Now genl_register_family() is the only thing (other than the
users themselves, perhaps, but I didn't find any doing that)
writing to the family struct.
In all families that I found, genl_register_family() is only
called from __init functions (some indirectly, in which case
I've add __init annotations to clarifly things), so all can
actually be marked __ro_after_init.
This protects the data structure from accidental corruption.
Instead of providing macros/inline functions to initialize
the families, make all users initialize them statically and
get rid of the macros.
This reduces the kernel code size by about 1.6k on x86-64
(with allyesconfig).
Static family IDs have never really been used, the only
use case was the workaround I introduced for those users
that assumed their family ID was also their multicast
group ID.
Additionally, because static family IDs would never be
reserved by the generic netlink code, using a relatively
low ID would only work for built-in families that can be
registered immediately after generic netlink is started,
which is basically only the control family (apart from
the workaround code, which I also had to add code for so
it would reserve those IDs)
Thus, anything other than GENL_ID_GENERATE is flawed and
luckily not used except in the cases I mentioned. Move
those workarounds into a few lines of code, and then get
rid of GENL_ID_GENERATE entirely, making it more robust.
These few drivers call ether_setup(), but have no ndo_change_mtu, and thus
were overlooked for changes to MTU range checking behavior. They
previously had no range checks, so for feature-parity, set their min_mtu
to 0 and max_mtu to ETH_MAX_MTU (65535), instead of the 68 and 1500
inherited from the ether_setup() changes. Fine-tuning can come after we get
back to full feature-parity here.
CC: netdev@vger.kernel.org
Reported-by: Asbjoern Sloth Toennesen <asbjorn@asbjorn.st>
CC: Asbjoern Sloth Toennesen <asbjorn@asbjorn.st>
CC: R Parameswaran <parameswaran.r7@gmail.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
With centralized MTU checking, there's nothing productive done by
eth_change_mtu that isn't already done in dev_set_mtu, so mark it as
deprecated and remove all usage of it in the kernel. All callers have been
audited for calls to alloc_etherdev* or ether_setup directly, which means
they all have a valid dev->min_mtu and dev->max_mtu. Now eth_change_mtu
prints out a netdev_warn about being deprecated, for the benefit of
out-of-tree drivers that might be utilizing it.
Of note, dvb_net.c actually had dev->mtu = 4096, while using
eth_change_mtu, meaning that if you ever tried changing it's mtu, you
couldn't set it above 1500 anymore. It's now getting dev->max_mtu also set
to 4096 to remedy that.
v2: fix up lantiq_etop, missed breakage due to drive not compiling on x86
skb is not freed if newsk is NULL. Rework the error path so free_skb is
unconditionally called on function exit.
Fixes: c3ea9fa27413 ("[IrDA] af_irda: IRDA_ASSERT cleanups")
Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com>
We've already set sk to sock->sk and dereferenced it, so if it's NULL
we would have crashed already. Moreover, if it was NULL we would have
crashed anyway when jumping to 'out' and trying to unlock the sock.
Furthermore, if we had assigned a different value to 'sk' we would
have been calling lock_sock() and release_sock() on different sockets.
My conclusion is that these two lines are complete nonsense and only
serve to confuse the reader.
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
If iriap_register_lsap() fails to allocate memory, self->lsap is
set to NULL. However, none of the callers handle the failure and
irlmp_connect_request() will happily dereference it:
iriap_register_lsap: Unable to allocated LSAP!
UBSAN: Undefined behaviour in net/irda/irlmp.c:378:2
member access within null pointer of type 'struct lsap_cb'
CPU: 1 PID: 15403 Comm: trinity-c0 Not tainted 4.8.0-rc1+ #81
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org
04/01/2014
0000000000000000 ffff88010c7e78a8 ffffffff82344f40 0000000041b58ab3
ffffffff84f98000 ffffffff82344e94 ffff88010c7e78d0 ffff88010c7e7880
ffff88010630ad00 ffffffff84a5fae0 ffffffff84d3f5c0 000000000000017a
Call Trace:
[<ffffffff82344f40>] dump_stack+0xac/0xfc
[<ffffffff8242f5a8>] ubsan_epilogue+0xd/0x8a
[<ffffffff824302bf>] __ubsan_handle_type_mismatch+0x157/0x411
[<ffffffff83b7bdbc>] irlmp_connect_request+0x7ac/0x970
[<ffffffff83b77cc0>] iriap_connect_request+0xa0/0x160
[<ffffffff83b77f48>] state_s_disconnect+0x88/0xd0
[<ffffffff83b78904>] iriap_do_client_event+0x94/0x120
[<ffffffff83b77710>] iriap_getvaluebyclass_request+0x3e0/0x6d0
[<ffffffff83ba6ebb>] irda_find_lsap_sel+0x1eb/0x630
[<ffffffff83ba90c8>] irda_connect+0x828/0x12d0
[<ffffffff833c0dfb>] SYSC_connect+0x22b/0x340
[<ffffffff833c7e09>] SyS_connect+0x9/0x10
[<ffffffff81007bd3>] do_syscall_64+0x1b3/0x4b0
[<ffffffff845f946a>] entry_SYSCALL64_slow_path+0x25/0x25
The bug seems to have been around since forever.
There's more problems with missing error checks in iriap_init() (and
indeed all of irda_init()), but that's a bigger problem that needs
very careful review and testing. This patch will fix the most serious
bug (as it's easily reached from unprivileged userspace).
I have tested my patch with a reproducer.
Pull networking updates from David Miller:
1) Unified UDP encapsulation offload methods for drivers, from
Alexander Duyck.
2) Make DSA binding more sane, from Andrew Lunn.
3) Support QCA9888 chips in ath10k, from Anilkumar Kolli.
4) Several workqueue usage cleanups, from Bhaktipriya Shridhar.
5) Add XDP (eXpress Data Path), essentially running BPF programs on RX
packets as soon as the device sees them, with the option to mirror
the packet on TX via the same interface. From Brenden Blanco and
others.
6) Allow qdisc/class stats dumps to run lockless, from Eric Dumazet.
7) Add VLAN support to b53 and bcm_sf2, from Florian Fainelli.
8) Simplify netlink conntrack entry layout, from Florian Westphal.
9) Add ipv4 forwarding support to mlxsw spectrum driver, from Ido
Schimmel, Yotam Gigi, and Jiri Pirko.
10) Add SKB array infrastructure and convert tun and macvtap over to it.
From Michael S Tsirkin and Jason Wang.
11) Support qdisc packet injection in pktgen, from John Fastabend.
12) Add neighbour monitoring framework to TIPC, from Jon Paul Maloy.
13) Add NV congestion control support to TCP, from Lawrence Brakmo.
14) Add GSO support to SCTP, from Marcelo Ricardo Leitner.
15) Allow GRO and RPS to function on macsec devices, from Paolo Abeni.
16) Support MPLS over IPV4, from Simon Horman.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
xgene: Fix build warning with ACPI disabled.
be2net: perform temperature query in adapter regardless of its interface state
l2tp: Correctly return -EBADF from pppol2tp_getname.
net/mlx5_core/health: Remove deprecated create_singlethread_workqueue
net: ipmr/ip6mr: update lastuse on entry change
macsec: ensure rx_sa is set when validation is disabled
tipc: dump monitor attributes
tipc: add a function to get the bearer name
tipc: get monitor threshold for the cluster
tipc: make cluster size threshold for monitoring configurable
tipc: introduce constants for tipc address validation
net: neigh: disallow transition to NUD_STALE if lladdr is unchanged in neigh_update()
MAINTAINERS: xgene: Add driver and documentation path
Documentation: dtb: xgene: Add MDIO node
drivers: net: xgene: ethtool: Use phy_ethtool_gset and sset
drivers: net: xgene: Use exported functions
drivers: net: xgene: Enable MDIO driver
drivers: net: xgene: Add backward compatibility
drivers: net: phy: xgene: Add MDIO driver
I ran into this:
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 2 PID: 2012 Comm: trinity-c3 Not tainted 4.7.0-rc7+ #19
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
task: ffff8800b745f2c0 ti: ffff880111740000 task.ti: ffff880111740000
RIP: 0010:[<ffffffff82bbf066>] [<ffffffff82bbf066>] irttp_connect_request+0x36/0x710
RSP: 0018:ffff880111747bb8 EFLAGS: 00010286
RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 0000000069dd8358
RDX: 0000000000000009 RSI: 0000000000000027 RDI: 0000000000000048
RBP: ffff880111747c00 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000069dd8358 R11: 1ffffffff0759723 R12: 0000000000000000
R13: ffff88011a7e4780 R14: 0000000000000027 R15: 0000000000000000
FS: 00007fc738404700(0000) GS:ffff88011af00000(0000) knlGS:0000000000000000
CR2: 00007fc737fdfb10 CR3: 0000000118087000 CR4: 00000000000006e0
Stack:
0000000000000200 ffff880111747bd8 ffffffff810ee611 ffff880119f1f220
ffff880119f1f4f8 ffff880119f1f4f0 ffff88011a7e4780 ffff880119f1f232
ffff880119f1f220 ffff880111747d58 ffffffff82bca542 0000000000000000
Call Trace:
[<ffffffff82bca542>] irda_connect+0x562/0x1190
[<ffffffff825ae582>] SYSC_connect+0x202/0x2a0
[<ffffffff825b4489>] SyS_connect+0x9/0x10
[<ffffffff8100334c>] do_syscall_64+0x19c/0x410
[<ffffffff83295ca5>] entry_SYSCALL64_slow_path+0x25/0x25
Code: 41 89 ca 48 89 e5 41 57 41 56 41 55 41 54 41 89 d7 53 48 89 fb 48 83 c7 48 48 89 fa 41 89 f6 48 c1 ea 03 48 83 ec 20 4c 8b 65 10 <0f> b6 04 02 84 c0 74 08 84 c0 0f 8e 4c 04 00 00 80 7b 48 00 74
RIP [<ffffffff82bbf066>] irttp_connect_request+0x36/0x710
RSP <ffff880111747bb8>
---[ end trace 4cda2588bc055b30 ]---
The problem is that irda_open_tsap() can fail and leave self->tsap = NULL,
and then irttp_connect_request() almost immediately dereferences it.
Cc: stable@vger.kernel.org
In ircomm_tty_get_serial_info, struct serial_struct is memset to 0 and
then some members set to 0 explicitly.
Remove the latter as it is obviously superfluous.
And remove the retinfo check against NULL. copy_to_user will take care
of that.
Part of hub6 cleanup series.
Cc: Samuel Ortiz <samuel@sortiz.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty and serial driver updates from Greg KH:
"Here's the large TTY and Serial driver update for 4.7-rc1.
A few new serial drivers are added here, and Peter has fixed a bunch
of long-standing bugs in the tty layer and serial drivers as normal.
Full details in the shortlog.
All of these have been in linux-next for a while with no reported
issues"
* tag 'tty-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (88 commits)
MAINTAINERS: 8250: remove website reference
serial: core: Fix port mutex assert if lockdep disabled
serial: 8250_dw: fix wrong logic in dw8250_check_lcr()
tty: vt, finish looping on duplicate
tty: vt, return error when con_startup fails
QE-UART: add "fsl,t1040-ucc-uart" to of_device_id
serial: mctrl_gpio: Drop support for out1-gpios and out2-gpios
serial: 8250dw: Add device HID for future AMD UART controller
Fix OpenSSH pty regression on close
serial: mctrl_gpio: add IRQ locking
serial: 8250: Integrate Fintek into 8250_base
serial: mps2-uart: add support for early console
serial: mps2-uart: add MPS2 UART driver
dt-bindings: document the MPS2 UART bindings
serial: sirf: Use generic uart-has-rtscts DT property
serial: sirf: Introduce helper variable struct device_node *np
serial: mxs-auart: Use generic uart-has-rtscts DT property
serial: imx: Use generic uart-has-rtscts DT property
doc: DT: Add Generic Serial Device Tree Bindings
serial: 8250: of: Make tegra_serial_handle_break() static
Replace all trans_start updates with netif_trans_update helper.
change was done via spatch:
struct net_device *d;
- d->trans_start = jiffies
+ netif_trans_update(d)
Compile tested only.
Cc: user-mode-linux-devel@lists.sourceforge.net
Cc: linux-xtensa@linux-xtensa.org
Cc: linux1394-devel@lists.sourceforge.net
Cc: linux-rdma@vger.kernel.org
Cc: netdev@vger.kernel.org
Cc: MPT-FusionLinux.pdl@broadcom.com
Cc: linux-scsi@vger.kernel.org
Cc: linux-can@vger.kernel.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-omap@vger.kernel.org
Cc: linux-hams@vger.kernel.org
Cc: linux-usb@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: linux-s390@vger.kernel.org
Cc: devel@driverdev.osuosl.org
Cc: b.a.t.m.a.n@lists.open-mesh.org
Cc: linux-bluetooth@vger.kernel.org
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
Acked-by: Antonio Quartulli <a@unstable.cc>
Replace ASYNC_INITIALIZED bit in the tty_port::flags field with
TTY_PORT_INITIALIZED bit in the tty_port::iflags field. Introduce helpers
tty_port_set_initialized() and tty_port_initialized() to abstract
atomic bit ops.
Note: the transforms for test_and_set_bit() and test_and_clear_bit()
are unnecessary as the state transitions are already mutually exclusive;
the tty lock prevents concurrent open/close/hangup.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Replace ASYNC_CHECK_CD bit in the tty_port::flags field with
TTY_PORT_CHECK_CD bit in the tty_port::iflags field. Introduce helpers
tty_port_set_check_carrier() and tty_port_check_carrier() to abstract
the atomic bit ops.
Replace ASYNC_NORMAL_ACTIVE bit in the tty_port::flags field with
TTY_PORT_ACTIVE bit in the tty_port::iflags field. Introduce helpers
tty_port_set_active() and tty_port_active() to abstract atomic bit ops.
Extract state changes from port lock sections, as this usage is
broken and confused; the state transitions are protected by the
tty lock (which mutually excludes parallel open/close/hangup),
and no user tests the active state while holding the port lock.
Replace ASYNC_CTS_FLOW bit in the tty_port::flags field with
TTY_PORT_CTS_FLOW bit in the tty_port::iflags field. Add
tty_port_set_cts_flow() helper to abstract the atomic bit ops.
Abstract TTY_THROTTLED bit tests with tty_throttled().
Abstract TTY_IO_ERROR status test treewide with tty_io_error().
NB: tty->flags uses atomic bit ops; replace non-atomic bit test
with test_bit().
We want the fixes in here, and this resolves a merge error in tty_io.c
self->ctrl_skb is protected by self->spinlock, we should not
access it out of the lock. Move the debugging printk inside.
The tty core no longer provides nor uses ASYNC_CLOSING; remove from
tty_port_close_start() and tty_port_close_end() as well as tty drivers
which open-code these state changes. Unfortunately, even though the
bit is masked from userspace, its inclusion in a uapi header precludes
removing the macro.
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: linux-cris-kernel@axis.com
Expressions of the form "tty->termios.c_*flag & FLAG"
are more clearly expressed with the termios flags macros,
I_FLAG(), C_FLAG(), O_FLAG(), and L_FLAG().
Convert treewide.
Acked-by: Johan Hovold <johan@kernel.org>
郭永刚 reported that one could simply crash the kernel as root by
using a simple program:
int socket_fd;
struct sockaddr_in addr;
addr.sin_port = 0;
addr.sin_addr.s_addr = INADDR_ANY;
addr.sin_family = 10;
socket_fd = socket(10,3,0x40000000);
connect(socket_fd , &addr,16);
AF_INET, AF_INET6 sockets actually only support 8-bit protocol
identifiers. inet_sock's skc_protocol field thus is sized accordingly,
thus larger protocol identifiers simply cut off the higher bits and
store a zero in the protocol fields.
This could lead to e.g. NULL function pointer because as a result of
the cut off inet_num is zero and we call down to inet_autobind, which
is NULL for raw sockets.
kernel: Call Trace:
kernel: [<ffffffff816db90e>] ? inet_autobind+0x2e/0x70
kernel: [<ffffffff816db9a4>] inet_dgram_connect+0x54/0x80
kernel: [<ffffffff81645069>] SYSC_connect+0xd9/0x110
kernel: [<ffffffff810ac51b>] ? ptrace_notify+0x5b/0x80
kernel: [<ffffffff810236d8>] ? syscall_trace_enter_phase2+0x108/0x200
kernel: [<ffffffff81645e0e>] SyS_connect+0xe/0x10
kernel: [<ffffffff81779515>] tracesys_phase2+0x84/0x89
I found no particular commit which introduced this problem.
CVE: CVE-2015-8543
Cc: Cong Wang <cwang@twopensource.com>
Reported-by: 郭永刚 <guoyonggang@360.cn>
Pull tty/serial driver updates from Greg KH:
"Here is the big tty and serial driver update for 4.4-rc1.
Lots of serial driver updates and a few small tty core changes. Full
All of these have been in linux-next for a while"
* tag 'tty-4.4-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (148 commits)
tty: Use unbound workqueue for all input workers
tty: Abstract tty buffer work
tty: Prevent tty teardown during tty_write_message()
tty: core: Use correct spinlock flavor in tiocspgrp()
tty: Combine SIGTTOU/SIGTTIN handling
serial: amba-pl011: fix incorrect integer size in pl011_fifo_to_tty()
ttyFDC: Fix build problems due to use of module_{init,exit}
tty: remove unneeded return statement
serial: 8250_mid: add support for DMA engine handling from UART MMIO
dmaengine: hsu: remove platform data
dmaengine: hsu: introduce stubs for the exported functions
dmaengine: hsu: make the UART driver in control of selecting this driver
serial: fix mctrl helper functions
serial: 8250_pci: Intel MID UART support to its own driver
serial: fsl_lpuart: add earlycon support
tty: disable unbind for old 74xx based serial/mpsc console port
serial: pl011: Spelling s/clocks-names/clock-names/
n_tty: Remove reader wakeups for TTY_BREAK/TTY_PARITY chars
tty: synclink, fix indentation
serial: at91, fix rs485 properties
"irlmp_unregister_service"
The irlmp_unregister_service() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
This is decrementing the pointer, instead of the value stored in the
pointer. KASan detects it as an out of bounds reference.
Reported-by: "Berry Cheng 程君(成淼)" <chengmiao.cj@alibaba-inc.com>
Since at least before 2.6.30, tty drivers that do not drop the tty lock
while closing cannot observe ASYNC_CLOSING set while holding the
tty lock; this includes the tty driver's open() and hangup() methods,
since the tty core calls these methods holding the tty lock.
For these drivers, waiting for ASYNC_CLOSING to clear while opening
is not required, since this condition cannot occur. Similarly, even
when the open() method drops and reacquires the tty lock after
blocking, ASYNC_CLOSING cannot be set (again, for drivers that
do not drop the tty lock while closing).
Now that tty port drivers no longer drop the tty lock while closing
(since 'tty: Remove tty_wait_until_sent_from_close()'), the same
conditions apply: waiting for ASYNC_CLOSING to clear while opening
is not required, nor is re-checking ASYNC_CLOSING after dropping and
reacquiring the tty lock while blocking (eg., in *_block_til_ready()).
Note: The ASYNC_CLOSING flag state is still maintained since several
bitrotting drivers use it for (dubious) other purposes.
API compliance scanning with coccinelle flagged:
./net/irda/timer.c:63:35-37: use of msecs_to_jiffies probably perferable
Converting milliseconds to jiffies by "val * HZ / 1000" technically
is not a clean solution as it does not handle all corner cases correctly.
By changing the conversion to use msecs_to_jiffies(val) conversion is
correct in all cases. Further the () around the arithmetic expression
was dropped.
Patch was compile tested for x86_64_defconfig + CONFIG_IRDA=m
Patch is against 4.1-rc4 (localversion-next is -next-20150522)
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
drivers/net/ethernet/cadence/macb.c
Overlapping changes in macb driver, mostly fixes and cleanups
in 'net' overlapping with the integration of at91_ether into
macb in 'net-next'.
Pull tty/serial fixes from Greg KH:
"Here are some tty and serial driver fixes for 4.0-rc3.
Along with the atime fix that you know about, here are some other
serial driver bugfixes as well. Most notable is a wait_until_sent
bugfix that was traced back to being around since before 2.6.12 that
Johan has fixed up.
All have been in linux-next successfully"
* tag 'tty-4.0-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
TTY: fix tty_wait_until_sent maximum timeout
TTY: fix tty_wait_until_sent on 64-bit machines
USB: serial: fix infinite wait_until_sent timeout
TTY: bfin_jtag_comm: remove incorrect wait_until_sent operation
net: irda: fix wait_until_sent poll timeout
serial: uapi: Declare all userspace-visible io types
serial: core: Fix iotype userspace breakage
serial: sprd: Fix missing spin_unlock in sprd_handle_irq()
console: Fix console name size mismatch
tty: fix up atime/mtime mess, take four
serial: 8250_dw: Fix get_mctrl behaviour
serial:8250:8250_pci: delete unneeded quirk entries
serial:8250:8250_pci: fix redundant entry report for WCH_CH352_2S
Change email address for 8250_pci
serial: 8250: Revert "tty: serial: 8250_core: read only RX if there is something in the FIFO"
Revert "tty/serial: of_serial: add DT alias ID handling"
In case an infinite timeout (0) is requested, the irda wait_until_sent
implementation would use a zero poll timeout rather than the default
200ms.
Note that wait_until_sent is currently never called with a 0-timeout
argument due to a bug in tty_wait_until_sent.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: stable <stable@vger.kernel.org> # v2.6.12
Signed-off-by: Johan Hovold <johan@kernel.org>
drivers/net/ethernet/rocker/rocker.c
The rocker commit was two overlapping changes, one to rename
the ->vport member to ->pport, and another making the bitmask
expression use '1ULL' instead of plain '1'.
After TIPC doesn't depend on iocb argument in its internal
implementations of sendmsg() and recvmsg() hooks defined in proto
structure, no any user is using iocb argument in them at all now.
Then we can drop the redundant iocb argument completely from kinds of
implementations of both sendmsg() and recvmsg() in the entire
networking stack.
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Use helper functions to access current->state.
Direct assignments are prone to races and therefore buggy.
current->state = TASK_RUNNING can be replaced by __set_current_state()
Thanks to Peter Zijlstra for the exact definition of the problem.
Suggested-By: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Fabian Frederick <fabf@skynet.be>
This is only an API consolidation and should make things more readable
it replaces var * HZ / 1000 constructs by msecs_to_jiffies(var).
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
Making things const is a good thing.
(x86-64 defconfig with all irda)
$ size net/irda/built-in.o*
109276 1868 244 111388 1b31c net/irda/built-in.o.new
108828 2316 244 111388 1b31c net/irda/built-in.o.old
drivers/net/ethernet/chelsio/cxgb4vf/sge.c
drivers/net/ethernet/intel/ixgbe/ixgbe_phy.c
sge.c was overlapping two changes, one to use the new
__dev_alloc_page() in net-next, and one to use s->fl_pg_order in net.
ixgbe_phy.c was a set of overlapping whitespace changes.
Fix the build failures that result from the use of pr_debug
without the referenced char * arrays being defined.
Use the normal kernel debugging mechanism which also
enables dynamic_debug at the same time.
Other miscellanea:
o Remove sysctl for irda_debug
o Remove function tracing like uses (use ftrace instead)
o Coalesce formats
o Realign arguments
o Remove unnecessary OOM messages
And use the more common mechanisms directly.
Other miscellanea:
o Coalesce formats
o Add missing newlines
o Realign arguments
o Remove unnecessary OOM message logging as
there's a generic stack dump already on OOM.
This encapsulates all of the skb_copy_datagram_iovec() callers
with call argument signature "skb, offset, msghdr->msg_iov, length".
When we move to iov_iters in the networking, the iov_iter object will
sit in the msghdr.
Having a helper like this means there will be less places to touch
during that transformation.
Based upon descriptions and patch from Al Viro.
The sk_prot is irda's own set of protocol handlers, so irda should
statically know what that function is anyway, without using an indirect
pointer. And as it happens, we know *exactly* what that pointer is
statically: it's NULL, because irda doesn't define a disconnect
operation.
So calling that function is doubly wrong, and will just cause an oops.
Reported-by: Martin Lang <mlg.hessigheim@gmail.com>
irlan_open is only called by __init irlan_init in same module.
Signed-off-by: Maks Naumov <maksqwe1@ukr.net>
"Highlights:
1) Steady transitioning of the BPF instructure to a generic spot so
all kernel subsystems can make use of it, from Alexei Starovoitov.
2) SFC driver supports busy polling, from Alexandre Rames.
3) Take advantage of hash table in UDP multicast delivery, from David
Held.
4) Lighten locking, in particular by getting rid of the LRU lists, in
inet frag handling. From Florian Westphal.
5) Add support for various RFC6458 control messages in SCTP, from
Geir Ola Vaagland.
6) Allow to filter bridge forwarding database dumps by device, from
Jamal Hadi Salim.
7) virtio-net also now supports busy polling, from Jason Wang.
8) Some low level optimization tweaks in pktgen from Jesper Dangaard
Brouer.
9) Add support for ipv6 address generation modes, so that userland
can have some input into the process. From Jiri Pirko.
10) Consolidate common TCP connection request code in ipv4 and ipv6,
from Octavian Purdila.
11) New ARP packet logger in netfilter, from Pablo Neira Ayuso.
12) Generic resizable RCU hash table, with intial users in netlink and
nftables. From Thomas Graf.
13) Maintain a name assignment type so that userspace can see where a
network device name came from (enumerated by kernel, assigned
explicitly by userspace, etc.) From Tom Gundersen.
14) Automatic flow label generation on transmit in ipv6, from Tom
Herbert.
15) New packet timestamping facilities from Willem de Bruijn, meant to
assist in measuring latencies going into/out-of the packet
scheduler, latency from TCP data transmission to ACK, etc"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1536 commits)
cxgb4 : Disable recursive mailbox commands when enabling vi
net: reduce USB network driver config options.
tg3: Modify tg3_tso_bug() to handle multiple TX rings
amd-xgbe: Perform phy connect/disconnect at dev open/stop
amd-xgbe: Use dma_set_mask_and_coherent to set DMA mask
net: sun4i-emac: fix memory leak on bad packet
sctp: fix possible seqlock seadlock in sctp_packet_transmit()
Revert "net: phy: Set the driver when registering an MDIO bus device"
cxgb4vf: Turn off SGE RX/TX Callback Timers and interrupts in PCI shutdown routine
team: Simplify return path of team_newlink
bridge: Update outdated comment on promiscuous mode
net-timestamp: ACK timestamp for bytestreams
net-timestamp: TCP timestamping
net-timestamp: SCHED timestamp on entering packet scheduler
net-timestamp: add key to disambiguate concurrent datagrams
net-timestamp: move timestamp flags out of sk_flags
net-timestamp: extend SCM_TIMESTAMPING ancillary data struct
cxgb4i : Move stray CPL definitions to cxgb4 driver
tcp: reduce spurious retransmits due to transient SACK reneging
qlcnic: Initialize dcbnl_ops before register_netdev
