path: root/net/rds
2011-07-01net: rds: fix const array syntaxGreg Dietsche
Correct the syntax so that both array and pointer are const. Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-17net/rds: use prink_ratelimited() instead of printk_ratelimit()Manuel Zerpies
Since printk_ratelimit() shouldn't be used anymore (see comment in include/linux/printk.h), replace it with printk_ratelimited() Signed-off-by: Manuel Zerpies <manuel.f.zerpies@ww.stud.uni-erlangen.de> Signed-off-by: David S. Miller <davem@conan.davemloft.net>
2011-06-06net: remove interrupt.h inclusion from netdevice.hAlexey Dobriyan
* remove interrupt.g inclusion from netdevice.h -- not needed * fixup fallout, add interrupt.h and hardirq.h back where needed. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25RDMA/cma: Pass QP type into rdma_create_id()Sean Hefty
The RDMA CM currently infers the QP type from the port space selected by the user. In the future (eg with RDMA_PS_IB or XRC), there may not be a 1-1 correspondence between port space and QP type. For netlink export of RDMA CM state, we want to export the QP type to userspace, so it is cleaner to explicitly associate a QP type to an ID. Modify rdma_create_id() to allow the user to specify the QP type, and use it to make our selections of datagram versus connected mode. Signed-off-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2011-03-23rds: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andy Grover <andy.grover@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rds: stop including asm-generic/bitops/le.h directlyAkinobu Mita
asm-generic/bitops/le.h is only intended to be included directly from asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h which implements generic ext2 or minix bit operations. This stops including asm-generic/bitops/le.h directly and use ext2 non-atomic bit operations instead. It seems odd to use ext2_*_bit() on rds, but it will replaced with __{set,clear,test}_bit_le() after introducing little endian bit operations for all architectures. This indirect step is necessary to maintain bisectability for some architectures which have their own little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andy Grover <andy.grover@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits) bonding: enable netpoll without checking link status xfrm: Refcount destination entry on xfrm_lookup net: introduce rx_handler results and logic around that bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag bonding: wrap slave state work net: get rid of multiple bond-related netdevice->priv_flags bonding: register slave pointer for rx_handler be2net: Bump up the version number be2net: Copyright notice change. Update to Emulex instead of ServerEngines e1000e: fix kconfig for crc32 dependency netfilter ebtables: fix xt_AUDIT to work with ebtables xen network backend driver bonding: Improve syslog message at device creation time bonding: Call netif_carrier_off after register_netdevice bonding: Incorrect TX queue offset net_sched: fix ip_tos2prio xfrm: fix __xfrm_route_forward() be2net: Fix UDP packet detected status in RX compl Phonet: fix aligned-mode pipe socket buffer header reserve netxen: support for GbE port settings ... Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c with the staging updates.
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bnx2x/bnx2x_cmn.c
2011-03-08rds: prevent BUG_ON triggering on congestion map updatesNeil Horman
Recently had this bug halt reported to me: kernel BUG at net/rds/send.c:329! Oops: Exception in kernel mode, sig: 5 [#1] SMP NR_CPUS=1024 NUMA pSeries Modules linked in: rds sunrpc ipv6 dm_mirror dm_region_hash dm_log ibmveth sg ext4 jbd2 mbcache sd_mod crc_t10dif ibmvscsic scsi_transport_srp scsi_tgt dm_mod [last unloaded: scsi_wait_scan] NIP: d000000003ca68f4 LR: d000000003ca67fc CTR: d000000003ca8770 REGS: c000000175cab980 TRAP: 0700 Not tainted (2.6.32-118.el6.ppc64) MSR: 8000000000029032 <EE,ME,CE,IR,DR> CR: 44000022 XER: 00000000 TASK = c00000017586ec90[1896] 'krdsd' THREAD: c000000175ca8000 CPU: 0 GPR00: 0000000000000150 c000000175cabc00 d000000003cb7340 0000000000002030 GPR04: ffffffffffffffff 0000000000000030 0000000000000000 0000000000000030 GPR08: 0000000000000001 0000000000000001 c0000001756b1e30 0000000000010000 GPR12: d000000003caac90 c000000000fa2500 c0000001742b2858 c0000001742b2a00 GPR16: c0000001742b2a08 c0000001742b2820 0000000000000001 0000000000000001 GPR20: 0000000000000040 c0000001742b2814 c000000175cabc70 0800000000000000 GPR24: 0000000000000004 0200000000000000 0000000000000000 c0000001742b2860 GPR28: 0000000000000000 c0000001756b1c80 d000000003cb68e8 c0000001742b27b8 NIP [d000000003ca68f4] .rds_send_xmit+0x4c4/0x8a0 [rds] LR [d000000003ca67fc] .rds_send_xmit+0x3cc/0x8a0 [rds] Call Trace: [c000000175cabc00] [d000000003ca67fc] .rds_send_xmit+0x3cc/0x8a0 [rds] (unreliable) [c000000175cabd30] [d000000003ca7e64] .rds_send_worker+0x54/0x100 [rds] [c000000175cabdb0] [c0000000000b475c] .worker_thread+0x1dc/0x3c0 [c000000175cabed0] [c0000000000baa9c] .kthread+0xbc/0xd0 [c000000175cabf90] [c000000000032114] .kernel_thread+0x54/0x70 Instruction dump: 4bfffd50 60000000 60000000 39080001 935f004c f91f0040 41820024 813d017c 7d094a78 7d290074 7929d182 394a0020 <0b090000> 40e2ff68 4bffffa4 39200000 Kernel panic - not syncing: Fatal exception Call Trace: [c000000175cab560] [c000000000012e04] .show_stack+0x74/0x1c0 (unreliable) [c000000175cab610] [c0000000005a365c] .panic+0x80/0x1b4 [c000000175cab6a0] [c00000000002fbcc] .die+0x21c/0x2a0 [c000000175cab750] [c000000000030000] ._exception+0x110/0x220 [c000000175cab910] [c000000000004b9c] program_check_common+0x11c/0x180 Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-01rds/ib: use system_wq instead of rds_ib_fmr_wqTejun Heo
With cmwq, there's no reason to use dedicated rds_ib_fmr_wq - it's not in the memory reclaim path and the maximum number of concurrent work items is bound by the number of devices. Drop it and use system_wq instead. This rds_ib_fmr_init/exit() noops. Both removed. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andy Grover <andy.grover@oracle.com>
2011-01-19net: cleanup unused macros in net directoryShan Wei
Clean up some unused macros in net/*. 1. be left for code change. e.g. PGV_FROM_VMALLOC, PGV_FROM_VMALLOC, KMEM_SAFETYZONE. 2. never be used since introduced to kernel. e.g. P9_RDMA_MAX_SGE, UTIL_CTRL_PKT_SIZE. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22Net: rds: Makefile: Remove deprecated itemsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Also, use the ccflags-$ flag instead of EXTRA_CFLAGS because EXTRA_CFLAGS is deprecated and should now be switched. Last but not least, took out if-conditionals. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-17rds: Integer overflow in RDS cmsg handlingDan Rosenberg
In rds_cmsg_rdma_args(), the user-provided args->nr_local value is restricted to less than UINT_MAX. This seems to need a tighter upper bound, since the calculation of total iov_size can overflow, resulting in a small sock_kmalloc() allocation. This would probably just result in walking off the heap and crashing when calling rds_rdma_pages() with a high count value. If it somehow doesn't crash here, then memory corruption could occur soon after. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-08rds: Fix rds message leak in rds_message_map_pagesPavel Emelyanov
The sgs allocation error path leaks the allocated message. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-03rds: Remove kfreed tcp conn from listPavel Emelyanov
All the rds_tcp_connection objects are stored list, but when being freed it should be removed from there. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-03rds: Lost locking in loop connection freeingPavel Emelyanov
The conn is removed from list in there and this requires proper lock protection. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-30RDS: Let rds_message_alloc_sgs() return NULLAndy Grover
Even with the previous fix, we still are reading the iovecs once to determine SGs needed, and then again later on. Preallocating space for sg lists as part of rds_message seemed like a good idea but it might be better to not do this. While working to redo that code, this patch attempts to protect against userspace rewriting the rds_iovec array between the first and second accesses. The consequences of this would be either a too-small or too-large sg list array. Too large is not an issue. This patch changes all callers of message_alloc_sgs to handle running out of preallocated sgs, and fail gracefully. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-30RDS: Copy rds_iovecs into kernel memory instead of rereading from userspaceAndy Grover
Change rds_rdma_pages to take a passed-in rds_iovec array instead of doing copy_from_user itself. Change rds_cmsg_rdma_args to copy rds_iovec array once only. This eliminates the possibility of userspace changing it after our sanity checks. Implement stack-based storage for small numbers of iovecs, based on net/socket.c, to save an alloc in the extremely common case. Although this patch reduces iovec copies in cmsg_rdma_args to 1, we still do another one in rds_rdma_extra_size. Getting rid of that one will be trickier, so it'll be a separate patch. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-30RDS: Clean up error handling in rds_cmsg_rdma_argsAndy Grover
We don't need to set ret = 0 at the end -- it's initialized to 0. Also, don't increment s_send_rdma stat if we're exiting with an error. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-30RDS: Return -EINVAL if rds_rdma_pages returns an errorAndy Grover
rds_cmsg_rdma_args would still return success even if rds_rdma_pages returned an error (or overflowed). Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-30net: fix rds_iovec page count overflowLinus Torvalds
As reported by Thomas Pollet, the rdma page counting can overflow. We get the rdma sizes in 64-bit unsigned entities, but then limit it to UINT_MAX bytes and shift them down to pages (so with a possible "+1" for an unaligned address). So each individual page count fits comfortably in an 'unsigned int' (not even close to overflowing into signed), but as they are added up, they might end up resulting in a signed return value. Which would be wrong. Catch the case of tot_pages turning negative, and return the appropriate error code. Reported-by: Thomas Pollet <thomas.pollet@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-21Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/core/dev.c
2010-10-21rds: make local functions/variables staticstephen hemminger
The RDS protocol has lots of functions that should be declared static. rds_message_get/add_version_extension is removed since it defined but never used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-15De-pessimize rds_page_copy_userLinus Torvalds
Don't try to "optimize" rds_page_copy_user() by using kmap_atomic() and the unsafe atomic user mode accessor functions. It's actually slower than the straightforward code on any reasonable modern CPU. Back when the code was written (although probably not by the time it was actually merged, though), 32-bit x86 may have been the dominant architecture. And there kmap_atomic() can be a lot faster than kmap() (unless you have very good locality, in which case the virtual address caching by kmap() can overcome all the downsides). But these days, x86-64 may not be more populous, but it's getting there (and if you care about performance, it's definitely already there - you'd have upgraded your CPU's already in the last few years). And on x86-64, the non-kmap_atomic() version is faster, simply because the code is simpler and doesn't have the "re-try page fault" case. People with old hardware are not likely to care about RDS anyway, and the optimization for the 32-bit case is simply buggy, since it doesn't verify the user addresses properly. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/qlcnic/qlcnic_init.c net/ipv4/ip_output.c
2010-09-24net: fix a lockdep splatEric Dumazet
We have for each socket : One spinlock (sk_slock.slock) One rwlock (sk_callback_lock) Possible scenarios are : (A) (this is used in net/sunrpc/xprtsock.c) read_lock(&sk->sk_callback_lock) (without blocking BH) <BH> spin_lock(&sk->sk_slock.slock); ... read_lock(&sk->sk_callback_lock); ... (B) write_lock_bh(&sk->sk_callback_lock) stuff write_unlock_bh(&sk->sk_callback_lock) (C) spin_lock_bh(&sk->sk_slock) ... write_lock_bh(&sk->sk_callback_lock) stuff write_unlock_bh(&sk->sk_callback_lock) spin_unlock_bh(&sk->sk_slock) This (C) case conflicts with (A) : CPU1 [A] CPU2 [C] read_lock(callback_lock) <BH> spin_lock_bh(slock) <wait to spin_lock(slock)> <wait to write_lock_bh(callback_lock)> We have one problematic (C) use case in inet_csk_listen_stop() : local_bh_disable(); bh_lock_sock(child); // spin_lock_bh(&sk->sk_slock) WARN_ON(sock_owned_by_user(child)); ... sock_orphan(child); // write_lock_bh(&sk->sk_callback_lock) lockdep is not happy with this, as reported by Tetsuo Handa It seems only way to deal with this is to use read_lock_bh(callbacklock) everywhere. Thanks to Jarek for pointing a bug in my first attempt and suggesting this solution. Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-19rds: spin_lock_irq() is not nestableDan Carpenter
This is basically just a cleanup. IRQs were disabled on the previous line so we don't need to do it again here. In the current code IRQs would get turned on one line earlier than intended. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-19rds: double unlock in rds_ib_cm_handle_connect()Dan Carpenter
We unlock after we goto out. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-19rds: signedness bugDan Carpenter
In the original code if the copy_from_user() fails in rds_rdma_pages() then the error handling fails and we get a stack trace from kmalloc(). Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08RDS: Implement masked atomic operationsAndy Grover
Add two CMSGs for masked versions of cswp and fadd. args struct modified to use a union for different atomic op type's arguments. Change IB to do masked atomic ops. Atomic op type in rds_message similarly unionized. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS/IB: print string constants in more placesZach Brown
This prints the constant identifier for work completion status and rdma cm event types, like we already do for IB event types. A core string array helper is added that each string type uses. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: cancel connection work structs as we shut downZach Brown
Nothing was canceling the send and receive work that might have been queued as a conn was being destroyed. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: don't call rds_conn_shutdown() from rds_conn_destroy()Zach Brown
rds_conn_shutdown() can return before the connection is shut down when it encounters an existing state that it doesn't understand. This lets rds_conn_destroy() then start tearing down the conn from under paths that are still using it. It's more reliable the shutdown work and wait for krdsd to complete the shutdown callback. This stopped some hangs I was seeing where krdsd was trying to shut down a freed conn. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: have sockets get transport module referencesZach Brown
Right now there's nothing to stop the various paths that use rs->rs_transport from racing with rmmod and executing freed transport code. The simple fix is to have binding to a transport also hold a reference to the transport's module, removing this class of races. We already had an unused t_owner field which was set for the modular transports and which wasn't set for the built-in loop transport. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: remove old rs_transport commentZach Brown
rs_transport is now also used by the rdma paths once the socket is bound. We don't need this stale comment to tell us what cscope can. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: lock rds_conn_count decrement in rds_conn_destroy()Zach Brown
rds_conn_destroy() can race with all other modifications of the rds_conn_count but it was modifying the count without locking. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: protect the list of IB devicesZach Brown
The RDS IB device list wasn't protected by any locking. Traversal in both the get_mr and FMR flushing paths could race with additon and removal. List manipulation is done with RCU primatives and is protected by the write side of a rwsem. The list traversal in the get_mr fast path is protected by a rcu read critical section. The FMR list traversal is more problematic because it can block while traversing the list. We protect this with the read side of the rwsem. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: print IB event strings as well as their numberZach Brown
It's nice to not have to go digging in the code to see which event occurred. It's easy to throw together a quick array that maps the ib event enums to their strings. I didn't see anything in the stack that does this translation for us, but I also didn't look very hard. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: flush fmrs before allocating new onesChris Mason
Flushing FMRs is somewhat expensive, and is currently kicked off when the interrupt handler notices that we are getting low. The result of this is that FMR flushing only happens from the interrupt cpus. This spreads the load more effectively by triggering flushes just before we allocate a new FMR. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-09-08RDS: properly use sg_init_tableChris Mason
This is only needed to keep debugging code from bugging. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-09-08RDS/IB: track signaled sendsZach Brown
We're seeing bugs today where IB connection shutdown clears the send ring while the tasklet is processing completed sends. Implementation details cause this to dereference a null pointer. Shutdown needs to wait for send completion to stop before tearing down the connection. We can't simply wait for the ring to empty because it may contain unsignaled sends that will never be processed. This patch tracks the number of signaled sends that we've posted and waits for them to complete. It also makes sure that the tasklet has finished executing. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: remove __init and __exit annotationZach Brown
The trivial amount of memory saved isn't worth the cost of dealing with section mismatches. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: Use SLAB_HWCACHE_ALIGN flag for kmem_cache_create()Andy Grover
We are *definitely* counting cycles as closely as DaveM, so ensure hwcache alignment for our recv ring control structs. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS/IB: always process recv completionsZach Brown
The recv refill path was leaking fragments because the recv event handler had marked a ring element as free without freeing its frag. This was happening because it wasn't processing receives when the conn wasn't marked up or connecting, as can be the case if it races with rmmod. Two observations support always processing receives in the callback. First, buildup should only post receives, thus triggering recv event handler calls, once it has built up all the state to handle them. Teardown should destroy the CQ and drain the ring before tearing down the state needed to process recvs. Both appear to be true today. Second, this test was fundamentally racy. There is nothing to stop rmmod and connection destruction from swooping in the moment after the conn state was sampled but before real receive procesing starts. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: return to a single-threaded krdsdZach Brown
We were seeing very nasty bugs due to fundamental assumption the current code makes about concurrent work struct processing. The code simpy isn't able to handle concurrent connection shutdown work function execution today, for example, which is very much possible once a multi-threaded krdsd was introduced. The problem compounds as additional work structs are added to the mix. krdsd is no longer perforance critical now that send and receive posting and FMR flushing are done elsewhere, so the safest fix is to move back to the single threaded krdsd that the current code was built around. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: create a work queue for FMR flushingZach Brown
This patch moves the FMR flushing work in to its own mult-threaded work queue. This is to maintain performance in preparation for returning the main krdsd work queue back to a single threaded work queue to avoid deep-rooted concurrency bugs. This is also good because it further separates FMRs, which might be removed some day, from the rest of the code base. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: destroy connections on rmmodZach Brown
IB connections were not being destroyed during rmmod. First, recently IB device removal callback was changed to disconnect connections that used the removing device rather than destroying them. So connections with devices during rmmod were not being destroyed. Second, rds_ib_destroy_nodev_conns() was being called before connections are disassociated with devices. It would almost never find connections in the nodev list. We first get rid of rds_ib_destroy_conns(), which is no longer called, and refactor the existing caller into the main body of the function and get rid of the list and lock wrappers. Then we call rds_ib_destroy_nodev_conns() *after* ib_unregister_client() has removed the IB device from all the conns and put the conns on the nodev list. The result is that IB connections are destroyed by rmmod. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: wait for IB dev freeing work to finish during rmmodZach Brown
The RDS IB client removal callback can queue work to drop the final reference to an IB device. We have to make sure that this function has returned before we complete rmmod or the work threads can try to execute freed code. Signed-off-by: Zach Brown <zach.brown@oracle.com>
