This patch adds the macro MODULE_ALIAS_NFCT_HELPER that defines a
way to provide generic and persistent aliases for the connection
tracking helpers.
This next patch requires this patch.
Make per-netns a) expectation hash and b) expectations count.
Expectations always belongs to netns to which it's master conntrack belong.
This is natural and doesn't bloat expectation.
Proc files and leaf users are stubbed to init_net, this is temporary.
Helper's ->help hook can run concurrently with itself, so iterating over
SIP helpers with static pointer won't work reliably.
request
Some Inovaphone PBXs exhibit very stange behaviour: when dialing for
example "123", the device sends INVITE requests for "1", "12" and
"123" back to back. The first requests will elicit error responses
from the receiver, causing the SIP helper to flush the RTP
expectations even though we might still see a positive response.
Note the sequence number of the last INVITE request that contained a
media description and only flush the expectations when receiving a
negative response for that sequence number.
Reported by Ingo Molnar.
The SIP helper is also useful without NAT. This patch adds an ifdef
around the RTP call optimization for NATed clients.
Add accessors for l3num and protonum and get rid of some overly long
expressions.
Some callers pass uninitialized structures, clear the address to make
sure later comparisions work properly.
Optimize call routing between NATed endpoints: when an external
registrar sends a media description that contains an existing RTP
expectation from a different SNATed connection, the gatekeeper
is trying to route the call directly between the two endpoints.
We assume both endpoints can reach each other directly and
"un-NAT" the addresses, which makes the media stream go between
the two endpoints directly.
Add support for multiple media channels and use it to create
expectations for video streams when present.
The SDP connection addresses may be contained in the payload multiple
times (in the session description and/or once per media description),
currently only the session description is properly updated. Split up
SDP mangling so the function setting up expectations only updates the
media port, update connection addresses from media descriptions while
parsing them and at the end update the session description when the
final addresses are known.
Create expectations for the RTCP connections in addition to RTP connections.
address
Media streams can come from anywhere, add a module parameter which
controls whether wildcard expectations or expectations between the
two signalling endpoints are created.
Since the same media description sent on multiple connections may
results in multiple identical expections when using a wildcard source,
we need to check whether a similar expectation already exists for a
different connection before attempting to register it.
Create expectations for incoming signalling connections when seeing
a REGISTER request. This is needed when the registrar uses a
different source port number for signalling messages and for receiving
incoming calls from other endpoints than the registrar.
helpers
Introduce URI and header parameter parsing helpers. These are needed
by the conntrack helper to parse expiration values in Contact: header
parameters and by the NAT helper to properly update the Via-header
rport=, received= and maddr= parameters.
Flush the RTP expectations we've created when a call is hung up or
terminated otherwise.
Both may contains SDP offers/answers.
Perform NAT last after parsing the packet. This makes no difference
currently, but is needed when dealing with registrations to make
sure we seen the unNATed addresses.
Add support for per-method request/response handlers and perform SDP
parsing for INVITE/UPDATE requests and for all informational and
successful responses.
Use the URI parsing helper to get the numerical addresses and get rid of the
text based header translation.
Introduce a helper function to parse a SIP-URI in a header value, optionally
iterating through all headers of this kind.
Introduce new function for SIP header parsing that properly deals with
continuation lines and whitespace in headers and use it.
The request URI is not a header and needs to be treated differently than
real SIP headers. Add a seperate function for parsing it and get rid of
the POS_REQ_URI/POS_REG_REQ_URI definitions.
SDP and SIP headers are quite different, SIP can have continuation lines,
leading and trailing whitespace after the colon and is mostly case-insensitive
while SDP headers always begin on a new line and are followed by an equal
sign and the value, without any whitespace.
Introduce new SDP header parsing function and convert all users that used
the SIP header parsing function. This will allow to properly deal with the
special SIP cases in the SIP header parsing function later.
Replace sizeof/memcmp by strlen/strcmp. Use case-insensitive comparison
for SIP methods and the SIP/2.0 string, as specified in RFC 3261.
The conntrack reference and ctinfo can be derived from the packet.
After mangling the packet, the pointer to the data and the length of the data
portion may change and need to be adjusted.
Use double data pointers and a pointer to the length everywhere and add a
helper function to the NAT helper for performing the adjustments.
"limit" marks the first character outside the bounds.
Introduce expectation classes and policies. An expectation class
is used to distinguish different types of expectations by the
same helper (for example audio/video/t.120). The expectation
policy is used to hold the maximum number of expectations and
the initial timeout for each class.
The individual classes are isolated from each other, which means
that for example an audio expectation will only evict other audio
expectations.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Teach sparse about locking here, and fix signed/unsigned warnings.
A few netfilter modules provide their own union of IPv4 and IPv6
address storage. Will unify that in this patch series.
(1/4): Rename union nf_conntrack_address to union nf_inet_addr and
move it to x_tables.h.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
The userinfo component of a SIP-URI is optional, continue parsing at the
beginning of the SIP-URI in case its not found.
The check got lost during the conversion to nf_conntrack.
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements.
Since conntrack currently allows to use masks for every bit of both
helper and expectation tuples, we can't hash them and have to keep
them on two global lists that are searched for every new connection.
This patch removes the never used ability to use masks for the
destination part of the expectation tuple and completely removes
masks from helpers since the only reasonable choice is a full
match on l3num, protonum and src.u.all.
Currently there is a wild mix of nf_conntrack_expect_, nf_ct_exp_,
expect_, exp_, ...
Consistently use nf_ct_ as prefix for exported functions.
Signed-off-by: Jerome Borsboom <j.borsboom@erasmusmc.nl>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
When checking for an @-sign in skp_epaddr_len, make sure not to
run over the packet boundaries.
When trying to skip over the username in the Contact header, stop at the
end of the line if no @ is found to avoid mangling following headers.
We don't need to worry about continuation lines because we search inside
a SIP URI.
Fixes Netfilter Bugzilla #532.
Signed-off-by: Lars Immisch <lars@ibp.de>
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
Add IPv4 and IPv6 capable nf_conntrack port of the SIP conntrack/NAT helper.
