commit 4b90a603a1b21d63cf743cc833680cb195a729f6 upstream.
When the ahash driver returns -EBUSY, AH4/6 input functions return
NET_XMIT_DROP, presumably copied from the output code path. But
returning transmit codes on input doesn't make a lot of sense.
Since NET_XMIT_DROP is a positive int, this gets interpreted as
the next header type (i.e., success). As that can only end badly,
remove the check.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
Change-Id: Ia5db571c5c73a87397fa10dfb668f85b7942f3b0
Reviewed-on: http://git-master/r/79659
[ Upstream commit 8a622e71f58ec9f092fc99eacae0e6cf14f6e742 ]
md5 key is added in socket through remote address.
remote address should be used in finding md5 key when
sending out reset packet.
Signed-off-by: shawnlu <shawn.lu@ericsson.com>
Change-Id: Ib092cc760c830540564414aa1d400e5eb78208f6
Reviewed-on: http://git-master/r/79697
[ Upstream commit 5b35e1e6e9ca651e6b291c96d1106043c9af314a ]
This commit fixes tcp_trim_head() to recalculate the number of
segments in the skb with the skb's existing MSS, so trimming the head
causes the skb segment count to be monotonically non-increasing - it
should stay the same or go down, but not increase.
Previously tcp_trim_head() used the current MSS of the connection. But
if there was a decrease in MSS between original transmission and ACK
(e.g. due to PMTUD), this could cause tcp_trim_head() to
counter-intuitively increase the segment count when trimming bytes off
the head of an skb. This violated assumptions in tcp_tso_acked() that
tcp_trim_head() only decreases the packet count, so that packets_acked
in tcp_tso_acked() could underflow, leading tcp_clean_rtx_queue() to
pass u32 pkts_acked values as large as 0xffffffff to
ca_ops->pkts_acked().
As an aside, if tcp_trim_head() had really wanted the skb to reflect
the current MSS, it should have called tcp_set_skb_tso_segs()
unconditionally, since a decrease in MSS would mean that a
single-packet skb should now be sliced into multiple segments.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Nandita Dukkipati <nanditad@google.com>
Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Change-Id: I8e7359bbd561e78d0d9be4c3f871b22114504c8b
Reviewed-on: http://git-master/r/79696
Linux 3.1.9
Makefile
Change-Id: I22227ab33ba7ddaba8e6fe049393c58a83d73648
commit a8c1f65c79cbbb2f7da782d4c9d15639a9b94b27 upstream.
Commit 5b7c84066733c5dfb0e4016d939757b38de189e4 ('ipv4: correct IGMP
behavior on v3 query during v2-compatibility mode') added yet another
case for query parsing, which can result in max_delay = 0. Substitute
a value of 1, as in the usual v3 case.
Reported-by: Simon McVittie <smcv@debian.org>
References: http://bugs.debian.org/654876
[ Upstream commit b9eda06f80b0db61a73bd87c6b0eb67d8aca55ad ]
Acked-by: David Miller <davem@davemloft.net>
Change-Id: Ie3b22a8ecc595fd80bc3cd84d32e7d4ee7fe9ad8
Reviewed-on: http://git-master/r/74226
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
[ Upstream commit 9f28a2fc0bd77511f649c0a788c7bf9a5fd04edb ]
Commit 2c8cec5c10b (ipv4: Cache learned PMTU information in inetpeer)
removed IP route cache garbage collector a bit too soon, as this gc was
responsible for expired routes cleanup, releasing their neighbour
reference.
As pointed out by Robert Gladewitz, recent kernels can fill and exhaust
their neighbour cache.
Reintroduce the garbage collection, since we'll have to wait our
neighbour lookups become refcount-less to not depend on this stuff.
Reported-by: Robert Gladewitz <gladewitz@gmx.de>
Change-Id: I44f6d7e64fc76fe710b95afee4fee984c19d0e64
Reviewed-on: http://git-master/r/74225
[ Upstream commit e688a604807647c9450f9c12a7cb6d027150a895 ]
Chris Boot reported crashes occurring in ipv6_select_ident().
[ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>]
ipv6_select_ident+0x31/0xa7
[ 461.578229] Call Trace:
[ 461.580742] <IRQ>
[ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2
[ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155
[ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b
[ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e
[nf_conntrack_ipv6]
[ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543
[ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a
[bridge]
[ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459
[ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76
[bridge]
[ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f
[bridge]
[ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.677299] [<ffffffffa0379215>] ?
nf_bridge_update_protocol+0x20/0x20 [bridge]
[ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack]
[ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56
[bridge]
[ 461.704616] [<ffffffffa0379031>] ?
nf_bridge_push_encap_header+0x1c/0x26 [bridge]
[ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95
[bridge]
[ 461.719490] [<ffffffffa037900a>] ?
nf_bridge_pull_encap_header+0x1c/0x27 [bridge]
[ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge]
[ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56
[bridge]
This is caused by bridge netfilter special dst_entry (fake_rtable), a
special shared entry, where attaching an inetpeer makes no sense.
Problem is present since commit 87c48fa3b46 (ipv6: make fragment
identifications less predictable)
Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and
__ip_select_ident() fallback to the 'no peer attached' handling.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Change-Id: Id23270aae3214c26691f95922a63c70549232c22
Reviewed-on: http://git-master/r/74224
[ Upstream commit d01ff0a049f749e0bf10a35bb23edd012718c8c2 ]
After reset ipv4_devconf->data[IPV4_DEVCONF_ACCEPT_LOCAL] to 0,
we should flush route cache, or it will continue receive packets with local
source address, which should be dropped.
Signed-off-by: Weiping Pan <panweiping3@gmail.com>
Change-Id: I4e1a937bf13f758c7be089f614e7e84bdafcc0af
Reviewed-on: http://git-master/r/74222
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
[ Upstream commit cd7816d14953c8af910af5bb92f488b0b277e29d ]
previous commit 3fb72f1e6e6165c5f495e8dc11c5bbd14c73385c
makes IP-Config wait for carrier on at least one network device.
Before waiting (predefined value 120s), check that at least one device
was successfully brought up. Otherwise (e.g. buggy bootloader
which does not set the MAC address) there is no point in waiting
for carrier.
Cc: Micha Nelissen <micha@neli.hopto.org>
Cc: Holger Brunck <holger.brunck@keymile.com>
Signed-off-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Change-Id: I77fe0b97b750a3064e67330b131811edeebbc29b
Reviewed-on: http://git-master/r/74217
commit 72b36015ba43a3cca5303f5534d2c3e1899eae29 upstream.
Same fix as 731abb9cb2 for ipip and sit tunnel.
Commit 1c5cae815d removed an explicit call to dev_alloc_name in
ipip_tunnel_locate and ipip6_tunnel_locate, because register_netdevice
will now create a valid name, however the tunnel keeps a copy of the
name in the private parms structure. Fix this by copying the name back
after register_netdevice has successfully returned.
This shows up if you do a simple tunnel add, followed by a tunnel show:
$ sudo ip tunnel add mode ipip remote 10.2.20.211
$ ip tunnel
tunl0: ip/ip remote any local any ttl inherit nopmtudisc
tunl%d: ip/ip remote 10.2.20.211 local any ttl inherit
$ sudo ip tunnel add mode sit remote 10.2.20.212
$ ip tunnel
sit0: ipv6/ip remote any local any ttl 64 nopmtudisc 6rd-prefix 2002::/16
sit%d: ioctl 89f8 failed: No such device
sit%d: ipv6/ip remote 10.2.20.212 local any ttl inherit
Signed-off-by: Ted Feng <artisdom@gmail.com>
Change-Id: Id853ba9cde9afd951d9bc8a86c7e90dfed2ad60b
Reviewed-on: http://git-master/r/74156
reference.
[ 461.580742] <IRQ>
[nf_conntrack_ipv6]
[bridge]
[bridge]
[bridge]
[bridge]
[bridge]
[bridge]
for carrier.
$ ip tunnel
$ ip tunnel
arch/arm/Kconfig
Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa
[ Upstream commit f61759e6b831a55b89e584b198c3da325e2bc379 ]
__mkroute_output fails to work with the original tos
and uses value with stripped RTO_ONLINK bit. Make sure we put
the original TOS bits into rt_key_tos because it used to match
cached route.
Signed-off-by: Julian Anastasov <ja@ssi.bg>
[ Upstream commit efbc368dcc6426d5430b9b8eeda944cf2cb74b8c,
incorporating a follow-on change to prevent an OOPS ]
Otherwise we won't notice the peer GENID change.
Reported-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit de68dca1816660b0d3ac89fa59ffb410007a143f ]
Now inetpeer is the place where we cache redirect information for ipv4
destinations, we must be able to invalidate informations when a route is
added/removed on host.
As inetpeer is not yet namespace aware, this patch adds a shared
redirect_genid, and a per inetpeer redirect_genid. This might be changed
later if inetpeer becomes ns aware.
Cache information for one inerpeer is valid as long as its
redirect_genid has the same value than global redirect_genid.
Reported-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
Tested-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com>
[ Upstream commit 9cc20b268a5a14f5e57b8ad405a83513ab0d78dc ]
commit f39925dbde77 (ipv4: Cache learned redirect information in
inetpeer.) introduced a regression in ICMP redirect handling.
It assumed ipv4_dst_check() would be called because all possible routes
were attached to the inetpeer we modify in ip_rt_redirect(), but thats
not true.
commit 7cc9150ebe (route: fix ICMP redirect validation) tried to fix
this but solution was not complete. (It fixed only one route)
So we must lookup existing routes (including different TOS values) and
call check_peer_redir() on them.
Reported-by: Ivan Zahariev <famzah@icdsoft.com>
CC: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 7cc9150ebe8ec06cafea9f1c10d92ddacf88d8ae ]
The commit f39925dbde7788cfb96419c0f092b086aa325c0f
(ipv4: Cache learned redirect information in inetpeer.)
removed some ICMP packet validations which are required by
RFC 1122, section 3.2.2.2:
A Redirect message SHOULD be silently discarded if the new
gateway address it specifies is not on the same connected
(sub-) net through which the Redirect arrived [INTRO:2,
Appendix A], or if the source of the Redirect is not the
current first-hop gateway for the specified destination (see
Section 3.3.1).
Signed-off-by: Flavio Leitner <fbl@redhat.com>
[ Upstream commit 59445b6b1f90b97c4e28062b96306bacfa4fb170 ]
In func ipv4_dst_check,check_peer_pmtu should be called only when peer is updated.
So,if the peer is not updated in ip_rt_frag_needed,we can not inc __rt_peer_genid.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
[ Upstream commit 218fa90f072e4aeff9003d57e390857f4f35513e ]
After commit f2c31e32b378 (fix NULL dereferences in check_peer_redir()),
dst_get_neighbour() should be guarded by rcu_read_lock() /
rcu_read_unlock() section.
Reported-by: Miles Lane <miles.lane@gmail.com>
[ Upstream commit b12f62efb8ec0b9523bdb6c2d412c07193086de9 ]
When opt->srr_is_hit is set skb_rtable(skb) has been updated for
'nexthop' and iph->daddr should always equals to skb_rtable->rt_dst
holds, We need update iph->daddr either.
Signed-off-by: Li Wei <lw@cn.fujitsu.com>
[ Upstream commit b7ea81a58adc123a4e980cb0eff9eb5c144b5dc7 ]
The AH4/6 ahash input callbacks read out the nexthdr field from the AH
header *after* they overwrite that header. This is obviously not going
to end well. Fix it up.
[ Upstream commit 069294e813ed5f27f82613b027609bcda5f1b914 ]
The AH4/6 ahash output callbacks pass nexthdr to xfrm_output_resume
instead of the error code. This appears to be a copy+paste error from
the input case, where nexthdr is expected. This causes the driver to
continuously add AH headers to the datagram until either an allocation
fails and the packet is dropped or the ahash driver hits a synchronous
fallback and the resulting monstrosity is transmitted.
Correct this issue by simply passing the error code unadulterated.
Currently, calling tcp_nuke_addr to reset IPv6 connections
resets IPv4 connections as well, because all Android
framework sockets are dual-stack (i.e., IPv6) sockets, and
we don't check the source address to see if the connection
was in fact an IPv4 connection.
Fix this by checking the source address and not resetting
the connection if it's a mapped address.
Also slightly tweak the IPv4 code path, which doesn't check
for mapped addresses either. This was not causing any
problems because tcp_is_local normally always returns true
for LOOPBACK4_IPV6 (127.0.0.6), because the loopback
interface is configured as as 127.0.0.0/8. However,
checking explicitly for LOOPBACK4_IPV6 makes the code a bit
more robust.
Bug: 5535055
Change-Id: I4d6ed3497c5b8643c864783cf681f088cf6b8d2a
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
ip_route_output_key can return an ERR_PTR, don't dereference it.
Change-Id: I6b86a451b2bdb33873d79b3cf90c11dbe72bc081
Signed-off-by: Colin Cross <ccross@android.com>
Allow the REJECT --reject-with icmp*blabla to also set the matching error
locally on the socket affected by the reject.
This allows the process to see an error almost as if it received it
via ICMP.
It avoids the local process who's ingress packet is rejected to have to
wait for a pseudo-eternity until some timeout kicks in.
Ideally, this should be enabled with a new iptables flag similar to
--reject-with-sock-err
For now it is enabled with CONFIG_IP*_NF_TARGET_REJECT_SKERR option.
Change-Id: I649a4fd5940029ec0b3233e5abb205da6984891e
Signed-off-by: JP Abgrall <jpa@google.com>
Change-Id: I247b8dc2e32bb83e731209928600e92892dd042c
On Linux, when an interface goes down all its IPv6
addresses are deleted, so relying on knowing the previous
IPv6 addresses on the interface is brittle. Instead,
support nuking all sockets that are bound to IP addresses
that are not configured and up on the system. This
behaviour is triggered by specifying the unspecified
address (:: or 0.0.0.0). If an IP address is specified, the
behaviour is unchanged, except the ioctl now supports IPv6
as well as IPv4.
Signed-off-by: Chia-chi Yeh <chiachi@android.com>
Signed-off-by: Mike Chan <mike@android.com>
Add a family of knobs to /sys/kernel/ipv4 for controlling the TCP window size:
tcp_wmem_min
tcp_wmem_def
tcp_wmem_max
tcp_rmem_min
tcp_rmem_def
tcp_rmem_max
This six values mirror the sysctl knobs in /proc/sys/net/ipv4/tcp_wmem and
/proc/sys/net/ipv4/tcp_rmem.
Sysfs, unlike sysctl, allows us to set and manage the files' permissions and
owners.
Signed-off-by: Robert Love <rlove@google.com>
Introduce a new socket ioctl, SIOCKILLADDR, that nukes all sockets
bound to the same local address. This is useful in situations with
dynamic IPs, to kill stuck connections.
Signed-off-by: Brian Swetland <swetland@google.com>
net: fix tcp_v4_nuke_addr
Signed-off-by: Dima Zavin <dima@android.com>
net: ipv4: Fix a spinlock recursion bug in tcp_v4_nuke.
We can't hold the lock while calling to tcp_done(), so we drop
it before calling. We then have to start at the top of the chain again.
net: ipv4: Fix race in tcp_v4_nuke_addr().
To fix a recursive deadlock in 2.6.29, we stopped holding the hash table lock
across tcp_done() calls. This fixed the deadlock, but introduced a race where
the socket could die or change state.
Fix: Before unlocking the hash table, we grab a reference to the socket. We
can then unlock the hash table without risk of the socket going away. We then
lock the socket, which is safe because it is pinned. We can then call
tcp_done() without recursive deadlock and without race. Upon return, we unlock
the socket and then unpin it, killing it.
Change-Id: Idcdae072b48238b01bdbc8823b60310f1976e045
Acked-by: Dima Zavin <dima@android.com>
ipv4: disable bottom halves around call to tcp_done().
ipv4: Move sk_error_report inside bh_lock_sock in tcp_v4_nuke_addr
When sk_error_report is called, it wakes up the user-space thread, which then
calls tcp_close. When the tcp_close is interrupted by the tcp_v4_nuke_addr
ioctl thread running tcp_done, it leaks 392 bytes and triggers a WARN_ON.
This patch moves the call to sk_error_report inside the bh_lock_sock, which
matches the locking used in tcp_v4_err.
With CONFIG_ANDROID_PARANOID_NETWORK, require specific uids/gids to instantiate
network sockets.
paranoid networking: Use in_egroup_p() to check group membership
The previous group_search() caused trouble for partners with module builds.
in_egroup_p() is also cleaner.
Signed-off-by: Nick Pelly <npelly@google.com>
Fix 2.6.29 build.
Signed-off-by: Arve Hjønnevåg <arve@android.com>
net: Fix compilation of the IPv6 module
Fix compilation of the IPv6 module -- current->euid does not exist anymore,
current_euid() is what needs to be used.
Signed-off-by: Steinar H. Gunderson <sesse@google.com>
[ Upstream commit b73233960a59ee66e09d642f13d0592b13651e94 ]
There is bug in commit 5e2b61f(ipv4: Remove flowi from struct rtable).
It makes xfrm4_fill_dst() modify wrong data structure.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
Reported-by: Kim Phillips <kim.phillips@freescale.com>
The transparent socket option setting was not copied to the time wait
socket when an inet socket was being replaced by a time wait socket. This
broke the --transparent option of the socket match and may have caused
that FIN packets belonging to sockets in FIN_WAIT2 or TIME_WAIT state
were being dropped by the packet filter.
Signed-off-by: KOVACS Krisztian <hidden@balabit.hu>
lost_skb_hint is used by tcp_mark_head_lost() to mark the first unhandled skb.
lost_cnt_hint is the number of packets or sacked packets before the lost_skb_hint;
When shifting a skb that is before the lost_skb_hint, if tcp_is_fack() is ture,
the skb has already been counted in the lost_cnt_hint; if tcp_is_fack() is false,
tcp_sacktag_one() will increase the lost_cnt_hint. So tcp_shifted_skb() does not
need to adjust the lost_cnt_hint by itself. When shifting a skb that is equal to
lost_skb_hint, the shifted packets will not be counted by tcp_mark_head_lost().
So tcp_shifted_skb() should adjust the lost_cnt_hint even tcp_is_fack(tp) is true.
tcp_v4_clear_md5_list() assumes that multiple tcp md5sig peers
only hold one reference to md5sig_pool. but tcp_v4_md5_do_add()
increases use count of md5sig_pool for each peer. This patch
makes tcp_v4_md5_do_add() only increases use count for the first
tcp md5sig peer.
D-SACK is allowed to reside below snd_una. But the corresponding check
in tcp_is_sackblock_valid() is the exact opposite. It looks like a typo.
Commit 4670994d(net,rcu: convert call_rcu(fc_rport_free_rcu) to
kfree_rcu()) introduced a memory leak. This patch reverts it.
"Possible SYN flooding on port xxxx " messages can fill logs on servers.
Change logic to log the message only once per listener, and add two new
SNMP counters to track :
TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client
TCPReqQFullDrop : number of times a SYN request was dropped because
syncookies were not enabled.
Based on a prior patch from Tom Herbert, and suggestions from David.
CC: Tom Herbert <therbert@google.com>
commit d0733d2e29b65 (Check for mistakenly passed in non-IPv4 address)
added regression on legacy apps that use bind() with AF_UNSPEC family.
Relax the check, but make sure the bind() is done on INADDR_ANY
addresses, as AF_UNSPEC has probably no sane meaning for other
addresses.
Bugzilla reference : https://bugzilla.kernel.org/show_bug.cgi?id=42012
Reported-and-bisected-by: Rene Meier <r_meier@freenet.de>
CC: Marcus Meissner <meissner@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
A userspace listener may send (bogus) NF_STOLEN verdict, which causes skb leak.
This problem was previously fixed via
64507fdbc29c3a622180378210ecea8659b14e40 (netfilter:
nf_queue: fix NF_STOLEN skb leak) but this had to be reverted because
NF_STOLEN can also be returned by a netfilter hook when iterating the
rules in nf_reinject.
Reject userspace NF_STOLEN verdict, as suggested by Michal Miroslaw.
This is complementary to commit fad54440438a7c231a6ae347738423cbabc936d9
(netfilter: avoid double free in nf_reinject).
Cc: Julian Anastasov <ja@ssi.bg>
Should check use count of include mode filter instead of total number
of include mode filters.
