path: root/net/sched
2007-04-25[NET_SCHED]: qdisc: remove unnecessary memory barriersPatrick McHardy
We're holding dev->queue_lock in qdisc_watchdog_schedule and qdisc_watchdog_cancel, no need for the barriers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Unline tcf_destroyPatrick McHardy
Uninline tcf_destroy and add a helper function to destroy an entire filter chain. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: turn PSCHED_GET_TIME into inline functionPatrick McHardy
2007-04-25[NET_SCHED]: turn PSCHED_TDIFF_SAFE into inline functionPatrick McHardy
Also rename to psched_tdiff_bounded. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: kill PSCHED_TDIFFPatrick McHardy
2007-04-25[NET_SCHED]: kill PSCHED_SET_PASTPERFECT/PSCHED_IS_PASTPERFECTPatrick McHardy
Use direct assignment and comparison instead. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: kill PSCHED_TLESSPatrick McHardy
2007-04-25[NET_SCHED]: kill PSCHED_TADD/PSCHED_TADD2Patrick McHardy
2007-04-25[NET_SCHED]: kill PSCHED_AUDIT_TDIFFPatrick McHardy
2007-04-25[NET_SCHED]: sch_netem: fix off-by-one in send time comparisonPatrick McHardy
netem checks PSCHED_TLESS(cb->time_to_send, now) to find out whether it is allowed to send a packet, which is equivalent to cb->time_to_send < now. Use !PSCHED_TLESS(now, cb->time_to_send) instead to properly handle cb->time_to_send == now. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETEM]: spelling errorsStephen Hemminger
Get rid of some of my creative spelling. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED] qdisc: avoid transmit softirq on watchdog wakeupStephen Hemminger
If possible, avoid having to do a transmit softirq when a qdisc watchdog decides to re-enable. The watchdog routine runs off a timer, so it is already in the same effective context as the softirq. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETEM]: avoid excessive requeuesStephen Hemminger
The netem code would call getnstimeofday() and dequeue/requeue after every packet, even if it was waiting. Avoid this overhead by using the throttled flag. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETEM]: Optimize tfifoStephen Hemminger
In most cases, the next packet will be sent after the last one. So optimize that case. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETEM]: use better types for time valuesStephen Hemminger
The random number generator always generates 32 bit values. The time values are limited by psched_tdiff_t Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETEM]: report reorder percent correctly.Stephen Hemminger
If you setup netem to just delay packets; "tc qdisc ls" will report the reordering as 100%. Well it's a lie, reorder isn't used unless gap is set, so just set value to 0 so the output of utility is correct. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKT_SCHED] act: Use rtnl registration interfaceThomas Graf
Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[PKT_SCHED] cls: Use rtnl registration interfaceThomas Graf
2007-04-25[PKT_SCHED] qdisc: Use rtnl registration interfaceThomas Graf
2007-04-25[NETLINK]: Use nlmsg_trim() where appropriateArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Fix warningPatrick McHardy
net/sched/sch_api.c: In function 'psched_show': net/sched/sch_api.c:1219: warning: format '%08x' expects type 'unsigned int', but argument 6 has type 's64' Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: sch_cbq: fix watchdog scheduled too latePatrick McHardy
q->now is increased during dequeue and doesn't contain the current time afterwards, resulting in a too large timeout value for the qdisc watchdog. Use "now" instead, which still contains the current time. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: Export real timer resolution in /proc/net/pschedPatrick McHardy
The timer resolution exported in /proc/net/psched is used by userspace to calculate HTB's burst values. Currently it is set to HZ, since we're now using hrtimers, use KTIME_MONOTONIC_RES, which makes HTB use smaller burst values. This patch also affects libnl, which incorrectly uses this value for the SFQ perturbation parameter, which is always in seconds, and some routing cache values, which are in USER_HZ, so both cases are broken anyway. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: kill jiffie conversion macrosPatrick McHardy
Now that all packet schedulers have been converted to hrtimers most users of PSCHED_JIFFIE2US and PSCHED_US2JIFFIE are gone. The remaining users use it to convert external time units to packet scheduler clock ticks, so use PSCHED_TICKS_PER_SEC instead. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: sch_htb: use hrtimer based watchdogPatrick McHardy
2007-04-25[NET_SCHED]: sch_cbq: use hrtimer for delay_timerPatrick McHardy
Switch delay_timer to hrtimer. The class penalty parameter is changed to use psched ticks as units. Since iproute never supported using this and the only existing user (libnl) incorrectly assumes psched ticks as units anyway, this shouldn't break anything. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: sch_cbq: fix cbq_undelay_prio for non-active prioritesPatrick McHardy
cbq_undelay_prio is supposed to return a time delta, but returns the current time for non-active priorities, causing cbq_undelay to mark the priority as active and schedule a timer for twice the current time. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET_SCHED]: sch_cbq: use hrtimer based watchdogPatrick McHardy
2007-04-25[NET_SCHED]: sch_netem: use hrtimer based watchdogPatrick McHardy
2007-04-25[NET_SCHED]: sch_tbf: use hrtimer based watchdogPatrick McHardy
2007-04-25[NET_SCHED]: sch_hfsc: use hrtimer based watchdogPatrick McHardy
2007-04-25[NET_SCHED]: Add hrtimer based qdisc watchdogPatrick McHardy
2007-04-25[NET_SCHED]: Use ktime as clocksourcePatrick McHardy
Get rid of the manual clock source selection mess and use ktime. Also use a scalar representation, which allows to clean up pkt_sched.h a bit more and results in less ktime_to_ns() calls in most cases. The PSCHED_US2JIFFIE/PSCHED_JIFFIE2US macros are implemented quite inefficient by this patch, following patches will convert all qdiscs to hrtimers and get rid of them entirely. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->nh.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET] SCHED: Use htons() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-09[NET_SCHED]: cls_tcindex: fix compatibility breakagePatrick McHardy
Userspace uses an integer for TCA_TCINDEX_SHIFT, the kernel was changed to expect and use a u16 value in 2.6.11, which broke compatibility on big endian machines. Change back to use int. Reported by Ole Reinartz <ole.reinartz@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-02[NET_SCHED]: cls_basic: fix memory leak in basic_destroyPatrick McHardy
tp->root is not freed on destruction. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-29[IFB]: Fix crash on input device removalPatrick McHardy
The input_device pointer is not refcounted, which means the device may disappear while packets are queued, causing a crash when ifb passes packets with a stale skb->dev pointer to netif_rx(). Fix by storing the interface index instead and do a lookup where neccessary. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-27[NET_SCHED]: sch_htb/sch_hfsc: fix oops in qlen_notifyPatrick McHardy
During both HTB and HFSC class deletion the class is removed from the class hash before calling qdisc_tree_decrease_qlen. This makes the ->get operation in qdisc_tree_decrease_qlen fail, so it passes a NULL pointer to ->qlen_notify, causing an oops. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-26[NET]: Remove dead net/sched/Makefile entry for sch_hpfq.o.Robert P. J. Day
Remove the worthless net/sched/Makefile entry for the non-existent source file sch_hpfq.c. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-25[NET_SCHED]: cls_basic: fix NULL pointer dereferencePatrick McHardy
cls_basic doesn't allocate tp->root before it is linked into the active classifier list, resulting in a NULL pointer dereference when packets hit the classifier before its ->change function is called. Reported by Chris Madden <chris@reflexsecurity.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-22[NET]: fix up misplaced inlines.Dave Jones
Turning up the warnings on gcc makes it emit warnings about the placement of 'inline' in function declarations. Here's everything that was under net/ Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-13[NET_SCHED]: sch_hfsc: replace ASSERT macro by WARN_ONPatrick McHardy
2007-02-12[PATCH] mark struct file_operations const 8Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] SCHED: Fix whitespace errors.YOSHIFUJI Hideaki
