path: root/net/ipv6/addrconf.c
2005-06-28[IPV6]: Don't dump temporary addresses twiceYOSHIFUJI Hideaki
Each IPv6 Temporary Address (w/ CONFIG_IPV6_PRIVACY) is dumped twice to netlink. Because temporary addresses are listed in idev->addr_list, there's no need to dump idev->tempaddr separately. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[NETLINK]: Missing padding fields in dumped structuresPatrick McHardy
Plug holes with padding fields and initialized them to zero. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-28[NETLINK]: Missing initializations in dumped dataPatrick McHardy
Mostly missing initialization of padding fields of 1 or 2 bytes length, two instances of uninitialized nlmsgerr->msg of 16 bytes length. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-23[PATCH] create a kstrdup library functionPaulo Marques
This patch creates a new kstrdup library function and changes the "local" implementations in several places to use this function. Most of the changes come from the sound and net subsystems. The sound part had already been acknowledged by Takashi Iwai and the net part by David S. Miller. I left UML alone for now because I would need more time to read the code carefully before making changes there. Signed-off-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[IPV6]: V6 route events reported with wrong netlink PID and seq numberJamal Hadi Salim
Essentially netlink at the moment always reports a pid and sequence of 0 always for v6 route activities. To understand the repurcassions of this look at: http://lists.quagga.net/pipermail/quagga-dev/2005-June/003507.html While fixing this, i took the liberty to resolve the outstanding issue of IPV6 routes inserted via ioctls to have the correct pids as well. This patch tries to behave as close as possible to the v4 routes i.e maintains whatever PID the socket issuing the command owns as opposed to the process. That made the patch a little bulky. I have tested against both netlink derived utility to add/del routes as well as ioctl derived one. The Quagga folks have tested against quagga. This fixes the problem and so far hasnt been detected to introduce any new issues. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Set correct pid for ioctl originating netlink eventsJamal Hadi Salim
This patch ensures that netlink events created as a result of programns using ioctls (such as ifconfig, route etc) contains the correct PID of those events. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Explicit typingJamal Hadi Salim
This patch converts "unsigned flags" to use more explict types like u16 instead and incrementally introduces NLMSG_NEW(). Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Correctly set NLM_F_MULTI without checking the pidJamal Hadi Salim
This patch rectifies some rtnetlink message builders that derive the flags from the pid. It is now explicit like the other cases which get it right. Also fixes half a dozen dumpers which did not set NLM_F_MULTI at all. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-13[IPv6] Don't generate temporary for TUN devicesRémi Denis-Courmont
Userland layer-2 tunneling devices allocated through the TUNTAP driver (drivers/net/tun.c) have a type of ARPHRD_NONE, and have no link-layer address. The kernel complains at regular interval when IPv6 Privacy extension are enabled because it can't find an hardware address : Dec 29 11:02:04 auguste kernel: __ipv6_regen_rndid(idev=cb3e0c00): cannot get EUI64 identifier; use random bytes. IPv6 Privacy extensions should probably be disabled on that sort of device. They won't work anyway. If userland wants a more usual Ethernet-ish interface with usual IPv6 autoconfiguration, it will use a TAP device with an emulated link-layer and a random hardware address rather than a TUN device. As far as I could fine, TUN virtual device from TUNTAP is the very only sort of device using ARPHRD_NONE as kernel device type. Signed-off-by: Rémi Denis-Courmont <rdenis@simphalempin.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-03[RTNETLINK] Cleanup rtnetlink_link tablesThomas Graf
Converts remaining rtnetlink_link tables to use c99 designated initializers to make greping a little bit easier. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[IPV6]: Fix a branch predictionYOSHIFUJI Hideaki
From: Tushar Gohad <tgohad@mvista.com> Signed-off-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
