Since we now hold RTNL lock in tc_action_net_exit(), it is good to
batch them to speedup tc action dismantle.
Cc: Jamal Hadi Salim <jhs@mojatatu.com>
Cc: Jiri Pirko <jiri@resnulli.us>
No one actually uses it.
Cc: Jiri Pirko <jiri@mellanox.com>
Simple cases of overlapping changes in the packet scheduler.
Must easier to resolve this time.
Which probably means that I screwed it up somehow.
This reverts commit ceffcc5e254b450e6159f173e4538215cebf1b59.
If we hold that refcnt, the netns can never be destroyed until
all actions are destroyed by user, this breaks our netns design
which we expect all actions are destroyed when we destroy the
whole netns.
Cc: Lucas Bates <lucasb@mojatatu.com>
Files removed in 'net-next' had their license header updated
in 'net'. We take the remove from 'net-next'.
TC actions have been destroyed asynchronously for a long time,
previously in a RCU callback and now in a workqueue. If we
don't hold a refcnt for its netns, we could use the per netns
data structure, struct tcf_idrinfo, after it has been freed by
netns workqueue.
Hold refcnt to ensure netns destroy happens after all actions
are gone.
Fixes: ddf97ccdd7cb ("net_sched: add network namespace support for tc actions")
Reported-by: Lucas Bates <lucasb@mojatatu.com>
Tested-by: Lucas Bates <lucasb@mojatatu.com>
Just do the rename into bpf_compute_data_pointers() as we'll add
one more pointer here to recompute.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: John Fastabend <john.fastabend@gmail.com>
Typically, each TC filter has its own action. All the actions of the
same type are saved in its hash table. But the hash buckets are too
small that it degrades to a list. And the performance is greatly
affected. For example, it takes about 0m11.914s to insert 64K rules.
If we convert the hash table to IDR, it only takes about 0m1.500s.
The improvement is huge.
But please note that the test result is based on previous patch that
cls_flower uses IDR.
Signed-off-by: Chris Mi <chrism@mellanox.com>
Signed-off-by: Jiri Pirko <jiri@mellanox.com>
Acked-by: Jamal Hadi Salim <jhs@mojatatu.com>
In order to be able to retrieve the attached programs from cls_bpf
and act_bpf, we need to expose the prog ids via netlink so that
an application can later on get an fd based on the id through the
BPF_PROG_GET_FD_BY_ID command, and dump related prog info via
BPF_OBJ_GET_INFO_BY_FD command for bpf(2).
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
Commit 7bd509e311f4 ("bpf: add prog_digest and expose it via
fdinfo/netlink") was recently discussed, partially due to
admittedly suboptimal name of "prog_digest" in combination
with sha1 hash usage, thus inevitably and rightfully concerns
about its security in terms of collision resistance were
raised with regards to use-cases.
The intended use cases are for debugging resp. introspection
only for providing a stable "tag" over the instruction sequence
that both kernel and user space can calculate independently.
It's not usable at all for making a security relevant decision.
So collisions where two different instruction sequences generate
the same tag can happen, but ideally at a rather low rate. The
"tag" will be dumped in hex and is short enough to introspect
in tracepoints or kallsyms output along with other data such
as stack trace, etc. Thus, this patch performs a rename into
prog_tag and truncates the tag to a short output (64 bits) to
make it obvious it's not collision-free.
Should in future a hash or facility be needed with a security
relevant focus, then we can think about requirements, constraints,
etc that would fit to that situation. For now, rework the exposed
parts for the current use cases as long as nothing has been
released yet. Tested on x86_64 and s390x.
Fixes: 7bd509e311f4 ("bpf: add prog_digest and expose it via fdinfo/netlink")
When loading a BPF program via bpf(2), calculate the digest over
the program's instruction stream and store it in struct bpf_prog's
digest member. This is done at a point in time before any instructions
are rewritten by the verifier. Any unstable map file descriptor
number part of the imm field will be zeroed for the hash.
fdinfo example output for progs:
# cat /proc/1590/fdinfo/5
pos: 0
flags: 02000002
mnt_id: 11
prog_type: 1
prog_jited: 1
prog_digest: b27e8b06da22707513aa97363dfb11c7c3675d28
memlock: 4096
When programs are pinned and retrieved by an ELF loader, the loader
can check the program's digest through fdinfo and compare it against
one that was generated over the ELF file's program section to see
if the program needs to be reloaded. Furthermore, this can also be
exposed through other means such as netlink in case of a tc cls/act
dump (or xdp in future), but also through tracepoints or other
facilities to identify the program. Other than that, the digest can
also serve as a base name for the work in progress kallsyms support
of programs. The digest doesn't depend/select the crypto layer, since
we need to keep dependencies to a minimum. iproute2 will get support
for this facility.
After setup we don't need to keep user space fd number around anymore, as
it also has no useful meaning for anyone, just remove it.
Make struct pernet_operations::id unsigned.
There are 2 reasons to do so:
1)
This field is really an index into an zero based array and
thus is unsigned entity. Using negative value is out-of-bound
access by definition.
2)
On x86_64 unsigned 32-bit data which are mixed with pointers
via array indexing or offsets added or subtracted to pointers
are preffered to signed 32-bit data.
"int" being used as an array index needs to be sign-extended
to 64-bit before being used.
void f(long *p, int i)
g(p[i]);
roughly translates to
movsx rsi, esi
mov rdi, [rsi+...]
call g
MOVSX is 3 byte instruction which isn't necessary if the variable is
unsigned because x86_64 is zero extending by default.
Now, there is net_generic() function which, you guessed it right, uses
"int" as an array index:
static inline void *net_generic(const struct net *net, int id)
ptr = ng->ptr[id - 1];
And this function is used a lot, so those sign extensions add up.
Patch snipes ~1730 bytes on allyesconfig kernel (without all junk
messing with code generation):
add/remove: 0/0 grow/shrink: 70/598 up/down: 396/-2126 (-1730)
Unfortunately some functions actually grow bigger.
This is a semmingly random artefact of code generation with register
allocator being used differently. gcc decides that some variable
needs to live in new r8+ registers and every access now requires REX
prefix. Or it is shifted into r12, so [r12+0] addressing mode has to be
used which is longer than [r8]
However, overall balance is in negative direction:
function old new delta
nfsd4_lock 3886 3959 +73
tipc_link_build_proto_msg 1096 1140 +44
mac80211_hwsim_new_radio 2776 2808 +32
tipc_mon_rcv 1032 1058 +26
svcauth_gss_legacy_init 1413 1429 +16
tipc_bcbase_select_primary 379 392 +13
nfsd4_exchange_id 1247 1260 +13
nfsd4_setclientid_confirm 782 793 +11
put_client_renew_locked 494 480 -14
ip_set_sockfn_get 730 716 -14
geneve_sock_add 829 813 -16
nfsd4_sequence_done 721 703 -18
nlmclnt_lookup_host 708 686 -22
nfsd4_lockt 1085 1063 -22
nfs_get_client 1077 1050 -27
tcf_bpf_init 1106 1076 -30
nfsd4_encode_fattr 5997 5930 -67
Total: Before=154856051, After=154854321, chg -0.00%
Wrap several common instances of:
kmemdup(nla_data(attr), nla_len(attr), GFP_KERNEL);
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
We have a small skb_at_tc_ingress() helper for testing for ingress, so
make use of it. cls_bpf already uses it and so should act_bpf.
The skb_mac_header_was_set() test in cls_bpf's and act_bpf's fast-path is
actually unnecessary and can be removed altogether. This was added by
commit a166151cbe33 ("bpf: fix bpf helpers to use skb->mac_header relative
offsets"), which was later on improved by 3431205e0397 ("bpf: make programs
see skb->data == L2 for ingress and egress"). We're always guaranteed to
have valid mac header at the time we invoke cls_bpf_classify() or tcf_bpf().
Reason is that since 6d1ccff62780 ("net: reset mac header in dev_start_xmit()")
we do skb_reset_mac_header() in __dev_queue_xmit() before we could call
into sch_handle_egress() or any subsequent enqueue. sch_handle_ingress()
always sees a valid mac header as well (things like skb_reset_mac_len()
would badly fail otherwise). Thus, drop the unnecessary test in classifier
and action case.
struct tc_action is confusing, currently we use it for two purposes:
1) Pass in arguments and carry out results from helper functions
2) A generic representation for tc actions
The first one is error-prone, since we need to make sure we don't
miss anything. This patch aims to get rid of this use, by moving
tc_action into tcf_common, so that they are allocated together
in hashtable and can be cast'ed easily.
And together with the following patch, we could really make
tc_action a generic representation for all tc actions and each
type of action can inherit from it.
Since bpf_prog_get() and program type check is used in a couple of places,
refactor this into a small helper function that we can make use of. Since
the non RO prog->aux part is not used in performance critical paths and a
program destruction via RCU is rather very unlikley when doing the put, we
shouldn't have an issue just doing the bpf_prog_get() + prog->type != type
check, but actually not taking the ref at all (due to being in fdget() /
fdput() section of the bpf fd) is even cleaner and makes the diff smaller
as well, so just go for that. Callsites are changed to make use of the new
helper where possible.
Signed-off-by: Jamal Hadi Salim <jhs@mojatatu.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
Useful to know when the action was first used for accounting
(and debugging)
allow cls_bpf and act_bpf programs access skb->data and skb->data_end pointers.
The bpf helpers that change skb->data need to update data_end pointer as well.
The verifier checks that programs always reload data, data_end pointers
after calls to such bpf helpers.
We cannot add 'data_end' pointer to struct qdisc_skb_cb directly,
since it's embedded as-is by infiniband ipoib, so wrapper struct is needed.
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Currently tc actions are stored in a per-module hashtable,
therefore are visible to all network namespaces. This is
probably the last part of the tc subsystem which is not
aware of netns now. This patch makes them per-netns,
several tc action API's need to be adjusted for this.
The tc action API code is ugly due to historical reasons,
we need to refactor that code in the future.
Existing bpf_clone_redirect() helper clones skb before redirecting
it to RX or TX of destination netdev.
Introduce bpf_redirect() helper that does that without cloning.
Benchmarked with two hosts using 10G ixgbe NICs.
One host is doing line rate pktgen.
Another host is configured as:
$ tc qdisc add dev $dev ingress
$ tc filter add dev $dev root pref 10 u32 match u32 0 0 flowid 1:2 \
action bpf run object-file tcbpf1_kern.o section clone_redirect_xmit drop
so it receives the packet on $dev and immediately xmits it on $dev + 1
The section 'clone_redirect_xmit' in tcbpf1_kern.o file has the program
that does bpf_clone_redirect() and performance is 2.0 Mpps
action bpf run object-file tcbpf1_kern.o section redirect_xmit drop
which is using bpf_redirect() - 2.4 Mpps
and using cls_bpf with integrated actions as:
$ tc filter add dev $dev root pref 10 \
bpf run object-file tcbpf1_kern.o section redirect_xmit integ_act classid 1
performance is 2.5 Mpps
To summarize:
u32+act_bpf using clone_redirect - 2.0 Mpps
u32+act_bpf using redirect - 2.4 Mpps
cls_bpf using redirect - 2.5 Mpps
For comparison linux bridge in this setup is doing 2.1 Mpps
and ixgbe rx + drop in ip_rcv - 7.8 Mpps
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
Similar to act_gact/act_mirred, act_bpf can be lockless in packet processing
with extra care taken to free bpf programs after rcu grace period.
Replacement of existing act_bpf (very rare) is done with synchronize_rcu()
and final destruction is done from tc_action_ops->cleanup() callback that is
called from tcf_exts_destroy()->tcf_action_destroy()->__tcf_hash_release() when
bind and refcnt reach zero which is only possible when classifier is destroyed.
Previous two patches fixed the last two classifiers (tcindex and rsvp) to
call tcf_exts_destroy() from rcu callback.
Similar to gact/mirred there is a race between prog->filter and
prog->tcf_action. Meaning that the program being replaced may use
previous default action if it happened to return TC_ACT_UNSPEC.
act_mirred race betwen tcf_action and tcfm_dev is similar.
In all cases the race is harmless.
Long term we may want to improve the situation by replacing the whole
tc_action->priv as single pointer instead of updating inner fields one by one.
Fix harmless typo and avoid unnecessary copy of empty 'prog' into
unused 'strcut tcf_bpf_cfg old'.
Fixes: f4eaed28c783 ("act_bpf: fix memory leaks when replacing bpf programs")
Since the introduction of the BPF action in d23b8ad8ab23 ("tc: add BPF
based action"), late binding was not working as expected. I.e. setting
the action part for a classifier only via 'bpf index <num>', where <num>
is the index of an existing action, is being rejected by the kernel due
to other missing parameters.
It doesn't make sense to require these parameters such as BPF opcodes
etc, as they are not going to be used anyway: in this case, they're just
allocated/parsed and then freed again w/o doing anything meaningful.
Instead, parse and verify the remaining parameters *after* the test on
tcf_hash_check(), when we really know that we're dealing with creation
of a new action or replacement of an existing one and where late binding
is thus irrelevant.
After patch, test case is now working:
FOO="1,6 0 0 4294967295,"
tc actions add action bpf bytecode "$FOO"
tc filter add dev foo parent 1: bpf bytecode "$FOO" flowid 1:1 action bpf index 1
tc actions show action bpf
action order 0: bpf bytecode '1,6 0 0 4294967295' default-action pipe
index 1 ref 2 bind 1
tc filter show dev foo
filter protocol all pref 49152 bpf
filter protocol all pref 49152 bpf handle 0x1 flowid 1:1 bytecode '1,6 0 0 4294967295'
action order 1: bpf bytecode '1,6 0 0 4294967295' default-action pipe
Late binding of a BPF action can be useful for preloading maps (e.g. before
they hit traffic) in case of eBPF programs, or to share a single eBPF action
with multiple classifiers.
Acked-by: Alexei Starovoitov <ast@plumgrid.com>
arch/s390/net/bpf_jit_comp.c
drivers/net/ethernet/ti/netcp_ethss.c
net/bridge/br_multicast.c
net/ipv4/ip_fragment.c
All four conflicts were cases of simple overlapping
changes.
We currently trigger multiple memory leaks when replacing bpf
actions, besides others:
comm "tc", pid 1909, jiffies 4294851310 (age 1602.796s)
hex dump (first 32 bytes):
01 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 ................
18 b0 98 6d 00 88 ff ff 00 00 00 00 00 00 00 00 ...m............
backtrace:
[<ffffffff817e623e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff8120a22d>] __vmalloc_node_range+0x1bd/0x2c0
[<ffffffff8120a37a>] __vmalloc+0x4a/0x50
[<ffffffff811a8d0a>] bpf_prog_alloc+0x3a/0xa0
[<ffffffff816c0684>] bpf_prog_create+0x44/0xa0
[<ffffffffa09ba4eb>] tcf_bpf_init+0x28b/0x3c0 [act_bpf]
[<ffffffff816d7001>] tcf_action_init_1+0x191/0x1b0
[<ffffffff816d70a2>] tcf_action_init+0x82/0xf0
[<ffffffff816d4d12>] tcf_exts_validate+0xb2/0xc0
[<ffffffffa09b5838>] cls_bpf_modify_existing+0x98/0x340 [cls_bpf]
[<ffffffffa09b5cd6>] cls_bpf_change+0x1a6/0x274 [cls_bpf]
[<ffffffff816d56e5>] tc_ctl_tfilter+0x335/0x910
[<ffffffff816b9145>] rtnetlink_rcv_msg+0x95/0x240
[<ffffffff816df34f>] netlink_rcv_skb+0xaf/0xc0
[<ffffffff816b909e>] rtnetlink_rcv+0x2e/0x40
[<ffffffff816deaaf>] netlink_unicast+0xef/0x1b0
Issue is that the old content from tcf_bpf is allocated and needs
to be released when we replace it. We seem to do that since the
beginning of act_bpf on the filter and insns, later on the name as
well.
Example test case, after patch:
# FOO="1,6 0 0 4294967295,"
# BAR="1,6 0 0 4294967294,"
# tc actions add action bpf bytecode "$FOO" index 2
# tc actions show action bpf
index 2 ref 1 bind 0
# tc actions replace action bpf bytecode "$BAR" index 2
action order 0: bpf bytecode '1,6 0 0 4294967294' default-action pipe
# tc actions replace action bpf bytecode "$FOO" index 2
# tc actions del action bpf index 2
# echo "scan" > /sys/kernel/debug/kmemleak
# cat /sys/kernel/debug/kmemleak | grep "comm \"tc\"" | wc -l
0
Fixes: d23b8ad8ab23 ("tc: add BPF based action")
net/bridge/br_mdb.c
br_mdb.c conflict was a function call being removed to fix a bug in
'net' but whose signature was changed in 'net-next'.
prog->bpf_ops is populated when act_bpf is used with classic BPF and
prog->bpf_name is optionally used with extended BPF.
Fix memory leak when act_bpf is released.
Fixes: a8cb5f556b56 ("act_bpf: add initial eBPF support for actions")
Reuse existing percpu infrastructure John Fastabend added for qdisc.
This patch adds a new cpustats parameter to tcf_hash_create() and all
actions pass false, meaning this patch should have no effect yet.
Cc: Alexei Starovoitov <ast@plumgrid.com>
eBPF programs attached to ingress and egress qdiscs see inconsistent skb->data.
For ingress L2 header is already pulled, whereas for egress it's present.
This is known to program writers which are currently forced to use
BPF_LL_OFF workaround.
Since programs don't change skb internal pointers it is safe to do
pull/push right around invocation of the program and earlier taps and
later pt->func() will not be affected.
Multiple taps via packet_rcv(), tpacket_rcv() are doing the same trick
around run_filter/BPF_PROG_RUN even if skb_shared.
This fix finally allows programs to use optimized LD_ABS/IND instructions
without BPF_LL_OFF for higher performance.
tc ingress + cls_bpf + samples/bpf/tcbpf1_kern.o
w/o JIT w/JIT
before 20.5 23.6 Mpps
after 21.8 26.6 Mpps
Old programs with BPF_LL_OFF will still work as-is.
We can now undo most of the earlier workaround commit:
a166151cbe33 ("bpf: fix bpf helpers to use skb->mac_header relative offsets")
For the short-term solution, lets fix bpf helper functions to use
skb->mac_header relative offsets instead of skb->data in order to
get the same eBPF programs with cls_bpf and act_bpf work on ingress
and egress qdisc path. We need to ensure that mac_header is set
before calling into programs. This is effectively the first option
from below referenced discussion.
More long term solution for LD_ABS|LD_IND instructions will be more
intrusive but also more beneficial than this, and implemented later
as it's too risky at this point in time.
I.e., we plan to look into the option of moving skb_pull() out of
eth_type_trans() and into netif_receive_skb() as has been suggested
as second option. Meanwhile, this solution ensures ingress can be
used with eBPF, too, and that we won't run into ABI troubles later.
For dealing with negative offsets inside eBPF helper functions,
we've implemented bpf_skb_clone_unwritable() to test for unwriteable
headers.
Reference: http://thread.gmane.org/gmane.linux.network/359129/focus=359694
Fixes: 608cd71a9c7c ("tc: bpf: generalize pedit action")
Fixes: 91bc4822c3d6 ("tc: bpf: add checksum helpers")
This work extends the "classic" BPF programmable tc action by extending
its scope also to native eBPF code!
Together with commit e2e9b6541dd4 ("cls_bpf: add initial eBPF support
for programmable classifiers") this adds the facility to implement fully
flexible classifier and actions for tc that can be implemented in a C
subset in user space, "safely" loaded into the kernel, and being run in
native speed when JITed.
Also, since eBPF maps can be shared between eBPF programs, it offers the
possibility that cls_bpf and act_bpf can share data 1) between themselves
and 2) between user space applications. That means that, f.e. customized
runtime statistics can be collected in user space, but also more importantly
classifier and action behaviour could be altered based on map input from
the user space application.
For the remaining details on the workflow and integration, see the cls_bpf
commit e2e9b6541dd4. Preliminary iproute2 part can be found under [1].
[1] http://git.breakpoint.cc/cgit/dborkman/iproute2.git/log/?h=ebpf-act
Acked-by: Jiri Pirko <jiri@resnulli.us>
Revisiting commit d23b8ad8ab23 ("tc: add BPF based action") with regards
to eBPF support, I was thinking that it might be better to improve
return semantics from a BPF program invoked through BPF_PROG_RUN().
Currently, in case filter_res is 0, we overwrite the default action
opcode with TC_ACT_SHOT. A default action opcode configured through tc's
m_bpf can be: TC_ACT_RECLASSIFY, TC_ACT_PIPE, TC_ACT_SHOT, TC_ACT_UNSPEC,
TC_ACT_OK.
In cls_bpf, we have the possibility to overwrite the default class
associated with the classifier in case filter_res is _not_ 0xffffffff
(-1).
That allows us to fold multiple [e]BPF programs into a single one, where
they would otherwise need to be defined as a separate classifier with
its own classid, needlessly redoing parsing work, etc.
Similarly, we could do better in act_bpf: Since above TC_ACT* opcodes
are exported to UAPI anyway, we reuse them for return-code-to-tc-opcode
mapping, where we would allow above possibilities. Thus, like in cls_bpf,
a filter_res of 0xffffffff (-1) means that the configured _default_ action
is used. Any unkown return code from the BPF program would fail in
tcf_bpf() with TC_ACT_UNSPEC.
Should we one day want to make use of TC_ACT_STOLEN or TC_ACT_QUEUED,
which both have the same semantics, we have the option to either use
that as a default action (filter_res of 0xffffffff) or non-default BPF
return code.
All that will allow us to transparently use tcf_bpf() for both BPF
flavours.
Similarly as in cls_bpf, also this code needs to reject mismatches.
Reference: http://article.gmane.org/gmane.linux.network/347406
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
This action provides a possibility to exec custom BPF code.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
