path: root/net/netfilter/nf_conntrack_amanda.c
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-17netfilter: nf_conntrack: connection tracking helper name persistent aliasesPablo Neira Ayuso
This patch adds the macro MODULE_ALIAS_NFCT_HELPER that defines a way to provide generic and persistent aliases for the connection tracking helpers. This next patch requires this patch. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: add tuplehash l3num/protonum accessorsPatrick McHardy
Add accessors for l3num and protonum and get rid of some overly long expressions. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: annotate rest of nf_conntrack_* with constJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-03-25[NETFILTER]: nf_conntrack: introduce expectation classes and policiesPatrick McHardy
Introduce expectation classes and policies. An expectation class is used to distinguish different types of expectations by the same helper (for example audio/video/t.120). The expectation policy is used to hold the maximum number of expectations and the initial timeout for each class. The individual classes are isolated from each other, which means that for example an audio expectation will only evict other audio expectations. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: reduce masks to a subset of tuplesPatrick McHardy
Since conntrack currently allows to use masks for every bit of both helper and expectation tuples, we can't hash them and have to keep them on two global lists that are searched for every new connection. This patch removes the never used ability to use masks for the destination part of the expectation tuple and completely removes masks from helpers since the only reasonable choice is a full match on l3num, protonum and src.u.all. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack_expect: function naming unificationPatrick McHardy
Currently there is a wild mix of nf_conntrack_expect_, nf_ct_exp_, expect_, exp_, ... Consistently use nf_ct_ as prefix for exported functions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[NETFILTER]: nf_conntrack_amanda: fix textsearch_prepare() error checkAkinobu Mita
The return value from textsearch_prepare() needs to be checked by IS_ERR(). Because it returns error code as a pointer. Cc: "Brian J. Murrell" <netfilter@interlinx.bc.ca> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack: fix header inclusions for helpersYasuyuki Kozakai
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add amanda helper portPatrick McHardy
Add IPv4 and IPv6 capable nf_conntrack port of the Amanda conntrack/NAT helper. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
