Fix an Oopsable condition when nsm_mon_unmon is called as part of the
namespace cleanup, which now apparently happens after the utsname
has been freed.
Link: http://lkml.kernel.org/r/20150125220604.090121ae@neptune.home
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
Cc: stable@vger.kernel.org # 3.18
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
It's always set to whatever CONFIG_SUNRPC_DEBUG is, so just use that.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
If rpcbind causes our connection to the AF_LOCAL socket to close after
we've registered a service, then we want to be careful about reconnecting
since the mount namespace may have changed.
By simply refusing to reconnect the AF_LOCAL socket in the case of
unregister, we avoid the need to somehow save the mount namespace. While
this may lead to some services not unregistering properly, it should
be safe.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Nix <nix@esperi.org.uk>
Cc: Jeff Layton <jlayton@redhat.com>
Cc: stable@vger.kernel.org # 3.9.x
There is no need for the kernel to time out the AF_LOCAL connection to
the rpcbind socket, and doing so is problematic because when it is
time to reconnect, our process may no longer be using the same mount
namespace.
Reported-by: Nix <nix@esperi.org.uk>
addr.h
These routines are used by server and client code, so having them in a
separate header would be best.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Pull nfsd update from Bruce Fields:
"Included this time:
- more nfsd containerization work from Stanislav Kinsbursky: we're
not quite there yet, but should be by 3.9.
- NFSv4.1 progress: implementation of basic backchannel security
negotiation and the mandatory BACKCHANNEL_CTL operation. See
http://wiki.linux-nfs.org/wiki/index.php/Server_4.0_and_4.1_issues
for remaining TODO's
- Fixes for some bugs that could be triggered by unusual compounds.
Our xdr code wasn't designed with v4 compounds in mind, and it
shows. A more thorough rewrite is still a todo.
- If you've ever seen "RPC: multiple fragments per record not
supported" logged while using some sort of odd userland NFS client,
that should now be fixed.
- Further work from Jeff Layton on our mechanism for storing
information about NFSv4 clients across reboots.
- Further work from Bryan Schumaker on his fault-injection mechanism
(which allows us to discard selective NFSv4 state, to excercise
rarely-taken recovery code paths in the client.)
- The usual mix of miscellaneous bugs and cleanup.
Thanks to everyone who tested or contributed this cycle."
* 'for-3.8' of git://linux-nfs.org/~bfields/linux: (111 commits)
nfsd4: don't leave freed stateid hashed
nfsd4: free_stateid can use the current stateid
nfsd4: cleanup: replace rq_resused count by rq_next_page pointer
nfsd: warn on odd reply state in nfsd_vfs_read
nfsd4: fix oops on unusual readlike compound
nfsd4: disable zero-copy on non-final read ops
svcrpc: fix some printks
NFSD: Correct the size calculation in fault_inject_write
NFSD: Pass correct buffer size to rpc_ntop
nfsd: pass proper net to nfsd_destroy() from NFSd kthreads
nfsd: simplify service shutdown
nfsd: replace boolean nfsd_up flag by users counter
nfsd: simplify NFSv4 state init and shutdown
nfsd: introduce helpers for generic resources init and shutdown
nfsd: make NFSd service structure allocated per net
nfsd: make NFSd service boot time per-net
nfsd: per-net NFSd up flag introduced
nfsd: move per-net startup code to separated function
nfsd: pass net to __write_ports() and down
nfsd: pass net to nfsd_set_nrthreads()
This is a cleanup patch.
Signed-off-by: Stanislav Kinsbursky <skinsbursky@parallels.com>
Replace BUG_ON() with WARN_ON_ONCE() and truncate the encoded string if
len > max.
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
Without this patch kernel will panic on LockD start, because lockd_up() checks
lockd_up_net() result for negative value.
From my pow it's better to return negative value from rpcbind routines instead
of replacing all such checks like in lockd_up().
Cc: stable@vger.kernel.org [>= 3.0]
Pull the rest of the nfsd commits from Bruce Fields:
"... and then I cherry-picked the remainder of the patches from the
head of my previous branch"
This is the rest of the original nfsd branch, rebased without the
delegation stuff that I thought really needed to be redone.
I don't like rebasing things like this in general, but in this situation
this was the lesser of two evils.
* 'for-3.5' of git://linux-nfs.org/~bfields/linux: (50 commits)
nfsd4: fix, consolidate client_has_state
nfsd4: don't remove rebooted client record until confirmation
nfsd4: remove some dprintk's and a comment
nfsd4: return "real" sequence id in confirmed case
nfsd4: fix exchange_id to return confirm flag
nfsd4: clarify that renewing expired client is a bug
nfsd4: simpler ordering of setclientid_confirm checks
nfsd4: setclientid: remove pointless assignment
nfsd4: fix error return in non-matching-creds case
nfsd4: fix setclientid_confirm same_cred check
nfsd4: merge 3 setclientid cases to 2
nfsd4: pull out common code from setclientid cases
nfsd4: merge last two setclientid cases
nfsd4: setclientid/confirm comment cleanup
nfsd4: setclientid remove unnecessary terms from a logical expression
nfsd4: move rq_flavor into svc_cred
nfsd4: stricter cred comparison for setclientid/exchange_id
nfsd4: move principal name into svc_cred
nfsd4: allow removing clients not holding state
nfsd4: rearrange exchange_id logic to simplify
This new routine is responsible for service registration in a specified
network context.
The idea is to separate service creation from per-net operations.
Note also: since registering service with svc_bind() can fail, the
service will be destroyed and during destruction it will try to
unregister itself from rpcbind. In this case unregistration has to be
skipped.
Fix kernel-doc warnings in sunrpc/rpc_pipe.c and
sunrpc/rpcb_clnt.c:
Warning(net/sunrpc/rpcb_clnt.c:428): No description found for parameter 'net'
Warning(net/sunrpc/rpcb_clnt.c:567): No description found for parameter 'net'
Warning(net/sunrpc/rpc_pipe.c:133): No description found for parameter 'pipe'
Warning(net/sunrpc/rpc_pipe.c:133): Excess function parameter 'inode' description in 'rpc_queue_upcall'
Warning(net/sunrpc/rpc_pipe.c:839): No description found for parameter 'pipe'
Warning(net/sunrpc/rpc_pipe.c:839): Excess function parameter 'ops' description in 'rpc_mkpipe_dentry'
Warning(net/sunrpc/rpc_pipe.c:839): Excess function parameter 'flags' description in 'rpc_mkpipe_dentry'
Warning(net/sunrpc/rpc_pipe.c:949): No description found for parameter 'dentry'
Warning(net/sunrpc/rpc_pipe.c:949): Excess function parameter 'clnt' description in 'rpc_remove_client_dir'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
rbcb_getport_async() was looking up the rpc_xprt (reference++) and then
later looking it up again (reference++) to pass through the
rpcbind_args. The xprt would only be dereferenced once, when we were
done with the rpcbind_args (reference--). This leaves an extra
reference to the transport that would never go away.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
Stephen Rothwell reports:
net/sunrpc/rpcb_clnt.c: In function 'rpcb_enc_mapping':
net/sunrpc/rpcb_clnt.c:820:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_dec_getport':
net/sunrpc/rpcb_clnt.c:837:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_dec_set':
net/sunrpc/rpcb_clnt.c:860:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_enc_getaddr':
net/sunrpc/rpcb_clnt.c:892:19: warning: unused variable 'task' [-Wunused-variable]
net/sunrpc/rpcb_clnt.c: In function 'rpcb_dec_getaddr':
net/sunrpc/rpcb_clnt.c:914:19: warning: unused variable 'task' [-Wunused-variable]
fs/lockd/svclock.c:49:20: warning: 'nlmdbg_cookie2a' declared 'static' but never defined [-Wunused-function]
When the cl_xprt field is updated, the cl_server field will also have
to change. Since the contents of cl_server follow the remote endpoint
of cl_xprt, just move that field to the rpc_xprt.
[ cel: simplify check_gss_callback_principal(), whitespace changes ]
[ cel: forward ported to 3.4 ]
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
A migration event will replace the rpc_xprt used by an rpc_clnt. To
ensure this can be done safely, all references to cl_xprt must now use
a form of rcu_dereference().
Special care is taken with rpc_peeraddr2str(), which returns a pointer
to memory whose lifetime is the same as the rpc_xprt.
[ cel: fix lockdep splats and layering violations ]
[ cel: remove rpc_max_reqs(), add rpc_net_ns() ]
...and get rid of the superfluous cl_inline_name.
Pass request socket network namespace to rpc_uaddr2sockaddr() instead of
hardcoded "init_net", when decoding address in RPCBPROC_GETADDR procedure.
Parametrize rpc_uaddr2sockaddr() by network context and thus force it's callers to pass
in network context instead of using hard-coded "init_net".
These client are per network namespace and thus can be created for different
network namespaces.
Registering rpcbind program requires rpcbind clients, which are per network
namespace context.
Rpcbind clients are per network namespace.
Static rpcbind registering functions can be parametrized by network namespace
pointer, calculated only once, instead of using init_net pointer (or taking it
from current when virtualization will be comleted) in many places.
Static rpcbind creation functions can be parametrized by network namespace
This patch makes rpcbind logic works in network namespace context. IOW each
network namespace will have it's own unique rpcbind internals (clients and
friends) required for registering svc services per network namespace.
Rpcbind clients destruction during SUNRPC module removing is obsolete since now
those clients are destroying during last RPC service shutdown.
We don't need this code since rpcbind clients are creating during RPC service
creation.
This helpers will be used only for those services, that will send portmapper
registration calls.
All is simple: we just increase users counter if rpcbind clients has been
created already. Otherwise we create them and set users counter to 1.
v6:
1) added write memory barrier to rpcb_set_local to make sure, that rpcbind
clients become valid before rpcb_users assignment
2) explicitly set rpcb_users to 1 instead of incrementing it (looks clearer from
my pow).
v5: fixed races with rpcb_users in rpcb_get_local()
This helpers will be used for dynamical creation and destruction of rpcbind
clients.
Variable rpcb_users is actually a counter of lauched RPC services. If rpcbind
clients has been created already, then we just increase rpcb_users.
rpc_sockaddr2uaddr is only used by net/sunrpc/rpcb_clnt.c, where
it is used in a non-blockable context in at least one case.
Add non-blocking capability by adding a gfp_t argument
Because struct rpcbind_args *map was declared static, if two
threads entered this method at the same time, the values
assigned to map could be sent two two differen tasks.
This could cause all sorts of problems, include use-after-free
and double-free of memory.
Fix this by removing the static declaration so that the map
pointer is on the stack.
Signed-off-by: Ben Greear <greearb@candelatech.com>
Cc: stable@kernel.org
As libtirpc does in user space, have our registration API try using an
AF_LOCAL transport first when registering and unregistering.
This means we don't chew up privileged ports, and our registration is
bound to an "owner" (the effective uid of the process on the sending
end of the transport). Only that "owner" may unregister the service.
The kernel could probe rpcbind via an rpcbind query to determine
whether rpcbind has an AF_LOCAL service. For simplicity, we use the
same technique that libtirpc uses: simply fail over to network
loopback if creating an AF_LOCAL transport to the well-known rpcbind
service socket fails.
This means we open-code the pathname of the rpcbind socket in the
kernel. For now we have to do that anyway because the kernel's
RPC over AF_LOCAL implementation does not support autobind. That may
be undesirable in the long term.
Now that all client-side XDR decoder routines use xdr_streams, there
should be no need to support the legacy calling sequence [rpc_rqst *,
__be32 *, RPC res *] anywhere. We can construct an xdr_stream in the
generic RPC code, instead of in each decoder function.
This is a refactoring change. It should not cause different behavior.
Tested-by: J. Bruce Fields <bfields@redhat.com>
Now that all client-side XDR encoder routines use xdr_streams, there
__be32 *, RPC arg *] anywhere. We can construct an xdr_stream in the
generic RPC code, instead of in each encoder function.
Also, all the client-side encoder functions return 0 now, making a
return value superfluous. Take this opportunity to convert them to
return void instead.
Clean up.
Just fixed a panic where the nrprocs field in a different upper layer
client was set by hand incorrectly. Use the compiler-generated method
used by the other upper layer protocols.
Clean up.
The trend in the other XDR encoder functions is to BUG() when encoding
problems occur, since a problem here is always due to a local coding
error. Then, instead of a status, zero is unconditionally returned.
Update the rpcbind XDR encoders to behave this way.
To finish the update, use the new-style be32_to_cpup() and
cpu_to_be32() macros, and compute the buffer sizes using raw integers
instead of sizeof(). This matches the conventions used in other XDR
functions.
* 'for-2.6.37' of git://linux-nfs.org/~bfields/linux: (99 commits)
svcrpc: svc_tcp_sendto XPT_DEAD check is redundant
svcrpc: no need for XPT_DEAD check in svc_xprt_enqueue
svcrpc: assume svc_delete_xprt() called only once
svcrpc: never clear XPT_BUSY on dead xprt
nfsd4: fix connection allocation in sequence()
nfsd4: only require krb5 principal for NFSv4.0 callbacks
nfsd4: move minorversion to client
nfsd4: delay session removal till free_client
nfsd4: separate callback change and callback probe
nfsd4: callback program number is per-session
nfsd4: track backchannel connections
nfsd4: confirm only on succesful create_session
nfsd4: make backchannel sequence number per-session
nfsd4: use client pointer to backchannel session
nfsd4: move callback setup into session init code
nfsd4: don't cache seq_misordered replies
SUNRPC: Properly initialize sock_xprt.srcaddr in all cases
SUNRPC: Use conventional switch statement when reclassifying sockets
sunrpc/xprtrdma: clean up workqueue usage
sunrpc: Turn list_for_each-s into the ..._entry-s
Fix up trivial conflicts (two different deprecation notices added in
separate branches) in Documentation/feature-removal-schedule.txt
> The reason for this is in the future, we may want to support additional
> address family types. We should, therefore, ensure that every piece of
> code that is sensitive to address families fail in some orderly manner
> to let developers know where a change is needed.
Makes sense. I was under impression, that AF-s other than INET are not
cared about at all :(
Here's a fixed version of the patch.
Log:
Its callers check for ERR_PTR.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Reviewed-by: Chuck Lever <chuck.lever@oracle.com>
Clean up.
Clean up: rpcb_getport_sync() has no more users, so remove it.
SHRT_MAX and SHRT_MIN
- C99 knows about USHRT_MAX/SHRT_MAX/SHRT_MIN, not
USHORT_MAX/SHORT_MAX/SHORT_MIN.
- Make SHRT_MIN of type s16, not int, for consistency.
[akpm@linux-foundation.org: fix drivers/dma/timb_dma.c]
[akpm@linux-foundation.org: fix security/keys/keyring.c]
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Autobinding is handled by the rpciod process, not in user processes
that are generating regular RPC requests. Thus autobinding is usually
not affected by signals targetting user processes, such as KILL or
timer expiration events.
In addition, an RPC request generated by a user process that has
RPC_TASK_SOFTCONN set and needs to perform an autobind will hang if
the remote rpcbind service is not available.
For rpcbind queries on connection-oriented transports, let's use the
new soft connect semantic to return control to the user's process
quickly, if the kernel's rpcbind client can't connect to the remote
rpcbind service.
Logic is introduced in call_bind_status() to handle connection errors
that occurred during an asynchronous rpcbind query. The logic
abandons the rpcbind query if the RPC request has SOFTCONN set, and
retries after a few seconds in the normal case.
Use TCP with the soft connect semantic for local rpcbind upcalls so
the kernel can detect immediately if the local rpcbind daemon is not
running.
The kernel's rpcbind client creates and deletes an rpc_clnt and its
underlying transport socket for every upcall to the local rpcbind
daemon.
When starting a typical NFS server on IPv4 and IPv6, the NFS service
itself does three upcalls (one per version) times two upcalls (one
per transport) times two upcalls (one per address family), making 12,
plus another one for the initial call to unregister previous NFS
services. Starting the NLM service adds an additional 13 upcalls,
for similar reasons.
(Currently the NFS service doesn't start IPv6 listeners, but it will
soon enough).
Instead, let's create an rpc_clnt for rpcbind upcalls during the
first local rpcbind query, and cache it. This saves the overhead of
creating and destroying an rpc_clnt and a socket for every upcall.
The new logic also prevents the kernel from attempting an RPCB_SET or
RPCB_UNSET if it knows from the start that the local portmapper does
not support rpcbind protocol version 4. This will cut down on the
number of rpcbind upcalls in legacy environments.
Clean up: At one point, rpcb_local_clnt() handled IPv6 loopback
addresses too, but it doesn't any more; only IPv4 loopback is used
now. Get rid of the @addr and @addrlen arguments to
rpcb_local_clnt().
Clean up: Replace PROC macro with open coded C99 structure
initializers to improve readability.
The rpcbind v4 GETVERSADDR procedure is never sent by the current
implementation, so it is not copied to the new structures.
