path: root/net/sched/sch_mq.c
2009-09-17pkt_sched: Fix qstats.qlen updating in dump_statsJarek Poplawski
Some classful qdiscs miss qstats.qlen updating with q.qlen of their child qdiscs in dump_stats methods. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15pkt_sched: Fix tx queue selection in tc_modify_qdiscJarek Poplawski
After the recent mq change there is the new select_queue qdisc class method used in tc_modify_qdisc, but it works OK only for direct child qdiscs of mq qdisc. Grandchildren always get the first tx queue, which would give wrong qdisc_root etc. results (e.g. for sch_htb as child of sch_prio). This patch fixes it by using parent's dev_queue for such grandchildren qdiscs. The select_queue method's return type is changed BTW. With feedback from: Patrick McHardy <kaber@trash.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-09net_sched: fix estimator lock selection for mq child qdiscsPatrick McHardy
When new child qdiscs are attached to the mq qdisc, they are actually attached as root qdiscs to the device queues. The lock selection for new estimators incorrectly picks the root lock of the existing and to be replaced qdisc, which results in a use-after-free once the old qdisc has been destroyed. Mark mq qdisc instances with a new flag and treat qdiscs attached to mq as children similar to regular root qdiscs. Additionally prevent estimators from being attached to the mq qdisc itself since it only updates its byte and packet counters during dumps. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-06net_sched: add classful multiqueue dummy schedulerDavid S. Miller
This patch adds a classful dummy scheduler which can be used as root qdisc for multiqueue devices and exposes each device queue as a child class. This allows to address queues individually and graft them similar to regular classes. Additionally it presents an accumulated view of the statistics of all real root qdiscs in the dummy root. Two new callbacks are added to the qdisc_ops and qdisc_class_ops: - cl_ops->select_queue selects the tx queue number for new child classes. - qdisc_ops->attach() overrides root qdisc device grafting to attach non-shared qdiscs to the queues. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
