path: root/net/nfc/netlink.c
2015-12-29nfc: netlink: HCI event connectivity implementationChristophe Ricard
Add support for missing HCI event EVT_CONNECTIVITY and forward it to userspace. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-27NFC: netlink: Add mode parameter to deactivate_target functionsChristophe Ricard
In order to manage in a better way the nci poll mode state machine, add mode parameter to deactivate_target functions. This way we can manage different target state. mode parameter make sense only in nci core. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-10-19NFC: delete null dereferenceJulia Lawall
The exit label performs device_unlock(&dev->dev);, which will fail when dev is NULL, and nfc_put_device(dev);, which is not useful when dev is NULL, so just exit the function immediately. Problem found using scripts/coccinelle/null/deref_null.cocci Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-20nfc: netlink: Add capability to reply to vendor_cmd with dataChristophe Ricard
A proprietary vendor command may send back useful data to the user application. For example, the field level applied on the NFC router antenna. Still based on net/wireless/nl80211.c implementation, add nfc_vendor_cmd_alloc_reply_skb and nfc_vendor_cmd_reply in order to send back over netlink data generated by a proprietary command. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: netlink: Warning fixChristophe Ricard
When NFC_ATTR_VENDOR_DATA is not set, data_len is 0 and data is NULL. Fixes the following warning: net/nfc/netlink.c:1536:3: warning: 'data' may be used uninitialized +in this function [-Wmaybe-uninitialized] return cmd->doit(dev, data, data_len); Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-08-17nfc: netlink: Add check on NFC_ATTR_VENDOR_DATAChristophe Ricard
NFC_ATTR_VENDOR_DATA is an optional vendor_cmd argument. The current code was potentially using a non existing argument leading to potential catastrophic results. Cc: stable@vger.kernel.org Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-06-09NFC: netlink: Implement vendor command supportSamuel Ortiz
Vendor commands are passed from userspace through the NFC_CMD_VENDOR netlink command, allowing driver and hardware specific operations implementations like for example RF tuning or production line calibration. Drivers will associate a set of vendor commands to a vendor id, which could typically be an OUI. The netlink kernel implementation will try to match the received vendor id and sub command attributes with the registered ones. When such match is found, the driver defined sub command routine is called. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-04-13nfc: Fix portid type in urelease_workRichard Weinberger
portid is an unsigned integer. Fix urelease_work to match all other portid user in the kernel. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-02-02NFC: Forward NFC_EVT_TRANSACTION to user spaceChristophe Ricard
NFC_EVT_TRANSACTION is sent through netlink in order for a specific application running on a secure element to notify userspace of an event. Typically the secure element application counterpart on the host could interpret that event and act upon it. Forwarded information contains: - SE host generating the event - Application IDentifier doing the operation - Applications parameters Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2015-01-18netlink: make nlmsg_end() and genlmsg_end() voidJohannes Berg
Contrary to common expectations for an "int" return, these functions return only a positive value -- if used correctly they cannot even return 0 because the message header will necessarily be in the skb. This makes the very common pattern of if (genlmsg_end(...) < 0) { ... } be a whole bunch of dead code. Many places also simply do return nlmsg_end(...); and the caller is expected to deal with it. This also commonly (at least for me) causes errors, because it is very common to write if (my_function(...)) /* error condition */ and if my_function() does "return nlmsg_end()" this is of course wrong. Additionally, there's not a single place in the kernel that actually needs the message length returned, and if anyone needs it later then it'll be very easy to just use skb->len there. Remove this, and make the functions void. This removes a bunch of dead code as described above. The patch adds lines because I did - return nlmsg_end(...); + nlmsg_end(...); + return 0; I could have preserved all the function's return values by returning skb->len, but instead I've audited all the places calling the affected functions and found that none cared. A few places actually compared the return value with <= 0 in dump functionality, but that could just be changed to < 0 with no change in behaviour, so I opted for the more efficient version. One instance of the error I've made numerous times now is also present in net/phonet/pn_netlink.c in the route_dumpit() function - it didn't check for <0 or <=0 and thus broke out of the loop every single time. I've preserved this since it will (I think) have caused the messages to userspace to be formatted differently with just a single message for every SKB returned to userspace. It's possible that this isn't needed for the tools that actually use this, but I don't even know what they are so couldn't test that changing this behaviour would be acceptable. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-12-02NFC: Add se_io NFC operandChristophe Ricard
se_io allows to send apdu over the CLF to the embedded Secure Element. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2014-12-02NFC: netlink: Add new netlink command NFC_CMD_ACTIVATE_TARGETChristophe Ricard
Some tag might get deactivated after some read or write tentative. This may happen for example with Mifare Ultralight C tag when trying to read the last 4 blocks (starting block 0x2c) configured as write only. NFC_CMD_ACTIVATE_TARGET will try to reselect the tag in order to detect if it got remove from the field or if it is still present. Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2014-02-16NFC: Add netlink support for ISO/IEC 15693Mark A. Greer
Add ISO/IEC 15693 support by having netlink push the 1-byte DSFID and 8-byte UID tag information upstream. Signed-off-by: Mark A. Greer <mgreer@animalcreek.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-12-11nfc: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: linux-wireless@vger.kernel.org CC: Lauro Ramos Venancio <lauro.venancio@openbossa.org> CC: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> CC: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-11-19genetlink: make multicast groups const, prevent abuseJohannes Berg
Register generic netlink multicast groups as an array with the family and give them contiguous group IDs. Then instead of passing the global group ID to the various functions that send messages, pass the ID relative to the family - for most families that's just 0 because the only have one group. This avoids the list_head and ID in each group, adding a new field for the mcast group ID offset to the family. At the same time, this allows us to prevent abusing groups again like the quota and dropmon code did, since we can now check that a family only uses a group it owns. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: pass family to functions using groupsJohannes Berg
This doesn't really change anything, but prepares for the next patch that will change the APIs to pass the group ID within the family, rather than the global group ID. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-19genetlink: only pass array to genl_register_family_with_ops()Johannes Berg
As suggested by David Miller, make genl_register_family_with_ops() a macro and pass only the array, evaluating ARRAY_SIZE() in the macro, this is a little safer. The openvswitch has some indirection, assing ops/n_ops directly in that code. This might ultimately just assign the pointers in the family initializations, saving the struct genl_family_and_ops and code (once mcast groups are handled differently.) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-14genetlink: make all genl_ops users constJohannes Berg
Now that genl_ops are no longer modified in place when registering, they can be made const. This patch was done mostly with spatch: @@ identifier ops; @@ +const struct genl_ops ops[] = { ... }; (except the struct thing in net/openvswitch/datapath.c) Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-10-07NFC: Fix SE API related sparse warningSamuel Ortiz
se_io_cb can be declared static. This fixes the following sparse warning: net/nfc/netlink.c:1287:6: warning: symbol 'se_io_cb' was not declared. Should it be static? Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-09-25NFC: netlink: SE API implementationSamuel Ortiz
Implementation of the NFC_CMD_SE_IO command for sending ISO7816 APDUs to NFC embedded secure elements. The reply is forwarded to user space through NFC_CMD_SE_IO as well. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-14NFC: netlink: Add result of firmware operation to completion eventEric Lapuyade
Result is added as an NFC_ATTR_FIRMWARE_DOWNLOAD_STATUS attribute containing the standard errno positive value of the completion result. This event will be sent when the firmare download operation is done and will contain the operation result. Signed-off-by: Eric Lapuyade <eric.lapuyade@intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-08-14NFC: Add a GET_SE netlink APISamuel Ortiz
In order to fetch the discovered secure elements from an NFC controller, we need to send a netlink command that will dump the list of available SEs from NFC. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-07-31NFC: netlink: Rename CMD_FW_UPLOAD to CMD_FW_DOWNLOADSamuel Ortiz
Loading a firmware into a target is typically called firmware download, not firmware upload. So we rename the netlink API to NFC_CMD_FW_DOWNLOAD in order to avoid any terminology confusion from userspace. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-14NFC: Add secure element enablement netlink APISamuel Ortiz
Enabling or disabling an NFC accessible secure element through netlink requires giving both an NFC controller and a secure element indexes. Once enabled the secure element will handle card emulation once polling starts. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-14NFC: Send netlink events for secure elements additions and removalsSamuel Ortiz
When an NFC driver or host controller stack discovers a secure element, it will call nfc_add_se(). In order for userspace applications to use these secure elements, a netlink event will then be sent with the SE index and its type. With that information userspace applications can decide wether or not to enable SEs, through their indexes. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-14NFC: Remove the static supported_se fieldSamuel Ortiz
Supported secure elements are typically found during a discovery process initiated when the NFC controller is up and running. For a given NFC chipset there can be many configurations (embedded SE or not, with or without a SIM card wired to the NFC controller SWP interface, etc...) and thus driver code will never know before hand which SEs are available. So we remove this field, it will be replaced by a real SE discovery mechanism. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-14NFC: Add firmware upload netlink commandEric Lapuyade
As several NFC chipsets can have their firmwares upgraded and reflashed, this patchset adds a new netlink command to trigger that the driver loads or flashes a new firmware. This will allows userspace triggered firmware upgrade through netlink. The firmware name or hint is passed as a parameter, and the driver will eventually fetch the firmware binary through the request_firmware API. The cmd can only be executed when the nfc dev is not in use. Actual firmware loading/flashing is an asynchronous operation. Result of the operation shall send a new event up to user space through the nfc dev multicast socket. During operation, the nfc dev is not openable and thus not usable. Signed-off-by: Eric Lapuyade <eric.lapuyade@intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-04-26NFC: Move LLCP code to the NFC top level diirectorySamuel Ortiz
And stop making it optional. LLCP is a fundamental part of the NFC specifications and making it optional does not make much sense. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-03-10NFC: llcp: Service Name Lookup netlink interfaceThierry Escande
This adds a netlink interface for service name lookup support. Multiple URIs can be passed nested into the NFC_ATTR_LLC_SDP attribute using the NFC_CMD_LLC_SDREQ netlink command. When the SNL reply is received, a NFC_EVENT_LLC_SDRES event is sent to the user space. URI and SAP tuples are passed back, nested into NFC_ATTR_LLC_SDP attribute. Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-03-10NFC: Add missing type policies for netlink attributesThierry Escande
2013-01-10NFC: Initial Secure Element APISamuel Ortiz
Each NFC adapter can have several links to different secure elements and that property needs to be exported by the drivers. A secure element link can be enabled and disabled, and card emulation will be handled by the currently active one. Otherwise card emulation will be host implemented. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-10-29NFC: Extend netlink interface for LTO, RW, and MIUX parameters supportThierry Escande
NFC_CMD_LLC_GET_PARAMS: request LTO, RW, and MIUX parameters for a device NFC_CMD_LLC_SET_PARAMS: set one or more of LTO, RW, and MIUX parameters for a device. LTO must be set before the link is up otherwise -EINPROGRESS is returned. RW and MIUX can be set at anytime and will be passed in subsequent CONNECT and CC messages. If one of the passed parameters is wrong none is set and -EINVAL is returned. Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-10-26NFC: Fix some code style and whitespace issuesSzymon Janc
Signed-off-by: Szymon Janc <szymon.janc@tieto.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-10-26NFC: Add NFC_ATTR_RF_MODE when sending device netlink propertiesThierry Escande
This is useful when getting devices to know if they're in target or initiator mode. Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-28Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: net/nfc/netlink.c Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-09-27NFC: Fix sleeping in invalid context when netlink socket is closedSzymon Janc
netlink_register_notifier requires notify functions to not sleep. nfc_stop_poll locks device mutex and must not be called from notifier. Create workqueue that will handle this for all devices. BUG: sleeping function called from invalid context at kernel/mutex.c:269 in_atomic(): 0, irqs_disabled(): 0, pid: 4497, name: neard 1 lock held by neard/4497: Pid: 4497, comm: neard Not tainted 3.5.0-999-nfc+ #5 Call Trace: [<ffffffff810952c5>] __might_sleep+0x145/0x200 [<ffffffff81743dde>] mutex_lock_nested+0x2e/0x50 [<ffffffff816ffd19>] nfc_stop_poll+0x39/0xb0 [<ffffffff81700a17>] nfc_genl_rcv_nl_event+0x77/0xc0 [<ffffffff8174aa8c>] notifier_call_chain+0x5c/0x120 [<ffffffff8174abd6>] __atomic_notifier_call_chain+0x86/0x140 [<ffffffff8174ab50>] ? notifier_call_chain+0x120/0x120 [<ffffffff815e1347>] ? skb_dequeue+0x67/0x90 [<ffffffff8174aca6>] atomic_notifier_call_chain+0x16/0x20 [<ffffffff8162119a>] netlink_release+0x24a/0x280 [<ffffffff815d7aa8>] sock_release+0x28/0xa0 [<ffffffff815d7be7>] sock_close+0x17/0x30 [<ffffffff811b2a7c>] __fput+0xcc/0x250 [<ffffffff811b2c0e>] ____fput+0xe/0x10 [<ffffffff81085009>] task_work_run+0x69/0x90 [<ffffffff8101b951>] do_notify_resume+0x81/0xd0 [<ffffffff8174ef22>] int_signal+0x12/0x17 Signed-off-by: Szymon Janc <szymon.janc@tieto.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12Merge branch 'master' of ↵John W. Linville
2012-07-09NFC: Do not return EBUSY when stopping a poll that's already stoppedSamuel Ortiz
We check for the polling flag before checking if the netlink PID caller match. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-06-28net: Use NLMSG_DEFAULT_SIZE in combination with nlmsg_new()Thomas Graf
Using NLMSG_GOODSIZE results in multiple pages being used as nlmsg_new() will automatically add the size of the netlink header to the payload thus exceeding the page limit. NLMSG_DEFAULT_SIZE takes this into account. Signed-off-by: Thomas Graf <tgraf@suug.ch> Cc: Jiri Pirko <jpirko@redhat.com> Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Sergey Lapin <slapin@ossfans.org> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Reviewed-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-06-04NFC: Switch to Initiator mode when getting NFC_ATTR_PROTOCOLSSamuel Ortiz
That is needed for keeping backward compatibility with apps using the old netlink polling API (NFC_ATTR_PROTOCOLS instead of NFC_ATTR_IM_PROTOCOLS). Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-06-04NFC: Add target mode activation netlink eventSamuel Ortiz
Userspace gets a netlink event upon target mode activation. The LLCP layer is also signaled when we get an ATR_REQ in order to get the remote general bytes. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-06-04NFC: Add target mode protocols to the polling loop startup routineSamuel Ortiz
2012-05-15NFC: The NFC genl family structure should not be exposed globallyH Hartley Sweeten
The variable 'nfc_genl_family' is only referenced in this file and should be marked static to prevent it from being exposed globally. Quites the sparse warning: warning: symbol 'nfc_genl_family' was not declared. Should it be static? Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-15NFC: Specify usage for targets found and target lost eventsEric Lapuyade
It is now specified that nfc_target_found() and nfc_target_lost() core functions must not be called from an atomic context. This allow us to serialize calls and protect the targets table using the nfc device lock instead of a spinlock. Signed-off-by: Eric Lapuyade <eric.lapuyade@intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-18Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem Conflicts: drivers/net/wireless/iwlwifi/iwl-testmode.c include/net/nfc/nfc.h net/nfc/netlink.c net/wireless/nl80211.c
2012-04-12NFC: Add a target lost netlink eventSamuel Ortiz
Some chips are capable of detecting when a tag is out of the field, so they could send a netlink event about it to userspace. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-04-01nfc: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-06NFC: Core code identation fixesSamuel Ortiz
2012-03-06NFC: Remove the rf mode parameter from the DEP link up routineSamuel Ortiz
When calling nfc_dep_link_up, we implicitely are in initiator mode. Which means we also can provide the general bytes as a function argument, as all drivers will eventually request them. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
