path: root/net/ipv6/ipcomp6.c
2014-08-24ipv6: White-space cleansing : Structure layoutsIan Morris
This patch makes no changes to the logic of the code but simply addresses coding style issues as detected by checkpatch. Both objdump and diff -w show no differences. This patch addresses structure definitions, specifically it cleanses the brace placement and replaces spaces with tabs in a few places. Signed-off-by: Ian Morris <ipm@chirality.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-14ipcomp6: Use the IPsec protocol multiplexer APISteffen Klassert
Switch ipcomp6 to use the new IPsec protocol multiplexer. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-12-06ipv4/ipv6: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> CC: James Morris <jmorris@namei.org> CC: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> CC: Patrick McHardy <kaber@trash.net> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-16ipsec: Don't update the pmtu on ICMPV6_DEST_UNREACHSteffen Klassert
Currently we update the pmtu in the IPsec protocol error handlers if icmpv6 message type is either ICMPV6_DEST_UNREACH or ICMPV6_PKT_TOOBIG. Updating the pmtu on ICMPV6_DEST_UNREACH is wrong in any case, it causes strangely fragmented packets. Only ICMPV6_PKT_TOOBIG signalizes pmtu discovery, so remove the ICMPV6_DEST_UNREACH check in the IPsec protocol error handlers. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
2013-09-05ipv6:introduce function to find route for redirectDuan Jiong
RFC 4861 says that the IP source address of the Redirect is the same as the current first-hop router for the specified ICMP Destination Address, so the gateway should be taken into consideration when we find the route for redirect. There was once a check in commit a6279458c534d01ccc39498aba61c93083ee0372 ("NDISC: Search over all possible rules on receipt of redirect.") and the check went away in commit b94f1c0904da9b8bf031667afc48080ba7c3e8c9 ("ipv6: Use icmpv6_notify() to propagate redirect, instead of rt6_redirect()"). The bug is only "exploitable" on layer-2 because the source address of the redirect is checked to be a valid link-local address but it makes spoofing a lot easier in the same L2 domain nonetheless. Thanks very much for Hannes's help. Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-12ipv6: Add redirect support to all protocol icmp error handlers.David S. Miller
2012-06-15ipv6: Handle PMTU in ICMP error handlers.David S. Miller
One tricky issue on the ipv6 side vs. ipv4 is that the ICMP callouts to handle the error pass the 32-bit info cookie in network byte order whereas ipv4 passes it around in host byte order. Like the ipv4 side, we have two helper functions. One for when we have a socket context and one for when we do not. ip6ip6 tunnels are not handled here, because they handle PMTU events by essentially relaying another ICMP packet-too-big message back to the original sender. This patch allows us to get rid of rt6_do_pmtu_disc(). It handles all kinds of situations that simply cannot happen when we do the PMTU update directly using a fully resolved route. In fact, the "plen == 128" check in ip6_rt_update_pmtu() can very likely be removed or changed into a BUG_ON() check. We should never have a prefixed ipv6 route when we get there. Another piece of strange history here is that TCP and DCCP, unlike in ipv4, never invoke the update_pmtu() method from their ICMP error handlers. This is incredibly astonishing since this is the context where we have the most accurate context in which to make a PMTU update, namely we have a fully connected socket and associated cached socket route. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16net: ipv4 and ipv6: Convert printk(KERN_DEBUG to pr_debugJoe Perches
Use the current debugging style and enable dynamic_debug. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-05-16net: ipv6: Standardize prefixes for message loggingJoe Perches
Add #define pr_fmt(fmt) as appropriate. Add "IPv6: " to appropriate files. Convert printk(KERN_<LEVEL> to pr_<level> (but not KERN_DEBUG). Standardize on "%s: " not "%s(): " when emitting __func__. Use "%s: ", __func__ instead of embedding function name. Coalesce formats, align arguments. ADDRCONF output is now prefixed with "IPv6: " Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-22xfrm: SA lookups signature with markJamal Hadi Salim
pass mark to all SA lookups to prepare them for when we add code to have them search. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16Merge branch 'master' of ↵David S. Miller
2010-02-16ipcomp: Avoid duplicate calls to ipcomp_destroyHerbert Xu
When ipcomp_tunnel_attach fails we will call ipcomp_destroy twice. This may lead to double-frees on certain structures. As there is no reason to explicitly call ipcomp_destroy, this patch removes it from ipcomp*.c and lets the standard xfrm_state destruction take place. This is based on the discovery and patch by Alexey Dobriyan. Tested-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28netns xfrm: ipcomp6 supportAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-28netns xfrm: xfrm6_tunnel in netnsAlexey Dobriyan
I'm not sure about rcu stuff near kmem cache destruction: * checks for non-empty hashes look bogus, they're done _before_ rcu_berrier() * unregistering netns ops is done before kmem_cache destoy (as it should), and unregistering involves rcu barriers by itself So it looks nothing should be done. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify struct inet6_protocolAlexey Dobriyan
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-25netns xfrm: state lookup in netnsAlexey Dobriyan
2008-11-25netns xfrm: add struct xfrm_state::xs_netAlexey Dobriyan
To avoid unnecessary complications with passing netns around. * set once, very early after allocating * once set, never changes For a while create every xfrm_state in init_net. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-07-27ipcomp: Fix warnings after ipcomp consolidation.David S. Miller
net/ipv4/ipcomp.c: In function ‘ipcomp4_init_state’: net/ipv4/ipcomp.c:109: warning: unused variable ‘calg_desc’ net/ipv4/ipcomp.c:108: warning: unused variable ‘ipcd’ net/ipv4/ipcomp.c:107: warning: ‘err’ may be used uninitialized in this function net/ipv6/ipcomp6.c: In function ‘ipcomp6_init_state’: net/ipv6/ipcomp6.c:139: warning: unused variable ‘calg_desc’ net/ipv6/ipcomp6.c:138: warning: unused variable ‘ipcd’ net/ipv6/ipcomp6.c:137: warning: ‘err’ may be used uninitialized in this function Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25ipsec: ipcomp - Merge IPComp implementationsHerbert Xu
This patch merges the IPv4/IPv6 IPComp implementations since most of the code is identical. As a result future enhancements will no longer need to be duplicated. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-18net: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-02-28[IPCOMP]: Disable BH on output when using shared tfmHerbert Xu
Because we use shared tfm objects in order to conserve memory, (each tfm requires 128K of vmalloc memory), BH needs to be turned off on output as that can occur in process context. Previously this was done implicitly by the xfrm output code. That was lost when it became lockless. So we need to add the BH disabling to IPComp directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[XFRM]: constify 'struct xfrm_type'Eric Dumazet
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[IPCOMP]: Fetch nexthdr before ipch is destroyedHerbert Xu
When I moved the nexthdr setting out of IPComp I accidently moved the reading of ipch->nexthdr after the decompression. Unfortunately this means that we'd be reading from a stale ipch pointer which doesn't work very well. This patch moves the reading up so that we get the correct nexthdr value. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPSEC]: Forbid BEET + ipcomp for nowHerbert Xu
While BEET can theoretically work with IPComp the current code can't do that because it tries to construct a BEET mode tunnel type which doesn't (and cannot) exist. In fact as it is it won't even attach a tunnel object at all for BEET which is bogus. To support this fully we'd also need to change the policy checks on input to recognise a plain tunnel as a legal variant of an optional BEET transform. This patch simply fails such constructions for now. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-07[IPSEC]: Fix crypto_alloc_comp error checkingHerbert Xu
The function crypto_alloc_comp returns an errno instead of NULL to indicate error. So it needs to be tested with IS_ERR. This is based on a patch by Vicenç Beltran Querol. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-02cleanup asm/scatterlist.h includesAdrian Bunk
Not architecture specific code should not #include <asm/scatterlist.h>. This patch therefore either replaces them with #include <linux/scatterlist.h> or simply removes them if they were unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-17[IPSEC]: Disallow combinations of RO and AH/ESP/IPCOMPHerbert Xu
Combining RO and AH/ESP/IPCOMP does not make sense. So this patch adds a check in the state initialisation function to prevent this. This allows us to safely remove the mode input function of RO since it can never be called anymore. Indeed, if somehow it does get called we'll know about it through an OOPS instead of it slipping past silently. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Move IP length/checksum setting out of transformsHerbert Xu
This patch moves the setting of the IP length and checksum fields out of the transforms and into the xfrmX_output functions. This would help future efforts in merging the transforms themselves. It also adds an optimisation to ipcomp due to the fact that the transport offset is guaranteed to be zero. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Get rid of ipv6_{auth,esp,comp}_hdrHerbert Xu
This patch removes the duplicate ipv6_{auth,esp,comp}_hdr structures since they're identical to the IPv4 versions. Duplicating them would only create problems for ourselves later when we need to add things like extended sequence numbers. I've also added transport header type conversion headers for these types which are now used by the transforms. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Set skb->data to payload in x->mode->outputHerbert Xu
This patch changes the calling convention so that on entry from x->mode->output and before entry into x->type->output skb->data will point to the payload instead of the IP header. This is essentially a redistribution of skb_push/skb_pull calls with the aim of minimising them on the common path of tunnel + ESP. It'll also let us use the same calling convention between IPv4 and IPv6 with the next patch. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPSEC]: Store IPv6 nh pointer in mac_header on outputHerbert Xu
Current the x->mode->output functions store the IPv6 nh pointer in the skb network header. This is inconvenient because the network header then has to be fixed up before the packet can leave the IPsec stack. The mac header field is unused on output so we can use that to store this instead. This patch does that and removes the network header fix-up in xfrm_output. It also uses ipv6_hdr where appropriate in the x->type->output functions. There is also a minor clean-up in esp4 to make it use the same code as esp6 to help any subsequent effort to merge the two. Lastly it kills two redundant skb_set_* statements in BEET that were simply copied over from transport mode. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV6]: Remove unneeded pointer iph from ipcomp6_input() in net/ipv6/ipcomp6.cMicah Gruber
This trivial patch removes the unneeded pointer iph, which is never used. Signed-off-by: Micah Gruber <micah.gruber@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[XFRM]: Add module alias for transformation type.Masahide NAKAMURA
It is clean-up for XFRM type modules and adds aliases with its protocol: ESP, AH, IPCOMP, IPIP and IPv6 for IPsec ROUTING and DSTOPTS for MIPv6 It is almost the same thing as XFRM mode alias, but it is added new defines XFRM_PROTO_XXX for preprocessing since some protocols are defined as enum. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Acked-by: Ingo Oeser <netdev@axxeo.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_copy_to_linear_data{_offset}Arnaldo Carvalho de Melo
To clearly state the intent of copying to linear sk_buffs, _offset being a overly long variant but interesting for the sake of saving some bytes. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->h.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-10[NET] IPV6: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: 'info' argument of ipv6 ->err_handler() is net-endianAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-04[XFRM]: BEET modeDiego Beltrami
This patch introduces the BEET mode (Bound End-to-End Tunnel) with as specified by the ietf draft at the following link: http://www.ietf.org/internet-drafts/draft-nikander-esp-beet-mode-06.txt The patch provides only single family support (i.e. inner family = outer family). Signed-off-by: Diego Beltrami <diego.beltrami@gmail.com> Signed-off-by: Miika Komu <miika@iki.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Abhinav Pathak <abhinav.pathak@hiit.fi> Signed-off-by: Jeff Ahrenholz <ahrenholz@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[XFRM]: xfrm_state_lookup() annotationsAl Viro
spi argument of xfrm_state_lookup() is net-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM] STATE: Add a hook to find offset to be inserted header in outbound.Masahide NAKAMURA
On current kernel, ip6_find_1stfragopt() is used by IPv6 IPsec to find offset to be inserted header in outbound for transport mode. (BTW, no usage may be needed for IPv4 case.) Mobile IPv6 requires another logic for routing header and destination options header respectively. This patch is common platform for the offset and adopts it to IPsec. Based on MIPL2 kernel patch. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[XFRM]: Add XFRM_MODE_xxx for future use.Masahide NAKAMURA
Transformation mode is used as either IPsec transport or tunnel. It is required to add two more items, route optimization and inbound trigger for Mobile IPv6. Based on MIPL2 kernel patch. This patch was also written by: Ville Nuorvala <vnuorval@tcs.hut.fi> Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-21[CRYPTO] users: Use crypto_comp and crypto_has_*Herbert Xu
This patch converts all users to use the new crypto_comp type and the crypto_has_* functions. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
