path: root/net/netfilter
2008-05-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (73 commits) net: Fix typo in net/core/sock.c. ppp: Do not free not yet unregistered net device. netfilter: xt_iprange: module aliases for xt_iprange netfilter: ctnetlink: dump conntrack ID in event messages irda: Fix a misalign access issue. (v2) sctp: Fix use of uninitialized pointer cipso: Relax too much careful cipso hash function. tcp FRTO: work-around inorder receivers tcp FRTO: Fix fallback to conventional recovery New maintainer for Intel ethernet adapters DM9000: Use delayed work to update MII PHY state DM9000: Update and fix driver debugging messages DM9000: Add __devinit and __devexit attributes to probe and remove sky2: fix simple define thinko [netdrvr] sfc: sfc: Add self-test support [netdrvr] sfc: Increment rx_reset when reported as driver event [netdrvr] sfc: Remove unused macro EFX_XAUI_RETRAIN_MAX [netdrvr] sfc: Fix code formatting [netdrvr] sfc: Remove kernel-doc comments for removed members of struct efx_nic [netdrvr] sfc: Remove garbage from comment ...
2008-05-13netfilter: xt_iprange: module aliases for xt_iprangePhil Oester
Using iptables 1.3.8 with kernel 2.6.25, rules which include '-m iprange' don't automatically pull in xt_iprange module. Below patch adds module aliases to fix that. Patch against latest -git, but seems like a good candidate for -stable also. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-13netfilter: ctnetlink: dump conntrack ID in event messagesEric Leblond
Conntrack ID is not put (anymore ?) in event messages. This causes current ulogd2 code to fail because it uses the ID to build a hash in userspace. This hash is used to be able to output the starting time of a connection. Conntrack ID can be used in userspace application to maintain an easy match between kernel connections list and userspace one. It may worth to add it if there is no performance related issue. [ Patrick: it was never included in events, but really should be ] Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (32 commits) net: Added ASSERT_RTNL() to dev_open() and dev_close(). can: Fix can_send() handling on dev_queue_xmit() failures netns: Fix arbitrary net_device-s corruptions on net_ns stop. netfilter: Kconfig: default DCCP/SCTP conntrack support to the protocol config values netfilter: nf_conntrack_sip: restrict RTP expect flushing on error to last request macvlan: Fix memleak on device removal/crash on module removal net/ipv4: correct RFC 1122 section reference in comment tcp FRTO: SACK variant is errorneously used with NewReno e1000e: don't return half-read eeprom on error ucc_geth: Don't use RX clock as TX clock. cxgb3: Use CAP_SYS_RAWIO for firmware pcnet32: delete non NAPI code from driver. fs_enet: Fix a memory leak in fs_enet_mdio_probe [netdrvr] eexpress: IPv6 fails - multicast problems 3c59x: use netstats in net_device structure 3c980-TX needs EXTRA_PREAMBLE fix warning in drivers/net/appletalk/cops.c e1000e: Add support for BM PHYs on ICH9 uli526x: fix endianness issues in the setup frame uli526x: initialize the hardware prior to requesting interrupts ...
2008-05-08netfilter: Kconfig: default DCCP/SCTP conntrack support to the protocol ↵Patrick McHardy
config values When conntrack and DCCP/SCTP protocols are enabled, chances are good that people also want DCCP/SCTP conntrack and NAT support. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08netfilter: nf_conntrack_sip: restrict RTP expect flushing on error to last ↵Patrick McHardy
request Some Inovaphone PBXs exhibit very stange behaviour: when dialing for example "123", the device sends INVITE requests for "1", "12" and "123" back to back. The first requests will elicit error responses from the receiver, causing the SIP helper to flush the RTP expectations even though we might still see a positive response. Note the sequence number of the last INVITE request that contained a media description and only flush the expectations when receiving a negative response for that sequence number. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits) rose: Wrong list_lock argument in rose_node seqops netns: Fix reassembly timer to use the right namespace netns: Fix device renaming for sysfs bnx2: Update version to 1.7.5. bnx2: Update RV2P firmware for 5709. bnx2: Zero out context memory for 5709. bnx2: Fix register test on 5709. bnx2: Fix remote PHY initial link state. bnx2: Refine remote PHY locking. bridge: forwarding table information for >256 devices tg3: Update version to 3.92 tg3: Add link state reporting to UMP firmware tg3: Fix ethtool loopback test for 5761 BX devices tg3: Fix 5761 NVRAM sizes tg3: Use constant 500KHz MI clock on adapters with a CPMU hci_usb.h: fix hard-to-trigger race dccp: ccid2.c, ccid3.c use clamp(), clamp_t() net: remove NR_CPUS arrays in net/core/dev.c net: use get/put_unaligned_* helpers bluetooth: use get/put_unaligned_* helpers ...
2008-05-02netfilter: assign PDE->data before gluing PDE into /proc treeDenis V. Lunev
Replace proc_net_fops_create with proc_create_data. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02netfilter: assign PDE->fops before gluing PDE into /proc treeDenis V. Lunev
Replace create_proc_entry with specially created for this purpose proc_create. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
Simply replace proc_create and further data assigned with proc_create_data. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-01rename div64_64 to div64_u64Roman Zippel
Rename div64_64 to div64_u64 to make it consistent with the other divide functions, so it clearly includes the type of the divide. Move its definition to math64.h as currently no architecture overrides the generic implementation. They can still override it of course, but the duplicated declarations are avoided. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Avi Kivity <avi@qumranet.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (53 commits) tcp: Overflow bug in Vegas [IPv4] UFO: prevent generation of chained skb destined to UFO device iwlwifi: move the selects to the tristate drivers ipv4: annotate a few functions __init in ipconfig.c atm: ambassador: vcc_sf semaphore to mutex MAINTAINERS: The socketcan-core list is subscribers-only. netfilter: nf_conntrack: padding breaks conntrack hash on ARM ipv4: Update MTU to all related cache entries in ip_rt_frag_needed() sch_sfq: use del_timer_sync() in sfq_destroy() net: Add compat support for getsockopt (MCAST_MSFILTER) net: Several cleanups for the setsockopt compat support. ipvs: fix oops in backup for fwmark conn templates bridge: kernel panic when unloading bridge module bridge: fix error handling in br_add_if() netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packets netfilter: x_tables: fix net namespace leak when reading /proc/net/xxx_tables_names netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retval tcp: Limit cwnd growth when deferring for GSO tcp: Allow send-limited cwnd to grow up to max_burst when gso disabled [netdrvr] gianfar: Determine TBIPA value dynamically ...
2008-04-29Remove duplicated unlikely() in IS_ERR()Hirofumi Nakagawa
Some drivers have duplicated unlikely() macros. IS_ERR() already has unlikely() in itself. This patch cleans up such pointless code. Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jeff@garzik.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Carsten Otte <cotte@de.ibm.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29netfilter: nf_conntrack: padding breaks conntrack hash on ARMPhilip Craig
commit 0794935e "[NETFILTER]: nf_conntrack: optimize hash_conntrack()" results in ARM platforms hashing uninitialised padding. This padding doesn't exist on other architectures. Fix this by replacing NF_CT_TUPLE_U_BLANK() with memset() to ensure everything is initialised. There were only 4 bytes that NF_CT_TUPLE_U_BLANK() wasn't clearing anyway (or 12 bytes on ARM). Signed-off-by: Philip Craig <philipc@snapgear.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29netfilter: {nfnetlink,ip,ip6}_queue: fix skb_over_panic when enlarging packetsArnaud Ebalard
While reinjecting *bigger* modified versions of IPv6 packets using libnetfilter_queue, things work fine on a 2.6.24 kernel (2.6.22 too) but I get the following on recents kernels (2.6.25, trace below is against today's net-2.6 git tree): skb_over_panic: text:c04fddb0 len:696 put:632 head:f7592c00 data:f7592c00 tail:0xf7592eb8 end:0xf7592e80 dev:eth0 ------------[ cut here ]------------ invalid opcode: 0000 [#1] PREEMPT Process sendd (pid: 3657, ti=f6014000 task=f77c31d0 task.ti=f6014000) Stack: c071e638 c04fddb0 000002b8 00000278 f7592c00 f7592c00 f7592eb8 f7592e80 f763c000 f6bc5200 f7592c40 f6015c34 c04cdbfc f6bc5200 00000278 f6015c60 c04fddb0 00000020 f72a10c0 f751b420 00000001 0000000a 000002b8 c065582c Call Trace: [<c04fddb0>] ? nfqnl_recv_verdict+0x1c0/0x2e0 [<c04cdbfc>] ? skb_put+0x3c/0x40 [<c04fddb0>] ? nfqnl_recv_verdict+0x1c0/0x2e0 [<c04fd115>] ? nfnetlink_rcv_msg+0xf5/0x160 [<c04fd03e>] ? nfnetlink_rcv_msg+0x1e/0x160 [<c04fd020>] ? nfnetlink_rcv_msg+0x0/0x160 [<c04f8ed7>] ? netlink_rcv_skb+0x77/0xa0 [<c04fcefc>] ? nfnetlink_rcv+0x1c/0x30 [<c04f8c73>] ? netlink_unicast+0x243/0x2b0 [<c04cfaba>] ? memcpy_fromiovec+0x4a/0x70 [<c04f9406>] ? netlink_sendmsg+0x1c6/0x270 [<c04c8244>] ? sock_sendmsg+0xc4/0xf0 [<c011970d>] ? set_next_entity+0x1d/0x50 [<c0133a80>] ? autoremove_wake_function+0x0/0x40 [<c0118f9e>] ? __wake_up_common+0x3e/0x70 [<c0342fbf>] ? n_tty_receive_buf+0x34f/0x1280 [<c011d308>] ? __wake_up+0x68/0x70 [<c02cea47>] ? copy_from_user+0x37/0x70 [<c04cfd7c>] ? verify_iovec+0x2c/0x90 [<c04c837a>] ? sys_sendmsg+0x10a/0x230 [<c011967a>] ? __dequeue_entity+0x2a/0xa0 [<c011970d>] ? set_next_entity+0x1d/0x50 [<c0345397>] ? pty_write+0x47/0x60 [<c033d59b>] ? tty_default_put_char+0x1b/0x20 [<c011d2e9>] ? __wake_up+0x49/0x70 [<c033df99>] ? tty_ldisc_deref+0x39/0x90 [<c033ff20>] ? tty_write+0x1a0/0x1b0 [<c04c93af>] ? sys_socketcall+0x7f/0x260 [<c0102ff9>] ? sysenter_past_esp+0x6a/0x91 [<c05f0000>] ? snd_intel8x0m_probe+0x270/0x6e0 ======================= Code: 00 00 89 5c 24 14 8b 98 9c 00 00 00 89 54 24 0c 89 5c 24 10 8b 40 50 89 4c 24 04 c7 04 24 38 e6 71 c0 89 44 24 08 e8 c4 46 c5 ff <0f> 0b eb fe 55 89 e5 56 89 d6 53 89 c3 83 ec 0c 8b 40 50 39 d0 EIP: [<c04ccdfc>] skb_over_panic+0x5c/0x60 SS:ESP 0068:f6015bf8 Looking at the code, I ended up in nfq_mangle() function (called by nfqnl_recv_verdict()) which performs a call to skb_copy_expand() due to the increased size of data passed to the function. AFAICT, it should ask for 'diff' instead of 'diff - skb_tailroom(e->skb)'. Because the resulting sk_buff has not enough space to support the skb_put(skb, diff) call a few lines later, this results in the call to skb_over_panic(). The patch below asks for allocation of a copy with enough space for mangled packet and the same amount of headroom as old sk_buff. While looking at how the regression appeared (e2b58a67), I noticed the same pattern in ipq_mangle_ipv6() and ipq_mangle_ipv4(). The patch corrects those locations too. Tested with bigger reinjected IPv6 packets (nfqnl_mangle() path), things are ok (2.6.25 and today's net-2.6 git tree). Signed-off-by: Arnaud Ebalard <arno@natisbad.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29netfilter: x_tables: fix net namespace leak when reading ↵Pavel Emelyanov
/proc/net/xxx_tables_names The seq_open_net() call should be accompanied with seq_release_net() one. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-29netfilter: xt_TCPOPTSTRIP: signed tcphoff for ipv6_skip_exthdr() retvalRoel Kluin
if tcphoff remains unsigned, a negative ipv6_skip_exthdr() return value will go unnoticed, Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-19netfilter: Fix SIP conntrack build with NAT disabled.Patrick McHardy
Reported by Ingo Molnar. The SIP helper is also useful without NAT. This patch adds an ifdef around the RTP call optimization for NATed clients. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6.26
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/ehea/ehea_main.c drivers/net/wireless/iwlwifi/Kconfig drivers/net/wireless/rt2x00/rt61pci.c net/ipv4/inet_timewait_sock.c net/ipv6/raw.c net/mac80211/ieee80211_sta.c
2008-04-14[NETFILTER]: nf_conntrack: fix incorrect check for expectationsPatrick McHardy
The expectation classes changed help->expectations to an array, fix use as scalar value. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: replace NF_CT_DUMP_TUPLE macro indrection by ↵Jan Engelhardt
function call Directly call IPv4 and IPv6 variants where the address family is easily known. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: const annotations in nf_conntrack_sctp, ↵Jan Engelhardt
nf_nat_proto_gre Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_tuple.hJan Engelhardt
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_l4protoJan Engelhardt
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_l3protoJan Engelhardt
2008-04-14[NETFILTER]: nf_conntrack: add tuplehash l3num/protonum accessorsPatrick McHardy
Add accessors for l3num and protonum and get rid of some overly long expressions. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack_tcp: catch invalid state updates over ctnetlinkPatrick McHardy
Invalid states can cause out-of-bound memory accesses of the state table. Also don't insist on having a new state contained in the netlink message. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack_extend: warn on confirmed conntracksPatrick McHardy
New extensions may only be added to unconfirmed conntracks to avoid races when reallocating the storage. Also change NF_CT_ASSERT to use WARN_ON to get backtraces. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: add DCCP protocol supportPatrick McHardy
Add DCCP conntrack helper. Thanks to Gerrit Renker <gerrit@erg.abdn.ac.uk> for review and testing. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: Add partial checksum validation helperPatrick McHardy
Move the UDP-Lite conntrack checksum validation to a generic helper similar to nf_checksum() and make it fall back to nf_checksum() in case the full packet is to be checksummed and hardware checksums are available. This is to be used by DCCP conntrack, which also needs to verify partial checksums. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack_netlink: clean up NAT protocol parsingPatrick McHardy
Move responsibility for setting the IP_NAT_RANGE_PROTO_SPECIFIED flag to the NAT protocol, properly propagate errors and get rid of ugly return value convention. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack_sip: clear address in parse_addr()Patrick McHardy
Some callers pass uninitialized structures, clear the address to make sure later comparisions work properly. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: annotate rest of nf_conntrack_* with constJan Engelhardt
2008-04-14[NETFILTER]: annotate {arp,ip,ip6,x}tables with constJan Engelhardt
2008-04-14[NETFILTER]: annotate xtables targets with const and remove castsJan Engelhardt
2008-04-14[NETFILTER]: nf_conntrack: less hairy ifdefs around proc and sysctlAlexey Dobriyan
Patch splits creation of /proc/net/nf_conntrack, /proc/net/stat/nf_conntrack and net.netfilter hierarchy into their own functions with dummy ones if PROC_FS or SYSCTL is not set. Also, remove dead "ret = 0" write while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-09[NETFILTER]: xt_hashlimit: fix mask calculationPatrick McHardy
Shifts larger than the data type are undefined, don't try to shift an u32 by 32. Also remove some special-casing of bitmasks divisible by 32. Based on patch by Jan Engelhardt <jengelh@computergmbh.de>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
2008-03-27[NETFILTER]: Replate direct proc_fops assignment with proc_create call.Denis V. Lunev
This elliminates infamous race during module loading when one could lookup proc entry without proc_fops assigned. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: update copyrightPatrick McHardy
2008-03-25[NETFILTER]: nf_conntrack_sip: RTP routing optimizationPatrick McHardy
Optimize call routing between NATed endpoints: when an external registrar sends a media description that contains an existing RTP expectation from a different SNATed connection, the gatekeeper is trying to route the call directly between the two endpoints. We assume both endpoints can reach each other directly and "un-NAT" the addresses, which makes the media stream go between the two endpoints directly. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: support multiple media channelsPatrick McHardy
Add support for multiple media channels and use it to create expectations for video streams when present. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_nat_sip: split up SDP manglingPatrick McHardy
The SDP connection addresses may be contained in the payload multiple times (in the session description and/or once per media description), currently only the session description is properly updated. Split up SDP mangling so the function setting up expectations only updates the media port, update connection addresses from media descriptions while parsing them and at the end update the session description when the final addresses are known. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: create RTCP expectationsPatrick McHardy
Create expectations for the RTCP connections in addition to RTP connections. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: allow media expectations with wildcard source ↵Patrick McHardy
address Media streams can come from anywhere, add a module parameter which controls whether wildcard expectations or expectations between the two signalling endpoints are created. Since the same media description sent on multiple connections may results in multiple identical expections when using a wildcard source, we need to check whether a similar expectation already exists for a different connection before attempting to register it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: create signalling expectationsPatrick McHardy
Create expectations for incoming signalling connections when seeing a REGISTER request. This is needed when the registrar uses a different source port number for signalling messages and for receiving incoming calls from other endpoints than the registrar. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: introduce URI and header parameter parsing ↵Patrick McHardy
helpers Introduce URI and header parameter parsing helpers. These are needed by the conntrack helper to parse expiration values in Contact: header parameters and by the NAT helper to properly update the Via-header rport=, received= and maddr= parameters. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: flush expectations on call terminationPatrick McHardy
Flush the RTP expectations we've created when a call is hung up or terminated otherwise. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-25[NETFILTER]: nf_conntrack_sip: process ACK and PRACK methodsPatrick McHardy
Both may contains SDP offers/answers. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
