path: root/net/mac80211
2008-05-20mac80211: fix NULL pointer dereference in ieee80211_compatible_ratesHelmut Schaa
Fix a possible NULL pointer dereference in ieee80211_compatible_rates introduced in the patch "mac80211: fix association with some APs". If no bss is available just use all supported rates in the association request. Signed-off-by: Helmut Schaa <hschaa@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-20mac80211: don't claim iwspy supportJohannes Berg
We removed iwspy support a very long time ago because it is useless, but forgot to stop claiming to support it. Apparently, nobody cares, but remove it nonetheless. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-16mac80211: Add RTNL version of ieee80211_iterate_active_interfacesIvo van Doorn
Since commit e38bad4766a110b61fa6038f10be16ced8c6cc38 mac80211: make ieee80211_iterate_active_interfaces not need rtnl rt2500usb and rt73usb broke down due to attempting register access in atomic context (which is not possible for USB hardware). This patch restores ieee80211_iterate_active_interfaces() to use RTNL lock, and provides the non-RTNL version under a new name: ieee80211_iterate_active_interfaces_atomic() So far only rt2x00 uses ieee80211_iterate_active_interfaces(), and those drivers require the RTNL version of ieee80211_iterate_active_interfaces(). Since they already call that function directly, this patch will automatically fix the USB rt2x00 drivers. v2: Rename ieee80211_iterate_active_interfaces_rtnl Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-16mac80211 : Association with 11n hidden ssid ap.Abhijeet Kolekar
This patch fixes the association problem with 11n hidden ssid ap. Patch fixes the problem of associating with hidden ssid when all three parameters ap,essid and channel are given to iwconfig. This patch removes the condition of checking three parameters and always checks for bss in bss list while associating. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: Use skb_header_cloned() on TX path.David S. Miller
When skb_header_cloned() returns false you can change the headers however you like. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12mac80211: assign needed_headroom/tailroom for netdevsJohannes Berg
This assigns the netdev's needed_headroom/tailroom members to take advantage of pre-allocated space for 802.11 headers. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12mac80211: add missing newlines in printk()Pavel Roskin
Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: fix association with some APsHelmut Schaa
Some APs refuse association if the supported rates contained in the association request do not match its own supported rates. This patch introduces a new function which builds the intersection between the AP's supported rates and the client's supported rates to work around such problems. The same approach is already used in ipw2200 for example. Signed-off-by: Helmut Schaa <hschaa@suse.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12Fix potential scheduling while atomic in mesh_path_add.Pavel Emelyanov
Calling synchronize_rcu() under write-lock-ed pathtbl_resize_lock may result in this warning (and other side effects). It looks safe just dropping this lock before calling synchronize_rcu. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12Fix not checked kmalloc() result.Pavel Emelyanov
The new_node kmallocation is not checked for success, so add this check. BTW, it also happens under the read_lock. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12Fix GFP_KERNEL allocation under read lock.Pavel Emelyanov
The mesh_path_add() read-locks the pathtbl_resize_lock and calls kmalloc with GFP_KERNEL mask. Fix it and move the endadd2 label lower. It should be _before_ the if() beyond, but it makes no sense for it being there, so I move it right after this if(). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: mesh hwmp: fix kfree(skb)Patrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: fix access to null skbLuis Carlos Cobo
Without this patch, if xmit_skb is null but net_ratelimit() returns 0 we would go to the else branch and access the null xmit_skb. Pointed out by Johannes Berg. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: fix incorrect mesh header lengthLuis Carlos Cobo
This should have been updated at the same time we were transitioning from 3 byte to 4 byte mesh sequence number. Pointed out by Johannes Berg. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: Don't encrypt beaconsIvo van Doorn
mac80211 should set the IEEE80211_TX_CTL_DO_NOT_ENCRYPT flag in tx_control structure to inform drivers not to encrypt the beacon. Drivers that only check for that flag before accessing the hw_key field, will otherwise cause a NULL pointer dereference since that field is not configured for beacons. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12mac80211: fix debugfs default key oopsJohannes Berg
Under certain circumstances (in AP mode) the debugfs function that is supposed to add the default key symlink can encounter a NULL default_key pointer. This patch makes it handle that situtation gracefully. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-12fix irq flags in mac80211 codeSteven Rostedt
A file in the net/mac80211 directory uses "int" for flags. This can cause hard to find bugs on some architectures. This patch converts the flags to use "long" instead. This bug was discovered by doing an allyesconfig make on the -rt kernel where checks are done to ensure all flags are of size sizeof(long). Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-04mac80211: Do not free net device after it is unregistered.Pavel Emelyanov
The error path in ieee80211_register_hw() may call the unregister_netdev() and right after it - the free_netdev(), which is wrong, since the unregister releases the device itself. So the proposed fix is to NULL the local->mdev after unregister is done and check this before calling free_netdev(). I checked - no code uses the local->mdev after unregister in this error path (but even if some did this would be a BUG). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2008-04-30mac80211: incorrect shift directionHarvey Harrison
Looks like 5d2cdcd4e85c5187db30a6b29f79fbbe59f39f78 ("mac80211: get a TKIP phase key from skb") got the shifts wrong. Noticed by sparse: net/mac80211/tkip.c:234:25: warning: right shift by bigger than source value net/mac80211/tkip.c:235:25: warning: right shift by bigger than source value net/mac80211/tkip.c:236:25: warning: right shift by bigger than source value Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: insert WDS peer after adding interfaceJohannes Berg
This reorders the open code so that WDS peer STA info entries are added after the corresponding interface is added to the driver so that driver callbacks aren't invoked out of order. Also make any master device startup fatal. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: don't allow invalid WDS peer addressesJohannes Berg
Rather than just disallowing the zero address, disallow all invalid ones. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: assign conf.beacon_control for meshJohannes Berg
Drivers can rightfully assume that they get a beacon_control if the beacon is set. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: use 4-byte mesh sequence numberLuis Carlos Cobo
This follows the new 802.11s/D2.0 draft. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: iwlwifi: Allow building iwl3945 without iwl4965. wireless: Fix compile error with wifi & leds tcp: Fix slab corruption with ipv6 and tcp6fuzz ipv4/ipv6 compat: Fix SSM applications on 64bit kernels. [IPSEC]: Use digest_null directly for auth sunrpc: fix missing kernel-doc can: Fix copy_from_user() results interpretation Revert "ipv6: Fix typo in net/ipv6/Kconfig" tipc: endianness annotations ipv6: result of csum_fold() is already 16bit, no need to cast [XFRM] AUDIT: Fix flowlabel text format ambibuity.
2008-04-27wireless: Fix compile error with wifi & ledsLuca Tettamanti
Fix build error caused by commit e82404ad612ebabc65d15c3d59b971cb35c3ff36 ("iwlwifi: Select LEDS_CLASS.") from David Miller: Since MAC80211_LEDS is selected by wireless drivers it must select its own dependencies otherwise a build error may occur (kbuild will select the symbol regardless of "depends" constraints). Signed-off-By: Luca Tettamanti <kronos.it@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27asm/unaligned.h doesn't work well as the very first includeAl Viro
2008-04-23mac80211: fix use before check of Qdisc lengthRon Rindjunsky
This patch fixes use of Qdisc length in requeue function, before we checked the reference is valid. (Adrian Bunk's catch) Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23net/mac80211/rx.c: fix off-by-oneAdrian Bunk
This patch fixes an off-by-one in net/mac80211/rx.c introduced by commit 8318d78a44d49ac1edf2bdec7299de3617c4232e (cfg80211 API for channels/bitrates, mac80211 and driver conversion) and spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23mac80211: Fix race between ieee80211_rx_bss_put and lookup routines.Pavel Emelyanov
The put routine first decrements the users counter and then (if it is zero) locks the sta_bss_lock and removes one from the list and the hash. Thus, any of ieee80211_sta_config_auth, ieee80211_rx_bss_get or ieee80211_rx_mesh_bss_get can race with it by finding a bss that is about to get kfree-ed. Using atomic_dec_and_lock in ieee80211_rx_bss_put takes care of this race. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-23mac80211: Fix n-band association problemAbhijeet Kolekar
There are two structures named wmm_info and wmm_param, they are used while parsing the beacon frame. (Check the function ieee802_11_parse_elems). Certain APs like D-link does not set the fifth bit in WMM IE. While sending the association request to n-only ap it checks for wmm_ie. If it is set then only ieee80211_ht_cap is sent during association request. So n-only association fails. And this patch fixes this problem by copying the wmm_info to wmm_ie, which enables the "wmm" flag in iee80211_send_assoc. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Acked-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-16mac80211: rework scanning to account for probe response/beacon differenceJohannes Berg
This patch reworks the scanning code (ieee80211_rx_bss_info) to take more parameters from beacons and keep a BSS info structure alive when only beacons for it are received. This fixes a problem with iwlwifi drivers (where we don't understand the root cause of the problem yet) and another driver for some broken hardware (which cannot send probe requests unless associated, so can't always actively scan.) Signed-off-by: Bill Moss <bmoss@clemson.edu> [jmberg: reformatted comments, make probe_resp a bool] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: allow WDS modeJohannes Berg
This allows creating interfaces in WDS mode or switching existing ones into WDS mode (both via cfg80211 and wext.) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: fix key todo list orderJohannes Berg
When we add multiple todo entries, we rely on them being executed mostly in the right order, especially when a key is being replaced. But when a default key is replaced, the todo list order will differ from the order when the key being replaced is not a default key, so problems will happen. Hence, just move each todo item to the end of the list when it is added so we can in the other code ensure that hw accel for a key will be disabled before it is enabled for the replacement. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: fix spinlock recursionJohannes Berg
When STAs are expired, we need to hold the sta_lock. Using the same lock for keys too would then mean we'd need another key free function, and that'll just lead to confusion, so just use a new spinlock for all key lists. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: no BSS changes to driver from beacons processed during scanningReinette Chatre
There is no need to send BSS changes to driver from beacons processed during scanning. We are more interested in beacons from an AP with which we are associated - these will still be used to send updates to driver as the beacons are received without scanning. This change·removes the requirement that bss_info_changed needs to be atomic. The beacons received during scanning are processed from a tasklet, but if we do not call bss_info_changed for these beacons there is no need for it to be atomic. This function (bss_info_changed) is called either from workqueue or ioctl in all other instances. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Acked-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: further RCU fixesJohannes Berg
There were a few more instances of sta_info_get calls not being protected by RCU, fix them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: fix key hwaccel raceJohannes Berg
The previous key locking patch left a small race: it would be possible to add a key and take the interface down before the key todo is run so that hwaccel for that key is enabled on an interface that is down. Avoid this by running the todo list when an interface is brought up or down. This patch also fixes a small bug: before this change, a few functions used the key list without the lock that protects it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mlme.c: fixup some merge damageJohn W. Linville
This one got renamed, complicating the merge a bit...this should restore it to its intended state. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-15mac80211: remove message on receiving unexpected unencrypted framesJohannes Berg
Some people are getting this message a lot, and we have traced it to broken access points that much too often send completely empty frames (all bytes zeroed, which they shouldn't do at all.) Since we cannot do anything about such frames in any case except the special case where we're debugging an AP, just remove the message. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-09mac80211: use short_preamble mode from capability if ERP IE not presentVladimir Koutny
When associating to a b-only AP where there is no ERP IE, short preamble mode is left at previous state (probably also protection mode). In this case, disable protection and use short preamble mode as specified in capability field. The same is done if capability field is changed on-the-fly. Signed-off-by: Vladimir Koutny <vlado@ksp.sk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: fix key debugfs default_key linkJohannes Berg
The default_key symlink points to the key index rather than they key counter, fix it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: rename filesJohannes Berg
This patch renames all mac80211 files (except ieee80211_i.h) to get rid of the useless ieee80211_ prefix. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: fix key vs. sta locking problemsJohannes Berg
Up to now, key manipulation is supposed to run under RTNL to avoid concurrent manipulations and also allow the set_key() hardware callback to sleep. This is not feasible because STA structs are rcu-protected and thus a lot of operations there cannot take the RTNL. Also, key references are rcu-protected so we cannot do things atomically. This patch changes key locking completely: * key operations are now atomic * hardware crypto offload is enabled and disabled from a workqueue, due to that key freeing is also delayed * debugfs code is also run from a workqueue * keys reference STAs (and vice versa!) so during STA unlink the STAs key reference is removed but not the keys STA reference, to avoid races key todo work is run before STA destruction. * fewer STA operations now need the RTNL which was required due to key operations This fixes the locking problems lockdep pointed out and also makes things more light-weight because the rtnl isn't required as much. Note that the key todo lock/key mutex are global locks, this is not required, of course, they could be per-hardware instead. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: fix sta-info pinningJohannes Berg
When a STA is supposed to be unlinked but is pinned, it still needs to be unlinked from all structures. Only at the end of the unlink process should we check for pin status and invalidate the callers reference if it is pinned. Move the pin status check down. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: fix defined but not usedJiri Slaby
These two symbols are used only in ifdeffed function. Move them to that section too. net/mac80211/sta_info.c:387: warning: `__sta_info_pin' defined but not used net/mac80211/sta_info.c:397: warning: `__sta_info_unpin' defined but not used Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Michael Wu <flamingice@sourmilk.net> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Jiri Benc <jbenc@suse.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: BA session debug prints changesRon Rindjunsky
This patch contains next issues: 1 - prevents "stop BA session" multiple warnings 2 - adds debug print to stop Rx BA session flow 3 - adds EOL in one debug print Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: notify mac from low level driver (iwlwifi)Mohamed Abbas
Add new API to MAC80211 to allow low level driver to notify MAC with driver status. Signed-off-by: Mohamed Abbas <mabbas@linux.intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: fix ieee80211_ioctl_giwrateJohannes Berg
The ieee80211_ioctl_giwrate() ioctl handler doesn't rcu_read_lock() its access to the sta table, fix it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
