path: root/net/socket.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-27net: Add MSG_WAITFORONE flag to recvmmsgBrandon L Black
Add new flag MSG_WAITFORONE for the recvmmsg() syscall. When this flag is specified for a blocking socket, recvmmsg() will only block until at least 1 packet is available. The default behavior is to block until all vlen packets are available. This flag has no effect on non-blocking sockets or when used in combination with MSG_DONTWAIT. Signed-off-by: Brandon L Black <blblack@gmail.com> Acked-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-17fs: no games with DCACHE_UNHASHEDNick Piggin
Filesystems outside the regular namespace do not have to clear DCACHE_UNHASHED in order to have a working /proc/$pid/fd/XXX. Nothing in proc prevents the fd link from being used if its dentry is not in the hash. Also, it does not get put into the dcache hash if DCACHE_UNHASHED is clear; that depends on the filesystem calling d_add or d_rehash. So delete the misleading comments and needless code. Acked-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch alloc_file() to passing struct pathAl Viro
... and have the caller grab both mnt and dentry; kill leak in infiniband, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16switch sock_alloc_file() to alloc_file()Al Viro
2009-12-16merge sock_alloc_fd/sock_attach_fd into a new helperAl Viro
2009-12-16reorder alloc_fd/attach_fd in socketpair()Al Viro
2009-12-02net: compat_mmsghdr must be used in sys_recvmmsgJean-Mickael Guerin
Both to traverse the entries and to set the msg_len field. Commiter note: folded two patches and avoided one branch repeating the compat test. Signed-off-by: Jean-Mickael Guerin <jean-mickael.guerin@6wind.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11net/atm: move all compat_ioctl handling to atm/ioctl.cArnd Bergmann
We have two implementations of the compat_ioctl handling for ATM, the one that we have had for ages in fs/compat_ioctl.c and the one added to net/atm/ioctl.c by David Woodhouse. Unfortunately, both versions are incomplete, and in practice we use a very confusing combination of the two. For ioctl numbers that have the same identifier on 32 and 64 bit systems, we go directly through the compat_ioctl socket operation, for those that differ, we do a conversion in fs/compat_ioctl.c. This patch moves both variants into the vcc_compat_ioctl() function, while preserving the current behaviour. It also kills off the COMPATIBLE_IOCTL definitions that we never use here. Doing it this way is clearly not a good solution, but I hope it is a step into the right direction, so that someone is able to clean up this mess for real. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-11net/compat: fix dev_ifsioc emulation corner casesArnd Bergmann
Handling for SIOCSHWTSTAMP is broken on architectures with a split user/kernel address space like s390, because it passes a real user pointer while using set_fs(KERNEL_DS). A similar problem might arise the next time somebody adds code to dev_ifsioc. Split up dev_ifsioc into three separate functions for SIOCSHWTSTAMP, SIOC*IFMAP and all other numbers so we can get rid of set_fs in all potentially affected cases. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Patrick Ohly <patrick.ohly@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08net/compat_ioctl: support SIOCWANDEVArnd Bergmann
This adds compat_ioctl support for SIOCWANDEV, which has always been missing. The definition of struct compat_ifreq was missing an ifru_settings fields that is needed to support SIOCWANDEV, so add that and clean up the whitespace damage in the struct definition. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-08net, compat_ioctl: fix SIOCGMII ioctlsArnd Bergmann
SIOCGMIIPHY and SIOCGMIIREG return data through ifreq, so it needs to be converted on the way out as well. SIOCGIFPFLAGS is unused, but has the same problem in theory. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06net, compat_ioctl: handle more ioctls correctlyArnd Bergmann
The MII ioctls and SIOCSIFNAME need to go through ifsioc conversion, which they never did so far. Some others are not implemented in the native path, so we can just return -EINVAL directly. Add IFSLAVE ioctls to the EINVAL list and move it to the end to optimize the code path for the common case. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06compat: move sockios handling to net/socket.cArnd Bergmann
This removes the original socket compat_ioctl code from fs/compat_ioctl.c and converts the code from the copy in net/socket.c into a single function. We add a few cycles of runtime to compat_sock_ioctl() with the long switch() statement, but gain some cycles in return by simplifying the call chain to get there. Due to better inlining, save 1.5kb of object size in the process, and enable further savings: before: text data bss dec hex filename 13540 18008 2080 33628 835c obj/fs/compat_ioctl.o 14565 636 40 15241 3b89 obj/net/socket.o after: text data bss dec hex filename 8916 15176 2080 26172 663c obj/fs/compat_ioctl.o 20725 636 40 21401 5399 obj/net/socket.o Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-06net: copy socket ioctl code to net/socket.hArnd Bergmann
This makes an identical copy of the socket compat_ioctl code from fs/compat_ioctl.c to net/socket.c, as a preparation for moving the functionality in a way that can be easily reviewed. The code is hidden inside of #if 0 and gets activated in the patch that will make it work. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Introduce recvmmsg socket syscallArnaldo Carvalho de Melo
Meaning receive multiple messages, reducing the number of syscalls and net stack entry/exit operations. Next patches will introduce mechanisms where protocols that want to optimize this operation will provide an unlocked_recvmsg operation. This takes into account comments made by: . Paul Moore: sock_recvmsg is called only for the first datagram, sock_recvmsg_nosec is used for the rest. . Caitlin Bestler: recvmmsg now has a struct timespec timeout, that works in the same fashion as the ppoll one. If the underlying protocol returns a datagram with MSG_OOB set, this will make recvmmsg return right away with as many datagrams (+ the OOB one) it has received so far. . Rémi Denis-Courmont & Steven Whitehouse: If we receive N < vlen datagrams and then recvmsg returns an error, recvmmsg will return the successfully received datagrams, store the error and return it in the next call. This paves the way for a subsequent optimization, sk_prot->unlocked_recvmsg, where we will be able to acquire the lock only at batch start and end, not at every underlying recvmsg call. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-09Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-10-07wext: refactorJohannes Berg
Refactor wext to * split out iwpriv handling * split out iwspy handling * split out procfs support * allow cfg80211 to have wireless extensions compat code w/o CONFIG_WIRELESS_EXT After this, drivers need to - select WIRELESS_EXT - for wext support - select WEXT_PRIV - for iwpriv support - select WEXT_SPY - for iwspy support except cfg80211 -- which gets new hooks in wext-core.c and can then get wext handlers without CONFIG_WIRELESS_EXT. Wireless extensions procfs support is auto-selected based on PROC_FS and anything that requires the wext core (i.e. WIRELESS_EXT or CFG80211_WEXT). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-06net: speedup sk_wake_async()Eric Dumazet
An incoming datagram must bring into cpu cache *lot* of cache lines, in particular : (other parts omitted (hash chains, ip route cache...)) On 32bit arches : offsetof(struct sock, sk_rcvbuf) =0x30 (read) offsetof(struct sock, sk_lock) =0x34 (rw) offsetof(struct sock, sk_sleep) =0x50 (read) offsetof(struct sock, sk_rmem_alloc) =0x64 (rw) offsetof(struct sock, sk_receive_queue)=0x74 (rw) offsetof(struct sock, sk_forward_alloc)=0x98 (rw) offsetof(struct sock, sk_callback_lock)=0xcc (rw) offsetof(struct sock, sk_drops) =0xd8 (read if we add dropcount support, rw if frame dropped) offsetof(struct sock, sk_filter) =0xf8 (read) offsetof(struct sock, sk_socket) =0x138 (read) offsetof(struct sock, sk_data_ready) =0x15c (read) We can avoid sk->sk_socket and socket->fasync_list referencing on sockets with no fasync() structures. (socket->fasync_list ptr is probably already in cache because it shares a cache line with socket->wait, ie location pointed by sk->sk_sleep) This avoids one cache line load per incoming packet for common cases (no fasync()) We can leave (or even move in a future patch) sk->sk_socket in a cold location Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-28net: Add explicit bound checks in net/socket.cArjan van de Ven
The sys_socketcall() function has a very clever system for the copy size of its arguments. Unfortunately, gcc cannot deal with this in terms of proving that the copy_from_user() is then always in bounds. This is the last (well 9th of this series, but last in the kernel) such case around. With this patch, we can turn on code to make having the boundary provably right for the whole kernel, and detect introduction of new security accidents of this type early on. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-23Move magic numbers into magic.hNick Black
Move various magic-number definitions into magic.h. Signed-off-by: Nick Black <dank@qemfd.net> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22const: mark remaining super_operations constAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-15[PATCH] net: kmemcheck annotation in struct socketEric Dumazet
struct socket has a 16 bit hole that triggers kmemcheck warnings. As suggested by Ingo, use kmemcheck annotations Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-13Make sock_sendpage() use kernel_sendpage()Linus Torvalds
kernel_sendpage() does the proper default case handling for when the socket doesn't have a native sendpage implementation. Now, arguably this might be something that we could instead solve by just specifying that all protocols should do it themselves at the protocol level, but we really only care about the common protocols. Does anybody really care about sendpage on something like Appletalk? Not likely. Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Julien TINNES <julien@cr0.org> Acked-by: Tavis Ormandy <taviso@sdf.lonestar.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: b44: Use kernel DMA addresses for the kernel DMA API forcedeth: Fix resume from hibernation regression. xfrm: fix fragmentation on inter family tunnels ibm_newemac: Fix dangerous struct assumption gigaset: documentation update gigaset: in file ops, check for device disconnect before anything else bas_gigaset: use tasklet_hi_schedule for timing critical tasklets net/802/fddi.c: add MODULE_LICENSE smsc911x: remove unused #include <linux/version.h> axnet_cs: fix phy_id detection for bogus Asix chip. bnx2: Use request_firmware() b44: Fix sizes passed to b44_sync_dma_desc_for_{device,cpu}() socket: use percpu_add() while updating sockets_in_use virtio_net: Set the mac config only when VIRITO_NET_F_MAC myri_sbus: use request_firmware e1000: fix loss of multicast packets vxge: should include tcp.h Conflict in firmware/WHENCE (SCSI vs net firmware)
2009-04-04socket: use percpu_add() while updating sockets_in_useEric Dumazet
sock_alloc() currently uses following code to update sockets_in_use get_cpu_var(sockets_in_use)++; put_cpu_var(sockets_in_use); This translates to : c0436274: b8 01 00 00 00 mov $0x1,%eax c0436279: e8 42 40 df ff call c022a2c0 <add_preempt_count> c043627e: bb 20 4f 6a c0 mov $0xc06a4f20,%ebx c0436283: e8 18 ca f0 ff call c0342ca0 <debug_smp_processor_id> c0436288: 03 1c 85 60 4a 65 c0 add -0x3f9ab5a0(,%eax,4),%ebx c043628f: ff 03 incl (%ebx) c0436291: b8 01 00 00 00 mov $0x1,%eax c0436296: e8 75 3f df ff call c022a210 <sub_preempt_count> c043629b: 89 e0 mov %esp,%eax c043629d: 25 00 e0 ff ff and $0xffffe000,%eax c04362a2: f6 40 08 08 testb $0x8,0x8(%eax) c04362a6: 75 07 jne c04362af <sock_alloc+0x7f> c04362a8: 8d 46 d8 lea -0x28(%esi),%eax c04362ab: 5b pop %ebx c04362ac: 5e pop %esi c04362ad: c9 leave c04362ae: c3 ret c04362af: e8 cc 5d 09 00 call c04cc080 <preempt_schedule> c04362b4: 8d 74 26 00 lea 0x0(%esi,%eiz,1),%esi c04362b8: eb ee jmp c04362a8 <sock_alloc+0x78> While percpu_add(sockets_in_use, 1) translates to a single instruction : c0436275: 64 83 05 20 5f 6a c0 addl $0x1,%fs:0xc06a5f20 Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-28lsm: Remove the socket_post_accept() hookPaul Moore
The socket_post_accept() hook is not currently used by any in-tree modules and its existence continues to cause problems by confusing people about what can be safely accomplished using this hook. If a legitimate need for this hook arises in the future it can always be reintroduced. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-03-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits) fs: avoid I_NEW inodes Merge code for single and multiple-instance mounts Remove get_init_pts_sb() Move common mknod_ptmx() calls into caller Parse mount options just once and copy them to super block Unroll essentials of do_remount_sb() into devpts vfs: simple_set_mnt() should return void fs: move bdev code out of buffer.c constify dentry_operations: rest constify dentry_operations: configfs constify dentry_operations: sysfs constify dentry_operations: JFS constify dentry_operations: OCFS2 constify dentry_operations: GFS2 constify dentry_operations: FAT constify dentry_operations: FUSE constify dentry_operations: procfs constify dentry_operations: ecryptfs constify dentry_operations: CIFS constify dentry_operations: AFS ...
2009-03-27constify dentry_operations: restAl Viro
2009-03-26Merge branch 'bkl-removal' of git://git.lwn.net/linux-2.6Linus Torvalds
* 'bkl-removal' of git://git.lwn.net/linux-2.6: Rationalize fasync return values Move FASYNC bit handling to f_op->fasync() Use f_lock to protect f_flags Rename struct file->f_ep_lock
2009-03-16Move FASYNC bit handling to f_op->fasync()Jonathan Corbet
Removing the BKL from FASYNC handling ran into the challenge of keeping the setting of the FASYNC bit in filp->f_flags atomic with regard to calls to the underlying fasync() function. Andi Kleen suggested moving the handling of that bit into fasync(); this patch does exactly that. As a result, we have a couple of internal API changes: fasync() must now manage the FASYNC bit, and it will be called without the BKL held. As it happens, every fasync() implementation in the kernel with one exception calls fasync_helper(). So, if we make fasync_helper() set the FASYNC bit, we can avoid making any changes to the other fasync() functions - as long as those functions, themselves, have proper locking. Most fasync() implementations do nothing but call fasync_helper() - which has its own lock - so they are easily verified as correct. The BKL had already been pushed down into the rest. The networking code has its own version of fasync_helper(), so that code has been augmented with explicit FASYNC bit handling. Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: David Miller <davem@davemloft.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-02-15net: socket infrastructure for SO_TIMESTAMPINGPatrick Ohly
The overlap with the old SO_TIMESTAMP[NS] options is handled so that time stamping in software (net_enable_timestamp()) is enabled when SO_TIMESTAMP[NS] and/or SO_TIMESTAMPING_RX_SOFTWARE is set. It's disabled if all of these are off. Signed-off-by: Patrick Ohly <patrick.ohly@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-14[CVE-2009-0029] System call wrappers part 22Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 21Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 07Heiko Carstens
2009-01-04sanitize audit_fd_pair()Al Viro
* no allocations * return void Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-04sanitize audit_socketcallAl Viro
* don't bother with allocations * now that it can't fail, make it return void Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ppp_generic.c
2008-12-18net: Fix module refcount leak in kernel_accept()Wei Yongjun
The kernel_accept() does not hold the module refcount of newsock->ops->owner, so we need __module_get(newsock->ops->owner) code after call kernel_accept() by hand. In sunrpc, the module refcount is missing to hold. So this cause kernel panic. Used following script to reproduct: while [ 1 ]; do mount -t nfs4 192.168.0.19:/ /mnt touch /mnt/file umount /mnt lsmod | grep ipv6 done This patch fixed the problem by add __module_get(newsock->ops->owner) to kernel_accept(). So we do not need to used __module_get(newsock->ops->owner) in every place when used kernel_accept(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-11-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ixgbe/ixgbe_main.c include/net/mac80211.h net/phonet/af_phonet.c
2008-11-19reintroduce accept4Ulrich Drepper
Introduce a new accept4() system call. The addition of this system call matches analogous changes in 2.6.27 (dup3(), evenfd2(), signalfd4(), inotify_init1(), epoll_create1(), pipe2()) which added new system calls that differed from analogous traditional system calls in adding a flags argument that can be used to access additional functionality. The accept4() system call is exactly the same as accept(), except that it adds a flags bit-mask argument. Two flags are initially implemented. (Most of the new system calls in 2.6.27 also had both of these flags.) SOCK_CLOEXEC causes the close-on-exec (FD_CLOEXEC) flag to be enabled for the new file descriptor returned by accept4(). This is a useful security feature to avoid leaking information in a multithreaded program where one thread is doing an accept() at the same time as another thread is doing a fork() plus exec(). More details here: http://udrepper.livejournal.com/20407.html "Secure File Descriptor Handling", Ulrich Drepper). The other flag is SOCK_NONBLOCK, which causes the O_NONBLOCK flag to be enabled on the new open file description created by accept4(). (This flag is merely a convenience, saving the use of additional calls fcntl(F_GETFL) and fcntl (F_SETFL) to achieve the same result. Here's a test program. Works on x86-32. Should work on x86-64, but I (mtk) don't have a system to hand to test with. It tests accept4() with each of the four possible combinations of SOCK_CLOEXEC and SOCK_NONBLOCK set/clear in 'flags', and verifies that the appropriate flags are set on the file descriptor/open file description returned by accept4(). I tested Ulrich's patch in this thread by applying against 2.6.28-rc2, and it passes according to my test program. /* test_accept4.c Copyright (C) 2008, Linux Foundation, written by Michael Kerrisk <mtk.manpages@gmail.com> Licensed under the GNU GPLv2 or later. */ #define _GNU_SOURCE #include <unistd.h> #include <sys/syscall.h> #include <sys/socket.h> #include <netinet/in.h> #include <stdlib.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #define PORT_NUM 33333 #define die(msg) do { perror(msg); exit(EXIT_FAILURE); } while (0) /**********************************************************************/ /* The following is what we need until glibc gets a wrapper for accept4() */ /* Flags for socket(), socketpair(), accept4() */ #ifndef SOCK_CLOEXEC #define SOCK_CLOEXEC O_CLOEXEC #endif #ifndef SOCK_NONBLOCK #define SOCK_NONBLOCK O_NONBLOCK #endif #ifdef __x86_64__ #define SYS_accept4 288 #elif __i386__ #define USE_SOCKETCALL 1 #define SYS_ACCEPT4 18 #else #error "Sorry -- don't know the syscall # on this architecture" #endif static int accept4(int fd, struct sockaddr *sockaddr, socklen_t *addrlen, int flags) { printf("Calling accept4(): flags = %x", flags); if (flags != 0) { printf(" ("); if (flags & SOCK_CLOEXEC) printf("SOCK_CLOEXEC"); if ((flags & SOCK_CLOEXEC) && (flags & SOCK_NONBLOCK)) printf(" "); if (flags & SOCK_NONBLOCK) printf("SOCK_NONBLOCK"); printf(")"); } printf("\n"); #if USE_SOCKETCALL long args[6]; args[0] = fd; args[1] = (long) sockaddr; args[2] = (long) addrlen; args[3] = flags; return syscall(SYS_socketcall, SYS_ACCEPT4, args); #else return syscall(SYS_accept4, fd, sockaddr, addrlen, flags); #endif } /**********************************************************************/ static int do_test(int lfd, struct sockaddr_in *conn_addr, int closeonexec_flag, int nonblock_flag) { int connfd, acceptfd; int fdf, flf, fdf_pass, flf_pass; struct sockaddr_in claddr; socklen_t addrlen; printf("=======================================\n"); connfd = socket(AF_INET, SOCK_STREAM, 0); if (connfd == -1) die("socket"); if (connect(connfd, (struct sockaddr *) conn_addr, sizeof(struct sockaddr_in)) == -1) die("connect"); addrlen = sizeof(struct sockaddr_in); acceptfd = accept4(lfd, (struct sockaddr *) &claddr, &addrlen, closeonexec_flag | nonblock_flag); if (acceptfd == -1) { perror("accept4()"); close(connfd); return 0; } fdf = fcntl(acceptfd, F_GETFD); if (fdf == -1) die("fcntl:F_GETFD"); fdf_pass = ((fdf & FD_CLOEXEC) != 0) == ((closeonexec_flag & SOCK_CLOEXEC) != 0); printf("Close-on-exec flag is %sset (%s); ", (fdf & FD_CLOEXEC) ? "" : "not ", fdf_pass ? "OK" : "failed"); flf = fcntl(acceptfd, F_GETFL); if (flf == -1) die("fcntl:F_GETFD"); flf_pass = ((flf & O_NONBLOCK) != 0) == ((nonblock_flag & SOCK_NONBLOCK) !=0); printf("nonblock flag is %sset (%s)\n", (flf & O_NONBLOCK) ? "" : "not ", flf_pass ? "OK" : "failed"); close(acceptfd); close(connfd); printf("Test result: %s\n", (fdf_pass && flf_pass) ? "PASS" : "FAIL"); return fdf_pass && flf_pass; } static int create_listening_socket(int port_num) { struct sockaddr_in svaddr; int lfd; int optval; memset(&svaddr, 0, sizeof(struct sockaddr_in)); svaddr.sin_family = AF_INET; svaddr.sin_addr.s_addr = htonl(INADDR_ANY); svaddr.sin_port = htons(port_num); lfd = socket(AF_INET, SOCK_STREAM, 0); if (lfd == -1) die("socket"); optval = 1; if (setsockopt(lfd, SOL_SOCKET, SO_REUSEADDR, &optval, sizeof(optval)) == -1) die("setsockopt"); if (bind(lfd, (struct sockaddr *) &svaddr, sizeof(struct sockaddr_in)) == -1) die("bind"); if (listen(lfd, 5) == -1) die("listen"); return lfd; } int main(int argc, char *argv[]) { struct sockaddr_in conn_addr; int lfd; int port_num; int passed; passed = 1; port_num = (argc > 1) ? atoi(argv[1]) : PORT_NUM; memset(&conn_addr, 0, sizeof(struct sockaddr_in)); conn_addr.sin_family = AF_INET; conn_addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK); conn_addr.sin_port = htons(port_num); lfd = create_listening_socket(port_num); if (!do_test(lfd, &conn_addr, 0, 0)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, 0)) passed = 0; if (!do_test(lfd, &conn_addr, 0, SOCK_NONBLOCK)) passed = 0; if (!do_test(lfd, &conn_addr, SOCK_CLOEXEC, SOCK_NONBLOCK)) passed = 0; close(lfd); exit(passed ? EXIT_SUCCESS : EXIT_FAILURE); } [mtk.manpages@gmail.com: rewrote changelog, updated test program] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Tested-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <linux-api@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the networking subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: netdev@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/ath5k/base.c net/8021q/vlan_core.c
2008-11-03net: remove two duplicated #includeJianjun Kong
Removed duplicated #include <rdma/ib_verbs.h> in net/9p/trans_rdma.c and #include <linux/thread_info.h> in net/socket.c Signed-off-by: Jianjun Kong <jianjun@zeuux.org> Signed-off-by: David S. Miller <davem@davemloft.net>
