path: root/net/netfilter/xt_RATEEST.c
2009-08-17net: restore gnet_stats_basic to previous definitionEric Dumazet
In 5e140dfc1fe87eae27846f193086724806b33c7d "net: reorder struct Qdisc for better SMP performance" the definition of struct gnet_stats_basic changed incompatibly, as copies of this struct are shipped to userland via netlink. Restoring old behavior is not welcome, for performance reason. Fix is to use a private structure for kernel, and teach gnet_stats_copy_basic() to convert from kernel to user land, using legacy structure (struct gnet_stats_basic) Based on a report and initial patch from Michael Spang. Reported-by: Michael Spang <mspang@csclub.uwaterloo.ca> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (6/6)Jan Engelhardt
This patch does this for target extensions' destroy functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (5/6)Jan Engelhardt
This patch does this for target extensions' checkentry functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (4/6)Jan Engelhardt
This patch does this for target extensions' target functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: implement NFPROTO_UNSPEC as a wildcard for extensionsJan Engelhardt
When a match or target is looked up using xt_find_{match,target}, Xtables will also search the NFPROTO_UNSPEC module list. This allows for protocol-independent extensions (like xt_time) to be reused from other components (e.g. arptables, ebtables). Extensions that take different codepaths depending on match->family or target->family of course cannot use NFPROTO_UNSPEC within the registration structure (e.g. xt_pkttype). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: x_tables: use NFPROTO_* in extensionsJan Engelhardt
2008-04-14[NETFILTER]: annotate xtables targets with const and remove castsJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Update modules' descriptionsJan Engelhardt
Updates the MODULE_DESCRIPTION() tags for all Netfilter modules, actually describing what the module does and not just "netfilter XYZ target". Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: add RATEEST targetPatrick McHardy
Add new rate estimator target (using gen_estimator). In combination with the rateest match (next patch) this can be used for load-based multipath routing. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
