path: root/net/sched
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-17[PKT_SCHED]: Fix datalen check in tcf_simp_init().Patrick McHardy
datalen is unsigned so it can never be less than zero, but that's ok because the attribute passed to nla_len() has been validated and therefore a negative return value is impossible. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[NET_SCHED] sch_api: fix qdisc_tree_decrease_qlen() loopJarek Poplawski
TC_H_MAJ(parentid) for root classes is the same as for ingress, and if ingress qdisc is created qdisc_lookup() returns its pointer (without ingress NULL is returned). After this all qdisc_lookups give the same, and we get endless loop. (I don't know how this could hide for so long - it should trigger with every leaf class deleted if it's qdisc isn't empty.) After this fix qdisc_lookup() is omitted both for ingress and root parents, but looking for root is only wasting a little time here... Many thanks to Enrico Demarin for finding a test for catching this bug, which probably bothered quite a lot of admins. Reported-by: Enrico Demarin <enrico@superclick.com>, Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-12[NET_SCHED] cls_u32: refcounting fix for u32_delete()Jarek Poplawski
Deleting of nonroot hnodes mostly doesn't work in u32_delete(): refcnt == 1 is expected, but such hnodes' refcnts are initialized with 0 and charged only with "link" nodes. Now they'll start with 1 like usual. Thanks to Patrick McHardy for an improving suggestion. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-02Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/s2io.c
2008-03-28[NET]: Add preemption point in qdisc_runHerbert Xu
The qdisc_run loop is currently unbounded and runs entirely in a softirq. This is bad as it may create an unbounded softirq run. This patch fixes this by calling need_resched and breaking out if necessary. It also adds a break out if the jiffies value changes since that would indicate we've been transmitting for too long which starves other softirqs. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-23Merge branch 'master' of ../net-2.6/David S. Miller
Conflicts: net/ipv6/ndisc.c
2008-03-23sch_htb: fix "too many events" situationMartin Devera
HTB is event driven algorithm and part of its work is to apply scheduled events at proper times. It tried to defend itself from livelock by processing only limited number of events per dequeue. Because of faster computers some users already hit this hardcoded limit. This patch limits processing up to 2 jiffies (why not 1 jiffie ? because it might stop prematurely when only fraction of jiffie remains). Signed-off-by: Martin Devera <devik@cdi.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-17[PKT_SCHED]: annotate cls_u32Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05[IPV4]: Add 'rtable' field in struct sk_buff to alias 'dst' and avoid castsEric Dumazet
(Anonymous) unions can help us to avoid ugly casts. A common cast it the (struct rtable *)skb->dst one. Defining an union like : union { struct dst_entry *dst; struct rtable *rtable; }; permits to use skb->rtable in place. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-10[PKT_SCHED] ematch: Fix build warning.David S. Miller
Commit 954415e33ed6cfa932c13e8c2460bd05e50723b5 ("[PKT_SCHED] ematch: tcf_em_destroy robustness") removed a cast on em->data when passing it to kfree(), but em->data is an integer type that can hold pointers as well as other values so the cast is necessary. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09[NET_SCHED] sch_htb: htb_requeue fixJarek Poplawski
htb_requeue() enqueues skbs for which htb_classify() returns NULL. This is wrong because such skbs could be handled by NET_CLS_ACT code, and the decision could be different than earlier in htb_enqueue(). So htb_requeue() is changed to work and look more like htb_enqueue(). Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09[PKT_SCHED] ematch: tcf_em_destroy robustnessStephen Hemminger
Make the code in tcf_em_tree_destroy more robust and cleaner: * Don't need to cast pointer to kfree() or avoid passing NULL. * After freeing the tree, clear the pointer to avoid possible problems from repeated free. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09[PKT_SCHED]: deinline functions in meta matchStephen Hemminger
A couple of functions in meta match don't need to be inline. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09[PKT_SCHED] ematch: oops from uninitialized variable (resend)Stephen Hemminger
Setting up a meta match causes a kernel OOPS because of uninitialized elements in tree. [ 37.322381] BUG: unable to handle kernel NULL pointer dereference at 0000000000000000 [ 37.322381] IP: [<ffffffff883fc717>] :em_meta:em_meta_destroy+0x17/0x80 [ 37.322381] Call Trace: [ 37.322381] [<ffffffff803ec83d>] tcf_em_tree_destroy+0x2d/0xa0 [ 37.322381] [<ffffffff803ecc8c>] tcf_em_tree_validate+0x2dc/0x4a0 [ 37.322381] [<ffffffff803f06d2>] nla_parse+0x92/0xe0 [ 37.322381] [<ffffffff883f9672>] :cls_basic:basic_change+0x202/0x3c0 [ 37.322381] [<ffffffff802a3917>] kmem_cache_alloc+0x67/0xa0 [ 37.322381] [<ffffffff803ea221>] tc_ctl_tfilter+0x3b1/0x580 [ 37.322381] [<ffffffff803dffd0>] rtnetlink_rcv_msg+0x0/0x260 [ 37.322381] [<ffffffff803ee944>] netlink_rcv_skb+0x74/0xa0 [ 37.322381] [<ffffffff803dffc8>] rtnetlink_rcv+0x18/0x20 [ 37.322381] [<ffffffff803ee6c3>] netlink_unicast+0x263/0x290 [ 37.322381] [<ffffffff803cf276>] __alloc_skb+0x96/0x160 [ 37.322381] [<ffffffff803ef014>] netlink_sendmsg+0x274/0x340 [ 37.322381] [<ffffffff803c7c3b>] sock_sendmsg+0x12b/0x140 [ 37.322381] [<ffffffff8024de90>] autoremove_wake_function+0x0/0x30 [ 37.322381] [<ffffffff8024de90>] autoremove_wake_function+0x0/0x30 [ 37.322381] [<ffffffff803c7c3b>] sock_sendmsg+0x12b/0x140 [ 37.322381] [<ffffffff80288611>] zone_statistics+0xb1/0xc0 [ 37.322381] [<ffffffff803c7e5e>] sys_sendmsg+0x20e/0x360 [ 37.322381] [<ffffffff803c7411>] sockfd_lookup_light+0x41/0x80 [ 37.322381] [<ffffffff8028d04b>] handle_mm_fault+0x3eb/0x7f0 [ 37.322381] [<ffffffff8020c2fb>] system_call_after_swapgs+0x7b/0x80 Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07[TC]: oops in em_metaStephen Hemminger
If userspace passes a unknown match index into em_meta, then em_meta_change will return an error and the data for the match will not be set. This then causes an null pointer dereference when the cleanup is done in the error path via tcf_em_tree_destroy. Since the tree structure comes kzalloc, it is initialized to NULL. Discovered when testing a new version of tc command against an accidental older kernel. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[NET_SCHED]: cls_flow: support classification based on VLAN tagPatrick McHardy
2008-02-05[NET_SCHED]: cls_flow: fix key mask validity checkPatrick McHardy
Since we're using fls(), we need to check whether the value is non-zero first. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[NET_SCHED]: em_meta: fix compile warningPatrick McHardy
net/sched/em_meta.c: In function 'meta_int_vlan_tag': net/sched/em_meta.c:179: warning: 'tag' may be used uninitialized in this function Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[PKT_SCHED]: vlan tag matchStephen Hemminger
Provide a way to use tc filters on vlan tag even if tag is buried in skb due to hardware acceleration. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[NET_SCHED]: Add #ifdef CONFIG_NET_EMATCH in net/sched/cls_flow.c (latest ↵Rami Rosen
git broken build) The 2.6 latest git build was broken when using the following configuration options: CONFIG_NET_EMATCH=n CONFIG_NET_CLS_FLOW=y with the following error: net/sched/cls_flow.c: In function 'flow_dump': net/sched/cls_flow.c:598: error: 'struct tcf_ematch_tree' has no member named 'hdr' make[2]: *** [net/sched/cls_flow.o] Error 1 make[1]: *** [net/sched] Error 2 make: *** [net] Error 2 see the recent post by Li Zefan: http://www.spinics.net/lists/netdev/msg54434.html The reason for this crash is that struct tcf_ematch_tree (net/pkt_cls.h) is empty when CONFIG_NET_EMATCH is not defined. When CONFIG_NET_EMATCH is defined, the tcf_ematch_tree structure indeed holds a struct tcf_ematch_tree_hdr (hdr) as flow_dump() expects. This patch adds #ifdef CONFIG_NET_EMATCH in flow_dump to avoid this. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NET_SCHED]: Add flow classifierPatrick McHardy
Add new "flow" classifier, which is meant to extend the SFQ hashing capabilities without hard-coding new hash functions and also allows deterministic mappings of keys to classes, replacing some out of tree iptables patches like IPCLASSIFY (maps IPs to classes), IPMARK (maps IPs to marks, with fw filters to classes), ... Some examples: - Classic SFQ hash: tc filter add ... flow hash \ keys src,dst,proto,proto-src,proto-dst divisor 1024 - Classic SFQ hash, but using information from conntrack to work properly in combination with NAT: tc filter add ... flow hash \ keys nfct-src,nfct-dst,proto,nfct-proto-src,nfct-proto-dst divisor 1024 - Map destination IPs of 192.168.0.0/24 to classids 1-257: tc filter add ... flow map \ key dst addend -192.168.0.0 divisor 256 - alternatively: tc filter add ... flow map \ key dst and 0xff - similar, but reverse ordered: tc filter add ... flow map \ key dst and 0xff xor 0xff Perturbation is currently not supported because we can't reliable kill the timer on destruction. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NET_SCHED]: sch_sfq: make internal queues visible as classesPatrick McHardy
Add support for dumping statistics and make internal queues visible as classes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NET_SCHED]: sch_sfq: add support for external classifiersPatrick McHardy
Add support for external classifiers to allow using different flow hash functions similar to ESFQ. When no classifier is attached the built-in hash is used as before. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NET_SCHED]: Constify struct tcf_ext_mapPatrick McHardy
2008-01-31[PKT_SCHED] sch_teql.c: Duplicate IFF_BROADCAST in FMASK, remove 2nd.Roel Kluin
Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NET_SCHED]: sch_ingress: remove netfilter supportPatrick McHardy
Since the old policer code is gone, TC actions are needed for policing. The ingress qdisc can get packets directly from netif_receive_skb() in case TC actions are enabled or through netfilter otherwise, but since without TC actions there is no policer the only thing it actually does is count packets. Remove the netfilter support and always require TC actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in ematchesPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in actionsPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in classifiersPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_policy for attribute validation in packet schedulersPatrick McHardy
2008-01-28[NET_SCHED]: sch_api: introduce constant for rate table sizePatrick McHardy
2008-01-28[NET_SCHED]: Use typeful attribute parsing helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use typeful attribute construction helpersPatrick McHardy
2008-01-28[NET_SCHED]: Use NLA_PUT_STRING for string dumpingPatrick McHardy
2008-01-28[NET_SCHED]: Use nla_nest_start/nla_nest_endPatrick McHardy
Use nla_nest_start/nla_nest_end for dumping nested attributes. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Propagate nla_parse return valuePatrick McHardy
nla_parse() returns more detailed errno codes, propagate them back on error. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: act_api: use PTR_ERR in tcf_action_init/tcf_action_getPatrick McHardy
2008-01-28[NET_SCHED]: act_api: use nlmsg_parsePatrick McHardy
Convert open-coded nlmsg_parse to use the real function. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: act_api: fix netlink API conversion bugPatrick McHardy
Fix two invalid attribute accesses, indices start at 1 with the new netlink API. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_netem: use nla_parse_nested_compatPatrick McHardy
Replace open coded equivalent of nla_parse_nested_compat(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: sch_atm: fix format string warningPatrick McHardy
Fix format string warning introduces by the netlink API conversion: net/sched/sch_atm.c:250: warning: format '%lu' expects type 'long unsigned int', but argument 3 has type 'int'. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Convert actions from rtnetlink to new netlink APIPatrick McHardy
2008-01-28[NET_SCHED]: Convert classifiers from rtnetlink to new netlink APIPatrick McHardy
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: mark classifier ops __read_mostlyPatrick McHardy
Additionally remove unnecessary NULL initilizations of the next pointer. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET_SCHED]: Move EXPORT_SYMBOL next to exported symbolPatrick McHardy
