[ Upstream commit 3f1e6d3fd37bd4f25e5b19f1c7ca21850426c33f ]
gred_change_vq() is called under sch_tree_lock(sch).
This means a spinlock is held, and we are not allowed to sleep in this
context.
We might pre-allocate memory using GFP_KERNEL before taking spinlock,
but this is not suitable for stable material.
Change-Id: I79a25778ca9fbc4ea2bd8c1f32d73bd73a1a3817
Reviewed-on: http://git-master/r/74218
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Cleanup net/sched code to current CodingStyle and practices.
Reduce inline abuse
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
After implementing qdisc->ops->peek() and changing sch_netem into
classless qdisc there are no more qdisc->ops->requeue() users. This
patch removes this method with its wrappers (qdisc_requeue()), and
also unused qdisc->requeue structure. There are a few minor fixes of
warnings (htb_enqueue()) and comments btw.
The idea to kill ->requeue() and a similar patch were first developed
by David S. Miller.
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
Add qdisc->ops->peek() implementation for work-conserving qdiscs.
With feedback from Patrick McHardy.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
It can be obtained via the netdev_queue. So create a helper routine,
qdisc_dev(), to make the transformations nicer looking.
Now, qdisc_alloc() now no longer needs a net_device pointer argument.
Make nlmsg_trim(), nlmsg_cancel(), genlmsg_cancel(), and
nla_nest_cancel() void functions.
Return -EMSGSIZE instead of -1 if the provided message buffer is not
big enough.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
nla_parse() returns more detailed errno codes, propagate them back on
error.
Convert packet schedulers to use the netlink API. Unfortunately a gradual
conversion is not possible without breaking compilation in the middle or
adding lots of casts, so this patch converts them all in one step. The
patch has been mostly generated automatically with some minor edits to
at least allow seperate conversion of classifiers and actions.
Qdisc_class_ops are const, and Qdisc_ops are mostly read.
Using "const" and "__read_mostly" qualifiers helps to reduce false
sharing.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Introduces a new flag TC_RED_HARDDROP which specifies that if ECN
marking is enabled packets should still be dropped once the
average queue length exceeds the maximum threshold.
This _may_ help to avoid global synchronisation during small
bursts of peers advertising but not caring about ECN. Use this
option very carefully, it does more harm than good if
(qth_max - qth_min) does not cover at least two average burst
cycles.
The difference to the current behaviour, in which we'd run into
the hard queue limit, is that due to the low pass filter of RED
short bursts are less likely to cause a global synchronisation.
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
Adds a new u8 flags in a unused padding area of the netlink
message. Adds ECN marking support to be used instead of dropping
packets immediately.
Removes unnecessary includes, initializers, and simplifies
the code a bit.
Since we are no longer depending on the default VQ to be always
allocated we can leave it up to the user to actually create it.
This gives the user the ability to leave it out on purpose and
enqueue packets directly to the device without applying the RED
algorithm.
Introduces a new red parameter set for use in equalize mode,
although only the qavg variable and the idle period marker are
being used for now this makes it possible to allow a separate
parameter set to be used for equalize later on.
The use of this separate parameter set fixes a bogus start of
an idle period in gred_drop() which did start an idle period
on the default VQ even if equalize mode was disabled.
The case when the default VQ is not set up yet is already handled
in a less error prone way.
Try to enqueue packets if we cannot associate it with a VQ, this
basically means that the default VQ has not been set up yet.
We must check if the VQ still exists while requeueing, the VQ
might have been changed between dequeue and the requeue of the
underlying qdisc.
Adds a transformation function returning the DP index for a
given skb according to its tc_index.
Qdiscs are not supposed to reset statistics in reset() and while
changing parameters. My argumentation is that if the user wants
the counters to be reset he can simply remove and readd the
qdiscs, that's what most users do anyway.
Simplifies code a lot by separating the red algorithm and the
queueing logic. We now differentiate between probability marks
and forced marks but sum them together again to not break
backwards compatibility.
This brings GRED back to the level of RED and improves the
accuracy of the averge queue length calculations when stab
suggests a zero shift.
Introduces a function gred_change_vq() acting as a central point
to change VQ parameters. Fixes priority inheritance in rio mode
when the default DP equals 0. Adds proper locking during changes.
Introduces a function gred_change_table_def() acting as a central
point to change the table definition.
Adds missing validations for table definition: MAX_DPs > DPs > 0
and def_DP < DPs thus fixing possible invalid memory reference
oopses. Only root could do it but having a typo crashing the
machine is a bit hard.
Adds missing locking while changing the table definition, the
operation of changing the number of DPs and removing shadowed VQs
may not be interrupted by a dequeue.
Avoids the allocation of a buffer by appending the VQs directly
to the skb and simplifies the code by using the appropriate
message construction macros.
Introduces a flags variable using bitops and transforms eqp to use
it. Converts the conditions of the form (wred && rio) to (wred)
since wred can only be enabled in rio mode anyway.
The patch also improves WRED mode detection. The current behaviour
does not allow WRED mode to be turned off again without removing
the whole qdisc first. The new algorithm checks each VQ against
each other looking for equal priorities every time a VQ is changed
or added. The performance is poor, O(n**2), but it's used only
during administrative tasks and the number of VQs is strictly
limited.
infrastructure for it.
Let it rip!
