Now the skb->nh union has just one member, .raw, i.e. it is just like the
skb->mac union, strange, no? I'm just leaving it like that till the transport
layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or
->mac_header_offset?), ditto for ->{h,nh}.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
For the places where we need a pointer to the network header, it is still legal
to touch skb->nh.raw directly if just adding to, subtracting from or setting it
to another layer header.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
This patch changes xfrm6_tunnel register and deregister
interface to prepare for solving the conflict of device
tunnels with inter address family IPsec tunnel.
There is no device which conflicts with IPv4 over IPv6
IPsec tunnel.
Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org>
seq argument is net-endian
XFRM_STATE_WILDRECV flag is introduced; the last resort state is set
it and receives packet which is not route optimized but uses such
extension headers i.e. Mobile IPv6 signaling (binding update and
acknowledgement). A node enabled Mobile IPv6 adds the state.
Based on MIPL2 kernel patch.
Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
Transformation mode is used as either IPsec transport or tunnel.
It is required to add two more items, route optimization and inbound trigger
for Mobile IPv6.
This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi>
This patch adds the structure xfrm_mode. It is meant to represent
the operations carried out by transport/tunnel modes.
By doing this we allow additional encapsulation modes to be added
without clogging up the xfrm_input/xfrm_output paths.
Candidate modes include 4-to-6 tunnel mode, 6-to-4 tunnel mode, and
BEET modes.
This patch removes the *_decap_state structures which were previously
used to share state between input/post_input. This is no longer
needed.
This patch removes the decap_state argument from the xfrm input hook.
Previously this function allowed the input hook to share state with
the post_input hook. The latter has since been removed.
The only purpose for it now is to check the encap type. However, it
is easier and better to move the encap type check to the generic
xfrm_rcv function. This allows us to get rid of the decap state
argument altogether.
Basically this patch moves the generic tunnel protocol stuff out of
xfrm4_tunnel/xfrm6_tunnel and moves it into the new files of tunnel4.c
and tunnel6 respectively.
The reason for this is that the problem that Hugo uncovered is only
the tip of the iceberg. The real problem is that when we removed the
dependency of ipip on xfrm4_tunnel we didn't really consider the module
case at all.
For instance, as it is it's possible to build both ipip and xfrm4_tunnel
as modules and if the latter is loaded then ipip simply won't load.
After considering the alternatives I've decided that the best way out of
this is to restore the dependency of ipip on the non-xfrm-specific part
of xfrm4_tunnel. This is acceptable IMHO because the intention of the
removal was really to be able to use ipip without the xfrm subsystem.
This is still preserved by this patch.
So now both ipip/xfrm4_tunnel depend on the new tunnel4.c which handles
the arbitration between the two. The order of processing is determined
by a simple integer which ensures that ipip gets processed before
xfrm4_tunnel.
The situation for ICMP handling is a little bit more complicated since
we may not have enough information to determine who it's for. It's not
a big deal at the moment since the xfrm ICMP handlers are basically
no-ops. In future we can deal with this when we look at ICMP caching
in general.
The user-visible change to this is the removal of the TUNNEL Kconfig
prompts. This makes sense because it can only be used through IPCOMP
as it stands.
The addition of the new modules shouldn't introduce any problems since
module dependency will cause them to be loaded.
Oh and I also turned some unnecessary pskb's in IPv6 related to this
patch to skb's.
When the innermost transform uses transport mode the decapsulated packet
is not visible to netfilter. Pass the packet through the PRE_ROUTING and
LOCAL_IN hooks again before handing it to upper layer protocols to make
netfilter-visibility symetrical to the output path.
Move nextheader offset to the IP6CB to make it possible to pass a
packet to ip6_input_finish multiple times and have it skip already
parsed headers. As a nice side effect this gets rid of the manual
hopopts skipping in ip6_input_finish.
infrastructure for it.
Let it rip!
