commit de960aa9ab4decc3304959f69533eef64d05d8e8 upstream.
This moves part of Eric Dumazets skb_gso_seglen helper from tbf sched to
skbuff core so it may be reused by upcoming ip forwarding path patch.
[ Upstream commit 4d0820cf6a55d72350cb2d24a4504f62fbde95d9 ]
If a too small burst is inadvertently set on TBF, we might trigger
a bug in tbf_segment(), as 'skb' instead of 'segs' was used in a
qdisc_reshape_fail() call.
tc qdisc add dev eth0 root handle 1: tbf latency 50ms burst 1KB rate
50mbit
Fix the bug, and add a warning, as such configuration is not
going to work anyway for non GSO packets.
(For some reason, one has to use a burst >= 1520 to get a working
configuration, even with old kernels. This is a probable iproute2/tc
bug)
Based on a report and initial patch from Yang Yingliang
Fixes: e43ac79a4bc6 ("sch_tbf: segment too big GSO packets")
Reported-by: Yang Yingliang <yangyingliang@huawei.com>
Merge 'net' bug fixes into 'net-next' as we have patches
that will build on top of them.
This merge commit includes a change from Emil Goode
(emilgoode@gmail.com) that fixes a warning that would
have been introduced by this merge. Specifically it
fixes the pingv6_ops method ipv6_chk_addr() to add a
"const" to the "struct net_device *dev" argument and
likewise update the dummy_ipv6_chk_addr() declaration.
commit 56b765b79 ("htb: improved accuracy at high rates")
broke the "overhead xxx" handling, as well as the "linklayer atm"
attribute.
tc class add ... htb rate X ceil Y linklayer atm overhead 10
This patch restores the "overhead xxx" handling, for htb, tbf
and act_police
The "linklayer atm" thing needs a separate fix.
Reported-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Vimalkumar <j.vimal@gmail.com>
Cc: Jiri Pirko <jpirko@redhat.com>
If a GSO packet has a length above tbf burst limit, the packet
is currently silently dropped.
Current way to handle this is to set the device in non GSO/TSO mode, or
setting high bursts, and its sub optimal.
We can actually segment too big GSO packets, and send individual
segments as tbf parameters allow, allowing for better interoperability.
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Jiri Pirko <jiri@resnulli.us>
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
Current TBF uses rate table computed by the "tc" userspace program,
which has the following issue:
The rate table has 256 entries to map packet lengths to
token (time units). With TSO sized packets, the 256 entry granularity
leads to loss/gain of rate, making the token bucket inaccurate.
Thus, instead of relying on rate table, this patch explicitly computes
the time and accounts for packet transmission times with nanosecond
granularity.
This is a followup to 56b765b79e9a78dc7d3f8850ba5e5567205a3ecd
("htb: improved accuracy at high rates").
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
Provide child qdisc backlog (byte count) information so that "tc -s
qdisc" can report it to user.
qdisc netem 30: root refcnt 18 limit 1000 delay 20.0ms 10.0ms
Sent 948517 bytes 898 pkt (dropped 0, overlimits 0 requeues 1)
rate 175056bit 16pps backlog 114b 1p requeues 1
qdisc tbf 40: parent 30: rate 256000bit burst 20Kb/8 mpu 0b lat 0us
Sent 948517 bytes 898 pkt (dropped 15, overlimits 611 requeues 0)
backlog 18168b 12p requeues 0
net/sched/sch_hfsc.c
net/sched/sch_htb.c
net/sched/sch_tbf.c
In commit 44b8288308ac9d (net_sched: pfifo_head_drop problem), we fixed
a problem with pfifo_head drops that incorrectly decreased
sch->bstats.bytes and sch->bstats.packets
Several qdiscs (CHOKe, SFQ, pfifo_head, ...) are able to drop a
previously enqueued packet, and bstats cannot be changed, so
bstats/rates are not accurate (over estimated)
This patch changes the qdisc_bstats updates to be done at dequeue() time
instead of enqueue() time. bstats counters no longer account for dropped
frames, and rates are more correct, since enqueue() bursts dont have
effect on dequeue() rate.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
In commit 371121057607e (net: QDISC_STATE_RUNNING dont need atomic bit
ops) I moved QDISC_STATE_RUNNING flag to __state container, located in
the cache line containing qdisc lock and often dirtied fields.
I now move TCQ_F_THROTTLED bit too, so that we let first cache line read
mostly, and shared by all cpus. This should speedup HTB/CBQ for example.
Not using test_bit()/__clear_bit()/__test_and_set_bit allows to use an
"unsigned int" for __state container, reducing by 8 bytes Qdisc size.
Introduce helpers to hide implementation details.
CC: Patrick McHardy <kaber@trash.net>
CC: Jesper Dangaard Brouer <hawk@diku.dk>
CC: Jarek Poplawski <jarkao2@gmail.com>
CC: Jamal Hadi Salim <hadi@cyberus.ca>
CC: Stephen Hemminger <shemminger@vyatta.com>
Cleanup net/sched code to current CodingStyle and practices.
Reduce inline abuse
HTB takes into account skb is segmented in stats updates.
Generalize this to all schedulers.
They should use qdisc_bstats_update() helper instead of manipulating
bstats.bytes and bstats.packets
Add bstats_update() helper too for classes that use
gnet_stats_basic_packed fields.
Note : Right now, TCQ_F_CAN_BYPASS shortcurt can be taken only if no
stab is setup on qdisc.
This is based on work originally done by Patric McHardy.
Signed-off-by: Ben Greear <greearb@candelatech.com>
Several netem users use TBF for rate control. But every time the parameters
of TBF are changed it destroys the child qdisc, requiring reconfigation.
Better to just keep child qdisc and just notify it of changed limit.
The class argument to the ->graft(), ->leaf(), ->dump(), ->dump_stats() all
originate from either ->get() or ->walk() and are always valid.
Remove unnecessary checks.
Some schedulers don't support creating, changing or deleting classes.
Make the respective callbacks optionally and consistently return
-EOPNOTSUPP for unsupported operations, instead of currently either
-EOPNOTSUPP, -ENOSYS or no error.
In case of sch_prio and sch_multiq, the removed operations additionally
checked for an invalid class. This is not necessary since the class
argument can only orginate from ->get() or in case of ->change is 0
for creation of new classes, in which case ->change() incorrectly
returned -ENOENT.
As a side-effect, this patch fixes a possible (root-only) NULL pointer
function call in sch_ingress, which didn't implement a so far mandatory
->delete() operation.
Some qdiscs don't support attaching filters. Handle this centrally in
cls_api and return a proper errno code (EOPNOTSUPP) instead of EINVAL.
tcp_sack_swap seems unnecessary so I pushed swap to the caller.
Also removed comment that seemed then pointless, and added include
when not already there. Compile tested.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
The use of xchg() hasn't been necessary since 2.2.something when proper
locking was added to packet schedulers.
After implementing qdisc->ops->peek() and changing sch_netem into
classless qdisc there are no more qdisc->ops->requeue() users. This
patch removes this method with its wrappers (qdisc_requeue()), and
also unused qdisc->requeue structure. There are a few minor fixes of
warnings (htb_enqueue()) and comments btw.
The idea to kill ->requeue() and a similar patch were first developed
by David S. Miller.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
This patch adds qdisc_peek_dequeued() wrapper to emulate peek method
with qdisc->dequeue() and storing "peeked" skb in qdisc->gso_skb until
dequeuing. This is mainly for compatibility reasons not to break some
strange configs because peeking is expected for non-work-conserving
parent qdiscs to query work-conserving child qdiscs.
This implementation requires using qdisc_dequeue_peeked() wrapper
instead of directly calling qdisc->dequeue() for all qdiscs ever
querried with qdisc->ops->peek() or qdisc_peek_dequeued().
Use qdisc->ops->peek() instead of ->dequeue() & ->requeue() pair.
After this patch the only remaining user of qdisc->ops->requeue() is
netem_enqueue(). Based on ideas of Herbert Xu, Patrick McHardy and
David S. Miller.
Based upon a bug report by Josip Rodin.
Packet schedulers should only return NET_XMIT_DROP iff
the packet really was dropped. If the packet does reach
the device after we return NET_XMIT_DROP then TCP can
crash because it depends upon the enqueue path return
values being accurate.
Patrick McHardy <kaber@trash.net> noticed:
"The other problem that affects all qdiscs supporting actions is
TC_ACT_QUEUED/TC_ACT_STOLEN getting mapped to NET_XMIT_SUCCESS
even though the packet is not queued, corrupting upper qdiscs'
qlen counters."
and later explained:
"The reason why it translates it at all seems to be to not increase
the drops counter. Within a single qdisc this could be avoided by
other means easily, upper qdiscs would still increase the counter
when we return anything besides NET_XMIT_SUCCESS though.
This means we need a new NET_XMIT return value to indicate this to
the upper qdiscs. So I'd suggest to introduce NET_XMIT_STOLEN,
return that to upper qdiscs and translate it to NET_XMIT_SUCCESS
in dev_queue_xmit, similar to NET_XMIT_BYPASS."
David Miller <davem@davemloft.net> noticed:
"Maybe these NET_XMIT_* values being passed around should be a set of
bits. They could be composed of base meanings, combined with specific
attributes.
So you could say "NET_XMIT_DROP | __NET_XMIT_NO_DROP_COUNT"
The attributes get masked out by the top-level ->enqueue() caller,
such that the base meanings are the only thing that make their
way up into the stack. If it's only about communication within the
qdisc tree, let's simply code it that way."
This patch is trying to realize these ideas.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Use nla_nest_start/nla_nest_end for dumping nested attributes.
nla_parse() returns more detailed errno codes, propagate them back on
error.
Convert packet schedulers to use the netlink API. Unfortunately a gradual
conversion is not possible without breaking compilation in the middle or
adding lots of casts, so this patch converts them all in one step. The
patch has been mostly generated automatically with some minor edits to
at least allow seperate conversion of classifiers and actions.
Qdisc_class_ops are const, and Qdisc_ops are mostly read.
Using "const" and "__read_mostly" qualifiers helps to reduce false
sharing.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Change L2T (length to time) macros, in all rate based schedulers, to
call a common function qdisc_l2t() that does the rate table lookup.
This function handles if the packet size lookup is larger than the
rate table, which often occurs with TSO enabled.
Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk>
Acked-by: Patrick McHardy <kaber@trash.net>
The NET_CLS_ACT option is now a full replacement for NET_CLS_POLICE,
remove the old code. The config option will be kept around to select
the equivalent NET_CLS_ACT options for a short time to allow easier
upgrades.
The behaviour of NET_CLS_POLICE for TC_POLICE_RECLASSIFY was to return
it to the qdisc, which could handle it internally or ignore it. With
NET_CLS_ACT however, tc_classify starts over at the first classifier
and never returns it to the qdisc. This makes it impossible to support
qdisc-internal reclassification, which in turn makes it impossible to
remove the old NET_CLS_POLICE code without breaking compatibility since
we have two qdiscs (CBQ and ATM) that support this.
This patch adds a tc_classify_compat function that handles
reclassification the old way and changes CBQ and ATM to use it.
This again is of course not fully backwards compatible with the previous
NET_CLS_ACT behaviour. Unfortunately there is no way to fully maintain
compatibility *and* support qdisc internal reclassification with
NET_CLS_ACT, but this seems like the better choice over keeping the two
incompatible options around forever.
Also rename to psched_tdiff_bounded.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes
on 64bit architectures, allowing us to combine the 4 bytes hole left by the
layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4
64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN...
Many calculations that previously required that skb->{transport,network,
mac}_header be first converted to a pointer now can be done directly, being
meaningful as offsets or pointers.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
When peeking at the next packet in a child qdisc by calling dequeue/requeue,
the upper qdisc qlen counter may get out of sync in case the requeue fails.
The qdisc and the child qdisc both have their counter decremented, but since
no packet is given to the upper qdisc it won't decrement its counter itself.
requeue should not fail, so this is mostly for "correctness".
Convert the "simple" qdiscs to use qdisc_tree_decrease_qlen() where
necessary:
- all graft operations
- destruction of old child qdiscs in prio, red and tbf change operation
- purging of queue in sfq change operation
Set parent classids in default qdiscs to allow walking up the tree
from outside the qdiscs. This is needed by the next patch.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
When TBF was converted to a classful qdisc, the semantic of the limit
parameter was broken. On initilization an inner bfifo qdisc is created
for backwards compatibility, when changing parameters however the new
limit is ignored and the current child qdisc remains in place.
Always replace the child qdisc by the default bfifo when limit is above
zero, otherwise don't touch the inner qdisc. Current tc version enforce
a limit above zero, other users can avoid creating the inner qdisc by
using zero.
The drop operation is optional and qdiscs must check if childs support it.
infrastructure for it.
Let it rip!
