Replace create_proc_entry with specially created for this purpose proc_create.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Acked-by: Patrick McHardy <kaber@trash.net>
Add accessors for l3num and protonum and get rid of some overly long
expressions.
Patch splits creation of /proc/net/nf_conntrack, /proc/net/stat/nf_conntrack
and net.netfilter hierarchy into their own functions with dummy ones
if PROC_FS or SYSCTL is not set. Also, remove dead "ret = 0" write
while I'm at it.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/usb/rndis_host.c
drivers/net/wireless/b43/dma.c
net/ipv6/ndisc.c
This elliminates infamous race during module loading when one could lookup
proc entry without proc_fops assigned.
Some netfilter code and rxrpc one use seq_open() to open
a proc file, but seq_release_private to release one.
This is harmless, but ambiguous.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Rename all "conntrack" variables to "ct" for more consistency and
avoiding some overly long lines.
Teach sparse about locking here, and fix signed/unsigned warnings.
Allows to remove five empty implementations.
Its unused and unlikely to ever be used.
This includes the most simple cases for netfilter.
The first part is tne queue modules for ipv4 and ipv6,
on which the net/ipv4/ and net/ipv6/ paths are reused
from the appropriate ipv4 and ipv6 code.
The conntrack module is also patched, but this hunk is
very small and simple.
Just switch to the consolidated calls.
ipt_recent() has to initialize the private, so use
the __seq_open_private() helper.
This patch makes /proc/net per network namespace. It modifies the global
variables proc_net and proc_net_stat to be per network namespace.
The proc_net file helpers are modified to take a network namespace argument,
and all of their callers are fixed to pass &init_net for that argument.
This ensures that all of the /proc/net files are only visible and
usable in the initial network namespace until the code behind them
has been updated to be handle multiple network namespaces.
Making /proc/net per namespace is necessary as at least some files
in /proc/net depend upon the set of network devices which is per
network namespace, and even more files in /proc/net have contents
that are relevant to a single network namespace.
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits)
[TG3]: Fix msi issue with kexec/kdump.
[NET] XFRM: Fix whitespace errors.
[NET] TIPC: Fix whitespace errors.
[NET] SUNRPC: Fix whitespace errors.
[NET] SCTP: Fix whitespace errors.
[NET] RXRPC: Fix whitespace errors.
[NET] ROSE: Fix whitespace errors.
[NET] RFKILL: Fix whitespace errors.
[NET] PACKET: Fix whitespace errors.
[NET] NETROM: Fix whitespace errors.
[NET] NETFILTER: Fix whitespace errors.
[NET] IPV4: Fix whitespace errors.
[NET] DCCP: Fix whitespace errors.
[NET] CORE: Fix whitespace errors.
[NET] BLUETOOTH: Fix whitespace errors.
[NET] AX25: Fix whitespace errors.
[PATCH] mac80211: remove rtnl locking in ieee80211_sta.c
[PATCH] mac80211: fix GCC warning on 64bit platforms
[GENETLINK]: Dynamic multicast groups.
[NETLIKN]: Allow removing multicast groups.
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Make all initialized struct seq_operations in net/ const
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements.
As a last step of preventing DoS by creating lots of expectations, this
patch introduces a global maximum and a sysctl to control it. The default
is initialized to 4 * the expectation hash table size, which results in
1/64 of the default maxmimum of conntracks.
nf_conntrack_expect.c
Convert conntrack hash to hlists to reduce its size and cache
footprint. Since the default hashsize to max. entries ratio
sucks (1:16), this patch doesn't reduce the amount of memory
used for the hash by default, but instead uses a better ratio
of 1:8, which results in the same max. entries value.
One thing worth noting is early_drop. It really should use LRU,
so it now has to iterate over the entire chain to find the last
unconfirmed entry. Since chains shouldn't be very long and the
entire operation is very rare this shouldn't be a problem.
The semantic effect of insert_at_head is that it would allow new registered
sysctl entries to override existing sysctl entries of the same name. Which is
pain for caching and the proc interface never implemented.
I have done an audit and discovered that none of the current users of
register_sysctl care as (excpet for directories) they do not register
duplicate sysctl entries.
So this patch simply removes the support for overriding existing entries in
the sys_sysctl interface since no one uses it or cares and it makes future
enhancments harder.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Corey Minyard <minyard@acm.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: David Chinner <dgc@sgi.com>
Cc: Patrick McHardy <kaber@trash.net>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
- move EXPORT_SYMBOL next to exported symbol
- use EXPORT_SYMBOL_GPL since this is what the original code used
Add NAT support for nf_conntrack. Joint work of Jozsef Kadlecsik,
Yasuyuki Kozakai, Martin Josefsson and myself.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
We usually uses 'xxx_find_get' for function which increments
reference count.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
This patch adds /proc/net/ip_conntrack, /proc/net/ip_conntrack_expect and
/proc/net/stat/ip_conntrack files to keep old programs using them working.
The /proc/net/ip_conntrack and /proc/net/ip_conntrack_expect files show only
IPv4 entries, the /proc/net/stat/ip_conntrack shows global statistics.
Using extern in a C file is a bad idea because the compiler can't
catch type errors.
Remove the usage of ASSERT_READ_LOCK/ASSERT_WRITE_LOCK in nf_conntrack,
it didn't do anything, it was just an empty define and it uglified the code.
Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se>
Rename 'struct nf_conntrack_protocol' to 'struct nf_conntrack_l4proto' in
order to help distinguish it from 'struct nf_conntrack_l3proto'. It gets
rather confusing with 'nf_conntrack_protocol'.
This patch splits out L3/L4 protocol handling into its own file
nf_conntrack_proto.c
This patch splits out the event cache into its own file
nf_conntrack_ecache.c
This patch splits out expectation handling into its own file
Kill listhelp.h and use the list.h functions instead.
Change some netfilter tunables to __read_mostly. Also fixed some
incorrect file reference comments while I was in there.
(this will be my last __read_mostly patch unless someone points out
something else that needs it)
Signed-off-by: Brian Haley <brian.haley@hp.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Add a secmark field to IP and NF conntracks, so that security markings
on packets can be copied to their associated connections, and also
copied back to packets as required. This is similar to the network
mark field currently used with conntrack, although it is intended for
enforcement of security policy rather than network policy.
Signed-off-by: James Morris <jmorris@namei.org>
Fix section mismatch warnings caused by netfilter's init_or_cleanup
functions used in many places by splitting the init from the cleanup
parts.
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
x_tables matches and targets that require nf_conntrack_ipv[4|6] to work
don't have enough information to load on demand these modules. This
patch introduces the following changes to solve this issue:
o nf_ct_l3proto_try_module_get: try to load the layer 3 connection
tracker module and increases the refcount.
o nf_ct_l3proto_module put: drop the refcount of the module.
This patch moves all helper related data fields of 'struct nf_conn'
into a separate structure 'struct nf_conn_help'. This new structure
is only present in conntrack entries for which we actually have a
helper loaded.
Also, this patch cleans up the nf_conntrack 'features' mechanism to
resemble what the original idea was: Just glue the feature-specific
data structures at the end of 'struct nf_conn', and explicitly
re-calculate the pointer to it when needed rather than keeping
pointers around.
Saves 20 bytes per conntrack on my x86_64 box. A non-helped conntrack
is 276 bytes. We still need to save another 20 bytes in order to fit
into to target of 256bytes.
Signed-off-by: Harald Welte <laforge@netfilter.org>
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
