Also remove a few stray DECLARE_MAC_BUF that were no longer
used at all.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
In "mac80211: make master iface not wireless" I accidentally
forgot to include these changes ... leading to the expected
BUG_ON errors.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This patch changes mac80211 to share some more data about
stations with drivers. Should help iwlwifi and ath9k when
they get around to updating, and might also help with
implementing rate control algorithms without internals.
Cc: Sujith Manoharan <Sujith.Manoharan@atheros.com>
Bit 4-5 of DSCP should not be considered by classify_d1. The
802.11 QoS Priority field is only depending on the precedence level.
Signed-off-by: Daniel Wagner <wagi@monom.org>
qdisc_root_lock() is only %100 safe to use when the RTNL
semaphore is held.
This patch fixes mac80211 to not use the skb->cb over the queue step
from virtual interfaces to the master. The patch also, for now,
disables aggregation because that would still require requeuing,
will fix that in a separate patch. There are two other places (software
requeue and powersaving stations) where requeue can happen, but that is
not currently used by any drivers/not possible to use respectively.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
We can simply use the qdisc->q.lock for all of the
qdisc tree synchronization.
The only behavior change is that we do not drop packets under any
circumstances. If that is absolutely needed, we could easily add it
back.
With cleanups and help from Johannes Berg.
alloc_netdev_mq() now allocates an array of netdev_queue
structures for TX, based upon the queue_count argument.
Furthermore, all accesses to the TX queues are now vectored
through the netdev_get_tx_queue() and netdev_for_each_tx_queue()
interfaces. This makes it easy to grep the tree for all
things that want to get to a TX queue of a net device.
Problem spots which are not really multiqueue aware yet, and
only work with one queue, can easily be spotted by grepping
for all netdev_get_tx_queue() calls that pass in a zero index.
Now qdisc, qdisc_sleeping, and qdisc_list also live there.
The lock is now an attribute of the device queue.
One thing to notice is that "suspicious" places
emerge which will need specific training about
multiple queue handling. They are so marked with
explicit "netdev->rx_queue" and "netdev->tx_queue"
references.
It can be obtained via the netdev_queue. So create a helper routine,
qdisc_dev(), to make the transformations nicer looking.
Now, qdisc_alloc() now no longer needs a net_device pointer argument.
A netdev_queue is an entity managed by a qdisc.
Currently there is one RX and one TX queue, and a netdev_queue merely
contains a backpointer to the net_device.
The Qdisc struct is augmented with a netdev_queue pointer as well.
Eventually the 'dev' Qdisc member will go away and we will have the
resulting hierarchy:
net_device --> netdev_queue --> Qdisc
Also, qdisc_alloc() and qdisc_create_dflt() now take a netdev_queue
pointer argument.
Also remove the WLAN_IS_QOS_DATA inline after removing the last
two users. This starts moving away from using rx->fc to using
the header frame_control directly.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch removes useless tid assignment for management and control frames
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Documentation/feature-removal-schedule.txt
drivers/net/wan/hdlc_fr.c
drivers/net/wireless/iwlwifi/iwl-4965.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
This patch reworks the mac80211 debug settings making them more focused
and adding help text for those that didn't have one. It also removes a
number of printks that can be triggered remotely and add no value, e.g.
"too short deauthentication frame received - ignoring".
If somebody really needs to debug that they should just add a monitor
interface and look at the frames in wireshark.
Pass double tcf_proto pointers to tcf_destroy_chain() to make it
clear the start of the filter list for more consistency.
drivers/net/wireless/rt2x00/Kconfig
drivers/net/wireless/rt2x00/rt2x00usb.c
net/sctp/protocol.c
This patch adds '\n' in debug printk (wme.c HT DEBUG)
This patch updates mac80211 and drivers to be multi-queue aware and
use that instead of the internal queue mapping. Also does a number
of cleanups in various pieces of the code that fall out and reduces
internal mac80211 state size.
This patch converts mac80211 and all drivers to have transmit
information and status in skb->cb rather than allocating extra
memory for it and copying all the data around. To make it fit,
a union is used where only data that is necessary for all steps
is kept outside of the union.
A number of fixes were done by Ivo, as well as the rt2x00 part
of this patch.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/wireless/iwlwifi/iwl-4965-rs.c
drivers/net/wireless/rt2x00/rt61pci.c
Signed-off-by: Pavel Roskin <proski@gnu.org>
In commit e100bb64bf7cdeae7f742a65ee1985649a7fd1b4 (mac80211:
QoS related cleanups) I accidentally changed a variable from
int to u16 causing a warning that a comparison for < 0 was always
false. John thought this was a missing deletion of code and removed
the warning by deleting the never executed branch of code in commit
3df5ee60f1ee559b1417397461891f8b483e8089 (wireless: fix warning
introduced by "mac80211: QoS related cleanups") but the problem really
was my mistake of using a u16 variable for the queue variable when
that variable can also contain an error code. This patch restores
the original code and variable type.
net/mac80211/wme.c: In function ‘wme_qdiscop_enqueue’:
net/mac80211/wme.c:219: warning: comparison is always false due to limited range of data type
drivers/net/wireless/p54/p54common.c: In function ‘p54_conf_tx’:
drivers/net/wireless/p54/p54common.c:947: warning: comparison is always false due to limited range of data type
This
* makes the queue number passed to drivers a u16
(as it will be with skb_get_queue_mapping)
* removes the useless queue number defines
* splits hw->queues into hw->queues/ampdu_queues
* removes the debugfs files for per-queue counters
* removes some dead QoS code
* removes the beacon queue configuration for IBSS
so that the drivers now never get a queue number
bigger than (hw->queues + hw->ampdu_queues - 1)
for tx and only in the range 0..hw->queues-1 for
conf_tx.
This patch fixes use of Qdisc length in requeue function, before we checked
the reference is valid. (Adrian Bunk's catch)
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This makes access to the STA hash table/list use RCU to protect
against freeing of items. However, it's not a true RCU, the
copy step is missing: whenever somebody changes a STA item it
is simply updated. This is an existing race condition that is
now somewhat understandable.
This patch also fixes the race key freeing vs. STA destruction
by making sure that sta_info_destroy() is always called under
RTNL and frees the key.
This fix allows to control the number of bits that qdiscs book keeping
can be done for with respect to the qdisc pool
This patch allows qdisc support in A-MPDU Tx. a method to
handle QoS <-> TID switches is present in this patch.
Convert packet schedulers to use the netlink API. Unfortunately a gradual
conversion is not possible without breaking compilation in the middle or
adding lots of casts, so this patch converts them all in one step. The
patch has been mostly generated automatically with some minor edits to
at least allow seperate conversion of classifiers and actions.
This patch assigns correct TID to frames transmitted between
two stations in the same BSS in AP mode.
The problem is that skb->protocol is not set to ETH_P_IP and it is wrong
to use that field at this stage.
The fix compares the LLC/Protocol headers explicitly to check if the
encapsulated frame is IP frame
Signed-off-by: Guy Cohen <guy.cohen@intel.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Qdisc_class_ops are const, and Qdisc_ops are mostly read.
Using "const" and "__read_mostly" qualifiers helps to reduce false
sharing.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Removes the management interface since it is only required
for hostapd/userspace MLME, will not be in the final tree
at least in this form and hostapd/userspace MLME currently
do not work against this tree anyway.
This cleans up some whitespace to make the mac80211
version in mainline diverge less from wireless-dev.
Acked-by: Michael Wu <flamingice@sourmilk.net>
remove bitfields from struct ieee80211_tx_packet_data
[Johannes: completely clear flags in ieee80211_remove_tx_extra]
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
This patch moves the QoS handlers into rx.c making it possible
to compile wme.c only when NET_SCHED is defined.
Signed-off-by: Jiri Benc <jbenc@suse.cz>
wme.c triggers a sparse warning; it wasn't noticed before because until
recently ARRAY_SIZE triggered a sparse error.
Add mac80211, the IEEE 802.11 software MAC layer.
