git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nf-next
Pablo Neira Ayuso says:
The following batch contains:
* Three fixes for the new synproxy target available in your
net-next tree, from Jesper D. Brouer and Patrick McHardy.
* One fix for TCPMSS to correctly handling the fragmentation
case, from Phil Oester. I'll pass this one to -stable.
Packets reaching SYNPROXY were default dropped, as they were most
likely invalid (given the recommended state matching). This
patch, changes SYNPROXY target to let packets, not consumed,
continue being processed by the stack.
This will be more in line other target modules. As it will allow
more flexible configurations of handling, logging or matching on
packets in INVALID states.
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Patrick McHardy <kaber@trash.net>
Its seems Patrick missed to incoorporate some of my requested changes
during review v2 of SYNPROXY netfilter module.
Which were, to avoid SYN+ACK packets to enter the path, meant for the
ACK packet from the client (from the 3WHS).
Further there were a bug in ip6t_SYNPROXY.c, for matching SYN packets
that didn't exclude the ACK flag.
Go a step further with SYN packet/flag matching by excluding flags
ACK+FIN+RST, in both IPv4 and IPv6 modules.
The intented usage of SYNPROXY is as follows:
(gracefully describing usage in commit)
iptables -t raw -A PREROUTING -i eth0 -p tcp --dport 80 --syn -j NOTRACK
iptables -A INPUT -i eth0 -p tcp --dport 80 -m state UNTRACKED,INVALID \
-j SYNPROXY --sack-perm --timestamp --mss 1480 --wscale 7 --ecn
echo 0 > /proc/sys/net/netfilter/nf_conntrack_tcp_loose
This does filter SYN flags early, for packets in the UNTRACKED state,
but packets in the INVALID state with other TCP flags could still
reach the module, thus this stricter flag matching is still needed.
tcp_rcv_established() returns only one value namely 0. We change the return
value to void (as suggested by David Miller).
After commit 0c24604b (tcp: implement RFC 5961 4.2), we no longer send RSTs in
response to SYNs. We can remove the check and processing on the return value of
tcp_rcv_established().
We also fix jtcp_rcv_established() in tcp_probe.c to match that of
Signed-off-by: Vijay Subramanian <subramanian.vijay@gmail.com>
The goal of this patch is to harmonize cleanup done on a skbuff on rx path.
Before this patch, behaviors were different depending of the tunnel type.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
The goal of this patch is to harmonize cleanup done on a skbuff on xmit path.
This function was only used when a packet was sent to another netns. Now, it can
also be used after tunnel encapsulation or decapsulation.
Only skb_orphan() should not be done when a packet is not crossing netns.
This argument is not used, let's remove it.
This config option is superfluous in that it only guards a call
to neigh_app_ns(). Enabling CONFIG_ARPD by default has no
change in behavior. There will now be call to __neigh_notify()
for each ARP resolution, which has no impact unless there is a
user space daemon waiting to receive the notification, i.e.,
the case for which CONFIG_ARPD was designed anyways.
Suggested-by: Eric W. Biederman <ebiederm@xmission.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Gao feng <gaofeng@cn.fujitsu.com>
Cc: Joe Perches <joe@perches.com>
Cc: Veaceslav Falico <vfalico@redhat.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
As suggested by Pravin, we can unify the code in case of duplicated
code.
Cc: Pravin Shelar <pshelar@nicira.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Similar to commit 731362674580cb0c696cd1b1a03d8461a10cf90a
(tunneling: Add generic Tunnel segmentation)
This patch adds generic tunneling offloading support for
IPv6-UDP based tunnels.
This can be used by tunneling protocols like VXLAN.
Cc: Jesse Gross <jesse@nicira.com>
Cc: Pravin B Shelar <pshelar@nicira.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
This patch adds the IPv6 version of "arp_reduce", ndisc_send_na()
will be needed.
Cc: David Stevens <dlstevens@us.ibm.com>
in6_dev_put() will be needed by vxlan module, so is
in6_dev_finish_destroy().
route short circuit only has IPv4 part, this patch adds
the IPv6 part. nd_tbl will be needed.
Because vxlan module will call ip6_dst_lookup() in TX path,
which will hold write lock. So we have to release this write lock
before calling ndisc_send_rs(), otherwise could deadlock.
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
It is needed by vxlan module. Noticed by Mike.
Cc: Mike Rapoport <mike.rapoport@ravellosystems.com>
In case IPv6 is compiled as a module, introduce a stub
for ipv6_sock_mc_join and ipv6_sock_mc_drop etc.. It will be used
by vxlan module. Suggested by Ben.
This is an ugly but easy solution for now.
Cc: Ben Hutchings <bhutchings@solarflare.com>
It will be used the vxlan kernel module.
It will be used by vxlan, and may not be inlined.
A sk variable initialized to ndisc_sk is already available outside
of the branch.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
This patch implements RFC6980: Drop fragmented ndisc packets by
default. If a fragmented ndisc packet is received the user is informed
that it is possible to disable the check.
Cc: Fernando Gont <fernando@gont.com.ar>
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Add an IPv6 version of the SYNPROXY target. The main differences to the
IPv4 version is routing and IP header construction.
Tested-by: Martin Topholm <mph@one.com>
Extract the local TCP stack independant parts of tcp_v6_init_sequence()
and cookie_v6_check() and export them for use by the upcoming IPv6 SYNPROXY
target.
Split out sequence number adjustments from NAT and move them to the conntrack
core to make them usable for SYN proxying. The sequence number adjustment
information is moved to a seperate extend. The extend is added to new
conntracks when a NAT mapping is set up for a connection using a helper.
As a side effect, this saves 24 bytes per connection with NAT in the common
case that a connection does not have a helper assigned.
'nf_defrag_ipv6' is built as a separate module; it shouldn't be
included in the 'nf_conntrack_ipv6' module as well.
Signed-off-by: Nathan Hintz <nlhintz@hotmail.com>
As reported by Casper Gripenberg, in a bridged setup, using ip[6]t_REJECT
with the tcp-reset option sends out reset packets with the src MAC address
of the local bridge interface, instead of the MAC address of the intended
destination. This causes some routers/firewalls to drop the reset packet
as it appears to be spoofed. Fix this by bypassing ip[6]_local_out and
setting the MAC of the sender in the tcp reset packet.
This closes netfilter bugzilla #531.
Signed-off-by: Phil Oester <kernel@linuxace.com>
drivers/net/wireless/iwlwifi/pcie/trans.c
include/linux/inetdevice.h
The inetdevice.h conflict involves moving the IPV4_DEVCONF values
into a UAPI header, overlapping additions of some new entries.
The iwlwifi conflict is a context overlap.
rfc 4861 says the Redirected Header option is optional, so
the kernel should not drop the Redirect Message that has no
Redirected Header option. In this patch, the function
ip6_redirect_no_header() is introduced to deal with that
condition.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Instead of hard-coding length values, use a define to make it clear
where those lengths come from.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
For the functions mld_gq_start_timer(), mld_ifc_start_timer(),
and mld_dad_start_timer(), rather use unsigned long than int
as we operate only on unsigned values anyway. This seems more
appropriate as there is no good reason to do type conversions
to int, that could lead to future errors.
Use proper API functions to calculate jiffies from milliseconds and
not the crude method of dividing HZ by a value. This ensures more
accurate values even in the case of strange HZ values. While at it,
also simplify code in the mlh2 case by using max().
When an Xin6 tunnel is set up, we check other netdevices to inherit the link-
local address. If none is available, the interface will not have any link-local
address. RFC4862 expects that each interface has a link local address.
Now than this kind of tunnels supports x-netns, it's easy to fall in this case
(by creating the tunnel in a netns where ethernet interfaces stand and then
moving it to a other netns where no ethernet interface is available).
RFC4291, Appendix A suggests two methods: the first is the one currently
implemented, the second is to generate a unique identifier, so that we can
always generate the link-local address. Let's use eth_random_addr() to generate
this interface indentifier.
I remove completly the previous method, hence for the whole life of the
interface, the link-local address remains the same (previously, it depends on
which ethernet interfaces were up when the tunnel interface was set up).
This reverts commit df8372ca747f6da9e8590775721d9363c1dfc87e.
These changes are buggy and make unintended semantic changes
to ip6_tnl_add_linklocal().
ERROR: code indent should use tabs where possible: fix 2.
ERROR: do not use assignment in if condition: fix 5.
Signed-off-by: Ding Tianhong <dingtianhong@huawei.com>
Just follow the Joe Perches's opinion, it is a better way to fix the
style errors.
Suggested-by: Joe Perches <joe@perches.com>
net/netfilter/nf_conntrack_proto_tcp.c
The conflict had to do with overlapping changes dealing with
fixing the use of an "s32" to hold the value returned by
NAT_OFFSET().
The following batch contains Netfilter/IPVS updates for your net-next tree.
More specifically, they are:
* Trivial typo fix in xt_addrtype, from Phil Oester.
* Remove net_ratelimit in the conntrack logging for consistency with other
logging subsystem, from Patrick McHardy.
* Remove unneeded includes from the recently added xt_connlabel support, from
Florian Westphal.
* Allow to update conntracks via nfqueue, don't need NFQA_CFG_F_CONNTRACK for
this, from Florian Westphal.
* Remove tproxy core, now that we have socket early demux, from Florian
Westphal.
* A couple of patches to refactor conntrack event reporting to save a good
bunch of lines, from Florian Westphal.
* Fix missing locking in NAT sequence adjustment, it did not manifested in
any known bug so far, from Patrick McHardy.
* Change sequence number adjustment variable to 32 bits, to delay the
possible early overflow in long standing connections, also from Patrick.
* Comestic cleanups for IPVS, from Dragos Foianu.
* Fix possible null dereference in IPVS in the SH scheduler, from Daniel
Borkmann.
* Allow to attach conntrack expectations via nfqueue. Before this patch, you
had to use ctnetlink instead, thus, we save the conntrack lookup.
* Export xt_rpfilter and xt_HMARK header files, from Nicolas Dichtel.
It is not allowed for an ipv6 packet to contain multiple fragmentation
headers. So discard packets which were already reassembled by
fragmentation logic and send back a parameter problem icmp.
The updates for RFC 6980 will come in later, I have to do a bit more
research here.
Because of the max_addresses check attackers were able to disable privacy
extensions on an interface by creating enough autoconfigured addresses:
<http://seclists.org/oss-sec/2012/q4/292>
But the check is not actually needed: max_addresses protects the
kernel to install too many ipv6 addresses on an interface and guards
addrconf_prefix_rcv to install further addresses as soon as this limit
is reached. We only generate temporary addresses in direct response of
a new address showing up. As soon as we filled up the maximum number of
addresses of an interface, we stop installing more addresses and thus
also stop generating more temp addresses.
Even if the attacker tries to generate a lot of temporary addresses
by announcing a prefix and removing it again (lifetime == 0) we won't
install more temp addresses, because the temporary addresses do count
to the maximum number of addresses, thus we would stop installing new
autoconfigured addresses when the limit is reached.
This patch fixes CVE-2013-0343 (but other layer-2 attacks are still
possible).
Thanks to Ding Tianhong to bring this topic up again.
Cc: Ding Tianhong <dingtianhong@huawei.com>
Cc: George Kargiotakis <kargig@void.gr>
Cc: P J P <ppandit@redhat.com>
Acked-by: Ding Tianhong <dingtianhong@huawei.com>
UIDs are printed in the proc_fs as signed int, whereas
they are unsigned int.
Signed-off-by: Francesco Fusco <ffusco@redhat.com>
This patch allows to switch the netns when packet is encapsulated or
decapsulated. In other word, the encapsulated packet is received in a netns,
where the lookup is done to find the tunnel. Once the tunnel is found, the
packet is decapsulated and injecting into the corresponding interface which
stands to another netns.
When one of the two netns is removed, the tunnel is destroyed.
It's better to use available helpers for these tests.
Commit cab70040dfd95ee32144f02fade64f0cb94f31a0 ("net: igmp:
Reduce Unsolicited report interval to 1s when using IGMPv3") and
2690048c01f32bf45d1c1e1ab3079bc10ad2aea7 ("net: igmp: Allow user-space
configuration of igmp unsolicited report interval") by William Manley made
igmp unsolicited report intervals configurable per interface and corrected
the interval of unsolicited igmpv3 report messages resendings to 1s.
Same needs to be done for IPv6:
MLDv1 (RFC2710 7.10.): 10 seconds
MLDv2 (RFC3810 9.11.): 1 second
Both intervals are configurable via new procfs knobs
mldv1_unsolicited_report_interval and mldv2_unsolicited_report_interval.
(also added .force_mld_version to ipv6_devconf_dflt to bring structs in
line without semantic changes)
v2:
a) Joined documentation update for IPv4 and IPv6 MLD/IGMP
unsolicited_report_interval procfs knobs.
b) incorporate stylistic feedback from William Manley
v3:
a) add new DEVCONF_* values to the end of the enum (thanks to David
Miller)
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: William Manley <william.manley@youview.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Let nf_ct_delete handle delivery of the DESTROY event.
Based on earlier patch from Pablo Neira.
With GRO/LRO processing, there is a problem because Ip[6]InReceives SNMP
counters do not count the number of frames, but number of aggregated
segments.
Its probably too late to change this now.
This patch adds four new counters, tracking number of frames, regardless
of LRO/GRO, and on a per ECN status basis, for IPv4 and IPv6.
Ip[6]NoECTPkts : Number of packets received with NOECT
Ip[6]ECT1Pkts : Number of packets received with ECT(1)
Ip[6]ECT0Pkts : Number of packets received with ECT(0)
Ip[6]CEPkts : Number of packets received with Congestion Experienced
lph37:~# nstat | egrep "Pkts|InReceive"
IpInReceives 1634137 0.0
Ip6InReceives 3714107 0.0
Ip6InNoECTPkts 19205 0.0
Ip6InECT0Pkts 52651828 0.0
IpExtInNoECTPkts 33630 0.0
IpExtInECT0Pkts 15581379 0.0
IpExtInCEPkts 6 0.0
In case a subtree did not match we currently stop backtracking and return
NULL (root table from fib_lookup). This could yield in invalid routing
table lookups when using subtrees.
Instead continue to backtrack until a valid subtree or node is found
and return this match.
Also remove unneeded NULL check.
Reported-by: Teco Boot <teco@inf-net.nl>
Cc: David Lamparter <equinox@diac24.net>
Cc: <boutier@pps.univ-paris-diderot.fr>
Commit 91657eafb ("xfrm: take net hdr len into account for esp payload
size calculation") introduced a possible interger overflow in
esp{4,6}_get_mtu() handlers in case of x->props.mode equals
XFRM_MODE_TUNNEL. Thus, the following expression will overflow
unsigned int net_adj;
<case ipv{4,6} XFRM_MODE_TUNNEL>
net_adj = 0;
return ((mtu - x->props.header_len - crypto_aead_authsize(esp->aead) -
net_adj) & ~(align - 1)) + (net_adj - 2);
where (net_adj - 2) would be evaluated as <foo> + (0 - 2) in an unsigned
context. Fix it by simply removing brackets as those operations here
do not need to have special precedence.
Cc: Benjamin Poirier <bpoirier@suse.de>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Acked-by: Benjamin Poirier <bpoirier@suse.de>
Merge net into net-next to setup some infrastructure Eric
Dumazet needs for usbnet changes.
This change brings the suppressor attribute names into line; it also changes
the data types to provide a more consistent interface.
While -1 indicates that the suppressor is not enabled, values >= 0 for
suppress_prefixlen or suppress_ifgroup reject routing decisions violating the
constraint.
This changes the previously presented behaviour of suppress_prefixlen, where a
prefix length _less_ than the attribute value was rejected. After this change,
a prefix length less than *or* equal to the value is considered a violation of
the rule constraint.
It also changes the default values for default and newly added rules (disabling
any suppression for those).
Signed-off-by: Stefan Tomanek <stefan.tomanek@wertarbyte.de>
This change adds the ability to suppress a routing decision based upon the
interface group the selected interface belongs to. This allows it to
exclude specific devices from a routing decision.
