proc_net_remove is only used to remove proc entries
that under /proc/net,it's not a general function for
removing proc entries of netns. if we want to remove
some proc entries which under /proc/net/stat/, we still
need to call remove_proc_entry.
this patch use remove_proc_entry to replace proc_net_remove.
we can remove proc_net_remove after this patch.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
Right now, some modules such as bonding use proc_create
to create proc entries under /proc/net/, and other modules
such as ipv4 use proc_net_fops_create.
It looks a little chaos.this patch changes all of
proc_net_fops_create to proc_create. we can remove
proc_net_fops_create after this patch.
git://git.kernel.org/pub/scm/linux/kernel/git/klassert/ipsec-next
Steffen Klassert says:
1) Remove a duplicated call to skb_orphan() in pf_key, from Cong Wang.
2) Prepare xfrm and pf_key for algorithms without pf_key support,
from Jussi Kivilinna.
3) Fix an unbalanced lock in xfrm_output_one(), from Li RongQing.
4) Add an IPsec state resolution packet queue to handle
packets that are send before the states are resolved.
5) xfrm4_policy_fini() is unused since 2.6.11, time to remove it.
From Michal Kubecek.
6) The xfrm gc threshold was configurable just in the initial
namespace, make it configurable in all namespaces. From
Michal Kubecek.
7) We currently can not insert policies with mark and mask
such that some flows would be matched from both policies.
Allow this if the priorities of these policies are different,
the one with the higher priority is used in this case.
pfkey support
Mark existing algorithms as pfkey supported and make pfkey only use algorithms
that have pfkey_supported set.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
All users of xfrm_addr_cmp() use its result as boolean.
Introduce xfrm_addr_equal() (which is equal to !xfrm_addr_cmp())
and convert all users.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
skb_set_owner_r() will call skb_orphan(), I don't
see any reason to call it twice.
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Allow creation of af_key sockets.
Allow creation of llc sockets.
Allow creation of af_packet sockets.
Allow sending xfrm netlink control messages.
Allow binding to netlink multicast groups.
Allow sending to netlink multicast groups.
Allow adding and dropping netlink multicast groups.
Allow sending to all netlink multicast groups and port ids.
Allow reading the netfilter SO_IP_SET socket option.
Allow sending netfilter netlink messages.
Allow setting and getting ip_vs netfilter socket options.
Because sizeof() is size_t then if "len" is negative, it counts as a
large positive value.
The call tree looks like:
pfkey_sendmsg()
-> pfkey_process()
-> pfkey_spdadd()
-> parse_ipsecrequests()
It is a frequent mistake to confuse the netlink port identifier with a
process identifier. Try to reduce this confusion by renaming fields
that hold port identifiers portid instead of pid.
I have carefully avoided changing the structures exported to
userspace to avoid changing the userspace API.
I have successfully built an allyesconfig kernel with this change.
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
This is an initial merge in of Eric Biederman's work to start adding
user namespace support to the networking.
Sematically speaking, xfrm_mgr.acquire is called when kernel intends to ask
user space IKE daemon to negotiate SAs with peers. IOW the direction will
*always* be XFRM_POLICY_OUT, so remove int dir for clarity.
Signed-off-by: Fan Du <fan.du@windriver.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Cc: Sridhar Samudrala <sri@us.ibm.com>
Acked-by: Vlad Yasevich <vyasevich@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
At the point of this error-handling code, alloc_skb has succeded, so free
the resulting skb by jumping to the err label.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Instead of testing defined(CONFIG_IPV6) || defined(CONFIG_IPV6_MODULE)
C assignment can handle struct in6_addr copying.
Unnecessary casts of void * clutter the code.
These are the remainder casts after several specific
patches to remove netdev_priv and dev_priv.
Done via coccinelle script:
$ cat cast_void_pointer.cocci
type T;
T *pt;
void *pv;
- pt = (T *)pv;
+ pt = pv;
Acked-by: Paul Moore <paul.moore@hp.com>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
The %pK format specifier is designed to hide exposed kernel pointers,
specifically via /proc interfaces. Exposing these pointers provides an
easy target for kernel write vulnerabilities, since they reveal the
locations of writable structures containing easily triggerable function
pointers. The behavior of %pK depends on the kptr_restrict sysctl.
If kptr_restrict is set to 0, no deviation from the standard %p behavior
occurs. If kptr_restrict is set to 1, the default, if the current user
(intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG
(currently in the LSM tree), kernel pointers using %pK are printed as 0's.
If kptr_restrict is set to 2, kernel pointers using %pK are printed as
0's regardless of privileges. Replacing with 0's was chosen over the
default "(null)", which cannot be parsed by userland %p, which expects
"(nil)".
The supporting code for kptr_restrict and %pK are currently in the -mm
tree. This patch converts users of %p in net/ to %pK. Cases of printing
pointers to the syslog are not covered, since this would eliminate useful
information for postmortem debugging and the reading of the syslog is
already optionally protected by the dmesg_restrict sysctl.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
Cc: Thomas Graf <tgraf@infradead.org>
Cc: Eugene Teo <eugeneteo@kernel.org>
Cc: Kees Cook <kees.cook@canonical.com>
Cc: Eric Paris <eparis@parisplace.org>
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers
where possible, to make code intention more obvious.
If CONFIG_NET_KEY_MIGRATE is not defined the arguments of
pfkey_migrate stub do not match causing warning.
This actually pointed out a (seemingly known) bug where we mangle the
pfkey header in a potentially shared SKB, which is fixed here.
Change "return (EXPR);" to "return EXPR;"
return is not a function, parentheses are not required.
Put severity level on pfkey printk messages
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The original code saved the error value but just returned 0 in the end.
Acked-by: Jamal Hadi Salim <hadi@mojatatu.com>
pass mark to all SP lookups to prepare them for when we add code
to have them search.
Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca>
pass mark to all SA lookups to prepare them for when we add code
Get rid of custom locking that was using wait queue, lock, and atomic
to basically build a queued mutex. Use RCU for read side.
To see the effect make sure you have an empty SPD.
On window1 "ip xfrm mon" and on window2 issue "ip xfrm policy flush"
You get prompt back in window2 and you see the flush event on window1.
With this fix, you still get prompt on window1 but no event on window2.
Thanks to Alexey Dobriyan for finding a bug in earlier version
when using pfkey to do the flushing.
To see the effect make sure you have an empty SAD.
On window1 "ip xfrm mon" and on window2 issue "ip xfrm state flush"
RFC 2367 says flushing behavior should be:
1) user space -> kernel: flush
2) kernel: flush
3) kernel -> user space: flush event to ALL listeners
This is not realistic today in the presence of selinux policies
which may reject the flush etc. So we make the sequence become:
2) kernel: flush
3) kernel -> user space: flush response to originater from #1
4) if there were no errors then:
As reported by Alexey Dobriyan:
setkey now takes several seconds to run this simple script
and it spits "recv: Resource temporarily unavailable" messages.
#!/usr/sbin/setkey -f
flush;
spdflush;
add A B ipcomp 44 -m tunnel -C deflate;
add B A ipcomp 45 -m tunnel -C deflate;
spdadd A B any -P in ipsec
ipcomp/tunnel/192.168.1.2-192.168.1.3/use;
spdadd B A any -P out ipsec
ipcomp/tunnel/192.168.1.3-192.168.1.2/use;
Obviously applications want the events even when the table
is empty. So we cannot make this behavioral change.
Observed similar behavior on SPD as previouly seen on SAD flushing..
This fixes it.
cheers,
jamal
commit 428b20432dc31bc2e01a94cd451cf5a2c00d2bf4
Author: Jamal Hadi Salim <hadi@cyberus.ca>
Date: Thu Feb 11 05:49:38 2010 -0500
xfrm: Flushing empty SPD generates false events
You get prompt back in window1 and you see the flush event on window2.
-On window1 "ip xfrm mon"
-on window2 issue "ip xfrm state flush"
event on window2.
I was tempted to return -ESRCH on window1 (which would
show "RTNETLINK answers: No such process") but didnt want
to change current behavior.
cheers,
jamal
commit 5f3dd4a772326166e1bcf54acc2391df00dc7ab5
Date: Thu Feb 11 04:41:36 2010 -0500
xfrm: Flushing empty SAD generates false events
Simplify seq_file code.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
1. After sock_register() returns, it's possible to create sockets,
even if module still not initialized fully (blame generic module code
for that!)
2. Consequently, pfkey_create() can be called with pfkey_net_id still not
initialized which will BUG_ON in net_generic():
kernel BUG at include/net/netns/generic.h:43!
3. During netns shutdown, netns ops should be unregistered after
key manager unregistered because key manager calls can be triggered
from xfrm_user module:
general protection fault: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC
pfkey_broadcast+0x111/0x210 [af_key]
pfkey_send_notify+0x16a/0x300 [af_key]
km_state_notify+0x41/0x70
xfrm_flush_sa+0x75/0x90 [xfrm_user]
4. Unregister netns ops after socket ops just in case and for symmetry.
Reported by Luca Tettamanti.
Tested-by: Luca Tettamanti <kronos.it@gmail.com>
Use atomic_inc_return() in get_acqseq() to avoid taking a spinlock
__net_init/__net_exit are apparently not going away, so use them
to full extent.
In some cases __net_init was removed, because it was called from
__net_exit code.
Commit 4447bb33f09444920a8f1d89e1540137429351b6 ("xfrm: Store aalg in
xfrm_state with a user specified truncation length") breaks
installation of authentication algorithms via PF_KEY, as the state
specific truncation length is not installed with the algorithms
default truncation length. This patch initializes state properly to
the default if installed via PF_KEY.
Signed-off-by: Martin Willi <martin@strongswan.org>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Take advantage of the new pernet automatic storage management,
and stop using compatibility network namespace functions.
The generic __sock_create function has a kern argument which allows the
security system to make decisions based on if a socket is being created by
the kernel or by userspace. This patch passes that flag to the
net_proto_family specific create function, so it can do the same thing.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Create a new socket level option to report number of queue overflows
Recently I augmented the AF_PACKET protocol to report the number of frames lost
on the socket receive queue between any two enqueued frames. This value was
exported via a SOL_PACKET level cmsg. AFter I completed that work it was
requested that this feature be generalized so that any datagram oriented socket
could make use of this option. As such I've created this patch, It creates a
new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a
SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue
overflowed between any two given frames. It also augments the AF_PACKET
protocol to take advantage of this new feature (as it previously did not touch
sk->sk_drops, which this patch uses to record the overflow count). Tested
successfully by me.
Notes:
1) Unlike my previous patch, this patch simply records the sk_drops value, which
is not a number of drops between packets, but rather a total number of drops.
Deltas must be computed in user space.
2) While this patch currently works with datagram oriented protocols, it will
also be accepted by non-datagram oriented protocols. I'm not sure if thats
agreeable to everyone, but my argument in favor of doing so is that, for those
protocols which aren't applicable to this option, sk_drops will always be zero,
and reporting no drops on a receive queue that isn't used for those
non-participating protocols seems reasonable to me. This also saves us having
to code in a per-protocol opt in mechanism.
3) This applies cleanly to net-next assuming that commit
977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
All usages of structure net_proto_ops should be declared const.
All instances of file_operations should be const.
