path: root/net/mac80211/main.c
2008-08-07mac80211: keep mesh ifaces in allmulti modeLuis Carlos Cobo
Currently a mesh node will not forward a multicast frame if it is not subscribed to the specific multicast address. This patch addresses the issue and fixes mesh multicast forwarding. Signed-off-by: Luis Carlos Cobo <luisca@cozybit.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-08-04mac80211: make listen_interval be limited by low level driverTomas Winkler
This patch makes possible for a driver to specify maximal listen interval The possibility for user to configure listen interval is not implemented yet, currently the maximum provided by the driver or 1 is used. Mac80211 uses config handler to set listen interval for to the driver. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-29mac80211: partially fix skb->cb useJohannes Berg
This patch fixes mac80211 to not use the skb->cb over the queue step from virtual interfaces to the master. The patch also, for now, disables aggregation because that would still require requeuing, will fix that in a separate patch. There are two other places (software requeue and powersaving stations) where requeue can happen, but that is not currently used by any drivers/not possible to use respectively. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-29mac80211: return correct error return from ieee80211_wep_initJeremy Fitzhardinge
Return the proper error code rather than a hard-coded ENOMEM from ieee80211_wep_init. Also, print the error code on failure. Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-17mac80211: Reimplement WME using ->select_queue().David S. Miller
The only behavior change is that we do not drop packets under any circumstances. If that is absolutely needed, we could easily add it back. With cleanups and help from Johannes Berg. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Kill NETIF_F_MULTI_QUEUE.David S. Miller
There is no need for a feature bit for something that can be tested by simply checking the TX queue count. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-15netdev: Do not use TX lock to protect address lists.David S. Miller
Now that we have a specific lock to protect the network device unicast and multicast lists, remove extraneous grabs of the TX lock in cases where the code only needs address list protection. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-15netdev: Add netdev->addr_list_lock protection.David S. Miller
Add netif_addr_{lock,unlock}{,_bh}() helpers. Use them to protect operations that operate on or read the network device unicast and multicast address lists. Also use them in cases where the code simply wants to block calls into the driver's ->set_rx_mode() and ->set_multicast_list() methods. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14mac80211: revamp beacon configurationJohannes Berg
This patch changes mac80211's beacon configuration handling to never pass skbs to the driver directly but rather always require the driver to use ieee80211_beacon_get(). Additionally, it introduces "change flags" on the config_interface() call to enable drivers to figure out what is changing. Finally, it removes the beacon_update() driver callback in favour of having IBSS beacon delivered by ieee80211_beacon_get() as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: revamp virtual interface handlingJohannes Berg
This patch revamps the virtual interface handling and makes the code much easier to follow. Fewer functions, better names, less spaghetti code. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-14mac80211: make master netdev handling saneJohannes Berg
Currently, almost every interface type has a 'bss' pointer pointing to BSS information. This BSS information, however, is for a _local_ BSS, not for the BSS we joined, so having it on a STA mode interface makes little sense, but now they have it pointing to the master device, which is an AP mode virtual interface. However, except for some bitrate control data, this pointer is only used in AP/VLAN modes (for power saving stations.) Overall, it is not necessary to even have the master netdev be a valid virtual interface, and it doesn't have to be on the list of interfaces either. This patch changes the master netdev to be special, it now - no longer is on the list of virtual interfaces, which lets me remove a lot of tests for that - no longer has sub_if_data attached, since that isn't used Additionally, this patch changes some vlan/ap mode handling that is related to these 'bss' pointers described above (but in the VLAN case they actually make sense because there they point to the AP they belong to); it also adds some debugging code to IEEE80211_DEV_TO_SUB_IF to validate it is not called on the master netdev any more. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08netdev: Make netif_schedule() routines work with netdev_queue objects.David S. Miller
Only plain netif_schedule() remains taking a net_device, mostly as a compatability item while we transition the rest of these interfaces. Everything else calls netif_schedule_queue() or __netif_schedule(), both of which take a netdev_queue pointer. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08mac80211: Decrease number of explicit ->tx_queue references.David S. Miller
Accomplish this by using local variables. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move queue_lock into struct netdev_queue.David S. Miller
The lock is now an attribute of the device queue. One thing to notice is that "suspicious" places emerge which will need specific training about multiple queue handling. They are so marked with explicit "netdev->rx_queue" and "netdev->tx_queue" references. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-3945.c net/mac80211/mlme.c
2008-07-08mac80211: call bss_info_change only once upon disassociationTomas Winkler
This patch removes call of ieee80211_bss_info_change_notify from within ieee80211_reset_erp_info. This allows gathering all bss info changes into one call to the driver in the disassociation flow. Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-08mac80211: add block ack request capabilityRon Rindjunsky
This patch adds block ack request capability Signed-off-by: Ester Kummer <ester.kummer@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-07mac80211: Only flush workqueue when last interface was removedIvo van Doorn
Currently the ieee80211_hw->workqueue is flushed each time an interface is being removed. However most scheduled work is not interface specific but device specific, for example things like periodic work for link tuners. This patch will move the flush_workqueue() call to directly behind the call to ops->stop() to make sure the workqueue is only flushed when all interfaces are gone and there really shouldn't be any scheduled work in the drivers left. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-07-02mac80211: rework debug settings and make debugging saferJohannes Berg
This patch reworks the mac80211 debug settings making them more focused and adding help text for those that didn't have one. It also removes a number of printks that can be triggered remotely and add no value, e.g. "too short deauthentication frame received - ignoring". If somebody really needs to debug that they should just add a monitor interface and look at the frames in wireshark. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-27mac80211: make workqueue freezableJohannes Berg
This patch makes the mac80211 workqueue freezable making it interact a bit better with system suspend and not try to ping the AP while the hardware is down. This doesn't really help with implementing proper suspend in any way but makes some bad things trigger less. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-14mac80211: fix beacon interval valueTomas Winkler
This patch fixes setting beacon interval 1. in register_hw it honors value requested by the driver 2. It uses default 100 instead of 1000 or 10000. Scanning for beacon interval ~1sec and above is not sane Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-10Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tg3.c drivers/net/wireless/rt2x00/rt2x00dev.c net/mac80211/ieee80211_i.h
2008-06-09mac80211: Fixing slow IBSS rejoinAssaf Krauss
This patch fixes the issue of slow reconnection to an IBSS cell after disconnection from it. Now the interface's bssid is reset upon ifdown. ieee80211_sta_find_ibss: if (found && memcmp(ifsta->bssid, bssid, ETH_ALEN) != 0 && (bss = ieee80211_rx_bss_get(dev, bssid, local->hw.conf.channel->center_freq, ifsta->ssid, ifsta->ssid_len))) Note: In general disconnection is still not handled properly in mac80211 Signed-off-by: Assaf Krauss <assaf.krauss@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-06-03mac80211: fix deadlock in sta->lockTomas Winkler
This patch fixes a deadlock of sta->lock use, occurring while changing tx aggregation states, as dev_queue_xmit end up in new function test_and_clear_sta_flags that uses that lock thus leading to deadlock Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-28mac80211: fix a typo in ieee80211_handle_filtered_frame commentYi Zhu
fix a typo in ieee80211_handle_filtered_frame comment Signed-off-by: Yi Zhu <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: use multi-queue master netdeviceJohannes Berg
This patch updates mac80211 and drivers to be multi-queue aware and use that instead of the internal queue mapping. Also does a number of cleanups in various pieces of the code that fall out and reduces internal mac80211 state size. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: move TX info into skb->cbJohannes Berg
This patch converts mac80211 and all drivers to have transmit information and status in skb->cb rather than allocating extra memory for it and copying all the data around. To make it fit, a union is used where only data that is necessary for all steps is kept outside of the union. A number of fixes were done by Ivo, as well as the rt2x00 part of this patch. Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: let drivers wake but not start queuesJohannes Berg
Having drivers start queues is just confusing, their ->start() callback can block and do whatever is necessary, so let mac80211 start queues and have drivers wake queues when necessary (to get packets flowing again right away.) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-21mac80211: separate Tx and Rx MCS when configuring HTRon Rindjunsky
This patch follows the 11n spec in separation between Tx and Rx MCS capabilities. Up until now, when configuring the HT possible set of Tx MCS only Rx MCS were considered, assuming they are the same as the Tx MCS. This patch fixed this by looking at low level driver Tx capabilities. Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-4965-rs.c drivers/net/wireless/rt2x00/rt61pci.c
2008-05-14mac80211: use hardware flags for signal/noise unitsBruno Randolf
trying to clean up the signal/noise code. the previous code in mac80211 had confusing names for the related variables, did not have much definition of what units of signal and noise were provided and used implicit mechanisms from the wireless extensions. this patch introduces hardware capability flags to let the hardware specify clearly if it can provide signal and noise level values and which units it can provide. this also anticipates possible new units like RCPI in the future. for signal: IEEE80211_HW_SIGNAL_UNSPEC - unspecified, unknown, hw specific IEEE80211_HW_SIGNAL_DB - dB difference to unspecified reference point IEEE80211_HW_SIGNAL_DBM - dBm, difference to 1mW for noise we currently only have dBm: IEEE80211_HW_NOISE_DBM - dBm, difference to 1mW if IEEE80211_HW_SIGNAL_UNSPEC or IEEE80211_HW_SIGNAL_DB is used the driver has to provide the maximum value (max_signal) it reports in order for applications to make sense of the signal values. i tried my best to find out for each driver what it can provide and update it but i'm not sure (?) for some of them and used the more conservative guess in doubt. this can be fixed easily after this patch has been merged by changing the hardware flags of the driver. DRIVER SIGNAL MAX NOISE QUAL ----------------------------------------------------------------- adm8211 unspec(?) 100 n/a missing at76_usb unspec(?) (?) unused missing ath5k dBm dBm percent rssi b43legacy dBm dBm percent jssi(?) b43 dBm dBm percent jssi(?) iwl-3945 dBm dBm percent snr+more iwl-4965 dBm dBm percent snr+more p54 unspec 127 n/a missing rt2x00 dBm n/a percent rssi+tx/rx frame success rt2400 dBm n/a rt2500pci dBm n/a rt2500usb dBm n/a rt61pci dBm n/a rt73usb dBm n/a rtl8180 unspec(?) 65 n/a (?) rtl8187 unspec(?) 65 (?) noise(?) zd1211 dB(?) 100 n/a percent drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-14mac80211: proper STA info lockingJohannes Berg
As discussed earlier, we can unify locking in struct sta_info and use just a single spinlock protecting all members of the structure that need protection. Many don't, but one of the especially bad ones is the 'flags' member that can currently be clobbered when RX and TX is being processed on different CPUs at the same time. Because having four spinlocks for different, mostly exclusive parts of a single structure is overkill, this patch also kills the ampdu and mesh plink spinlocks and uses just a single one for everything. Because none of the spinlocks are nested, this is safe. It remains to be seen whether or not we should make the sta flags use atomic bit operations instead, for now though this is a safe thing and using atomic operations instead will be very simple using the new static inline functions this patch introduces for accessing sta->flags. Since spin_lock_bh() is used with this lock, there shouldn't be any contention even if aggregation is enabled at around the same time as both requires frame transmission/reception which is in a bh context. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Tomas Winkler <tomasw@gmail.com> Cc: Ron Rindjunsky <ron.rindjunsky@intel.com> Cc: Luis Carlos Cobo <luisca@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07mac80211: QoS related cleanupsJohannes Berg
This * makes the queue number passed to drivers a u16 (as it will be with skb_get_queue_mapping) * removes the useless queue number defines * splits hw->queues into hw->queues/ampdu_queues * removes the debugfs files for per-queue counters * removes some dead QoS code * removes the beacon queue configuration for IBSS so that the drivers now never get a queue number bigger than (hw->queues + hw->ampdu_queues - 1) for tx and only in the range 0..hw->queues-1 for conf_tx. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-07mac80211: a few code cleanupsJohannes Berg
This has some code cleanups (some inspired by checkpatch), I got bored at probably a third of the output though so if somebody else wants to... Signed-off-by: Johannes Berg <johannes@sipsolutions.net Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-05-04mac80211: Do not free net device after it is unregistered.Pavel Emelyanov
The error path in ieee80211_register_hw() may call the unregister_netdev() and right after it - the free_netdev(), which is wrong, since the unregister releases the device itself. So the proposed fix is to NULL the local->mdev after unregister is done and check this before calling free_netdev(). I checked - no code uses the local->mdev after unregister in this error path (but even if some did this would be a BUG). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-30mac80211: insert WDS peer after adding interfaceJohannes Berg
This reorders the open code so that WDS peer STA info entries are added after the corresponding interface is added to the driver so that driver callbacks aren't invoked out of order. Also make any master device startup fatal. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: don't allow invalid WDS peer addressesJohannes Berg
Rather than just disallowing the zero address, disallow all invalid ones. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-30mac80211: assign conf.beacon_control for meshJohannes Berg
Drivers can rightfully assume that they get a beacon_control if the beacon is set. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-16mac80211: fix spinlock recursionJohannes Berg
When STAs are expired, we need to hold the sta_lock. Using the same lock for keys too would then mean we'd need another key free function, and that'll just lead to confusion, so just use a new spinlock for all key lists. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-04-08mac80211: rename filesJohannes Berg
This patch renames all mac80211 files (except ieee80211_i.h) to get rid of the useless ieee80211_ prefix. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
