path: root/net/irda/irlap_event.c
2008-01-28[IrDA]: Frame length validation.Robie Basak
When using a stir4200-based USB adaptor to talk to a device that uses an mcp2150, the stir4200 sometimes drops an incoming frame causing the mcp2150 to try and retransmit the lost frame. In this combination, the next frame received from the mcp2150 is often invalid - either an empty i:rsp or an IrCOMM i:rsp with an invalid clen. These corner cases are now checked. Signed-off-by: Robie Basak <rb-oss-1@justgohome.co.uk> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IrDA]: Resend frames on timeout.Robie Basak
When final timer expires, it might also mean that the i:cmd wasn't received properly. If we have rejected frames, we can try to resend them. Signed-off-by: Robie Basak <rb-oss-1@justgohome.co.uk> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-06-08[IrDA]: f-timer reloading when sending rejected frames.G. Liakhovetski
Jean II was right: you have to re-charge the final timer when resending rejected frames. Otherwise it triggers at a wrong time and can break the currently running communication. Reproducible under rt-preempt. Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-08[IrDA]: Fix Rx/Tx path race.G. Liakhovetski
From: G. Liakhovetski <gl@dsa-ac.de> We need to switch to NRM _before_ sending the final packet otherwise we might hit a race condition where we get the first packet from the peer while we're still in LAP_XMIT_P. Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[IrDA]: Misc spelling corrections.G. Liakhovetski
Spelling corrections, from "to" to "too". Signed-off-by: G. Liakhovetski <gl@dsa-ac.de> Signed-off-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IRDA: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
