A packet filter might be installed for instance with setsockopt
SO_ATTACH_FILTER. af_iucv currently queues skbs rejected by filter
into the backlog queue. This does not make sense, since packets
rejected by filter can be dropped immediately. This patch adds
separate sk_filter return code checking, and dropping of packets
if applicable.
Signed-off-by: Ursula Braun <ubraun@linux.vnet.ibm.com>
Reported-by: Daniel Borkmann <daniel@iogearbox.net>
If a socket program has shut down the socket for sending, it can still
receive an undetermined number of packets. The AF_IUCV protocol for
HIPER transport requires sending of a WIN flag from time to time
from the receiver to the sender, otherwise the peer cannot continue
sending. That means sending of control flags must still work, even
though the AF_IUCV socket is shutdown for sending data.
sock_alloc_send_skb() returns with error EPIPE, if socket sk_shutdown
is SEND_SHUTDOWN. Thus this patch temporarily removes the send
shutdown attribute from the socket to enable transfer of control
flags.
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- TPM core and driver updates/fixes
- IPv6 security labeling (CALIPSO)
- Lots of Apparmor fixes
- Seccomp: remove 2-phase API, close hole where ptrace can change
syscall #"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (156 commits)
apparmor: fix SECURITY_APPARMOR_HASH_DEFAULT parameter handling
tpm: Add TPM 2.0 support to the Nuvoton i2c driver (NPCT6xx family)
tpm: Factor out common startup code
tpm: use devm_add_action_or_reset
tpm2_i2c_nuvoton: add irq validity check
tpm: read burstcount from TPM_STS in one 32-bit transaction
tpm: fix byte-order for the value read by tpm2_get_tpm_pt
tpm_tis_core: convert max timeouts from msec to jiffies
apparmor: fix arg_size computation for when setprocattr is null terminated
apparmor: fix oops, validate buffer size in apparmor_setprocattr()
apparmor: do not expose kernel stack
apparmor: fix module parameters can be changed after policy is locked
apparmor: fix oops in profile_unpack() when policy_db is not present
apparmor: don't check for vmalloc_addr if kvzalloc() failed
apparmor: add missing id bounds check on dfa verification
apparmor: allow SYS_CAP_RESOURCE to be sufficient to prlimit another task
apparmor: use list_next_entry instead of list_entry_next
apparmor: fix refcount race when finding a child profile
apparmor: fix ref count leak when profile sha1 hash is read
apparmor: check that xindex is in trans_table bounds
Pull networking updates from David Miller:
1) Unified UDP encapsulation offload methods for drivers, from
Alexander Duyck.
2) Make DSA binding more sane, from Andrew Lunn.
3) Support QCA9888 chips in ath10k, from Anilkumar Kolli.
4) Several workqueue usage cleanups, from Bhaktipriya Shridhar.
5) Add XDP (eXpress Data Path), essentially running BPF programs on RX
packets as soon as the device sees them, with the option to mirror
the packet on TX via the same interface. From Brenden Blanco and
others.
6) Allow qdisc/class stats dumps to run lockless, from Eric Dumazet.
7) Add VLAN support to b53 and bcm_sf2, from Florian Fainelli.
8) Simplify netlink conntrack entry layout, from Florian Westphal.
9) Add ipv4 forwarding support to mlxsw spectrum driver, from Ido
Schimmel, Yotam Gigi, and Jiri Pirko.
10) Add SKB array infrastructure and convert tun and macvtap over to it.
From Michael S Tsirkin and Jason Wang.
11) Support qdisc packet injection in pktgen, from John Fastabend.
12) Add neighbour monitoring framework to TIPC, from Jon Paul Maloy.
13) Add NV congestion control support to TCP, from Lawrence Brakmo.
14) Add GSO support to SCTP, from Marcelo Ricardo Leitner.
15) Allow GRO and RPS to function on macsec devices, from Paolo Abeni.
16) Support MPLS over IPV4, from Simon Horman.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
xgene: Fix build warning with ACPI disabled.
be2net: perform temperature query in adapter regardless of its interface state
l2tp: Correctly return -EBADF from pppol2tp_getname.
net/mlx5_core/health: Remove deprecated create_singlethread_workqueue
net: ipmr/ip6mr: update lastuse on entry change
macsec: ensure rx_sa is set when validation is disabled
tipc: dump monitor attributes
tipc: add a function to get the bearer name
tipc: get monitor threshold for the cluster
tipc: make cluster size threshold for monitoring configurable
tipc: introduce constants for tipc address validation
net: neigh: disallow transition to NUD_STALE if lladdr is unchanged in neigh_update()
MAINTAINERS: xgene: Add driver and documentation path
Documentation: dtb: xgene: Add MDIO node
drivers: net: xgene: ethtool: Use phy_ethtool_gset and sset
drivers: net: xgene: Use exported functions
drivers: net: xgene: Enable MDIO driver
drivers: net: xgene: Add backward compatibility
drivers: net: phy: xgene: Add MDIO driver
Use only simple inline assemblies which consist of a single basic
block if the register asm construct is being used.
Otherwise gcc would generate broken code if the compiler option
--sanitize-coverage=trace-pc would be used.
When an inbound message is bigger than a page, allocate a paged SKB,
and subsequently use IUCV receive primitive with IPBUFLST flag.
This relaxes the pressure to allocate big contiguous kernel buffers.
Signed-off-by: Eugene Crosser <Eugene.Crosser@ru.ibm.com>
Before introducing paged skbs in the receive path, get rid of the
function `iucv_fragment_skb()` that replaces one large linear skb
with several smaller linear skbs.
When an outbound message is bigger than a page, allocate and fill
a paged SKB, and subsequently use IUCV send primitive with IPBUFLST
flag. This relaxes the pressure to allocate big contiguous kernel
buffers.
Much like we had to do for AF_BLUETOOTH and AF_ALG, make sure we
properly clone the parent socket's LSM attributes to newly created
child sockets.
Signed-off-by: Paul Moore <paul@paul-moore.com>
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Reviewed-by: Evgeny Cherkashin <Eugene.Crosser@ru.ibm.com>
When the linear buffer of the received sk_buff is shorter than
the header, use skb_linearize(). sk_buffs with short linear buffer
happen on the sending side under high traffic, and some kernel
configurations, when allocated buffer starts just before page
boundary, and IUCV transport has to send it as two separate QDIO
buffer elements, with fist element shorter than the header.
Initialize storage for the future IUCV header that will be included
in the transmitted packet. Some of the header fields are unused with
HiperSockets transport, and will contain data left from some other
functions.
Reviewed-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
drivers/net/ethernet/renesas/ravb_main.c
kernel/bpf/syscall.c
net/ipv4/ipmr.c
All three conflicts were cases of overlapping changes.
This patch is a cleanup to make following patch easier to
review.
Goal is to move SOCK_ASYNC_NOSPACE and SOCK_ASYNC_WAITDATA
from (struct socket)->flags to a (struct socket_wq)->flags
to benefit from RCU protection in sock_wake_async()
To ease backports, we rename both constants.
Two new helpers, sk_set_bit(int nr, struct sock *sk)
and sk_clear_bit(int net, struct sock *sk) are added so that
following patch can change their implementation.
The memory barrier in the helper wq_has_sleeper is needed by just
about every user of waitqueue_active. This patch generalises it
by making it take a wait_queue_head_t directly. The existing
helper is renamed to skwq_has_sleeper.
The iucv code uses arrays as arguments. Even though this does not
really cause a problem, it could be misleading, since the compiler
turns array arguments into just a pointer argument. To be more
precise this patch changes the array arguments into pointers.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
drivers/net/usb/asix_common.c
drivers/net/usb/sr9800.c
drivers/net/usb/usbnet.c
include/linux/usb/usbnet.h
net/ipv4/tcp_ipv4.c
net/ipv6/tcp_ipv6.c
The TCP conflicts were overlapping changes. In 'net' we added a
READ_ONCE() to the socket cached RX route read, whilst in 'net-next'
Eric Dumazet touched the surrounding code dealing with how mini
sockets are handled.
With USB, it's a case of the same bug fix first going into net-next
and then I cherry picked it back into net.
When sending over AF_IUCV socket, errno was incorrectly set to
ENOMEM even when other values where appropriate, notably EAGAIN.
With this patch, error indicator returned by sock_alloc_send_skb()
is passed to the caller, rather than being overwritten with ENOMEM.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Introduce helper macro for_each_cmsghdr as a wrapper of the enumerating
cmsghdr from msghdr, just cleanup.
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
Use the more common pr_warn.
Coalesce formats.
Realign arguments.
An af_iucv stress test showed -EPIPE results for sendmsg()
calls. They are caused by quiescing a path even though it has
been already severed by peer. For IUCV transport shutdown()
consists of 2 steps:
(1) sending the shutdown message to peer
(2) quiescing the iucv path
If the iucv path between these 2 steps is severed due to peer
closing the path, the quiesce step is no longer needed.
Signed-off-by: Frank Blaschka <blaschka@linux.vnet.ibm.com>
Reported-by: Philipp Hachtmann <phacht@linux.vnet.ibm.com>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
In case of transport HIPER a sock struct is allocated for an incoming
connect request. If the backlog queue is full this socket is not
needed, but is left in the list of af_iucv sockets. Final socket
release posts console message "Attempt to release alive iucv socket".
This patch makes sure the new created socket is cleaned up correctly
if the backlog queue is full.
If a socket is bound to an address using before calling connect
it is usual to leave it to the network system to choose an appropriate
outgoing application name respective port address.
af_iucv on VM uses a counter and uses simple numbers as unique identifiers.
This behaviour was missing when af_iucv is used with HiperSockets.
This patch contains a simple approach to harmonize af_iucv's behaviour.
Signed-off-by: Philipp Hachtmann <phacht@linux.vnet.ibm.com>
When sending data through IUCV a MESSAGE COMPLETE interrupt
signals that sent data memory can be freed or reused again.
With commit f9c41a62bba3f3f7ef3541b2a025e3371bcbba97
"af_iucv: fix recvmsg by replacing skb_pull() function" the
MESSAGE COMPLETE callback iucv_callback_txdone() identifies
the wrong skb as being confirmed, which leads to data corruption.
This patch fixes the skb mapping logic in iucv_callback_txdone().
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Cc: <stable@vger.kernel.org>
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull second set of s390 patches from Martin Schwidefsky:
"The second part of Heikos uaccess rework, the page table walker for
uaccess is now a thing of the past (yay!)
The code change to fix the theoretical TLB flush problem allows us to
add a TLB flush optimization for zEC12, this machine has new
instructions that allow to do CPU local TLB flushes for single pages
and for all pages of a specific address space.
Plus the usual bug fixing and some more cleanup"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/uaccess: rework uaccess code - fix locking issues
s390/mm,tlb: optimize TLB flushing for zEC12
s390/mm,tlb: safeguard against speculative TLB creation
s390/irq: Use defines for external interruption codes
s390/irq: Add defines for external interruption codes
s390/sclp: add timeout for queued requests
kvm/s390: also set guest pages back to stable on kexec/kdump
lcs: Add missing destroy_timer_on_stack()
s390/tape: Add missing destroy_timer_on_stack()
s390/tape: Use del_timer_sync()
s390/3270: fix crash with multiple reset device requests
s390/bitops,atomic: add missing memory barriers
s390/zcrypt: add length check for aligned data to avoid overflow in msg-type 6
Pull CPU hotplug notifiers registration fixes from Rafael Wysocki:
"The purpose of this single series of commits from Srivatsa S Bhat
(with a small piece from Gautham R Shenoy) touching multiple
subsystems that use CPU hotplug notifiers is to provide a way to
register them that will not lead to deadlocks with CPU online/offline
operations as described in the changelog of commit 93ae4f978ca7f ("CPU
hotplug: Provide lockless versions of callback registration
functions").
The first three commits in the series introduce the API and document
it and the rest simply goes through the users of CPU hotplug notifiers
and converts them to using the new method"
* tag 'cpu-hotplug-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (52 commits)
net/iucv/iucv.c: Fix CPU hotplug callback registration
net/core/flow.c: Fix CPU hotplug callback registration
mm, zswap: Fix CPU hotplug callback registration
mm, vmstat: Fix CPU hotplug callback registration
profile: Fix CPU hotplug callback registration
trace, ring-buffer: Fix CPU hotplug callback registration
xen, balloon: Fix CPU hotplug callback registration
hwmon, via-cputemp: Fix CPU hotplug callback registration
hwmon, coretemp: Fix CPU hotplug callback registration
thermal, x86-pkg-temp: Fix CPU hotplug callback registration
octeon, watchdog: Fix CPU hotplug callback registration
oprofile, nmi-timer: Fix CPU hotplug callback registration
intel-idle: Fix CPU hotplug callback registration
clocksource, dummy-timer: Fix CPU hotplug callback registration
drivers/base/topology.c: Fix CPU hotplug callback registration
acpi-cpufreq: Fix CPU hotplug callback registration
zsmalloc: Fix CPU hotplug callback registration
scsi, fcoe: Fix CPU hotplug callback registration
scsi, bnx2fc: Fix CPU hotplug callback registration
scsi, bnx2i: Fix CPU hotplug callback registration
Use the new defines for external interruption codes to get rid
of "magic" numbers in the s390 source code. And while we're at it,
also rename the (un-)register_external_interrupt function to
something shorter so that this patch does not exceed the 80
columns all over the place.
Signed-off-by: Thomas Huth <thuth@linux.vnet.ibm.com>
Subsystems that want to register CPU hotplug callbacks, as well as perform
initialization for the CPUs that are already online, often do it as shown
below:
get_online_cpus();
for_each_online_cpu(cpu)
init_cpu(cpu);
register_cpu_notifier(&foobar_cpu_notifier);
put_online_cpus();
This is wrong, since it is prone to ABBA deadlocks involving the
cpu_add_remove_lock and the cpu_hotplug.lock (when running concurrently
with CPU hotplug operations).
Instead, the correct and race-free way of performing the callback
registration is:
cpu_notifier_register_begin();
init_cpu(cpu);
/* Note the use of the double underscored version of the API */
__register_cpu_notifier(&foobar_cpu_notifier);
cpu_notifier_register_done();
Fix the code in net/iucv/iucv.c by using this latter form of callback
registration. Also, provide helper functions to perform the common memory
allocations and frees, to condense repetitive code.
Cc: Ursula Braun <ursula.braun@de.ibm.com>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Commit f9c41a62bba3f3f7ef3541b2a025e3371bcbba97 introduced
a problem for SOCK_STREAM sockets, when only part of the
incoming iucv message is received by user space. In this
case the remaining data of the iucv message is lost.
This patch makes sure an incompletely received iucv message
is queued back to the receive queue.
Reported-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the net/* uses of the __cpuinit macros
from all C files.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: netdev@vger.kernel.org
So far, only net_device * could be passed along with netdevice notifier
event. This patch provides a possibility to pass custom structure
able to provide info that event listener needs to know.
Signed-off-by: Jiri Pirko <jiri@resnulli.us>
v2->v3: fix typo on simeth
shortened dev_getter
shortened notifier_info struct name
v1->v2: fix notifier_call parameter in call_netdevice_notifier()
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
When receiving data messages, the "BUG_ON(skb->len < skb->data_len)" in
the skb_pull() function triggers a kernel panic.
Replace the skb_pull logic by a per skb offset as advised by
Eric Dumazet.
Reviewed-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
drivers/nfc/microread/mei.c
net/netfilter/nfnetlink_queue_core.c
Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which
some cleanups are going to go on-top.
The current code does not fill the msg_name member in case it is set.
It also does not set the msg_namelen member to 0 and therefore makes
net/socket.c leak the local, uninitialized sockaddr_storage variable
to userland -- 128 bytes of kernel stack memory.
Fix that by simply setting msg_namelen to 0 as obviously nobody cared
about iucv_sock_recvmsg() not filling the msg_name in case it was set.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Commit 7d4c04fc170087119727119074e72445f2bb192b ("net: add option to enable
error queue packets waking select") has an issue due to operator precedence
causing the bit-wise OR to bind to the sock_flags call instead of the result of
the terniary conditional. This fixes the *_poll functions to work properly. The
old code results in "mask |= POLLPRI" instead of what was intended, which is to
only include POLLPRI when the socket option is enabled.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Currently, when a socket receives something on the error queue it only wakes up
the socket on select if it is in the "read" list, that is the socket has
something to read. It is useful also to wake the socket if it is in the error
list, which would enable software to wait on error queue packets without waking
up for regular data on the socket. The main use case is for receiving
timestamped transmit packets which return the timestamp to the socket via the
error queue. This enables an application to select on the socket for the error
queue only instead of for the regular traffic.
-v2-
* Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file
* Modified every socket poll function that checks error queue
Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Matthew Vick <matthew.vick@intel.com>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
The iucv base layer is initialized during the registration of the
first iucv handler. If no handler is registered and the
iucv_reboot_event() notifier is called, a missing check can cause
a kernel panic in iucv_block_cpu(). To solve this issue, check the
IRQ masks invoke iucv_block_cpu() for enabled CPUs only.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Now that irq sum accounting for /proc/stat's "intr" line works again we
have the oddity that the sum field (first field) contains only the sum
of the second (external irqs) and third field (I/O interrupts).
The reason for that is that these two fields are already sums of all other
fields. So if we would sum up everything we would count every interrupt
twice.
This is broken since the split interrupt accounting was merged two years
ago: 052ff461c8427629aee887ccc27478fc7373237c "[S390] irq: have detailed
statistics for interrupt types".
To fix this remove the split interrupt fields from /proc/stat's "intr"
line again and only have them in /proc/interrupts.
This restores the old behaviour, seems to be the only sane fix and mimics
a behaviour from other architectures where /proc/interrupts also contains
more than /proc/stat's "intr" line does.
Orphaning skb in dev_hard_start_xmit() makes bonding behavior
unfriendly for applications sending big UDP bursts : Once packets
pass the bonding device and come to real device, they might hit a full
qdisc and be dropped. Without orphaning, the sender is automatically
throttled because sk->sk_wmemalloc reaches sk->sk_sndbuf (assuming
sk_sndbuf is not too big)
We could try to defer the orphaning adding another test in
dev_hard_start_xmit(), but all this seems of little gain,
now that BQL tends to make packets more likely to be parked
in Qdisc queues instead of NIC TX ring, in cases where performance
matters.
Reverts commits :
fc6055a5ba31 net: Introduce skb_orphan_try()
87fd308cfc6b net: skb_tx_hash() fix relative to skb_orphan_try()
and removes SKBTX_DRV_NEEDS_SK_REF flag
Reported-and-bisected-by: Jean-Michel Hautbois <jhautbois@gmail.com>
Tested-by: Oliver Hartkopp <socketcan@hartkopp.net>
Acked-by: Oliver Hartkopp <socketcan@hartkopp.net>
Pull s390 patches from Martin Schwidefsky:
"The biggest patch is the rework of the smp code, something I wanted to
do for some time. There are some patches for our various dump methods
and one new thing: z/VM LGR detection. LGR stands for linux-guest-
relocation and is the guest migration feature of z/VM. For debugging
purposes we keep a log of the systems where a specific guest has lived."
Fix up trivial conflict in arch/s390/kernel/smp.c due to the scheduler
cleanup having removed some code next to removed s390 code.
[S390] kernel: Pass correct stack for smp_call_ipl_cpu()
[S390] Ensure that vmcore_info pointer is never accessed directly
[S390] dasd: prevent validate server for offline devices
[S390] Remove monolithic build option for zcrypt driver.
[S390] stack dump: fix indentation in output
[S390] kernel: Add OS info memory interface
[S390] Use block_sigmask()
[S390] kernel: Add z/VM LGR detection
[S390] irq: external interrupt code passing
[S390] irq: set __ARCH_IRQ_EXIT_IRQS_DISABLED
[S390] zfcpdump: Implement async sdias event processing
[S390] Use copy_to_absolute_zero() instead of "stura/sturg"
[S390] rework idle code
[S390] rework smp code
[S390] rename lowcore field
[S390] Fix gcc 4.6.0 compile warning
The external interrupt handlers have a parameter called ext_int_code.
Besides the name this paramter does not only contain the ext_int_code
but in addition also the "cpu address" (POP) which caused the external
interrupt.
To make the code a bit more obvious pass a struct instead so the called
function can easily distinguish between external interrupt code and
cpu address. The cpu address field however is named "subcode" since
some external interrupt sources do not pass a cpu address but a
different parameter (or none at all).
