These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
This patch adds the infrastructure to add fine timeout tuning
over nfnetlink. Now you can use the NFNL_SUBSYS_CTNETLINK_TIMEOUT
subsystem to create/delete/dump timeout objects that contain some
specific timeout policy for one flow.
The follow up patches will allow you attach timeout policy object
to conntrack via the CT target and the conntrack extension
infrastructure.
This patch defines a new interface for l4 protocol trackers:
unsigned int *(*get_timeouts)(struct net *net);
that is used to return the array of unsigned int that contains
the timeouts that will be applied for this flow. This is passed
to the l4proto->new(...) and l4proto->packet(...) functions to
specify the timeout policy.
This interface allows per-net global timeout configuration
(although only DCCP supports this by now) and it will allow
custom custom timeout configuration by means of follow-up
patches.
Use IS_ENABLED(CONFIG_FOO)
instead of defined(CONFIG_FOO) || defined (CONFIG_FOO_MODULE)
Signed-off-by: Igor Maravić <igorm@etf.rs>
ct->proto is big(60 bytes) due to structure ip_ct_tcp, and we don't need
to initialize the whole for all the other protocols. This patch moves
proto to the end of structure nf_conn, and pushes the initialization down
to the individual protocols.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
Make sure all printk messages have a severity level.
Split up the IPCT_STATUS event into an IPCT_REPLY event, which is generated
when the IPS_SEEN_REPLY bit is set, and an IPCT_ASSURED event, which is
generated when the IPS_ASSURED bit is set.
In combination with a following patch to support selective event delivery,
this can be used for "sparse" conntrack replication: start replicating the
conntrack entry after it reached the ASSURED state and that way it's SYN-flood
resistant.
Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
Introduce per-conntrack locks and use them instead of the global protocol
locks to avoid contention. Especially tcp_lock shows up very high in
profiles on larger machines.
This will also allow to simplify the upcoming reliable event delivery patches.
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
net/netfilter/nf_conntrack_proto_sctp.c: In function 'sctp_packet':
net/netfilter/nf_conntrack_proto_sctp.c:376: warning: array subscript is above array bounds
gcc doesn't realize that do_basic_checks() guarantees that there is
at least one valid chunk and thus new_state is never SCTP_CONNTRACK_MAX
after the loop. Initialize to SCTP_CONNTRACK_NONE to avoid the warning.
Based on patch by Wu Fengguang <wfg@linux.intel.com>
I want to compile out proc_* and sysctl_* handlers totally and
stub them to NULL depending on config options, however usage of &
will prevent this, since taking adress of NULL pointer will break
compilation.
So, drop & in front of every ->proc_handler and every ->strategy
handler, it was never needed in fact.
not skb
This is cleaner, we already know conntrack to which event is relevant.
and (try to) consistently use u_int8_t for the L3 family.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Introduced by a258860e (netfilter: ctnetlink: add full support for SCTP to ctnetlink):
net/netfilter/nf_conntrack_proto_sctp.c:483:2: warning: cast from restricted type
net/netfilter/nf_conntrack_proto_sctp.c:483:2: warning: incorrect type in argument 1 (different base types)
net/netfilter/nf_conntrack_proto_sctp.c:483:2: expected unsigned int [unsigned] [usertype] x
net/netfilter/nf_conntrack_proto_sctp.c:483:2: got restricted unsigned int const <noident>
net/netfilter/nf_conntrack_proto_sctp.c:487:2: warning: cast from restricted type
net/netfilter/nf_conntrack_proto_sctp.c:487:2: warning: incorrect type in argument 1 (different base types)
net/netfilter/nf_conntrack_proto_sctp.c:487:2: expected unsigned int [unsigned] [usertype] x
net/netfilter/nf_conntrack_proto_sctp.c:487:2: got restricted unsigned int const <noident>
net/netfilter/nf_conntrack_proto_sctp.c:532:42: warning: incorrect type in assignment (different base types)
net/netfilter/nf_conntrack_proto_sctp.c:532:42: expected restricted unsigned int <noident>
net/netfilter/nf_conntrack_proto_sctp.c:532:42: got unsigned int
net/netfilter/nf_conntrack_proto_sctp.c:534:39: warning: incorrect type in assignment (different base types)
net/netfilter/nf_conntrack_proto_sctp.c:534:39: expected restricted unsigned int <noident>
net/netfilter/nf_conntrack_proto_sctp.c:534:39: got unsigned int
This patch adds full support for SCTP to ctnetlink. This includes three
new attributes: state, original vtag and reply vtag.
nf_nat_proto_gre
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Rename all "conntrack" variables to "ct" for more consistency and
avoiding some overly long lines.
Teach sparse about locking here, and fix signed/unsigned warnings.
Instead of keeping pointers to the timeout values in a table, simply
put the timeout values in the table directly.
Use SCTP_CHUNK_FLAG_T instead of 0x1.
Don't take and release the lock once per SCTP chunk, simply hold it
the entire time while iterating through the chunks.
The name is misleading, it holds the new connection state, so rename it
to "newstate". Also rename "oldsctpstate" to "oldstate" for consistency.
Consolidate error paths and use proper symbolic return value instead
of magic values.
Eliminate a few lines over 80 characters by using a local variable to
hold the conntrack direction instead of using CTINFO2DIR everywhere.
Reduce the length of some overly long lines by renaming all
"conntrack" variables to "ct".
Use unsigned long instead of char for the bitmap and removed lots
of casts.
Reindent switch cases properly, get rid of weird constructs like "!(x == y)",
put logical operations on the end of the line instead of the next line, get
rid of superfluous braces.
The TCP and SCTP conntrack state transition tables only holds
small numbers, but gcc uses 4 byte per entry for the enum. Switching
to an u8 reduces the size from 480 to 120 bytes for TCP and from
576 to 144 bytes for SCTP.
Parenthesize macro parameters.
This patch adds support for SCTP to ctnetlink.
No one has bothered to set strategy routine for the the netfilter sysctls that
return jiffies to be sysctl_jiffies.
So it appears the sys_sysctl path is unused and untested, so this patch
removes the binary sysctl numbers.
Which fixes the netfilter oops in 2.6.23-rc2-mm2 for me.
Cc: Patrick McHardy <kaber@trash.net>
Also remove two unnecessary EXPORT_SYMBOLs and move the
nf_conntrack_l3proto_ipv4 declaration to the correct file.
dereference (CVE-2007-2876)
When creating a new connection by sending an unknown chunk type, we
don't transition to a valid state, causing a NULL pointer dereference
in sctp_packet when accessing sctp_timeouts[SCTP_CONNTRACK_NONE].
Fix by don't creating new conntrack entry if initial state is invalid.
Noticed by Vilmos Nebehaj <vilmos.nebehaj@ramsys.hu>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Resync with Al Viro's ip_conntrack annotations and fix a missed
spot in ip_nat_proto_icmp.c.
This patch adds an option to keep the connection tracking sysctls visible
under their old names.
Rename 'struct nf_conntrack_protocol' to 'struct nf_conntrack_l4proto' in
order to help distinguish it from 'struct nf_conntrack_l3proto'. It gets
rather confusing with 'nf_conntrack_protocol'.
Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se>
This patch splits out the event cache into its own file
nf_conntrack_ecache.c
Change some netfilter tunables to __read_mostly. Also fixed some
incorrect file reference comments while I was in there.
(this will be my last __read_mostly patch unless someone points out
something else that needs it)
Signed-off-by: Brian Haley <brian.haley@hp.com>
Acked-by: Patrick McHardy <kaber@trash.net>
When a packet without any chunks is received, the newconntrack variable
in sctp_packet contains an out of bounds value that is used to look up an
pointer from the array of timeouts, which is then dereferenced, resulting
in a crash. Make sure at least a single chunk is present.
Problem noticed by George A. Theall <theall@tenablesecurity.com>
CC net/netfilter/nf_conntrack_proto_sctp.o
net/netfilter/nf_conntrack_proto_sctp.c: In function `sctp_print_conntrack':
net/netfilter/nf_conntrack_proto_sctp.c:206: warning: implicit declaration of function `local_bh_disable'
net/netfilter/nf_conntrack_proto_sctp.c:208: warning: implicit declaration of function `local_bh_enable'
CC net/netfilter/nf_conntrack_netlink.o
net/netfilter/nf_conntrack_netlink.c: In function `ctnetlink_dump_table':
net/netfilter/nf_conntrack_netlink.c:429: warning: implicit declaration of function `local_bh_disable'
net/netfilter/nf_conntrack_netlink.c:452: warning: implicit declaration of function `local_bh_enable'
Spotted by Toralf Förster
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
