path: root/net/rxrpc/security.c
2019-07-08Merge tag 'keys-namespace-20190627' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs Pull keyring namespacing from David Howells: "These patches help make keys and keyrings more namespace aware. Firstly some miscellaneous patches to make the process easier: - Simplify key index_key handling so that the word-sized chunks assoc_array requires don't have to be shifted about, making it easier to add more bits into the key. - Cache the hash value in the key so that we don't have to calculate on every key we examine during a search (it involves a bunch of multiplications). - Allow keying_search() to search non-recursively. Then the main patches: - Make it so that keyring names are per-user_namespace from the point of view of KEYCTL_JOIN_SESSION_KEYRING so that they're not accessible cross-user_namespace. keyctl_capabilities() shows KEYCTL_CAPS1_NS_KEYRING_NAME for this. - Move the user and user-session keyrings to the user_namespace rather than the user_struct. This prevents them propagating directly across user_namespaces boundaries (ie. the KEY_SPEC_* flags will only pick from the current user_namespace). - Make it possible to include the target namespace in which the key shall operate in the index_key. This will allow the possibility of multiple keys with the same description, but different target domains to be held in the same keyring. keyctl_capabilities() shows KEYCTL_CAPS1_NS_KEY_TAG for this. - Make it so that keys are implicitly invalidated by removal of a domain tag, causing them to be garbage collected. - Institute a network namespace domain tag that allows keys to be differentiated by the network namespace in which they operate. New keys that are of a type marked 'KEY_TYPE_NET_DOMAIN' are assigned the network domain in force when they are created. - Make it so that the desired network namespace can be handed down into the request_key() mechanism. This allows AFS, NFS, etc. to request keys specific to the network namespace of the superblock. This also means that the keys in the DNS record cache are thenceforth namespaced, provided network filesystems pass the appropriate network namespace down into dns_query(). For DNS, AFS and NFS are good, whilst CIFS and Ceph are not. Other cache keyrings, such as idmapper keyrings, also need to set the domain tag - for which they need access to the network namespace of the superblock" * tag 'keys-namespace-20190627' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs: keys: Pass the network namespace into request_key mechanism keys: Network namespace domain tag keys: Garbage collect keys for which the domain has been removed keys: Include target namespace in match criteria keys: Move the user and user-session keyrings to the user_namespace keys: Namespace keyring names keys: Add a 'recurse' flag for keyring searches keys: Cache the hash value to avoid lots of recalculation keys: Simplify key description management
2019-06-26keys: Add a 'recurse' flag for keyring searchesDavid Howells
Add a 'recurse' flag for keyring searches so that the flag can be omitted and recursion disabled, thereby allowing just the nominated keyring to be searched and none of the children. Signed-off-by: David Howells <dhowells@redhat.com>
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 152Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 3029 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Allison Randal <allison@lohutok.net> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-03-30rxrpc: remove unused static variablesSebastian Andrzej Siewior
The rxrpc_security_methods and rxrpc_security_sem user has been removed in 648af7fca159 ("rxrpc: Absorb the rxkad security module"). This was noticed by kbuild test robot for the -RT tree but is also true for !RT. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
2017-06-05rxrpc: Permit multiple service bindingDavid Howells
Permit bind() to be called on an AF_RXRPC socket more than once (currently maximum twice) to bind multiple listening services to it. There are some restrictions: (1) All bind() calls involved must have a non-zero service ID. (2) The service IDs must all be different. (3) The rest of the address (notably the transport part) must be the same in all (a single UDP socket is shared). (4) This must be done before listen() or sendmsg() is called. This allows someone to connect to the service socket with different service IDs and lays the foundation for service upgrading. The service ID used by an incoming call can be extracted from the msg_name returned by recvmsg(). Signed-off-by: David Howells <dhowells@redhat.com>
2017-06-05rxrpc: Separate the connection's protocol service ID from the lookup IDDavid Howells
Keep the rxrpc_connection struct's idea of the service ID that is exposed in the protocol separate from the service ID that's used as a lookup key. This allows the protocol service ID on a client connection to get upgraded without making the connection unfindable for other client calls that also would like to use the upgraded connection. The connection's actual service ID is then returned through recvmsg() by way of msg_name. Whilst we're at it, we get rid of the last_service_id field from each channel. The service ID is per-connection, not per-call and an entire connection is upgraded in one go. Signed-off-by: David Howells <dhowells@redhat.com>
2016-09-29rxrpc: Reduce the rxrpc_local::services list to a pointerDavid Howells
Reduce the rxrpc_local::services list to just a pointer as we don't permit multiple service endpoints to bind to a single transport endpoints (this is excluded by rxrpc_lookup_local()). The reason we don't allow this is that if you send a request to an AFS filesystem service, it will try to talk back to your cache manager on the port you sent from (this is how file change notifications are handled). To prevent someone from stealing your CM callbacks, we don't let AF_RXRPC sockets share a UDP socket if at least one of them has a service bound. Signed-off-by: David Howells <dhowells@redhat.com>
2016-09-08rxrpc: Rewrite the data and ack handling codeDavid Howells
Rewrite the data and ack handling code such that: (1) Parsing of received ACK and ABORT packets and the distribution and the filing of DATA packets happens entirely within the data_ready context called from the UDP socket. This allows us to process and discard ACK and ABORT packets much more quickly (they're no longer stashed on a queue for a background thread to process). (2) We avoid calling skb_clone(), pskb_pull() and pskb_trim(). We instead keep track of the offset and length of the content of each packet in the sk_buff metadata. This means we don't do any allocation in the receive path. (3) Jumbo DATA packet parsing is now done in data_ready context. Rather than cloning the packet once for each subpacket and pulling/trimming it, we file the packet multiple times with an annotation for each indicating which subpacket is there. From that we can directly calculate the offset and length. (4) A call's receive queue can be accessed without taking locks (memory barriers do have to be used, though). (5) Incoming calls are set up from preallocated resources and immediately made live. They can than have packets queued upon them and ACKs generated. If insufficient resources exist, DATA packet #1 is given a BUSY reply and other DATA packets are discarded). (6) sk_buffs no longer take a ref on their parent call. To make this work, the following changes are made: (1) Each call's receive buffer is now a circular buffer of sk_buff pointers (rxtx_buffer) rather than a number of sk_buff_heads spread between the call and the socket. This permits each sk_buff to be in the buffer multiple times. The receive buffer is reused for the transmit buffer. (2) A circular buffer of annotations (rxtx_annotations) is kept parallel to the data buffer. Transmission phase annotations indicate whether a buffered packet has been ACK'd or not and whether it needs retransmission. Receive phase annotations indicate whether a slot holds a whole packet or a jumbo subpacket and, if the latter, which subpacket. They also note whether the packet has been decrypted in place. (3) DATA packet window tracking is much simplified. Each phase has just two numbers representing the window (rx_hard_ack/rx_top and tx_hard_ack/tx_top). The hard_ack number is the sequence number before base of the window, representing the last packet the other side says it has consumed. hard_ack starts from 0 and the first packet is sequence number 1. The top number is the sequence number of the highest-numbered packet residing in the buffer. Packets between hard_ack+1 and top are soft-ACK'd to indicate they've been received, but not yet consumed. Four macros, before(), before_eq(), after() and after_eq() are added to compare sequence numbers within the window. This allows for the top of the window to wrap when the hard-ack sequence number gets close to the limit. Two flags, RXRPC_CALL_RX_LAST and RXRPC_CALL_TX_LAST, are added also to indicate when rx_top and tx_top point at the packets with the LAST_PACKET bit set, indicating the end of the phase. (4) Calls are queued on the socket 'receive queue' rather than packets. This means that we don't need have to invent dummy packets to queue to indicate abnormal/terminal states and we don't have to keep metadata packets (such as ABORTs) around (5) The offset and length of a (sub)packet's content are now passed to the verify_packet security op. This is currently expected to decrypt the packet in place and validate it. However, there's now nowhere to store the revised offset and length of the actual data within the decrypted blob (there may be a header and padding to skip) because an sk_buff may represent multiple packets, so a locate_data security op is added to retrieve these details from the sk_buff content when needed. (6) recvmsg() now has to handle jumbo subpackets, where each subpacket is individually secured and needs to be individually decrypted. The code to do this is broken out into rxrpc_recvmsg_data() and shared with the kernel API. It now iterates over the call's receive buffer rather than walking the socket receive queue. Additional changes: (1) The timers are condensed to a single timer that is set for the soonest of three timeouts (delayed ACK generation, DATA retransmission and call lifespan). (2) Transmission of ACK and ABORT packets is effected immediately from process-context socket ops/kernel API calls that cause them instead of them being punted off to a background work item. The data_ready handler still has to defer to the background, though. (3) A shutdown op is added to the AF_RXRPC socket so that the AFS filesystem can shut down the socket and flush its own work items before closing the socket to deal with any in-progress service calls. Future additional changes that will need to be considered: (1) Make sure that a call doesn't hog the front of the queue by receiving data from the network as fast as userspace is consuming it to the exclusion of other calls. (2) Transmit delayed ACKs from within recvmsg() when we've consumed sufficiently more packets to avoid the background work item needing to run. Signed-off-by: David Howells <dhowells@redhat.com>
2016-09-08rxrpc: Convert rxrpc_local::services to an hlistDavid Howells
Convert the rxrpc_local::services list to an hlist so that it can be accessed under RCU conditions more readily. Signed-off-by: David Howells <dhowells@redhat.com>
2016-06-22rxrpc: Replace conn->trans->{local,peer} with conn->params.{local,peer}David Howells
Replace accesses of conn->trans->{local,peer} with conn->params.{local,peer} thus making it easier for a future commit to remove the rxrpc_transport struct. This also reduces the number of memory accesses involved. Signed-off-by: David Howells <dhowells@redhat.com>
2016-06-22rxrpc: Use structs to hold connection params and protocol infoDavid Howells
Define and use a structure to hold connection parameters. This makes it easier to pass multiple connection parameters around. Define and use a structure to hold protocol information used to hash a connection for lookup on incoming packet. Most of these fields will be disposed of eventually, including the duplicate local pointer. Whilst we're at it rename "proto" to "family" when referring to a protocol family. Signed-off-by: David Howells <dhowells@redhat.com>
2016-06-13rxrpc: Rename files matching ar-*.c to git rid of the "ar-" prefixDavid Howells
Rename files matching net/rxrpc/ar-*.c to get rid of the "ar-" prefix. This will aid splitting those files by making easier to come up with new names. Note that the not all files are simply renamed from ar-X.c to X.c. The following exceptions are made: (*) ar-call.c -> call_object.c ar-ack.c -> call_event.c call_object.c is going to contain the core of the call object handling. Call event handling is all going to be in call_event.c. (*) ar-accept.c -> call_accept.c Incoming call handling is going to be here. (*) ar-connection.c -> conn_object.c ar-connevent.c -> conn_event.c The former file is going to have the basic connection object handling, but there will likely be some differentiation between client connections and service connections in additional files later. The latter file will have all the connection-level event handling. (*) ar-local.c -> local_object.c This will have the local endpoint object handling code. The local endpoint event handling code will later be split out into local_event.c. (*) ar-peer.c -> peer_object.c This will have the peer endpoint object handling code. Peer event handling code will be placed in peer_event.c (for the moment, there is none). (*) ar-error.c -> peer_event.c This will become the peer event handling code, though for the moment it's actually driven from the local endpoint's perspective. Note that I haven't renamed ar-transport.c to transport_object.c as the intention is to delete it when the rxrpc_transport struct is excised. The only file that actually has its contents changed is net/rxrpc/Makefile. net/rxrpc/ar-internal.h will need its section marker comments updating, but I'll do that in a separate patch to make it easier for git to follow the history across the rename. I may also want to rename ar-internal.h at some point - but that would mean updating all the #includes and I'd rather do that in a separate step. Signed-off-by: David Howells <dhowells@redhat.com.
