path: root/net/sched/sch_mq.c
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-21net_sched: TCQ_F_CAN_BYPASS generalizationEric Dumazet
Now qdisc stab is handled before TCQ_F_CAN_BYPASS test in __dev_xmit_skb(), we can generalize TCQ_F_CAN_BYPASS to other qdiscs than pfifo_fast : pfifo, bfifo, pfifo_head_drop and sfq SFQ is special because it can have external classifiers, and in these cases, we cannot bypass queue discipline (packet could be dropped by classifier) without admin asking it, or further changes. Its worth doing this, especially for SFQ, avoiding dirtying memory in case no packets are already waiting in queue. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21net_sched: remove the unused parameter of qdisc_create_dflt()Changli Gao
The first parameter dev isn't in use in qdisc_create_dflt(). Signed-off-by: Changli Gao <xiaosuo@gmail.com> Acked-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-17net: Remove unnecessary returns from void function()sJoe Perches
This patch removes from net/ (but not any netfilter files) all the unnecessary return; statements that precede the last closing brace of void functions. It does not remove the returns that are immediately preceded by a label as gcc doesn't like that. Done via: $ grep -rP --include=*.[ch] -l "return;\n}" net/ | \ xargs perl -i -e 'local $/ ; while (<>) { s/\n[ \t\n]+return;\n}/\n}/g; print; }' Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-17pkt_sched: Fix qstats.qlen updating in dump_statsJarek Poplawski
Some classful qdiscs miss qstats.qlen updating with q.qlen of their child qdiscs in dump_stats methods. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15pkt_sched: Fix tx queue selection in tc_modify_qdiscJarek Poplawski
After the recent mq change there is the new select_queue qdisc class method used in tc_modify_qdisc, but it works OK only for direct child qdiscs of mq qdisc. Grandchildren always get the first tx queue, which would give wrong qdisc_root etc. results (e.g. for sch_htb as child of sch_prio). This patch fixes it by using parent's dev_queue for such grandchildren qdiscs. The select_queue method's return type is changed BTW. With feedback from: Patrick McHardy <kaber@trash.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-09net_sched: fix estimator lock selection for mq child qdiscsPatrick McHardy
When new child qdiscs are attached to the mq qdisc, they are actually attached as root qdiscs to the device queues. The lock selection for new estimators incorrectly picks the root lock of the existing and to be replaced qdisc, which results in a use-after-free once the old qdisc has been destroyed. Mark mq qdisc instances with a new flag and treat qdiscs attached to mq as children similar to regular root qdiscs. Additionally prevent estimators from being attached to the mq qdisc itself since it only updates its byte and packet counters during dumps. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: add classful multiqueue dummy schedulerDavid S. Miller
This patch adds a classful dummy scheduler which can be used as root qdisc for multiqueue devices and exposes each device queue as a child class. This allows to address queues individually and graft them similar to regular classes. Additionally it presents an accumulated view of the statistics of all real root qdiscs in the dummy root. Two new callbacks are added to the qdisc_ops and qdisc_class_ops: - cl_ops->select_queue selects the tx queue number for new child classes. - qdisc_ops->attach() overrides root qdisc device grafting to attach non-shared qdiscs to the queues. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
