path: root/net/mac80211/ibss.c
2013-09-07mac80211: add missing channel context releaseJohannes Berg
commit 2a3ba63c235fdcd37f6451bdf4a0c7865a3930cf upstream. IBSS needs to release the channel context when leaving but I evidently missed that. Fix it. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-16mac80211: parse VHT channel switch IEsJohannes Berg
VHT introduces multiple IEs that need to be parsed for a wide bandwidth channel switch. Two are (currently) needed in mac80211: * wide bandwidth channel switch element * channel switch wrapper element The former is contained in the latter for beacons and probe responses, but not for the spectrum management action frames so the IE parser needs a new argument to differentiate them. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-10mac80211: provide SSID in IBSS modeMarek Puzyniak
Some drivers need SSID in AP and IBSS mode. AP SSID is provided through BSS_CHANGED_SSID notification. There was no easy way to do the same for IBSS. In IBSS mode SSID is known but was not stored in BSS configuration. Extend the AP-mode functionality to also work in IBSS mode. Signed-off-by: Marek Puzyniak <marek.puzyniak@tieto.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-08mac80211: check DSSS params IE length in parserJohannes Berg
It's always just one byte, so check for that and remove the length field from the parser struct. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-25mac80211: ibss: use beacon_data struct for beacon and probe responseJohannes Berg
Instead of having an SKB all the time, use a beacon_data struct with just the information required. This also allows removing a synchronize_rcu() and using kfree_rcu() instead. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-25mac80211: ibss: disable beaconing before freeing beaconJohannes Berg
If we don't disable beaconing, the driver might attempt to continue, but would fail to request a beacon. That's strange, so disable beaconing first. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-03-06mac80211: cleanup suspend/resume on ibss modeStanislaw Gruszka
Remove not used any longer suspend/resume code. Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-15mac80211: stop toggling IEEE80211_HT_CAP_SUP_WIDTH_20_40Johannes Berg
For VHT, many more bandwidth changes are possible. As a first step, stop toggling the IEEE80211_HT_CAP_SUP_WIDTH_20_40 flag in the HT capabilities and instead introduce a bandwidth field indicating the currently usable bandwidth to transmit to the station. Of course, make all drivers use it. To achieve this, make ieee80211_ht_cap_ie_to_sta_ht_cap() get the station as an argument, rather than the new capabilities, so it can set up the new bandwidth field. If the station is a VHT station and VHT bandwidth is in use, also set the bandwidth accordingly. Doing this allows us to get rid of the supports_40mhz flag as the HT capabilities now reflect the true capability instead of the current setting. While at it, also fix ieee80211_ht_cap_ie_to_sta_ht_cap() to not ignore HT cap overrides when MCS TX isn't supported (not that it really happens...) Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-11mac80211: simplify idle handlingJohannes Berg
Now that we have channel contexts, idle is (pretty much) equivalent to not having a channel context. Change the code to use this relation so that there no longer is a need for a lot of idle recalculate calls everywhere. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-11cfg80211: move TSF into IEsJohannes Berg
While technically the TSF isn't an IE, it can be necessary to distinguish between the TSF from a beacon and a probe response, in particular in order to know the next DTIM TBTT, as not all APs are spec compliant wrt. TSF==0 being a DTIM TBTT and thus the DTIM count needs to be taken into account as well. To allow this, move the TSF into the IE struct so it can be known whence it came. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-02-11cfg80211: pass wiphy to cfg80211_ref_bss/put_bssJohannes Berg
This prepares for using the spinlock instead of krefs which is needed in the next patch to track the refs of combined BSSes correctly. Acked-by: Bing Zhao <bzhao@marvell.com> [mwifiex] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-31mac80211: start auth/assoc timeout on frame statusJohannes Berg
When sending authentication/association frames they might take a bit of time to go out because we may have to synchronise with the AP, in particular in the case where it's really a P2P GO. In this case the 200ms fixed timeout could potentially be too short if the beacon interval is relatively large. For drivers that report TX status we can do better. Instead of starting the timeout directly, start it only when the frame status arrives. Since then the frame was out on the air, we can wait shorter (the typical response time is supposed to be 30ms, wait 100ms.) Also, if the frame failed to be transmitted try again right away instead of waiting. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-03mac80211: track enable_beacon explicitlyJohannes Berg
Instead of calculating in ieee80211_bss_info_change_notify() whether beaconing should be enabled or not, set it in the correct places in the callers. This simplifies the logic in this function at the expense of offchannel, but is also more robust. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-03mac82011: use frame control to differentiate probe resp/beaconEmmanuel Grumbach
The probe response/beacon management frame RX code passes a bool parameter to differentiate beacons and probe responses. This is useless since we have the frame and can thus use its frame control field. Moreover it is buggy since there is one call to ieee80211_rx_bss_info with a beacon frame that is indicated as a probe response, which is also fixed by using the frame control field, so do that. Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-03mac80211: remove final sta_info_flush()Johannes Berg
When all interfaces have been removed, there can't be any stations left over, so there's no need to flush again. Remove this, and all code associated with it, which also simplifies the function. Tested-by: Ben Greear <greearb@candelatech.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-01-03mac80211: fix ibss scanningStanislaw Gruszka
Do not scan on no-IBSS and disabled channels in IBSS mode. Doing this can trigger Microcode errors on iwlwifi and iwlegacy drivers. Also rename ieee80211_request_internal_scan() function since it is only used in IBSS mode and simplify calling it from ieee80211_sta_find_ibss(). This patch should address: https://bugzilla.redhat.com/show_bug.cgi?id=883414 https://bugzilla.kernel.org/show_bug.cgi?id=49411 Reported-by: Jesse Kahtava <jesse_kahtava@f-m.fm> Reported-by: Mikko Rapeli <mikko.rapeli@iki.fi> Cc: stable@vger.kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-12-11Merge branch 'for-john' of git://git.sipsolutions.net/mac80211-nextJohn W. Linville
2012-12-04mac80211: adapt slot time in IBSS modeSimon Wunderlich
In 5GHz/802.11a, we are allowed to use short slot times. Doing this may increases performance by 20% for legacy connections (54 MBit/s). I can confirm this in my tests (27% more throughput using iperf), and also have a small positive effect (5% more throughput) for HT rates, tested on 1 stream. Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fokus.fraunhofer.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26Merge branch 'for-john' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/jberg/mac80211-next
2012-11-26mac80211: convert to channel definition structJohannes Berg
Convert mac80211 (and where necessary, some drivers a little bit) to the new channel definition struct. This will allow extending mac80211 for VHT, which is currently restricted to channel contexts since there are no drivers using that which makes it easier. As I also don't care about VHT for drivers not using the channel context API, I won't convert the previous API to VHT support. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26nl80211/cfg80211: support VHT channel configurationJohannes Berg
Change nl80211 to support specifying a VHT (or HT) using the control channel frequency (as before) and new attributes for the channel width and first and second center frequency. The old channel type is of course still supported for HT. Also change the cfg80211 channel definition struct to support these by adding the relevant fields to it (and removing the _type field.) This also adds new helper functions: - cfg80211_chandef_create to create a channel def struct given the control channel and channel type, - cfg80211_chandef_identical to check if two channel definitions are identical - cfg80211_chandef_compatible to check if the given channel definitions are compatible, and return the wider of the two This isn't entirely complete, but that doesn't matter until we have a driver using it. In particular, it's missing - regulatory checks on the usable bandwidth (if that even makes sense) - regulatory TX power (database can't deal with it) - a proper channel compatibility calculation for the new channel types Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26cfg80211: pass a channel definition structJohannes Berg
Instead of passing a channel pointer and channel type to all functions and driver methods, pass a new channel definition struct. Right now, this struct contains just the control channel and channel type, but for VHT this will change. Also, add a small inline cfg80211_get_chandef_type() so that drivers don't need to use the _type field of the new structure all the time, which will change. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-26mac80211: in ADHOC print debug message for every Auth messageAntonio Quartulli
The debug message has to be printed also for an Auth message with auth_sequence != 1. This helps understanding whether the two Auth messages are exchanged correctly or not. Signed-off-by: Antonio Quartulli <antonio@open-mesh.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-21Merge branch 'for-john' of ↵John W. Linville
2012-11-21Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/brcm80211/brcmfmac/wl_cfg80211.c drivers/net/wireless/iwlwifi/pcie/tx.c
2012-11-13mac80211: support RX_FLAG_MACTIME_ENDThomas Pedersen
Allow drivers to indicate their mactime is at RX completion and adjust for this in mac80211. Also rename the existing RX_FLAG_MACTIME_MPDU to RX_FLAG_MACTIME_START to clarify its intent. Based on similar code by Johannes Berg. Signed-off-by: Thomas Pedersen <thomas@cozybit.com> [fix docs, atheros drivers] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-11-13mac80211: deinitialize ibss-internals after emptiness checkSimon Wunderlich
The check whether the IBSS is active and can be removed should be performed before deinitializing the fields used for the check/search. Otherwise, the configured BSS will not be found and removed properly. To make it more clear for the future, rename sdata->u.ibss to the local pointer ifibss which is used within the checks. This behaviour was introduced by f3209bea110cade12e2b133da8b8499689cb0e2e ("mac80211: fix IBSS teardown race") Cc: stable@vger.kernel.org Cc: Ignacy Gawedzki <i@lri.fr> Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-29Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless Conflicts: drivers/net/wireless/mwifiex/cfg80211.c
2012-10-26mac80211: fix SSID copy on IBSS JOINAntonio Quartulli
The 'ssid' field of the cfg80211_ibss_params is a u8 pointer and its length is likely to be less than IEEE80211_MAX_SSID_LEN most of the time. This patch fixes the ssid copy in ieee80211_ibss_join() by using the SSID length to prevent it from reading beyond the string. Cc: stable@vger.kernel.org Signed-off-by: Antonio Quartulli <ordex@autistici.org> [rewrapped commit message, small rewording] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-18mac80211: Notify new IBSS network creationSujith Manoharan
Initialization of beacon transmission in IBSS mode depends on whether a new BSS is being created or joined. When joining an existing IBSS network, beaconing has to start only after a TSF-sync has happened - this is explained in 11.1.4. Introduce a new parameter in the BSS information structure to indicate creator/joiner mode. Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-17mac80211: Take status code as parameter to ieee80211_send_authJouni Malinen
Non-zero status code may be needed for Authentication frames, e.g., when using SAE. Signed-off-by: Jouni Malinen <j@w1.fi> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-17mac80211: track needed RX chains for channel contextsJohannes Berg
On each channel that the device is operating on, it may need to listen using one or more chains depending on the SMPS settings of the interfaces using it. The previous channel context changes completely removed this ability (before, it was available as the SMPS mode). Add per-context tracking of the required static and dynamic RX chains and notify the driver on changes. To achieve this, track the chains and SMPS mode used on each virtual interface and update the channel context whenever this changes. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-10-17mac80211: use channel contextsJohannes Berg
Instead of operating on a single channel only, use the new channel context infrastructure in all mac80211 code. This enables drivers that want to use the new channel context infrastructure to use multiple channels, while nothing should change for all the other drivers that don't support it. Right now this disables both TX power settings and spatial multiplexing powersave. Both need to be re-enabled on a channel context basis. Additionally, when channel contexts are used drop the connection when channel switch is received rather than trying to handle it. This will have to be improved later. [With fixes from Eliad and Emmanuel incorporated] Signed-off-by: Eliad Peller <eliad@wizery.com> Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-09-20mac80211: fix IBSS auth TX debug messageSylvain Roger Rieunier
In the IBSS auth TX debug message the BSSID and DA address are reversed, fix that. Signed-off-by: Sylvain Roger Rieunier <sylvain.roger.rieunier@gmail.com> [reword commit message and make it fit 72 cols] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-09-07mac80211: reply to AUTH with DEAUTH if sta allocation fails in IBSSAntonio Quartulli
Whenever a host gets an AUTH frame it first allocates a new station and then replies with another AUTH frame. However, if sta allocations fails the host should send a DEAUTH frame instead to tell the other end that something went wrong. Signed-off-by: Antonio Quartulli <ordex@autistici.org> [reword commit message a bit] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-20mac80211: add supported rates change notification in IBSSAntonio Quartulli
In IBSS it is possible that the supported rates set for a station changes over time (e.g. it gets first initialised as an empty set because of no available information about rates and updated later). In this case the driver has to be notified about the change in order to update its internal table accordingly (if needed). This behaviour is needed by all those drivers that handle rc internally but leave stations management to mac80211 Reported-by: Gui Iribarren <gui@altermundi.net> Signed-off-by: Antonio Quartulli <ordex@autistici.org> [Johannes - add docs, validate IBSS mode only, fix compilation] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-31mac80211: use eth_broadcast_addrJohannes Berg
Instead of memset(). Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-07-31mac80211: use oper_channel in ibssJohannes Berg
Using hw.conf.channel is wrong as it could be the temporary channel if any function like the beacon get function is called while scanning or during other temporary out-of-channel activities. Use oper_channel instead. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-24mac80211: clean up debuggingJohannes Berg
There are a few things that make the logging and debugging in mac80211 less useful than it should be right now: * a lot of messages should be pr_info, not pr_debug * wholesale use of pr_debug makes it require *both* Kconfig and dynamic configuration * there are still a lot of ifdefs * the style is very inconsistent, sometimes the sdata->name is printed in front Clean up everything, introducing new macros and separating out the station MLME debugging into a new Kconfig symbol. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-22mac80211: two small verbose debug cleanupsJohannes Berg
Two instances of CONFIG_MAC80211_VERBOSE_DEBUG should be different, fix them. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-20mac80211: send auth in IBSS only if userspace isn't handling itWill Hawkins
Check the auth frame registration count before sending "open system" authentication messages when a new station registers on a particular IBSS network. This stops us from sending out multiple authentication messages with different authentication algorithms. Signed-off-by: Will Hawkins <hawkinsw@opentechinstitute.org> [reword commit message a bit] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-05cfg80211: simplify cfg80211_can_beacon_sec_chan APIJohannes Berg
Change cfg80211_can_beacon_sec_chan() to return true if there is no secondary channel to simplify all the current users of it. They all check the channel type before calling the function because it returns false if there's no secondary channel. Also actually document the return value. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05net: mac80211: Add and use ibss_vdbg debugging macroJoe Perches
Simplify the use of #ifdef CONFIG_MAC80211_IBSS_DEBUG/#endif by adding a logging macro to encapsulate the test. Convert the appropriate uses too. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-06-05net: mac80211: Convert printk(KERN_DEBUG to pr_debugJoe Perches
Standardize the debugging to be able to use dynamic_debug. Coalesce formats, align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-nextJohn W. Linville
2012-05-16mac80211: Push the deleted comment to correct placeAshok Nagarajan
This comment is deleted in the patch "mac80211: Advertise HT protection mode in IEs". Moving the comment to the now corrected place. Signed-off-by: Ashok Nagarajan <ashok@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-05-15net: Convert net_ratelimit uses to net_<level>_ratelimitedJoe Perches
Standardize the net core ratelimited logging functions. Coalesce formats, align arguments. Change a printk then vprintk sequence to use printf extension %pV. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-14Merge branch 'master' of ↵David S. Miller
2012-05-09mac80211: Convert compare_ether_addr to ether_addr_equalJoe Perches
Use the new bool function ether_addr_equal to add some clarity and reduce the likelihood for misuse of compare_ether_addr for sorting. Done via cocci script: $ cat compare_ether_addr.cocci @@ expression a,b; @@ - !compare_ether_addr(a, b) + ether_addr_equal(a, b) @@ expression a,b; @@ - compare_ether_addr(a, b) + !ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) == 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !ether_addr_equal(a, b) != 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) == 0 + !ether_addr_equal(a, b) @@ expression a,b; @@ - ether_addr_equal(a, b) != 0 + ether_addr_equal(a, b) @@ expression a,b; @@ - !!ether_addr_equal(a, b) + ether_addr_equal(a, b) Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-08mac80211: Advertise HT protection mode in IEsAshok Nagarajan
Signed-off-by: Ashok Nagarajan <ashok@cozybit.com> Reviewed-by: Thomas Pedersen <thomas@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
