path: root/net/socket.c
2008-01-28[NET] sysctl: make sysctl_somaxconn per-namespacePavel Emelyanov
Just move the variable on the struct net and adjust its usage. Others sysctls from sys.net.core table are more difficult to virtualize (i.e. make them per-namespace), but I'll look at them as well a bit later. Signed-off-by: Pavel Emelyanov <xemul@oenvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Name magic constants in sock_wake_async()Pavel Emelyanov
The sock_wake_async() performs a bit different actions depending on "how" argument. Unfortunately this argument ony has numerical magic values. I propose to give names to their constants to help people reading this function callers understand what's going on without looking into this function all the time. I suppose this is 2.6.25 material, but if it's not (or the naming seems poor/bad/awful), I can rework it against the current net-2.6 tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Use sockfd_lookup_light in the rest of the net/socket.cPavel Emelyanov
Some time ago a sockfd_lookup_light was introduced and most of the socket.c file was patched to use it. However two routines were left - sys_sendto and sys_recvfrom. Patch them as well, since this helper does exactly what these two need. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[TCP]: Splice receive support.Jens Axboe
Support for network splice receive. Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-12[NET]: Add the helper kernel_sock_shutdown()Trond Myklebust
...and fix a couple of bugs in the NBD, CIFS and OCFS2 socket handlers. Looking at the sock->op->shutdown() handlers, it looks as if all of them take a SHUT_RD/SHUT_WR/SHUT_RDWR argument instead of the RCV_SHUTDOWN/SEND_SHUTDOWN arguments. Add a helper, and then define the SHUT_* enum to ensure that kernel users of shutdown() don't get confused. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-29[NET]: Fix error reporting in sys_socketpair().David S. Miller
If either of the two sock_alloc_fd() calls fail, we forget to update 'err' and thus we'll erroneously return zero in these cases. Based upon a report and patch from Rich Paul, and commentary from Chuck Ebbert. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17r/o bind mounts: filesystem helpers for custom 'struct file'sDave Hansen
Why do we need r/o bind mounts? This feature allows a read-only view into a read-write filesystem. In the process of doing that, it also provides infrastructure for keeping track of the number of writers to any given mount. This has a number of uses. It allows chroots to have parts of filesystems writable. It will be useful for containers in the future because users may have root inside a container, but should not be allowed to write to somefilesystems. This also replaces patches that vserver has had out of the tree for several years. It allows security enhancement by making sure that parts of your filesystem read-only (such as when you don't trust your FTP server), when you don't want to have entire new filesystems mounted, or when you want atime selectively updated. I've been using the following script to test that the feature is working as desired. It takes a directory and makes a regular bind and a r/o bind mount of it. It then performs some normal filesystem operations on the three directories, including ones that are expected to fail, like creating a file on the r/o mount. This patch: Some filesystems forego the vfs and may_open() and create their own 'struct file's. This patch creates a couple of helper functions which can be used by these filesystems, and will provide a unified place which the r/o bind mount code may patch. Also, rename an existing, static-scope init_file() to a less generic name. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: sanitize kernel_accept() error pathTony Battersby
If kernel_accept() returns an error, it may pass back a pointer to freed memory (which the caller should ignore). Make it pass back NULL instead for better safety. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: sparse warning fixesStephen Hemminger
Fix a bunch of sparse warnings. Mostly about 0 used as NULL pointer, and shadowed variable declarations. One notable case was that hash size should have been unsigned. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-27[NET]: Zero length write() on socket should not simply return 0.David S. Miller
This fixes kernel bugzilla #5731 It should generate an empty packet for datagram protocols when the socket is connected, for one. The check is doubly-wrong because all that a write() can be is a sendmsg() call with a NULL msg_control and a single entry iovec. No special semantics should be assigned to it, therefore the zero length check should be removed entirely. This matches the behavior of BSD and several other systems. Alan Cox notes that SuSv3 says the behavior of a zero length write on non-files is "unspecified", but that's kind of useless since BSD has defined this behavior for a quarter century and BSD is essentially what application folks code to. Based upon a patch from Stephen Hemminger. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-15[NET]: Fix unbalanced rcu_read_unlock in __sock_createHerbert Xu
The recent RCU work created an unbalanced rcu_read_unlock in __sock_create. This patch fixes that. Reported by oleg 123. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16O_CLOEXEC for SCM_RIGHTSUlrich Drepper
Part two in the O_CLOEXEC saga: adding support for file descriptors received through Unix domain sockets. The patch is once again pretty minimal, it introduces a new flag for recvmsg and passes it just like the existing MSG_CMSG_COMPAT flag. I think this bit is not used otherwise but the networking people will know better. This new flag is not recognized by recvfrom and recv. These functions cannot be used for that purpose and the asymmetry this introduces is not worse than the already existing MSG_CMSG_COMPAT situations. The patch must be applied on the patch which introduced O_CLOEXEC. It has to remove static from the new get_unused_fd_flags function but since scm.c cannot live in a module the function still hasn't to be exported. Here's a test program to make sure the code works. It's so much longer than the actual patch... #include <errno.h> #include <error.h> #include <fcntl.h> #include <stdio.h> #include <string.h> #include <unistd.h> #include <sys/socket.h> #include <sys/un.h> #ifndef O_CLOEXEC # define O_CLOEXEC 02000000 #endif #ifndef MSG_CMSG_CLOEXEC # define MSG_CMSG_CLOEXEC 0x40000000 #endif int main (int argc, char *argv[]) { if (argc > 1) { int fd = atol (argv[1]); printf ("child: fd = %d\n", fd); if (fcntl (fd, F_GETFD) == 0 || errno != EBADF) { puts ("file descriptor valid in child"); return 1; } return 0; } struct sockaddr_un sun; strcpy (sun.sun_path, "./testsocket"); sun.sun_family = AF_UNIX; char databuf[] = "hello"; struct iovec iov[1]; iov[0].iov_base = databuf; iov[0].iov_len = sizeof (databuf); union { struct cmsghdr hdr; char bytes[CMSG_SPACE (sizeof (int))]; } buf; struct msghdr msg = { .msg_iov = iov, .msg_iovlen = 1, .msg_control = buf.bytes, .msg_controllen = sizeof (buf) }; struct cmsghdr *cmsg = CMSG_FIRSTHDR (&msg); cmsg->cmsg_level = SOL_SOCKET; cmsg->cmsg_type = SCM_RIGHTS; cmsg->cmsg_len = CMSG_LEN (sizeof (int)); msg.msg_controllen = cmsg->cmsg_len; pid_t child = fork (); if (child == -1) error (1, errno, "fork"); if (child == 0) { int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (bind (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "bind"); if (listen (sock, SOMAXCONN) < 0) error (1, errno, "listen"); int conn = accept (sock, NULL, NULL); if (conn == -1) error (1, errno, "accept"); *(int *) CMSG_DATA (cmsg) = sock; if (sendmsg (conn, &msg, MSG_NOSIGNAL) < 0) error (1, errno, "sendmsg"); return 0; } /* For a test suite this should be more robust like a barrier in shared memory. */ sleep (1); int sock = socket (PF_UNIX, SOCK_STREAM, 0); if (sock < 0) error (1, errno, "socket"); if (connect (sock, (struct sockaddr *) &sun, sizeof (sun)) < 0) error (1, errno, "connect"); unlink (sun.sun_path); *(int *) CMSG_DATA (cmsg) = -1; if (recvmsg (sock, &msg, MSG_CMSG_CLOEXEC) < 0) error (1, errno, "recvmsg"); int fd = *(int *) CMSG_DATA (cmsg); if (fd == -1) error (1, 0, "no descriptor received"); char fdname[20]; snprintf (fdname, sizeof (fdname), "%d", fd); execl ("/proc/self/exe", argv[0], fdname, NULL); puts ("execl failed"); return 1; } [akpm@linux-foundation.org: Fix fastcall inconsistency noted by Michael Buesch] [akpm@linux-foundation.org: build fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Buesch <mb@bu3sch.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08VFS: delay the dentry name generation on sockets and pipesEric Dumazet
1) Introduces a new method in 'struct dentry_operations'. This method called d_dname() might be called from d_path() to build a pathname for special filesystems. It is called without locks. Future patches (if we succeed in having one common dentry for all pipes/sockets) may need to change prototype of this method, but we now use : char *d_dname(struct dentry *dentry, char *buffer, int buflen); 2) Adds a dynamic_dname() helper function that eases d_dname() implementations 3) Defines d_dname method for sockets : No more sprintf() at socket creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... 4) Defines d_dname method for pipes : No more sprintf() at pipe creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... A benchmark consisting of 1.000.000 calls to pipe()/close()/close() gives a *nice* speedup on my Pentium(M) 1.6 Ghz : 3.090 s instead of 3.450 s Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Christoph Hellwig <hch@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[SOCKET]: Export __sock_recv_timestampArnaldo Carvalho de Melo
Kernel: arch/x86_64/boot/bzImage is ready (#2) MODPOST 1816 modules WARNING: "__sock_recv_timestamp" [net/sctp/sctp.ko] undefined! WARNING: "__sock_recv_timestamp" [net/packet/af_packet.ko] undefined! WARNING: "__sock_recv_timestamp" [net/key/af_key.ko] undefined! WARNING: "__sock_recv_timestamp" [net/ipv6/ipv6.ko] undefined! WARNING: "__sock_recv_timestamp" [net/atm/atm.ko] undefined! make[2]: *** [__modpost] Error 1 make[1]: *** [modules] Error 2 make: *** [_all] Error 2 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Adding SO_TIMESTAMPNS / SCM_TIMESTAMPNS supportEric Dumazet
Now that network timestamps use ktime_t infrastructure, we can add a new SOL_SOCKET sockopt SO_TIMESTAMPNS. This command is similar to SO_TIMESTAMP, but permits transmission of a 'timespec struct' instead of a 'timeval struct' control message. (nanosecond resolution instead of microsecond) Control message is labelled SCM_TIMESTAMPNS instead of SCM_TIMESTAMP A socket cannot mix SO_TIMESTAMP and SO_TIMESTAMPNS : the two modes are mutually exclusive. sock_recv_timestamp() became too big to be fully inlined so I added a __sock_recv_timestamp() helper function. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: linux-arch@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] core: whitespace cleanupStephen Hemminger
Fix whitespace around keywords. Fix indentation especially of switch statements. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-26[NET]: Correct accept(2) recovery after sock_attach_fd()Alexey Dobriyan
* d_alloc() in sock_attach_fd() fails leaving ->f_dentry of new file NULL * bail out to out_fd label, doing fput()/__fput() on new file * but __fput() assumes valid ->f_dentry and dereferences it Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-17[PATCH] AUDIT_FD_PAIRAl Viro
Provide an audit record of the descriptor pair returned by pipe() and socketpair(). Rewritten from the original posted to linux-audit by John D. Ramsdell <ramsdell@mitre.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-02-12[PATCH] mark struct file_operations const 8Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET]: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NET]: Fix net/socket.c warnings.David S. Miller
GCC (correctly) says: net/socket.c: In function ‘sys_sendto’: net/socket.c:1510: warning: ‘err’ may be used uninitialized in this function net/socket.c: In function ‘sys_recvfrom’: net/socket.c:1571: warning: ‘err’ may be used uninitialized in this function sock_from_file() either returns filp->private_data or it sets *err and returns NULL. Callers return "err" on NULL, but filp->private_data could be NULL. Some minor rearrangements of error handling in sys_sendto and sys_recvfrom solves the issue. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[NET]: cleanup sock_from_file()Eric Dumazet
I believe dead code from sock_from_file() can be cleaned up. All sockets are now built using sock_attach_fd(), that puts the 'sock' pointer into file->private_data and &socket_file_ops into file->f_op I could not find a place where file->private_data could be set to NULL, keeping opened the file. So to get 'sock' from a 'file' pointer, either : - This is a socket file (f_op == &socket_file_ops), and we can directly get 'sock' from private_data. - This is not a socket, we return -ENOTSOCK and dont even try to find a socket via dentry/inode :) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-08[PATCH] struct path: convert netJosef Sipek
2006-12-07[PATCH] net: don't insert socket dentries into dentry_hashtableEric Dumazet
We currently insert socket dentries into the global dentry hashtable. This is suboptimal because there is currently no way these entries can be used for a lookup(). (/proc/xxx/fd/xxx uses a different mechanism). Inserting them in dentry hashtable slows dcache lookups. To let __dpath() still work correctly (ie not adding a " (deleted)") after dentry name, we do : - Right after d_alloc(), pretend they are hashed by clearing the DCACHE_UNHASHED bit. - Call d_instantiate() instead of d_add() : dentry is not inserted in hash table. __dpath() & friends work as intended during dentry lifetime. - At dismantle time, once dput() must clear the dentry, setting again DCACHE_UNHASHED bit inside the custom d_delete() function provided by socket code, so that dput() can just kill_it. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[NET]: The scheduled removal of the frame diverter.Adrian Bunk
This patch contains the scheduled removal of the frame diverter. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-02[PATCH] file: modify struct fown_struct to use a struct pidEric W. Biederman
File handles can be requested to send sigio and sigurg to processes. By tracking the destination processes using struct pid instead of pid_t we make the interface safe from all potential pid wrap around problems. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22[NET]: Change somaxconn sysctl to __read_mostlyBrian Haley
Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Kill double initialization in sock_alloc_inode.David S. Miller
No need to set ei->socket.flags to zero twice. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: sock_register interface changesStephen Hemminger
The sock_register() doesn't change the family, so the protocols can define it read-only. No caller ever checks return value from sock_unregister() Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: socket family using RCUStephen Hemminger
Replace the gross custom locking done in socket code for net_family[] with simple RCU usage. Some reordering necessary to avoid sleep issues with sock_alloc. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET] socket: code style cleanupStephen Hemminger
Make socket.c conform to current style: * run through Lindent * get rid of unneeded casts * split assignment and comparsion where possible Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Round out in-kernel sockets APISridhar Samudrala
This patch implements wrapper functions that provide a convenient way to access the sockets API for in-kernel users like sunrpc, cifs & ocfs2 etc and any future users. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: SELinux supportVenkat Yekkirala
Add NetLabel support to the SELinux LSM and modify the socket_post_create() LSM hook to return an error code. The most significant part of this patch is the addition of NetLabel hooks into the following SELinux LSM hooks: * selinux_file_permission() * selinux_socket_sendmsg() * selinux_socket_post_create() * selinux_socket_sock_rcv_skb() * selinux_socket_getpeersec_stream() * selinux_socket_getpeersec_dgram() * selinux_sock_graft() * selinux_inet_conn_request() The basic reasoning behind this patch is that outgoing packets are "NetLabel'd" by labeling their socket and the NetLabel security attributes are checked via the additional hook in selinux_socket_sock_rcv_skb(). NetLabel itself is only a labeling mechanism, similar to filesystem extended attributes, it is up to the SELinux enforcement mechanism to perform the actual access checks. In addition to the changes outlined above this patch also includes some changes to the extended bitmap (ebitmap) and multi-level security (mls) code to import and export SELinux TE/MLS attributes into and out of NetLabel. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-31[NET]: Rate limiting for socket allocation failure messages.Akinobu Mita
This patch limits the warning messages when socket allocation failures happen. It happens under memory pressure. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] sockaddr patchSteve Grubb
On Thursday 23 March 2006 09:08, John D. Ramsdell wrote: > I noticed that a socketcall(bind) and socketcall(connect) event contain a > record of type=SOCKADDR, but I cannot see one for a system call event > associated with socketcall(accept). Recording the sockaddr of an accepted > socket is important for cross platform information flow analys Thanks for pointing this out. The following patch should address this. Signed-off-by: Steve Grubb <sgrubb@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-04-19[NET]: sockfd_lookup_light() returns random error for -EBADFDHua Zhong
This applies to 2.6.17-rc2. There is a missing initialization of err in sockfd_lookup_light() that could return random error for an invalid file handle. Signed-off-by: Hua Zhong <hzhong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-11Merge branch 'splice' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] vfs: add splice_write and splice_read to documentation [PATCH] Remove sys_ prefix of new syscalls from __NR_sys_* [PATCH] splice: warning fix [PATCH] another round of fs/pipe.c cleanups [PATCH] splice: comment styles [PATCH] splice: add Ingo as addition copyright holder [PATCH] splice: unlikely() optimizations [PATCH] splice: speedups and optimizations [PATCH] pipe.c/fifo.c code cleanups [PATCH] get rid of the PIPE_*() macros [PATCH] splice: speedup __generic_file_splice_read [PATCH] splice: add direct fd <-> fd splicing support [PATCH] splice: add optional input and output offsets [PATCH] introduce a "kernel-internal pipe object" abstraction [PATCH] splice: be smarter about calling do_page_cache_readahead() [PATCH] splice: optimize the splice buffer mapping [PATCH] splice: cleanup __generic_file_splice_read() [PATCH] splice: only call wake_up_interruptible() when we really have to [PATCH] splice: potential !page dereference [PATCH] splice: mark the io page as accessed
2006-04-11[PATCH] for_each_possible_cpu: network codesKAMEZAWA Hiroyuki
for_each_cpu() actually iterates across all possible CPUs. We've had mistakes in the past where people were using for_each_cpu() where they should have been iterating across only online or present CPUs. This is inefficient and possibly buggy. We're renaming for_each_cpu() to for_each_possible_cpu() to avoid this in the future. This patch replaces for_each_cpu with for_each_possible_cpu under /net Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
