path: root/net/ipv6/udp_impl.h
2008-03-22[UDP]: Make full use of proto.h.udp_hash innovation.Pavel Emelyanov
After this we have only udp_lib_get_port to get the port and two stubs for ipv4 and ipv6. No difference in udp and udplite except for initialized h.udp_hash member. I tried to find a graceful way to drop the only difference between udp_v4_get_port and udp_v6_get_port (i.e. the rcv_saddr comparison routine), but adding one more callback on the struct proto didn't appear such :( Maybe later. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6] UDPLITE: Sparse: Declare non-static symbols in header.YOSHIFUJI Hideaki
Fix the following sparse warnings: | net/ipv6/udplite.c:45:14: warning: symbol 'udplitev6_prot' was not declared. Should it be static? | net/ipv6/udplite.c:80:12: warning: symbol 'udplitev6_init' was not declared. Should it be static? | net/ipv6/udplite.c:99:6: warning: symbol 'udplitev6_exit' was not declared. Should it be static? Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-10-15[IPV6]: Replace sk_buff ** with sk_buff * in input handlersHerbert Xu
With all the users of the double pointers removed from the IPv6 input path, this patch converts all occurances of sk_buff ** to sk_buff * in IPv6 input handlers. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-07[UDP]: Revert 2-pass hashing changes.David S. Miller
This reverts changesets: 6aaf47fa48d3c44280810b1b470261d340e4ed87 b7b5f487ab39bc10ed0694af35651a03d9cb97ff de34ed91c4ffa4727964a832c46e624dd1495cf5 fc038410b4b1643766f8033f4940bcdb1dace633 There are still some correctness issues recently discovered which do not have a known fix that doesn't involve doing a full hash table scan on port bind. So revert for now. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10[UDP]: Fix AF-specific references in AF-agnostic code.David S. Miller
__udp_lib_port_inuse() cannot make direct references to inet_sk(sk)->rcv_saddr as that is ipv4 specific state and this code is used by ipv6 too. Use an operations vector to solve this, and this also paves the way for ipv6 support for non-wild saddr hashing in UDP. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
