Currently, the SMC experimental TCP option in a SYN packet is lost on
the server side when SYN Cookies are active. However, the corresponding
SYNACK sent back to the client contains the SMC option. This causes an
inconsistent view of the SMC capabilities on the client and server.
This patch disables the SMC option in the SYNACK when SYN Cookies are
active to avoid this issue.
Fixes: 60e2a7780793b ("tcp: TCP experimental option for SMC")
Signed-off-by: Hans Wippel <hwippel@linux.vnet.ibm.com>
Signed-off-by: Ursula Braun <ubraun@linux.vnet.ibm.com>
KMSAN reported use of uninitialized memory in skb_set_hash_from_sk(),
which originated from the TCP request socket created in
cookie_v6_check():
BUG: KMSAN: use of uninitialized memory in tcp_transmit_skb+0xf77/0x3ec0
CPU: 1 PID: 2949 Comm: syz-execprog Not tainted 4.11.0-rc5+ #2931
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
TCP: request_sock_TCPv6: Possible SYN flooding on port 20028. Sending cookies. Check SNMP counters.
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x172/0x1c0 lib/dump_stack.c:52
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:927
__msan_warning_32+0x61/0xb0 mm/kmsan/kmsan_instr.c:469
skb_set_hash_from_sk ./include/net/sock.h:2011
tcp_transmit_skb+0xf77/0x3ec0 net/ipv4/tcp_output.c:983
tcp_send_ack+0x75b/0x830 net/ipv4/tcp_output.c:3493
tcp_delack_timer_handler+0x9a6/0xb90 net/ipv4/tcp_timer.c:284
tcp_delack_timer+0x1b0/0x310 net/ipv4/tcp_timer.c:309
call_timer_fn+0x240/0x520 kernel/time/timer.c:1268
expire_timers kernel/time/timer.c:1307
__run_timers+0xc13/0xf10 kernel/time/timer.c:1601
run_timer_softirq+0x36/0xa0 kernel/time/timer.c:1614
__do_softirq+0x485/0x942 kernel/softirq.c:284
invoke_softirq kernel/softirq.c:364
irq_exit+0x1fa/0x230 kernel/softirq.c:405
exiting_irq+0xe/0x10 ./arch/x86/include/asm/apic.h:657
smp_apic_timer_interrupt+0x5a/0x80 arch/x86/kernel/apic/apic.c:966
apic_timer_interrupt+0x86/0x90 arch/x86/entry/entry_64.S:489
RIP: 0010:native_restore_fl ./arch/x86/include/asm/irqflags.h:36
RIP: 0010:arch_local_irq_restore ./arch/x86/include/asm/irqflags.h:77
RIP: 0010:__msan_poison_alloca+0xed/0x120 mm/kmsan/kmsan_instr.c:440
RSP: 0018:ffff880024917cd8 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff10
RAX: 0000000000000246 RBX: ffff8800224c0000 RCX: 0000000000000005
RDX: 0000000000000004 RSI: ffff880000000000 RDI: ffffea0000b6d770
RBP: ffff880024917d58 R08: 0000000000000dd8 R09: 0000000000000004
R10: 0000160000000000 R11: 0000000000000000 R12: ffffffff85abf810
R13: ffff880024917dd8 R14: 0000000000000010 R15: ffffffff81cabde4
</IRQ>
poll_select_copy_remaining+0xac/0x6b0 fs/select.c:293
SYSC_select+0x4b4/0x4e0 fs/select.c:653
SyS_select+0x76/0xa0 fs/select.c:634
entry_SYSCALL_64_fastpath+0x13/0x94 arch/x86/entry/entry_64.S:204
RIP: 0033:0x4597e7
RSP: 002b:000000c420037ee0 EFLAGS: 00000246 ORIG_RAX: 0000000000000017
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00000000004597e7
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
RBP: 000000c420037ef0 R08: 000000c420037ee0 R09: 0000000000000059
R10: 0000000000000000 R11: 0000000000000246 R12: 000000000042dc20
R13: 00000000000000f3 R14: 0000000000000030 R15: 0000000000000003
chained origin:
save_stack_trace+0x37/0x40 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:302
kmsan_save_stack mm/kmsan/kmsan.c:317
kmsan_internal_chain_origin+0x12a/0x1f0 mm/kmsan/kmsan.c:547
__msan_store_shadow_origin_4+0xac/0x110 mm/kmsan/kmsan_instr.c:259
tcp_create_openreq_child+0x709/0x1ae0 net/ipv4/tcp_minisocks.c:472
tcp_v6_syn_recv_sock+0x7eb/0x2a30 net/ipv6/tcp_ipv6.c:1103
tcp_get_cookie_sock+0x136/0x5f0 net/ipv4/syncookies.c:212
cookie_v6_check+0x17a9/0x1b50 net/ipv6/syncookies.c:245
tcp_v6_cookie_check net/ipv6/tcp_ipv6.c:989
tcp_v6_do_rcv+0xdd8/0x1c60 net/ipv6/tcp_ipv6.c:1298
tcp_v6_rcv+0x41a3/0x4f00 net/ipv6/tcp_ipv6.c:1487
ip6_input_finish+0x82f/0x1ee0 net/ipv6/ip6_input.c:279
NF_HOOK ./include/linux/netfilter.h:257
ip6_input+0x239/0x290 net/ipv6/ip6_input.c:322
dst_input ./include/net/dst.h:492
ip6_rcv_finish net/ipv6/ip6_input.c:69
ipv6_rcv+0x1dbd/0x22e0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x2f6f/0x3a20 net/core/dev.c:4208
__netif_receive_skb net/core/dev.c:4246
process_backlog+0x667/0xba0 net/core/dev.c:4866
napi_poll net/core/dev.c:5268
net_rx_action+0xc95/0x1590 net/core/dev.c:5333
origin:
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:198
kmsan_kmalloc+0x7f/0xe0 mm/kmsan/kmsan.c:337
kmem_cache_alloc+0x1c2/0x1e0 mm/slub.c:2766
reqsk_alloc ./include/net/request_sock.h:87
inet_reqsk_alloc+0xa4/0x5b0 net/ipv4/tcp_input.c:6200
cookie_v6_check+0x4f4/0x1b50 net/ipv6/syncookies.c:169
Similar error is reported for cookie_v4_check().
Fixes: 58d607d3e52f ("tcp: provide skb->hash to synack packets")
Signed-off-by: Alexander Potapenko <glider@google.com>
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
We want to move some TCP sysctls to net namespaces in the future.
tcp_window_scaling, tcp_sack and tcp_timestamps being fetched
from tcp_parse_options(), we need to pass an extra parameter.
TCP Timestamps option is defined in RFC 7323
Traditionally on linux, it has been tied to the internal
'jiffies' variable, because it had been a cheap and good enough
generator.
For TCP flows on the Internet, 1 ms resolution would be much better
than 4ms or 10ms (HZ=250 or HZ=100 respectively)
For TCP flows in the DC, Google has used usec resolution for more
than two years with great success [1]
Receive size autotuning (DRS) is indeed more precise and converges
faster to optimal window size.
This patch converts tp->tcp_mstamp to a plain u64 value storing
a 1 usec TCP clock.
This choice will allow us to upstream the 1 usec TS option as
discussed in IETF 97.
[1] https://www.ietf.org/proceedings/97/slides/slides-97-tcpm-tcp-options-for-low-latency-00.pdf
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
Whole point of randomization was to hide server uptime, but an attacker
can simply start a syn flood and TCP generates 'old style' timestamps,
directly revealing server jiffies value.
Also, TSval sent by the server to a particular remote address vary
depending on syncookies being sent or not, potentially triggering PAWS
drops for innocent clients.
Lets implement proper randomization, including for SYNcookies.
Also we do not need to export sysctl_tcp_timestamps, since it is not
used from a module.
In v2, I added Florian feedback and contribution, adding tsoff to
tcp_get_cookie_sock().
v3 removed one unused variable in tcp_v4_connect() as Florian spotted.
Fixes: 95a22caee396c ("tcp: randomize tcp timestamp offsets for each connection")
Reviewed-by: Florian Westphal <fw@strlen.de>
Tested-by: Florian Westphal <fw@strlen.de>
Cc: Yuchung Cheng <ycheng@google.com>
SHA1 is slower and less secure than SipHash, and so replacing syncookie
generation with SipHash makes natural sense. Some BSDs have been doing
this for several years in fact.
The speedup should be similar -- and even more impressive -- to the
speedup from the sequence number fix in this series.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
jiffies based timestamps allow for easy inference of number of devices
behind NAT translators and also makes tracking of hosts simpler.
commit ceaa1fef65a7c2e ("tcp: adding a per-socket timestamp offset")
added the main infrastructure that is needed for per-connection ts
randomization, in particular writing/reading the on-wire tcp header
format takes the offset into account so rest of stack can use normal
tcp_time_stamp (jiffies).
So only two items are left:
- add a tsoffset for request sockets
- extend the tcp isn generator to also return another 32bit number
in addition to the ISN.
Re-use of ISN generator also means timestamps are still monotonically
increasing for same connection quadruple, i.e. PAWS will still work.
Includes fixes from Eric Dumazet.
Acked-by: Yuchung Cheng <ycheng@google.com>
- Use the UID in routing lookups made by protocol connect() and
sendmsg() functions.
- Make sure that routing lookups triggered by incoming packets
(e.g., Path MTU discovery) take the UID of the socket into
account.
- For packets not associated with a userspace socket, (e.g., ping
replies) use UID 0 inside the user namespace corresponding to
the network namespace the socket belongs to. This allows
all namespaces to apply routing and iptables rules to
kernel-originated traffic in that namespaces by matching UID 0.
This is better than using the UID of the kernel socket that is
sending the traffic, because the UID of kernel sockets created
at namespace creation time (e.g., the per-processor ICMP and
TCP sockets) is the UID of the user that created the socket,
which might not be mapped in the namespace.
Tested: compiles allnoconfig, allyesconfig, allmodconfig
Tested: https://android-review.googlesource.com/253302
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Rename NET_INC_STATS_BH() to __NET_INC_STATS()
and NET_ADD_STATS_BH() to __NET_ADD_STATS()
Pull networking updates from David Miller:
"Highlights:
1) Support more Realtek wireless chips, from Jes Sorenson.
2) New BPF types for per-cpu hash and arrap maps, from Alexei
Starovoitov.
3) Make several TCP sysctls per-namespace, from Nikolay Borisov.
4) Allow the use of SO_REUSEPORT in order to do per-thread processing
of incoming TCP/UDP connections. The muxing can be done using a
BPF program which hashes the incoming packet. From Craig Gallek.
5) Add a multiplexer for TCP streams, to provide a messaged based
interface. BPF programs can be used to determine the message
boundaries. From Tom Herbert.
6) Add 802.1AE MACSEC support, from Sabrina Dubroca.
7) Avoid factorial complexity when taking down an inetdev interface
with lots of configured addresses. We were doing things like
traversing the entire address less for each address removed, and
flushing the entire netfilter conntrack table for every address as
well.
8) Add and use SKB bulk free infrastructure, from Jesper Brouer.
9) Allow offloading u32 classifiers to hardware, and implement for
ixgbe, from John Fastabend.
10) Allow configuring IRQ coalescing parameters on a per-queue basis,
from Kan Liang.
11) Extend ethtool so that larger link mode masks can be supported.
From David Decotigny.
12) Introduce devlink, which can be used to configure port link types
(ethernet vs Infiniband, etc.), port splitting, and switch device
level attributes as a whole. From Jiri Pirko.
13) Hardware offload support for flower classifiers, from Amir Vadai.
14) Add "Local Checksum Offload". Basically, for a tunneled packet
the checksum of the outer header is 'constant' (because with the
checksum field filled into the inner protocol header, the payload
of the outer frame checksums to 'zero'), and we can take advantage
of that in various ways. From Edward Cree"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits)
bonding: fix bond_get_stats()
net: bcmgenet: fix dma api length mismatch
net/mlx4_core: Fix backward compatibility on VFs
phy: mdio-thunder: Fix some Kconfig typos
lan78xx: add ndo_get_stats64
lan78xx: handle statistics counter rollover
RDS: TCP: Remove unused constant
RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket
net: smc911x: convert pxa dma to dmaengine
team: remove duplicate set of flag IFF_MULTICAST
bonding: remove duplicate set of flag IFF_MULTICAST
net: fix a comment typo
ethernet: micrel: fix some error codes
ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it
bpf, dst: add and use dst_tclassid helper
bpf: make skb->tc_classid also readable
net: mvneta: bm: clarify dependencies
cls_bpf: reset class and reuse major in da
ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c
ldmvsw: Add ldmvsw.c driver code
$ make tags
GEN tags
ctags: Warning: drivers/acpi/processor_idle.c:64: null expansion of name pattern "\1"
ctags: Warning: drivers/xen/events/events_2l.c:41: null expansion of name pattern "\1"
ctags: Warning: kernel/locking/lockdep.c:151: null expansion of name pattern "\1"
ctags: Warning: kernel/rcu/rcutorture.c:133: null expansion of name pattern "\1"
ctags: Warning: kernel/rcu/rcutorture.c:135: null expansion of name pattern "\1"
ctags: Warning: kernel/workqueue.c:323: null expansion of name pattern "\1"
ctags: Warning: net/ipv4/syncookies.c:53: null expansion of name pattern "\1"
ctags: Warning: net/ipv6/syncookies.c:44: null expansion of name pattern "\1"
ctags: Warning: net/rds/page.c:45: null expansion of name pattern "\1"
Which are all the result of the DEFINE_PER_CPU pattern:
scripts/tags.sh:200: '/\<DEFINE_PER_CPU([^,]*, *\([[:alnum:]_]*\)/\1/v/'
scripts/tags.sh:201: '/\<DEFINE_PER_CPU_SHARED_ALIGNED([^,]*, *\([[:alnum:]_]*\)/\1/v/'
The below cures them. All except the workqueue one are within reasonable
distance of the 80 char limit. TJ do you have any preference on how to
fix the wq one, or shall we just not care its too long?
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
Allow accepted sockets to derive their sk_bound_dev_if setting from the
l3mdev domain in which the packets originated. A sysctl setting is added
to control the behavior which is similar to sk_mark and
sysctl_tcp_fwmark_accept.
This effectively allow a process to have a "VRF-global" listen socket,
with child sockets bound to the VRF device in which the packet originated.
A similar behavior can be achieved using sk_mark, but a solution using marks
is incomplete as it does not handle duplicate addresses in different L3
domains/VRFs. Allowing sockets to inherit the sk_bound_dev_if from l3mdev
domain provides a complete solution.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
This patch addresses multiple problems :
UDP/RAW sendmsg() need to get a stable struct ipv6_txoptions
while socket is not locked : Other threads can change np->opt
concurrently. Dmitry posted a syzkaller
(http://github.com/google/syzkaller) program desmonstrating
use-after-free.
Starting with TCP/DCCP lockless listeners, tcp_v6_syn_recv_sock()
and dccp_v6_request_recv_sock() also need to use RCU protection
to dereference np->opt once (before calling ipv6_dup_options())
This patch adds full RCU protection to np->opt
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
One 32bit hole is following skc_refcnt, use it.
skc_incoming_cpu can also be an union for request_sock rcv_wnd.
inet_reqsk_alloc() is used to allocate a temporary request
in order to generate a SYNACK with a cookie. Then later,
syncookie validation also uses a temporary request.
These paths already took a reference on listener refcount,
we can avoid a couple of atomic operations.
Some common IPv4/IPv6 code can be factorized.
Also constify cookie_init_sequence() socket argument.
Currently SYN/ACK RTT is measured in jiffies. For LAN the SYN/ACK
RTT is often measured as 0ms or sometimes 1ms, which would affect
RTT estimation and min RTT samping used by some congestion control.
This patch improves SYN/ACK RTT to be usec resolution if platform
supports it. While the timestamping of SYN/ACK is done in request
sock, the RTT measurement is carefully arranged to avoid storing
another u64 timestamp in tcp_sock.
For regular handshake w/o SYNACK retransmission, the RTT is sampled
right after the child socket is created and right before the request
sock is released (tcp_check_req() in tcp_minisocks.c)
For Fast Open the child socket is already created when SYN/ACK was
sent, the RTT is sampled in tcp_rcv_state_process() after processing
the final ACK an right before the request socket is released.
If the SYN/ACK was retransmistted or SYN-cookie was used, we rely
on TCP timestamps to measure the RTT. The sample is taken at the
same place in tcp_rcv_state_process() after the timestamp values
are validated in tcp_validate_incoming(). Note that we do not store
TS echo value in request_sock for SYN-cookies, because the value
is already stored in tp->rx_opt used by tcp_ack_update_rtt().
One side benefit is that the RTT measurement now happens before
initializing congestion control (of the passive side). Therefore
the congestion control can use the SYN/ACK RTT.
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Signed-off-by: Neal Cardwell <ncardwell@google.com>
IPv4 and IPv6 share same implementation of get_cookie_sock(),
and there is no point inlining it.
We add tcp_ prefix to the common helper name and export it.
ss should display ipv4 mapped request sockets like this :
tcp SYN-RECV 0 0 ::ffff:192.168.0.1:8080 ::ffff:192.0.2.1:35261
and not like this :
tcp SYN-RECV 0 0 192.168.0.1:8080 192.0.2.1:35261
We should init ireq->ireq_family based on listener sk_family,
not the actual protocol carried by SYN packet.
This means we can set ireq_family in inet_reqsk_alloc()
Fixes: 3f66b083a5b7 ("inet: introduce ireq_family")
One of the major issue for TCP is the SYNACK rtx handling,
done by inet_csk_reqsk_queue_prune(), fired by the keepalive
timer of a TCP_LISTEN socket.
This function runs for awful long times, with socket lock held,
meaning that other cpus needing this lock have to spin for hundred of ms.
SYNACK are sent in huge bursts, likely to cause severe drops anyway.
This model was OK 15 years ago when memory was very tight.
We now can afford to have a timer per request sock.
Timer invocations no longer need to lock the listener,
and can be run from all cpus in parallel.
With following patch increasing somaxconn width to 32 bits,
I tested a listener with more than 4 million active request sockets,
and a steady SYNFLOOD of ~200,000 SYN per second.
Host was sending ~830,000 SYNACK per second.
This is ~100 times more what we could achieve before this patch.
Later, we will get rid of the listener hash and use ehash instead.
While testing last patch series, I found req sock refcounting was wrong.
We must set skc_refcnt to 1 for all request socks added in hashes,
but also on request sockets created by FastOpen or syncookies.
It is tricky because we need to defer this initialization so that
future RCU lookups do not try to take a refcount on a not yet
fully initialized request socket.
Also get rid of ireq_refcnt alias.
Fixes: 13854e5a6046 ("inet: add proper refcounting to request sock")
The listener field in struct tcp_request_sock is a pointer
back to the listener. We now have req->rsk_listener, so TCP
only needs one boolean and not a full pointer.
listener socket can be used to set net pointer, and will
be later used to hold a reference on listener.
Add a const qualifier to first argument (struct request_sock_ops *),
and factorize all write_pnet(&ireq->ireq_net, sock_net(sk));
Before inserting request socks into general hash table,
fill their socket family.
I forgot to update dccp_v6_conn_request() & cookie_v6_check().
They both need to set ireq->ireq_net and ireq->ir_cookie
Lets clear ireq->ir_cookie in inet_reqsk_alloc()
Fixes: 33cf7c90fe2f ("net: add real socket cookies")
This patch allows to set ECN on a per-route basis in case the sysctl
tcp_ecn is not set to 1. In other words, when ECN is set for specific
routes, it provides a tcp_ecn=1 behaviour for that route while the rest
of the stack acts according to the global settings.
One can use 'ip route change dev $dev $net features ecn' to toggle this.
Having a more fine-grained per-route setting can be beneficial for various
reasons, for example, 1) within data centers, or 2) local ISPs may deploy
ECN support for their own video/streaming services [1], etc.
There was a recent measurement study/paper [2] which scanned the Alexa's
publicly available top million websites list from a vantage point in US,
Europe and Asia:
Half of the Alexa list will now happily use ECN (tcp_ecn=2, most likely
blamed to commit 255cac91c3 ("tcp: extend ECN sysctl to allow server-side
only ECN") ;)); the break in connectivity on-path was found is about
1 in 10,000 cases. Timeouts rather than receiving back RSTs were much
more common in the negotiation phase (and mostly seen in the Alexa
middle band, ranks around 50k-150k): from 12-thousand hosts on which
there _may_ be ECN-linked connection failures, only 79 failed with RST
when _not_ failing with RST when ECN is not requested.
It's unclear though, how much equipment in the wild actually marks CE
when buffers start to fill up.
We thought about a fallback to non-ECN for retransmitted SYNs as another
global option (which could perhaps one day be made default), but as Eric
points out, there's much more work needed to detect broken middleboxes.
Two examples Eric mentioned are buggy firewalls that accept only a single
SYN per flow, and middleboxes that successfully let an ECN flow establish,
but later mark CE for all packets (so cwnd converges to 1).
[1] http://www.ietf.org/proceedings/89/slides/slides-89-tsvarea-1.pdf, p.15
[2] http://ecn.ethz.ch/
Joint work with Daniel Borkmann.
Reference: http://thread.gmane.org/gmane.linux.network/335797
Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
The function cookie_check_timestamp(), both called from IPv4/6 context,
is being used to decode the echoed timestamp from the SYN/ACK into TCP
options used for follow-up communication with the peer.
We can remove ECN handling from that function, split it into a separate
one, and simply rename the original function into cookie_decode_options().
cookie_decode_options() just fills in tcp_option struct based on the
echoed timestamp received from the peer. Anything that fails in this
function will actually discard the request socket.
While this is the natural place for decoding options such as ECN which
commit 172d69e63c7f ("syncookies: add support for ECN") added, we argue
that in particular for ECN handling, it can be checked at a later point
in time as the request sock would actually not need to be dropped from
this, but just ECN support turned off.
Therefore, we split this functionality into cookie_ecn_ok(), which tells
us if the timestamp indicates ECN support AND the tcp_ecn sysctl is enabled.
This prepares for per-route ECN support: just looking at the tcp_ecn sysctl
won't be enough anymore at that point; if the timestamp indicates ECN
and sysctl tcp_ecn == 0, we will also need to check the ECN dst metric.
This would mean adding a route lookup to cookie_check_timestamp(), which
we definitely want to avoid. As we already do a route lookup at a later
point in cookie_{v4,v6}_check(), we can simply make use of that as well
for the new cookie_ecn_ok() function w/o any additional cost.
Only count packets that failed cookie-authentication.
We can get SYNCOOKIESFAILED > 0 while we never even sent a single cookie.
Remove trailing whitespace in tcp.h icmp.c syncookies.c
Signed-off-by: Kenjiro Nakayama <nakayamakenjiro@gmail.com>
Pull networking fixes from David Miller:
1) Include fixes for netrom and dsa (Fabian Frederick and Florian
Fainelli)
2) Fix FIXED_PHY support in stmmac, from Giuseppe CAVALLARO.
3) Several SKB use after free fixes (vxlan, openvswitch, vxlan,
ip_tunnel, fou), from Li ROngQing.
4) fec driver PTP support fixes from Luwei Zhou and Nimrod Andy.
5) Use after free in virtio_net, from Michael S Tsirkin.
6) Fix flow mask handling for megaflows in openvswitch, from Pravin B
Shelar.
7) ISDN gigaset and capi bug fixes from Tilman Schmidt.
8) Fix route leak in ip_send_unicast_reply(), from Vasily Averin.
9) Fix two eBPF JIT bugs on x86, from Alexei Starovoitov.
10) TCP_SKB_CB() reorganization caused a few regressions, fixed by Cong
Wang and Eric Dumazet.
11) Don't overwrite end of SKB when parsing malformed sctp ASCONF
chunks, from Daniel Borkmann.
12) Don't call sock_kfree_s() with NULL pointers, this function also has
the side effect of adjusting the socket memory usage. From Cong Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (90 commits)
bna: fix skb->truesize underestimation
net: dsa: add includes for ethtool and phy_fixed definitions
openvswitch: Set flow-key members.
netrom: use linux/uaccess.h
dsa: Fix conversion from host device to mii bus
tipc: fix bug in bundled buffer reception
ipv6: introduce tcp_v6_iif()
sfc: add support for skb->xmit_more
r8152: return -EBUSY for runtime suspend
ipv4: fix a potential use after free in fou.c
ipv4: fix a potential use after free in ip_tunnel_core.c
hyperv: Add handling of IP header with option field in netvsc_set_hash()
openvswitch: Create right mask with disabled megaflows
vxlan: fix a free after use
openvswitch: fix a use after free
ipv4: dst_entry leak in ip_send_unicast_reply()
ipv4: clean up cookie_v4_check()
ipv4: share tcp_v4_save_options() with cookie_v4_check()
ipv4: call __ip_options_echo() in cookie_v4_check()
atm: simplify lanai.c by using module_pci_driver
Commit 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line
misses") added a regression for SO_BINDTODEVICE on IPv6.
This is because we still use inet6_iif() which expects that IP6 control
block is still at the beginning of skb->cb[]
This patch adds tcp_v6_iif() helper and uses it where necessary.
Because __inet6_lookup_skb() is used by TCP and DCCP, we add an iif
parameter to it.
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Acked-by: Cong Wang <cwang@twopensource.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
ipv6_opt_accepted() assumes IP6CB(skb) holds the struct inet6_skb_parm
that it needs. Lets not assume this, as TCP stack might use a different
place.
only written once.
Replace uses of get_cpu_var for address calculation through this_cpu_ptr.
Cc: netdev@vger.kernel.org
Cc: Eric Dumazet <edumazet@google.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Since pktops is only used for IPv6 only and opts is used for IPv4
only, we can move these fields into a union and this allows us to drop
the inet6_reqsk_alloc function as after this change it becomes
equivalent with inet_reqsk_alloc.
This patch also fixes a kmemcheck issue in the IPv6 stack: the flags
field was not annotated after a request_sock was allocated.
Signed-off-by: Octavian Purdila <octavian.purdila@intel.com>
When using mark-based routing, sockets returned from accept()
may need to be marked differently depending on the incoming
connection request.
This is the case, for example, if different socket marks identify
different networks: a listening socket may want to accept
connections from all networks, but each connection should be
marked with the network that the request came in on, so that
subsequent packets are sent on the correct network.
This patch adds a sysctl to mark TCP sockets based on the fwmark
of the incoming SYN packet. If enabled, and an unmarked socket
receives a SYN, then the SYN packet's fwmark is written to the
connection's inet_request_sock, and later written back to the
accepted socket when the connection is established. If the
socket already has a nonzero mark, then the behaviour is the same
as it is today, i.e., the listening socket's fwmark is used.
Black-box tested using user-mode linux:
- IPv4/IPv6 SYN+ACK, FIN, etc. packets are routed based on the
mark of the incoming SYN packet.
- The socket returned by accept() is marked with the mark of the
- Tested with syncookies=1 and syncookies=2.
FLOWI_FLAG_CAN_SLEEP was used to notify xfrm about the posibility
to sleep until the needed states are resolved. This code is gone,
so FLOWI_FLAG_CAN_SLEEP is not needed anymore.
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
net_get_random_once
This patch splits the secret key for syncookies for ipv4 and ipv6 and
initializes them with net_get_random_once. This change was the reason I
did this series. I think the initialization of the syncookie_secret is
way to early.
Cc: Florian Westphal <fw@strlen.de>
In commit 634fb979e8f ("inet: includes a sock_common in request_sock")
I forgot that the two ports in sock_common do not have same byte order :
skc_dport is __be16 (network order), but skc_num is __u16 (host order)
So sparse complains because ir_loc_port (mapped into skc_num) is
considered as __u16 while it should be __be16
Let rename ir_loc_port to ireq->ir_num (analogy with inet->inet_num),
and perform appropriate htons/ntohs conversions.
Reported-by: Wu Fengguang <fengguang.wu@intel.com>
TCP listener refactoring, part 5 :
We want to be able to insert request sockets (SYN_RECV) into main
ehash table instead of the per listener hash table to allow RCU
lookups and remove listener lock contention.
This patch includes the needed struct sock_common in front
of struct request_sock
This means there is no more inet6_request_sock IPv6 specific
structure.
Following inet_request_sock fields were renamed as they became
macros to reference fields from struct sock_common.
Prefix ir_ was chosen to avoid name collisions.
loc_port -> ir_loc_port
loc_addr -> ir_loc_addr
rmt_addr -> ir_rmt_addr
rmt_port -> ir_rmt_port
iif -> ir_iif
Halve mss table size to make blind cookie guessing more difficult.
This is sad since the tables were already small, but there
is little alternative except perhaps adding more precise mss information
in the tcp timestamp. Timestamps are unfortunately not ubiquitous.
Guessing all possible cookie values still has 8-in 2**32 chance.
Reported-by: Jakob Lell <jakob@jakoblell.com>
We currently accept cookies that were created less than 4 minutes ago
(ie, cookies with counter delta 0-3). Combined with the 8 mss table
values, this yields 32 possible values (out of 2**32) that will be valid.
Reducing the lifetime to < 2 minutes halves the guessing chance while
still providing a large enough period.
While at it, get rid of jiffies value -- they overflow too quickly on
32 bit platforms.
getnstimeofday is used to create a counter that increments every 64s.
perf shows getnstimeofday cost is negible compared to sha_transform;
normal tcp initial sequence number generation uses getnstimeofday, too.
Extract the local TCP stack independant parts of tcp_v6_init_sequence()
and cookie_v6_check() and export them for use by the upcoming IPv6 SYNPROXY
target.
Tested-by: Martin Topholm <mph@one.com>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
TCPCT uses option-number 253, reserved for experimental use and should
not be used in production environments.
Further, TCPCT does not fully implement RFC 6013.
As a nice side-effect, removing TCPCT increases TCP's performance for
very short flows:
Doing an apache-benchmark with -c 100 -n 100000, sending HTTP-requests
for files of 1KB size.
before this patch:
average (among 7 runs) of 20845.5 Requests/Second
after:
average (among 7 runs) of 21403.6 Requests/Second
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
