path: root/net/rxrpc
2015-03-15rxrpc: bogus MSG_PEEK test in rxrpc_recvmsg()Al Viro
[I would really like an ACK on that one from dhowells; it appears to be quite straightforward, but...] MSG_PEEK isn't passed to ->recvmsg() via msg->msg_flags; as the matter of fact, neither the kernel users of rxrpc, nor the syscalls ever set that bit in there. It gets passed via flags; in fact, another such check in the same function is done correctly - as flags & MSG_PEEK. It had been that way (effectively disabled) for 8 years, though, so the patch needs beating up - that case had never been tested. If it is correct, it's -stable fodder. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-08ip: fix error queue empty skb handlingWillem de Bruijn
When reading from the error queue, msg_name and msg_control are only populated for some errors. A new exception for empty timestamp skbs added a false positive on icmp errors without payload. `traceroute -M udpconn` only displayed gateways that return payload with the icmp error: the embedded network headers are pulled before sock_queue_err_skb, leaving an skb with skb->len == 0 otherwise. Fix this regression by refining when msg_name and msg_control branches are taken. The solutions for the two fields are independent. msg_name only makes sense for errors that configure serr->port and serr->addr_offset. Test the first instead of skb->len. This also fixes another issue. saddr could hold the wrong data, as serr->addr_offset is not initialized in some code paths, pointing to the start of the network header. It is only valid when serr->port is set (non-zero). msg_control support differs between IPv4 and IPv6. IPv4 only honors requests for ICMP and timestamps with SOF_TIMESTAMPING_OPT_CMSG. The skb->len test can simply be removed, because skb->dev is also tested and never true for empty skbs. IPv6 honors requests for all errors aside from local errors and timestamps on empty skbs. In both cases, make the policy more explicit by moving this logic to a new function that decides whether to process msg_control and that optionally prepares the necessary fields in skb->cb[]. After this change, the IPv4 and IPv6 paths are more similar. The last case is rxrpc. Here, simply refine to only match timestamps. Fixes: 49ca0d8bfaf3 ("net-timestamp: no-payload option") Reported-by: Jan Niehusmann <jan@gondor.com> Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Changes v1->v2 - fix local origin test inversion in ip6_datagram_support_cmsg - make v4 and v6 code paths more similar by introducing analogous ipv4_datagram_support_cmsg - fix compile bug in rxrpc Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01rxrpc: don't multiply with HZ twiceFlorian Westphal
rxrpc_resend_timeout has an initial value of 4 * HZ; use it as-is. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-01rxrpc: terminate retrans loop when sending of skb failsFlorian Westphal
Typo, 'stop' is never set to true. Seems intent is to not attempt to retransmit more packets after sendmsg returns an error. This change is based on code inspection only. Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-04Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs More iov_iter work from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-04rxrpc: make the users of rxrpc_kernel_send_data() set kvec-backed msg_iter ↵Al Viro
properly Use iov_iter_kvec() there, get rid of set_fs() games - now that rxrpc_send_data() uses iov_iter primitives, it'll handle ITER_KVEC just fine. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-04rxrpc: switch rxrpc_send_data() to iov_iter primitivesAl Viro
Convert skb_add_data() to iov_iter; allows to get rid of the explicit messing with iovec in its only caller - skb_add_data() will keep advancing ->msg_iter for us, so there's no need to similate that manually. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-02net-timestamp: no-payload optionWillem de Bruijn
Add timestamping option SOF_TIMESTAMPING_OPT_TSONLY. For transmit timestamps, this loops timestamps on top of empty packets. Doing so reduces the pressure on SO_RCVBUF. Payload inspection and cmsg reception (aside from timestamps) are no longer possible. This works together with a follow on patch that allows administrators to only allow tx timestamping if it does not loop payload or metadata. Signed-off-by: Willem de Bruijn <willemb@google.com> ---- Changes (rfc -> v1) - add documentation - remove unnecessary skb->len test (thanks to Richard Cochran) Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-10net: introduce helper macro for_each_cmsghdrGu Zheng
Introduce helper macro for_each_cmsghdr as a wrapper of the enumerating cmsghdr from msghdr, just cleanup. Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-09put iov_iter into msghdrAl Viro
Note that the code _using_ ->msg_iter at that point will be very unhappy with anything other than unshifted iovec-backed iov_iter. We still need to convert users to proper primitives. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-05net: Add and use skb_copy_datagram_msg() helper.David S. Miller
This encapsulates all of the skb_copy_datagram_iovec() callers with call argument signature "skb, offset, msghdr->msg_iov, length". When we move to iov_iters in the networking, the iov_iter object will sit in the msghdr. Having a helper like this means there will be less places to touch during that transformation. Based upon descriptions and patch from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-10-12Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris. Mostly ima, selinux, smack and key handling updates. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (65 commits) integrity: do zero padding of the key id KEYS: output last portion of fingerprint in /proc/keys KEYS: strip 'id:' from ca_keyid KEYS: use swapped SKID for performing partial matching KEYS: Restore partial ID matching functionality for asymmetric keys X.509: If available, use the raw subjKeyId to form the key description KEYS: handle error code encoded in pointer selinux: normalize audit log formatting selinux: cleanup error reporting in selinux_nlmsg_perm() KEYS: Check hex2bin()'s return when generating an asymmetric key ID ima: detect violations for mmaped files ima: fix race condition on ima_rdwr_violation_check and process_measurement ima: added ima_policy_flag variable ima: return an error code from ima_add_boot_aggregate() ima: provide 'ima_appraise=log' kernel option ima: move keyring initialization to ima_init() PKCS#7: Handle PKCS#7 messages that contain no X.509 certs PKCS#7: Better handling of unsupported crypto KEYS: Overhaul key identification when searching for asymmetric keys KEYS: Implement binary asymmetric key ID handling ...
2014-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: arch/mips/net/bpf_jit.c drivers/net/can/flexcan.c Both the flexcan and MIPS bpf_jit conflicts were cases of simple overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-16KEYS: Remove key_type::match in favour of overriding default by match_preparseDavid Howells
A previous patch added a ->match_preparse() method to the key type. This is allowed to override the function called by the iteration algorithm. Therefore, we can just set a default that simply checks for an exact match of the key description with the original criterion data and allow match_preparse to override it as needed. The key_type::match op is then redundant and can be removed, as can the user_match() function. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Vivek Goyal <vgoyal@redhat.com>
2014-09-09RxRPC: Fix missing __user annotationDavid Howells
Fix a missing __user annotation in a cast of a user space pointer (found by checker). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-01sock: deduplicate errqueue dequeueWillem de Bruijn
sk->sk_error_queue is dequeued in four locations. All share the exact same logic. Deduplicate. Also collapse the two critical sections for dequeue (at the top of the recv handler) and signal (at the bottom). This moves signal generation for the next packet forward, which should be harmless. It also changes the behavior if the recv handler exits early with an error. Previously, a signal for follow-up packets on the errqueue would then not be scheduled. The new behavior, to always signal, is arguably a bug fix. For rxrpc, the change causes the same function to be called repeatedly for each queued packet (because the recv handler == sk_error_report). It is likely that all packets will fail for the same reason (e.g., memory exhaustion). This code runs without sk_lock held, so it is not safe to trust that sk->sk_err is immutable inbetween releasing q->lock and the subsequent test. Introduce int err just to avoid this potential race. Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22net: remove dead code after sk_data_ready changeEric Dumazet
As a followup to commit 676d23690fb ("net: Fix use after free by removing length arg from sk_data_ready callbacks"), we can remove some useless code in sock_queue_rcv_skb() and rxrpc_queue_rcv_skb() Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights: 1) Steady transitioning of the BPF instructure to a generic spot so all kernel subsystems can make use of it, from Alexei Starovoitov. 2) SFC driver supports busy polling, from Alexandre Rames. 3) Take advantage of hash table in UDP multicast delivery, from David Held. 4) Lighten locking, in particular by getting rid of the LRU lists, in inet frag handling. From Florian Westphal. 5) Add support for various RFC6458 control messages in SCTP, from Geir Ola Vaagland. 6) Allow to filter bridge forwarding database dumps by device, from Jamal Hadi Salim. 7) virtio-net also now supports busy polling, from Jason Wang. 8) Some low level optimization tweaks in pktgen from Jesper Dangaard Brouer. 9) Add support for ipv6 address generation modes, so that userland can have some input into the process. From Jiri Pirko. 10) Consolidate common TCP connection request code in ipv4 and ipv6, from Octavian Purdila. 11) New ARP packet logger in netfilter, from Pablo Neira Ayuso. 12) Generic resizable RCU hash table, with intial users in netlink and nftables. From Thomas Graf. 13) Maintain a name assignment type so that userspace can see where a network device name came from (enumerated by kernel, assigned explicitly by userspace, etc.) From Tom Gundersen. 14) Automatic flow label generation on transmit in ipv6, from Tom Herbert. 15) New packet timestamping facilities from Willem de Bruijn, meant to assist in measuring latencies going into/out-of the packet scheduler, latency from TCP data transmission to ACK, etc" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1536 commits) cxgb4 : Disable recursive mailbox commands when enabling vi net: reduce USB network driver config options. tg3: Modify tg3_tso_bug() to handle multiple TX rings amd-xgbe: Perform phy connect/disconnect at dev open/stop amd-xgbe: Use dma_set_mask_and_coherent to set DMA mask net: sun4i-emac: fix memory leak on bad packet sctp: fix possible seqlock seadlock in sctp_packet_transmit() Revert "net: phy: Set the driver when registering an MDIO bus device" cxgb4vf: Turn off SGE RX/TX Callback Timers and interrupts in PCI shutdown routine team: Simplify return path of team_newlink bridge: Update outdated comment on promiscuous mode net-timestamp: ACK timestamp for bytestreams net-timestamp: TCP timestamping net-timestamp: SCHED timestamp on entering packet scheduler net-timestamp: add key to disambiguate concurrent datagrams net-timestamp: move timestamp flags out of sk_flags net-timestamp: extend SCM_TIMESTAMPING ancillary data struct cxgb4i : Move stray CPL definitions to cxgb4 driver tcp: reduce spurious retransmits due to transient SACK reneging qlcnic: Initialize dcbnl_ops before register_netdev ...
2014-07-22KEYS: RxRPC: Use key preparsingDavid Howells
Make use of key preparsing in the RxRPC protocol so that quota size determination can take place prior to keyring locking when a key is being added. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Steve Dickson <steved@redhat.com>
2014-07-20net/rxrpc/ar-key.c: drop negativity check on unsigned valueAndrey Utkin
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=80611 Reported-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Andrey Utkin <andrey.krieger.utkin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-05-16af_rxrpc: Fix XDR length check in rxrpc key demarshalling.Nathaniel W Filardo
There may be padding on the ticket contained in the key payload, so just ensure that the claimed token length is large enough, rather than exactly the right size. Signed-off-by: Nathaniel Wesley Filardo <nwf@cs.jhu.edu> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-11net: Fix use after free by removing length arg from sk_data_ready callbacks.David S. Miller
Several spots in the kernel perform a sequence like: skb_queue_tail(&sk->s_receive_queue, skb); sk->sk_data_ready(sk, skb->len); But at the moment we place the SKB onto the socket receive queue it can be consumed and freed up. So this skb->len access is potentially to freed up memory. Furthermore, the skb->len can be modified by the consumer so it is possible that the value isn't accurate. And finally, no actual implementation of this callback actually uses the length argument. And since nobody actually cared about it's value, lots of call sites pass arbitrary values in such as '0' and even '1'. So just remove the length argument from the callback, that way there is no confusion whatsoever and all of these use-after-free cases get fixed as a side effect. Based upon a patch by Eric Dumazet and his suggestion to audit this issue tree-wide. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-04af_rxrpc: Keep rxrpc_call pointers in a hashtableTim Smith
Keep track of rxrpc_call structures in a hashtable so they can be found directly from the network parameters which define the call. This allows incoming packets to be routed directly to a call without walking through hierarchy of peer -> transport -> connection -> call and all the spinlocks that that entailed. Signed-off-by: Tim Smith <tim@electronghost.co.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2014-02-26af_rxrpc: Request an ACK for every alternate DATA packetDavid Howells
Set the RxRPC header flag to request an ACK packet for every odd-numbered DATA packet unless it's the last one (which implicitly requests an ACK anyway). This is similar to how librx appears to work. If we don't do this, we'll send out a full window of packets and then just sit there until the other side gets bored and sends an ACK to indicate that it's been idle for a while and has received no new packets. Requesting a lot of ACKs shouldn't be a problem as ACKs should be merged when possible. As AF_RXRPC currently works, it will schedule an ACK to be generated upon receipt of a DATA packet with the ACK-request packet set - and in the time taken to schedule this in a work queue, several other packets are likely to arrive and then all get ACK'd together. Signed-off-by: David Howells <dhowells@redhat.com>
2014-02-26af_rxrpc: Expose more RxRPC parameters via sysctlsDavid Howells
Expose RxRPC parameters via sysctls to control the Rx window size, the Rx MTU maximum size and the number of packets that can be glued into a jumbo packet. More info added to Documentation/networking/rxrpc.txt. Signed-off-by: David Howells <dhowells@redhat.com>
2014-02-26af_rxrpc: Improve ACK productionDavid Howells
Improve ACK production by the following means: (1) Don't send an ACK_REQUESTED ack immediately even if the RXRPC_MORE_PACKETS flag isn't set on a data packet that has also has RXRPC_REQUEST_ACK set. MORE_PACKETS just means that the sender just emptied its Tx data buffer. More data will be forthcoming unless RXRPC_LAST_PACKET is also flagged. It is possible to see runs of DATA packets with MORE_PACKETS unset that aren't waiting for an ACK. It is therefore better to wait a small instant to see if we can combine an ACK for several packets. (2) Don't send an ACK_IDLE ack immediately unless we're responding to the terminal data packet of a call. Whilst sending an ACK_IDLE mid-call serves to let the other side know that we won't be asking it to resend certain Tx buffers and that it can discard them, spamming it with loads of acks just because we've temporarily run out of data just distracts it. (3) Put the ACK_IDLE ack generation timeout up to half a second rather than a single jiffy. Just because we haven't been given more data immediately doesn't mean that more isn't forthcoming. The other side may be busily finding the data to send to us. Signed-off-by: David Howells <dhowells@redhat.com>
2014-02-26af_rxrpc: Add sysctls for configuring RxRPC parametersDavid Howells
Add sysctls for configuring RxRPC protocol handling, specifically controls on delays before ack generation, the delay before resending a packet, the maximum lifetime of a call and the expiration times of calls, connections and transports that haven't been recently used. More info added in Documentation/networking/rxrpc.txt. Signed-off-by: David Howells <dhowells@redhat.com>
2014-02-26af_rxrpc: Fix UDP MTU calculation from ICMP_FRAG_NEEDEDDavid Howells
AF_RXRPC sends UDP packets with the "Don't Fragment" bit set in an attempt to determine the maximum packet size between the local socket and the peer by invoking the generation of ICMP_FRAG_NEEDED packets. Once a packet is sent with the "Don't Fragment" bit set, it is then inconvenient to break it up as that requires recalculating all the rxrpc serial and sequence numbers and reencrypting all the fragments, so we switch off the "Don't Fragment" service temporarily and send the bounced packet again. Future packets then use the new MTU. That's all fine. The problem lies in rxrpc_UDP_error_report() where the code that deals with ICMP_FRAG_NEEDED packets lives. Packets of this type have a field (ee_info) to indicate the maximum packet size at the reporting node - but sometimes ee_info isn't filled in and is just left as 0 and the code must allow for this. When ee_info is 0, the code should take the MTU size we're currently using and reduce it for the next packet we want to send. However, it takes ee_info (which is known to be 0) and tries to reduce that instead. This was discovered by Coverity. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com>
2014-02-07af_rxrpc: Prevent RxRPC peers from ABORT-storming one anotherTim Smith
When an ABORT is sent, aborting a connection, the sender quite reasonably forgets about the connection. If another frame is received, another ABORT will be sent. When the receiver gets it, it no longer applies to an extant connection, so an ABORT is sent, and so on... Prevent this by never sending a rejection for an ABORT packet. Signed-off-by: Tim Smith <tim@electronghost.co.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2014-02-07af_rxrpc: Remove incorrect checksum calculation from rxrpc_recvmsg()Tim Smith
The UDP checksum was already verified in rxrpc_data_ready() - which calls skb_checksum_complete() - as the RxRPC packet header contains no checksum of its own. Subsequent calls to skb_copy_and_csum_datagram_iovec() are thus redundant and are, in any case, being passed only a subset of the UDP payload - so the checksum will always fail if that path is taken. So there is no need to check skb->ip_summed in rxrpc_recvmsg(), and no need for the csum_copy_error: exit path. Signed-off-by: Tim Smith <tim@electronghost.co.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2014-01-28Merge tag 'rxrpc-20140126' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs David Howells says: ==================== RxRPC fixes Here are some small AF_RXRPC fixes. (1) Fix a place where a spinlock is taken conditionally but is released unconditionally. (2) Fix a double-free that happens when cleaning up on a checksum error. (3) Fix handling of CHECKSUM_PARTIAL whilst delivering messages to userspace. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-26af_rxrpc: Handle frames delivered from another VMTim Smith
On input, CHECKSUM_PARTIAL should be treated the same way as CHECKSUM_UNNECESSARY. See include/linux/skbuff.h Signed-off-by: Tim Smith <tim@electronghost.co.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2014-01-26af_rxrpc: Avoid setting up double-free on checksum errorTim Smith
skb_kill_datagram() does not dequeue the skb when MSG_PEEK is unset. This leaves a free'd skb on the queue, resulting a double-free later. Without this, the following oops can occur: BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffff8154fcf7>] skb_dequeue+0x47/0x70 PGD 0 Oops: 0002 [#1] SMP Modules linked in: af_rxrpc ... CPU: 0 PID: 1191 Comm: listen Not tainted 3.12.0+ #4 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011 task: ffff8801183536b0 ti: ffff880035c92000 task.ti: ffff880035c92000 RIP: 0010:[<ffffffff8154fcf7>] skb_dequeue+0x47/0x70 RSP: 0018:ffff880035c93db8 EFLAGS: 00010097 RAX: 0000000000000246 RBX: ffff8800d2754b00 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000202 RDI: ffff8800d254c084 RBP: ffff880035c93dd0 R08: ffff880035c93cf0 R09: ffff8800d968f270 R10: 0000000000000000 R11: 0000000000000293 R12: ffff8800d254c070 R13: ffff8800d254c084 R14: ffff8800cd861240 R15: ffff880119b39720 FS: 00007f37a969d740(0000) GS:ffff88011fc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000008 CR3: 00000000d4413000 CR4: 00000000000006f0 Stack: ffff8800d254c000 ffff8800d254c070 ffff8800d254c2c0 ffff880035c93df8 ffffffffa041a5b8 ffff8800cd844c80 ffffffffa04385a0 ffff8800cd844cb0 ffff880035c93e18 ffffffff81546cef ffff8800d45fea00 0000000000000008 Call Trace: [<ffffffffa041a5b8>] rxrpc_release+0x128/0x2e0 [af_rxrpc] [<ffffffff81546cef>] sock_release+0x1f/0x80 [<ffffffff81546d62>] sock_close+0x12/0x20 [<ffffffff811aaba1>] __fput+0xe1/0x230 [<ffffffff811aad3e>] ____fput+0xe/0x10 [<ffffffff810862cc>] task_work_run+0xbc/0xe0 [<ffffffff8106a3be>] do_exit+0x2be/0xa10 [<ffffffff8116dc47>] ? do_munmap+0x297/0x3b0 [<ffffffff8106ab8f>] do_group_exit+0x3f/0xa0 [<ffffffff8106ac04>] SyS_exit_group+0x14/0x20 [<ffffffff8166b069>] system_call_fastpath+0x16/0x1b Signed-off-by: Tim Smith <tim@electronghost.co.uk> Signed-off-by: David Howells <dhowells@redhat.com>
2014-01-26RxRPC: do not unlock unheld spinlock in rxrpc_connect_exclusive()Alexey Khoroshilov
If rx->conn is not NULL, rxrpc_connect_exclusive() does not acquire the transport's client lock, but it still releases it. The patch adds locking of the spinlock to this path. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: David Howells <dhowells@redhat.com>
2014-01-21rxrpc: out of bound read in debug codeDan Carpenter
Smatch complains because we are using an untrusted index into the rxrpc_acks[] array. It's just a read and it's only in the debug code, but it's simple enough to add a check and fix it. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-19net: misc: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-11net/rxrpc: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: "David S. Miller" <davem@davemloft.net> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: David S. Miller <davem@davemloft.net>
2013-01-09rxrpc: Use FIELD_SIZEOF() in af_rxrpc_init().YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-14Merge branch 'modules-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module signing support from Rusty Russell: "module signing is the highlight, but it's an all-over David Howells frenzy..." Hmm "Magrathea: Glacier signing key". Somebody has been reading too much HHGTTG. * 'modules-next' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (37 commits) X.509: Fix indefinite length element skip error handling X.509: Convert some printk calls to pr_devel asymmetric keys: fix printk format warning MODSIGN: Fix 32-bit overflow in X.509 certificate validity date checking MODSIGN: Make mrproper should remove generated files. MODSIGN: Use utf8 strings in signer's name in autogenerated X.509 certs MODSIGN: Use the same digest for the autogen key sig as for the module sig MODSIGN: Sign modules during the build process MODSIGN: Provide a script for generating a key ID from an X.509 cert MODSIGN: Implement module signature checking MODSIGN: Provide module signing public keys to the kernel MODSIGN: Automatically generate module signing keys if missing MODSIGN: Provide Kconfig options MODSIGN: Provide gitignore and make clean rules for extra files MODSIGN: Add FIPS policy module: signature checking hook X.509: Add a crypto key parser for binary (DER) X.509 certificates MPILIB: Provide a function to read raw data into an MPI X.509: Add an ASN.1 decoder X.509: Add simple ASN.1 grammar compiler ...
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-09-13userns: net: Call key_alloc with GLOBAL_ROOT_UID, GLOBAL_ROOT_GID instead of ↵Eric W. Biederman
0, 0 In net/dns_resolver/dns_key.c and net/rxrpc/ar-key.c make them work with user namespaces enabled where key_alloc takes kuids and kgids. Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID instead of bare 0's. Cc: Sage Weil <sage@inktank.com> Cc: ceph-devel@vger.kernel.org Cc: David Howells <dhowells@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: linux-afs@lists.infradead.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/batman-adv/bridge_loop_avoidance.c net/batman-adv/bridge_loop_avoidance.h net/batman-adv/soft-interface.c net/mac80211/mlme.c With merge help from Antonio Quartulli (batman-adv) and Stephen Rothwell (drivers/net/usb/qmi_wwan.c). The net/mac80211/mlme.c conflict seemed easy enough, accounting for a conversion to some new tracing macros. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-10net: Fix (nearly-)kernel-doc comments for various functionsBen Hutchings
Fix incorrect start markers, wrapped summary lines, missing section breaks, incorrect separators, and some name mismatches. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-09net/rxrpc/ar-peer.c: remove invalid reference to list iterator variableJulia Lawall
If list_for_each_entry, etc complete a traversal of the list, the iterator variable ends up pointing to an address at an offset from the list head, and not a meaningful structure. Thus this value should not be used after the end of the iterator. This seems to be a copy-paste bug from a previous debugging message, and so the meaningless value is just deleted. This problem was found using Coccinelle (http://coccinelle.lip6.fr/). Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-11ipv4: Kill ip_rt_frag_needed().David S. Miller
There is zero point to this function. It's only real substance is to perform an extremely outdated BSD4.2 ICMP check, which we can safely remove. If you really have a MTU limited link being routed by a BSD4.2 derived system, here's a nickel go buy yourself a real router. The other actions of ip_rt_frag_needed(), checking and conditionally updating the peer, are done by the per-protocol handlers of the ICMP event. TCP, UDP, et al. have a handler which will receive this event and transmit it back into the associated route via dst_ops->update_pmtu(). This simplification is important, because it eliminates the one place where we do not have a proper route context in which to make an inetpeer lookup. Signed-off-by: David S. Miller <davem@davemloft.net>
