confirmed case
nfsd4: fix exchange_id to return confirm flag
nfsd4: clarify that renewing expired client is a bug
nfsd4: simpler ordering of setclientid_confirm checks
nfsd4: setclientid: remove pointless assignment
nfsd4: fix error return in non-matching-creds case
nfsd4: fix setclientid_confirm same_cred check
nfsd4: merge 3 setclientid cases to 2
nfsd4: pull out common code from setclientid cases
nfsd4: merge last two setclientid cases
nfsd4: setclientid/confirm comment cleanup
nfsd4: setclientid remove unnecessary terms from a logical expression
nfsd4: move rq_flavor into svc_cred
nfsd4: stricter cred comparison for setclientid/exchange_id
nfsd4: move principal name into svc_cred
nfsd4: allow removing clients not holding state
nfsd4: rearrange exchange_id logic to simplify
Pull nfsd update from Bruce Fields.
* 'for-3.5-take-2' of git://linux-nfs.org/~bfields/linux: (23 commits)
nfsd: trivial: use SEEK_SET instead of 0 in vfs_llseek
SUNRPC: split upcall function to extract reusable parts
nfsd: allocate id-to-name and name-to-id caches in per-net operations.
nfsd: make name-to-id cache allocated per network namespace context
nfsd: make id-to-name cache allocated per network namespace context
nfsd: pass network context to idmap init/exit functions
nfsd: allocate export and expkey caches in per-net operations.
nfsd: make expkey cache allocated per network namespace context
nfsd: make export cache allocated per network namespace context
nfsd: pass pointer to export cache down to stack wherever possible.
nfsd: pass network context to export caches init/shutdown routines
Lockd: pass network namespace to creation and destruction routines
NFSd: remove hard-coded dereferences to name-to-id and id-to-name caches
nfsd: pass pointer to expkey cache down to stack wherever possible.
nfsd: use hash table from cache detail in nfsd export seq ops
nfsd: pass svc_export_cache pointer as private data to "exports" seq file ops
nfsd: use exp_put() for svc_export_cache put
nfsd: use cache detail pointer from svc_export structure on cache put
nfsd: add link to owner cache detail to svc_export structure
nfsd: use passed cache_detail pointer expkey_parse()
Move the rq_flavor into struct svc_cred, and use it in setclientid and
exchange_id comparisons as well.
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Instead of keeping the principal name associated with a request in a
structure that's private to auth_gss and using an accessor function,
move it to svc_cred.
As a first step to converting struct cred to be all kuid_t and kgid_t
values convert the group values stored in group_info to always be
kgid_t values. Unless user namespaces are used this change should
have no effect.
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
This patch also changes svcauth_unix_purge() function: added network namespace
as a parameter and thus loop over all networks was replaced by only one call
for ip map cache purge.
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
The nfs containerization work is a prerequisite for Jeff Layton's reboot
recovery rework.
We check for zero length strings in the caller now, so these aren't
needed.
This patch converts ip_map_cache per network namespace implemenetation to the
same view, as other caches done in the series.
Besides generalization, code becomes shorter with this patch.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: J. Bruce Fields <bfields@redhat.com>
v2:
1) fixed silly usage of template cache as a real one (this code left from
static global cache for all)
This patch makes unix_gid_cache cache detail allocated and registered per
network namespace context.
Thus with this patch unix_gid_cache contents for network namespace "X" are
controlled from proc file system mount for the same network namespace "X".
Parametrize rpc_pton() by network context and thus force it's callers to pass
in network context instead of using hard-coded "init_net".
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE)
C assignment can handle struct in6_addr copying.
Like svcauth_unix, the symbol svcauth_null is used external from this
file. Declare it as extern to quiet the following sparse noise:
warning: symbol 'svcauth_null' was not declared. Should it be static?
Cc: Neil Brown <neilb@suse.de>
As promised in feature-removal-schedule.txt it is time to
remove the nfsctl system call.
Userspace has perferred to not use this call throughout 2.6 and it has been
excluded in the default configuration since 2.6.36 (9 months ago).
So this patch removes all the code that was being compiled out.
There are still references to sys_nfsctl in various arch systemcall tables
and related code. These should be cleaned out too, probably in the next
merge window.
Signed-off-by: NeilBrown <neilb@suse.de>
"After merging the nfsd tree, today's linux-next build (powerpc
ppc64_defconfig) produced this warning:
net/sunrpc/svcauth_unix.c: In function 'unix_domain_find':
net/sunrpc/svcauth_unix.c:58: warning: passing argument 1 of
+'svcauth_unix_domain_release' from incompatible pointer type
net/sunrpc/svcauth_unix.c:41: note: expected 'struct auth_domain *' but
argument
+is of type 'struct unix_domain *'
Introduced by commit 8b3e07ac908d ("svcrpc: fix rare race on unix_domain
creation")."
Note that "new" here is not yet fully initialized; auth_domain_put
should be called only on auth_domains that have actually been added to
the hash.
Before this fix, two attempts to add the same domain at once could
cause the hlist_del in auth_domain_put to fail.
[bfields@redhat.com: moved svcauth_unix_purge outside ifdef's.]
Once a sunrpc cache entry is VALID, we should be replacing it (and
allowing any concurrent users to destroy it on last put) instead of
trying to update it in place.
Otherwise someone referencing the ip_map we're modifying here could try
to use the m_client just as we're putting the last reference.
The bug should only be seen by users of the legacy nfsd interfaces.
(Thanks to Neil for suggestion to use sunrpc_invalidate.)
Reviewed-by: NeilBrown <neilb@suse.de>
These macros never be used for several years.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Everything that is required for that already exists:
* the per-net cache registration with respective proc entries
* the context (struct net) is available in all the users
There are two calls that operate on ip_map_cache and are
directly called from the nfsd code. Other places will be
handled in a different way.
They do not require the rqst actually and having the xprt simplifies
further patching.
This is done in order to facilitate getting the ip_map_cache from
which to put the ip_map.
The target is to have many ip_map_cache-s in the system. This particular
patch handles its usage by the ip_map_parse callback.
If we drop a request in the sunrpc layer, either due kmalloc failure,
or due to a cache miss when we could not queue the request for later
replay, then close the connection to encourage the client to retry sooner.
Note that if the drop happens in the NFS layer, NFSERR_JUKEBOX
(aka NFS4ERR_DELAY) is returned to guide the client concerning
replay.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
We should consistently treat uid's as unsigned--it's confusing when
the display of uid's in the cache contents isn't consistent with their
representation in upcalls.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
The existing logic in ip_map_parse() can not currently parse
shorthanded IPv6 addresses (anything with a double colon), nor can
it parse an IPv6 presentation address with a scope ID. An
IPv6-enabled mountd can pass down both.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
* 'for-2.6.33' of git://linux-nfs.org/~bfields/linux: (42 commits)
nfsd: remove pointless paths in file headers
nfsd: move most of nfsfh.h to fs/nfsd
nfsd: remove unused field rq_reffh
nfsd: enable V4ROOT exports
nfsd: make V4ROOT exports read-only
nfsd: restrict filehandles accepted in V4ROOT case
nfsd: allow exports of symlinks
nfsd: filter readdir results in V4ROOT case
nfsd: filter lookup results in V4ROOT case
nfsd4: don't continue "under" mounts in V4ROOT case
nfsd: introduce export flag for v4 pseudoroot
nfsd: let "insecure" flag vary by pseudoflavor
nfsd: new interface to advertise export features
nfsd: Move private headers to source directory
vfs: nfsctl.c un-used nfsd #includes
lockd: Remove un-used nfsd headers #includes
s390: remove un-used nfsd #includes
sparc: remove un-used nfsd #includes
parsic: remove un-used nfsd #includes
compat.c: Remove dependence on nfsd private headers
Not including net/atm/
Compiled tested x86 allyesconfig only
Added a > 80 column line or two, which I ignored.
Existing checkpatch plaints willfully, cheerfully ignored.
For nfsd we provide users the option of mapping uid's to server-side
supplementary group lists. That makes sense for nfsd, but not
necessarily for other rpc users (such as the callback client).
So move that lookup to svcauth_unix_set_client, which is a
program-specific method.
Might as well use the ipv6_addr_set_v4mapped() inline we created last
year.
Signed-off-by: Brian Haley <brian.haley@hp.com>
git://git.linux-nfs.org/projects/trondmy/nfs-2.6 into for-2.6.32-incoming
net/sunrpc/cache.c
For events that are rare, such as referral DNS lookups, it makes limited
sense to have a daemon constantly listening for upcalls on a channel. An
alternative in those cases might simply be to run the app that fills the
cache using call_usermodehelper_exec() and friends.
The following patch allows the cache_detail to specify alternative upcall
mechanisms for these particular cases.
When we look up an entry in the uid->gidlist cache, we take
a reference to the content but don't drop the reference to the
cache entry. So it never gets freed.
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u
can be replaced with %pI4
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Open code NIP6_FMT in the one call inside sscanf and one user
of NIP6() that could use %p6 in the netfilter code.
Commit f15364bd4cf8799a7677b6daeed7b67d9139d974 ("IPv6 support for NFS
server export caches") dropped a couple spaces, rendering the output
here difficult to read.
(However note that we expect the output to be parsed only by humans, not
machines, so this shouldn't have broken any userland software.)
This adds IPv6 support to the interfaces that are used to express nfsd
exports. All addressed are stored internally as IPv6; backwards
compatibility is maintained using mapped addresses.
Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji
for comments
Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net>
Cc: Brian Haley <brian.haley@hp.com>
Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org>
Do it for the server code...
Move the authinfo cache to svc_xprt. This allows both the TCP and RDMA
transports to share this logic. A flag bit is used to determine if
auth information is to be cached or not. Previously, this code looked
at the transport protocol.
I've also changed the spin_lock/unlock logic so that a lock is not taken for
transports that are not caching auth info.
Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
Acked-by: Neil Brown <neilb@suse.de>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Reviewed-by: Greg Banks <gnb@sgi.com>
