path: root/net/mac80211/util.c
2009-06-15mac80211: disconnect when user changes channelJohannes Berg
If we do not disconnect when a channel switch is requested, we end up eventually detection beacon loss from the AP and then disconnecting, without ever really telling the AP, so we might just as well disconnect right away. Additionally, this fixes a problem with iwlwifi where the driver will clear some internal state on channel changes like this and then get confused when we actually go clear that state from mac80211. It may look like this patch drops the no-IBSS check, but that is already handled by cfg80211 in the wext handler it provides for IBSS (cfg80211_ibss_wext_siwfreq). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: do not pass PS frames out of mac80211 againJohannes Berg
In order to handle powersave frames properly we had needed to pass these out to the device queues again, and introduce the skb->requeue bit. This, however, also has unnecessary overhead by needing to 'clean up' already tried frames, and this clean-up code is also buggy when software encryption is used. Instead of sending the frames via the master netdev queue again, simply put them into the pending queue. This also fixes a problem where frames for that particular station could be reordered when some were still on the software queues and older ones are re-injected into the software queue after them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: add rfkill supportJohannes Berg
To be easier on drivers and users, have cfg80211 register an rfkill structure that drivers can access. When soft-killed, simply take down all interfaces; when hard-killed the driver needs to notify us and we will take down the interfaces after the fact. While rfkilled, interfaces cannot be set UP. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03mac80211: fix transposed min/max CW valuesJohannes Berg
I accidentally transposed these in the patch that "fixed" the defaults, leading to extremely low throughput because of the huge min CW. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22wireless: move some utility functions from mac80211 to cfg80211Zhu Yi
The patch moves some utility functions from mac80211 to cfg80211. Because these functions are doing generic 802.11 operations so they are not mac80211 specific. The moving allows some fullmac drivers to be also benefit from these utility functions. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20mac80211: cancel/restart all timers across suspend/resumeJohannes Berg
We forgot to cancel all timers in mac80211 when suspending. In particular we forgot to deal with some things that can cause hardware reconfiguration -- while it is down. While at it we go ahead and add a warning in ieee80211_sta_work() if its run while the suspend->resume cycle is in effect. This should not happen and if it does it would indicate there is a bug lurking in either mac80211 or mac80211 drivers. With this now wpa_supplicant doesn't blink when I go to suspend and resume where as before there where issues with some timers running during the suspend->resume cycle. This caused a lot of incorrect assumptions and would at times bring back the device in an incoherent, but mostly recoverable, state. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11mac80211: set default QoS values according to specJohannes Berg
We've never really cared about the default QoS (WMM) values, but we really should if the AP doesn't send any. This patch makes mac80211 use the default values according to 802.11-2007, and additionally syncs the default values when we disassociate so whatever the last AP said gets "unconfigured". Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: add driver ops wrappersJohannes Berg
In order to later add tracing or verifications to the driver calls mac80211 makes, this patch adds static inline wrappers for all operations. All calls are now written as drv_<op>(local, ...); instead of local->ops-><op>(&local->hw, ...); Where necessary, the wrappers also do existence checking and return default values as appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: unify config_interface and bss_info_changedJohannes Berg
The config_interface method is a little strange, it contains the BSSID and beacon updates, while bss_info_changed contains most other BSS information for each interface. This patch removes config_interface and rolls all the information it previously passed to drivers into bss_info_changed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: validate TIM IE length (redux)Johannes Berg
The TIM IE must not be shorter than 4 bytes, so verify that when parsing it and use the proper type. To ease that adjust struct ieee80211_tim_ie to have a virtual bitmap of size at least 1. Also check that the TIM IE is actually present before trying to parse it! Because other people may need the function, make it a static inline in ieee80211.h. (The original "mac80211: validate TIM IE length" was a minimal fix for 2.6.30. This purports to be the full, correct fix. -- JWL) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22nl80211: Add set/get for frag/rts threshold and retry limitsJouni Malinen
Add new nl80211 attributes that can be used with NL80211_CMD_SET_WIPHY and NL80211_CMD_GET_WIPHY to manage fragmentation/RTS threshold and retry limits. Since these values are stored in struct wiphy, remove the local copy from mac80211 where feasible (frag & rts threshold). The retry limits are currently needed in struct ieee80211_conf, but these could be eventually removed since the driver should have access to the values in struct wiphy. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: implement beacon filtering in softwareJohannes Berg
Regardless of whether the hardware implements beacon filtering, there's no need to process all beacons in software all the time throughout the stack (mac80211 does a lot, then cfg80211, then in the future possibly userspace). This patch implements the "best possible" beacon filtering in mac80211. "Best possible" means that it can look for changes in all requested information elements, and distinguish vendor IEs by their OUI. In the future, we will add nl80211 API for userspace to request information elements and vendor IE OUIs to watch -- drivers can then implement the best they can do while software implements it fully. It is unclear whether or not this actually saves CPU time, but the data is all in the cache already so it should be fairly cheap. The additional _testing_, however, has great benefit; Without this, and on hardware that doesn't implement beacon filtering, wrong assumptions about, for example, scan result updates could quickly creep into code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: add hardware restart functionJohannes Berg
Some hardware defects may require the hardware to be re-initialised completely from scratch. Drivers would need much information (for instance the current MAC address, crypto keys, beaconing information, etc.) stored duplicated from mac80211 to be able to do this, so let mac80211 help them. The new ieee80211_restart_hw() function requires the same code as resuming, so move that code into a new ieee80211_reconfig() function in util.c and leave only the suspend code in pm.c. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: include HT capabilities in probe requestJohannes Berg
Include the HT capabilities in the probe request frame. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: pass all probe request IEs to driverJohannes Berg
Instead of just passing the cfg80211-requested IEs, pass the locally generated ones as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22cfg80211: introduce scan IE limit attributeJohannes Berg
This patch introduces a new attribute for a wiphy that tells userspace how long the information elements added to a probe request frame can be at most. It also updates the at76 to advertise that it cannot support that, and, for now until I can fix that, iwlwifi too. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211/iwlwifi: move virtual A-MDPU queue bookkeeping to iwlwifiJohannes Berg
This patch removes all the virtual A-MPDU-queue bookkeeping from mac80211. Curiously, iwlwifi already does its own bookkeeping, so it doesn't require much changes except where it needs to handle starting and stopping the queues in mac80211. To handle the queue stop/wake properly, we rewrite the software queue number for aggregation frames and internally to iwlwifi keep track of the queues that map into the same AC queue, and only talk to mac80211 about the AC queue. The implementation requires calling two new functions, iwl_stop_queue and iwl_wake_queue instead of the mac80211 counterparts. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Reinette Chattre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: rework the pending packets codeJohannes Berg
The pending packets code is quite incomprehensible, uses memory barriers nobody really understands, etc. This patch reworks it entirely, using the queue spinlock, proper stop bits and the skb queues themselves to indicate whether packets are pending or not (rather than a separate variable like before). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: rewrite fragmentationJohannes Berg
Fragmentation currently uses an allocated array to store the fragment skbs, and then keeps track of which have been sent and which are still pending etc. This is rather complicated; make it simpler by just chaining the fragments into skb->next and removing from that list when sent. Also simplifies all code that needs to touch fragments, since it now only needs to walk the skb->next list. This is a prerequisite for fixing the stored packet code, which I need to do for proper aggregation packet storing. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27nl80211: Remove NL80211_CMD_SET_MGMT_EXTRA_IEJouni Malinen
The functionality that NL80211_CMD_SET_MGMT_EXTRA_IE provided can now be achieved with cleaner design by adding IE(s) into NL80211_CMD_TRIGGER_SCAN, NL80211_CMD_AUTHENTICATE, NL80211_CMD_ASSOCIATE, NL80211_CMD_DEAUTHENTICATE, and NL80211_CMD_DISASSOCIATE. Since this is a very recently added command and there are no known (or known planned) applications using NL80211_CMD_SET_MGMT_EXTRA_IE and taken into account how much extra complexity it adds to the IE processing we have now (and need to add in the future to fix IE order in couple of frames), it looks like the best option is to just remove the implementation of this command for now. The enum values themselves are left to avoid changing the nl80211 command or attribute numbers. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27nl80211: Optional IEs into scan requestJouni Malinen
This extends the NL80211_CMD_TRIGGER_SCAN command to allow applications to specify a set of information element(s) to be added into Probe Request frames with NL80211_ATTR_IE. This provides support for the MLME-SCAN.request primitive parameter VendorSpecificInfo and can be used, e.g., to implement WPS scanning. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: split IBSS/managed codeJohannes Berg
This patch splits out the ibss code and data from managed (station) mode. The reason to do this is to better separate the state machines, and have the code be contained better so it gets easier to determine what exactly a given change will affect, that in turn makes it easier to understand. This is quite some churn, especially because I split sdata->u.sta into sdata->u.mgd and sdata->u.ibss, but I think it's easier to maintain that way. I've also shuffled around some code -- null function sending is only applicable to managed interfaces so put that into that file, some other functions are needed from various places so put them into util, and also rearranged the prototypes in ieee80211_i.h accordingly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: fix aggregation for hardware with ampdu queuesJohannes Berg
Hardware with AMPDU queues currently has broken aggregation. This patch fixes it by making all A-MPDUs go over the regular AC queues, but keeping track of the hardware queues in mac80211. As a first rough version, it actually stops the AC queue for extended periods of time, which can be removed by adding buffering internal to mac80211, but is currently not a huge problem because people rarely use multiple TIDs that are in the same AC (and iwlwifi currently doesn't operate as AP). This is a short-term fix, my current medium-term plan, which I hope to execute soon as well, but am not sure can finish before .30, looks like this: 1) rework the internal queuing layer in mac80211 that we use for fragments if the driver stopped queue in the middle of a fragmented frame to be able to queue more frames at once (rather than just a single frame with its fragments) 2) instead of stopping the entire AC queue, queue up the frames in a per-station/per-TID queue during aggregation session initiation, when the session has come up take all those frames and put them onto the queue from 1) 3) push the ampdu queue layer abstraction this patch introduces in mac80211 into the driver, and remove the virtual queue stuff from mac80211 again This plan will probably also affect ath9k in that mac80211 queues the frames instead of passing them down, even when there are no ampdu queues. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: add interface list lockJohannes Berg
Using only the RTNL has a number of problems, most notably that ieee80211_iterate_active_interfaces() and other interface list traversals cannot be done from the internal workqueue because it needs to be flushed under the RTNL. This patch introduces a new mutex that protects the interface list against modifications. A more detailed explanation is part of the code change. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: allow mac80211 drivers to get to struct ieee80211_hw from wiphyLuis R. Rodriguez
If a driver is given a wiphy and it wants to get to its private mac80211 driver area it can use wiphy_to_ieee80211_hw() to get first to its ieee80211_hw and then access the private structure via hw->priv. The wiphy_priv() is already being used internally by mac80211 and drivers should not use this. This can be helpful in a drivers reg_notifier(). Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29wireless: restrict to 32 legacy ratesJohannes Berg
Since the standards only define 12 legacy rates, 32 is certainly a sane upper limit and we don't need to use u64 everywhere. Add sanity checking that no more than 32 rates are registered and change the variables to u32 throughout. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Fix MFP Association Comeback to use Timeout Interval IEJouni Malinen
The separate Association Comeback Time IE was removed from IEEE 802.11w and the Timeout Interval IE (from IEEE 802.11r) is used instead. The editing on this is still somewhat incomplete in IEEE 802.11w/D7.0, but still, the use of Timeout Interval IE is the expected mechanism. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: 802.11w - Implement Association Comeback processingJouni Malinen
When MFP is enabled, the AP does not allow a STA to associate if an existing security association exists without first going through SA Query process. When this happens, the association request is denied with a new status code ("temporarily rejected") ans Association Comeback IE is used to notify when the association may be tried again (i.e., when the SA Query procedure has timed out). Use the comeback time to update the mac80211 client MLME timer for next association attempt to minimize waiting time if association is temporarily rejected. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: make wake/stop_queue_by_reason() functions staticKalle Valo
Fixes sparse warnings: net/mac80211/util.c:355:6: warning: symbol 'ieee80211_wake_queue_by_reason' was not declared. Should it be static? net/mac80211/util.c:385:6: warning: symbol 'ieee80211_stop_queue_by_reason' was not declared. Should it be static? Thanks to Johannes Berg for reporting this. Signed-off-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-19mac80211: track master queue statusKalle Valo
This is a preparation for the dynamic power save support. In future there are two paths to stop the master queues and we need to track this properly to avoid starting queues incorrectly. Implement this by adding a status array for each queue. The original idea and design is from Johannes Berg, I just did the implementation based on his notes. All the bugs are mine, of course. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-19mac80211: Fix HT channel selectionSujith
HT management is done differently for AP and STA modes, unify to just the ->config() callback since HT is fundamentally a PHY property and cannot be per-BSS. Rename enum nl80211_sec_chan_offset as nl80211_channel_type to denote the channel type ( NO_HT, HT20, HT40+, HT40- ). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-12-05nl80211: Add frequency configuration (including HT40)Jouni Malinen
This patch adds new NL80211_CMD_SET_WIPHY attributes NL80211_ATTR_WIPHY_FREQ and NL80211_ATTR_WIPHY_SEC_CHAN_OFFSET to allow userspace to set the operating channel (e.g., hostapd for AP mode). Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: remove rate_control_clearJohannes Berg
"Clearing" the rate control algorithm is pointless, none of the algorithms actually uses this operation and it's not even invoked properly for all channel switching. Also, there's no need to since rate control algorithms work per station. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: move bss_conf into vifJohannes Berg
Move bss_conf into the vif struct so that drivers can access it during ->tx without having to store it in the private data or similar. No driver updates because this is only for when they want to start using it. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: introduce hw config change flagsJohannes Berg
This makes mac80211 notify the driver which configuration actually changed, e.g. channel etc. No driver changes, this is just plumbing, driver authors are expected to act on this if they want to. Also remove the HW CONFIG debug printk, it's incorrect, often we configure something else. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31802.11: clean up/fix HT supportJohannes Berg
This patch cleans up a number of things: * the unusable definition of the HT capabilities/HT information information elements * variable names that are hard to understand * mac80211: move ieee80211_handle_ht to ht.c and remove the unused enable_ht parameter * mac80211: fix bug with MCS rate 32 in ieee80211_handle_ht * mac80211: fix bug with casting the result of ieee80211_bss_get_ie to an information element _contents_ rather than the whole element, add size checking (another out-of-bounds access bug fixed!) * mac80211: remove some unused return values in favour of BUG_ON checking * a few minor other things Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-31mac80211: clean up ieee80211_hw_config errorsJohannes Berg
Warn when ieee80211_hw_config returns an error, it shouldn't happen; remove a number of printks that would happen in such a case and one printk that is user-triggerable. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-10-14mac80211: fix HT information element parsingJohannes Berg
There's no checking that the HT IEs are of the right length which can be used by an attacker to cause an out-of-bounds access by sending a too short HT information/capability IE. Fix it by simply pretending those IEs didn't exist when too short. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: fix virtual interfaces vs. injectionJohannes Berg
Currently, virtual interface pointers passed to drivers might be from monitor interfaces and as such completely uninitialised because we do not tell the driver about monitor interfaces when those are created. Instead of passing them, we should therefore indicate to the driver that there is no information; do that by passing a NULL value and adjust drivers to cope with it. As a result, some mac80211 API functions also need to cope with a NULL vif pointer so drivers can still call them unconditionally. Also, when injecting frames we really don't want to pass NULL all the time, if we know we are the source address of a frame and have a local interface for that address, we can to use that interface. This also helps with processing the frame correctly for that interface which will help the 802.11w implementation. It's not entirely correct for VLANs or WDS interfaces because there the MAC address isn't unique, but it's already a lot better than what we do now. Finally, when injecting without a matching local interface, don't assign sequence numbers at all. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: use nl80211 interface typesJohannes Berg
There's really no reason for mac80211 to be using its own interface type defines. Use the nl80211 types and simplify the configuration code a bit: there's no need to translate them any more now. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: inform driver of basic ratesetJohannes Berg
Drivers need to know the basic rateset to be able to configure the ACK/CTS programming in hardware correctly. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: clean up scan namespaceJohannes Berg
Most of the scan functions are called ieee80211_sta_scan_* or similar, make clean it up so they are all just called ieee80211_scan_*. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-15mac80211: move ieee80211_set_freq to utilsJohannes Berg
It really doesn't belong into the wireless extensions code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: move frame TX functionJohannes Berg
The ieee80211_sta_tx function isn't MLME code any more, it's getting used by a lot of code. Move it to utils and rename it to ieee80211_tx_skb. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: initialise queue QoS parameters at hw startJohannes Berg
When hardware is started it might be in a confused state with respect to queue QoS parameters. This patch changes mac80211 to set sane defaults right after the hardware is brought up. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-09-11mac80211: move IE parsing to util fileJohannes Berg
Since IE parsing is required for the mlme and mesh code, it's not a static function anyway, and it's much better to have it in util rather than the overly large mlme.c Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: remove ieee80211_get_hdrlenHarvey Harrison
All users have been moved over to the version taking a le16 frame control rather than a cpu-endian value. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-22mac80211: add ieee80211_queue_stopped)Tomas Winkler
This patch adds ieee80211_queue_stopped that let drivers to query queue status Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-01mac80211: fix fragmentation kludgeTomas Winkler
This patch make mac80211 transmit correctly fragmented packet after queue was stopped Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-17mac80211: Reimplement WME using ->select_queue().David S. Miller
The only behavior change is that we do not drop packets under any circumstances. If that is absolutely needed, we could easily add it back. With cleanups and help from Johannes Berg. Signed-off-by: David S. Miller <davem@davemloft.net>
